  • Total Topics: 16,268
  • Online today: 175
  • Guests: 110
  • Total: 110
Pinto Powered Mustang Roadster
Started by rob289c, July 19, 2020, 06:19:07 PM
davidpinto
THEY ARE ALL STOCK REPLACEMENT PARTS ,THE NEW RACK FITS PINTOS & MUSTANG IIS WITH 1 3/4 INPUT SHAFT LGTH.
D BARHAM
rob289c
Glad it went off without a hitch.  Are all your new steering parts "stock" Pinto or T-Bird or other "kit" components?  Nothing on mine seemed to be bolt-in ready.
rob289c
davidpinto
I JUST REPLACED THE WHOLE STEERING SYSTEM ON MINE. `NEW ' RACK , PUMP AND ALL HOSES AND OUTER TIE RODS.THE OLD RACK FELL RIGHT OUT BUT THE NEW RACK WOULD NOT GO IN UNTIL I RAISED MOTOR UP .THE BODY WAS CONSIDERABLY LARGER DIAMETER.I MADE A BLEED TOOL OUT OF A 2 INCH RUBBER FREEZE PLUG ``PICTURED ''. PURGED ALL THE AIR OUT WITH MY VACUUM PUMP AT 45 LBS,CYCLED THE WHEEL A COUPLE TIMES,WORKS JUST PERFECT.DRIVES GREAT!
D BARHAM
Quote from: rob289c on May 10, 2023, 07:33:04 PM
... and Sunday will be devoted to Mother's Day:  Mom, Wife, and Mother In Law.
Yea, that is one day you don't want to mess up. It could affect your car hobby for the rest of your life!
rob289c
Yesterday I dropped off my power steering lines and today I picked them up.  Flare ends were installed at the rack end, just like I needed!  I loosely fit them to the rack and the pressure line to the pump and the return to where the cooler will mount.  The routing seems odd.  the pressure line essentially goes vertical from the rack, then to the left, then turns inboard to the pump.  I don't remember how they ran when I disassembled the car so maybe they are correct.  Since there is no inner fender to attach them to, it may make them look like they are routed incorrectly.  As long as they don't leak or impinge on anything else, I will be pleased.  I don't think I will get much time on it this weekend.  I have some other must do chores on Saturday and Sunday will be devoted to Mother's Day:  Mom, Wife, and Mother In Law.
rob289c
Quote from: rob289c on May 07, 2023, 05:47:02 PM
I'm glad to be back on it. I hope to make good progress this Summer.
I'm glad to see you back at work on it as well, and I share your hope for making good progress!
Dwayne :)
rob289c
I finally spent a little time on my project after a long Winter!  I didn't do much but it's the first progress since November unless you count replacing the right side motor mount in January and getting the car registered in my name in November or December.
So today my progress was to permanently mount the steering rack.  I won't re-hash all the details but late last Fall I had to order longer mounting bolts as the T-Bird rack requires spacers between the rack and crossmember.  By the time they came in I had already pushed the car into its Winter spot.  I had to cut about 3/4" off the right side bolt as it would have hit the bellhousing by the starter.
Next on the list is routing and installing the power steering hoses.  Fair warning...I may be asking for guidance in routing them.  I can't remember how they were routed when I disassembled the car.  Something that has to be done first is to get the hose ends at the rack end cut off and converted to AN-6 flare (female).  The originals are o-ring bubble flare and the T-bird rack has flare adapters.  I don't want to buy hoses, pump or rack so the easiest thing to do is get the hose ends modified.  Hopefully the local hydraulic shop can do it.  The former shop owner (retired) says they can do it.
When I go to install, I will likely need guidance on hose routing.  I'm glad to be back on it. I hope to make good progress this Summer.
rob289c
Quote from: rob289c on March 19, 2023, 10:05:12 AM
Still snowing here in Upstate NY, but Spring starts tomorrow so it's a matter of time.  I plan to rearrange the shop mid to late April so I can start working on it again.  I am looking forward to getting back on it and getting it running and roadworthy over the course of the Summer.  I know my wife will want me to do other things, but this project is high on my list to get done.  I envy those of you that have nice weather year 'round and can can play with your toys whenever you want!  Hopefully soon I will be making more regular progress reports, and requests for advice and help...
Looking forward to it!!!
Dwayne :)
rob289c
rob289c
rob289c
No progress on my project this weekend.  Single digits on Friday, below 0 Friday night and early Saturday morning.  It warmed up today so I hosed out the garage floor, sprayed the salt off the cars, and hosed down the driveway.  The power washer is in the basement and didn't get it out.  A few more weeks of Winter and Spring will be here...
rob289c
rob289c
I can't remember who I bought it from...I bought it 2-3 years ago.  I have the packing slip and/or invoice in my project folder.  I can look it up.  The upholstery guy was pointing out deficiencies that are noticeable if you look for them but it's good enough for this project.
rob289c
I think that seat looks pretty good.  From what company was the material purchased?
Dwayne :)
rob289c
Yep, thanks...good enough for me!  I got the seat frames from an old, defunct junkyard and the original covers were blue and in terrible shape.  The burlap was rotted and vinyl ripped and cracked.  I did a little fabbing and welding on the frames and now with the new padding and seat covers, they are WAY BETTER!
rob289c
firepinto
When someone restored my 73 Mach 1, they didn't use original looking covers or door cards, but they still do look nice.  A guy could go broke trying to keep everything original looking.  I think the seat turned out great!
'79 Pinto auto hatch back with an '80 2.3L and 4 speed transplant.  A 2.3 Turbo and T5 are waiting for the next transplant.
Plans changed, going V8 with TKX!
rob289c
I picked up my seat today.  Overall it came out pretty nice.  The upholstery shop owner did say that the seat cover material was pretty crappy quality and wasn't completely satisfied with the way it came out.  It looks fine to me and this isn't supposed to be a pristine show car anyway.  He had to modify it by cutting a slit in the center for the parking brake lever to protrude through.  On a Mustang, the parking brake is under the dash and pulls rearward.  I cut the Pinto parking brake well out of the area between the front seats and welded it into the Mustang driveshaft tunnel between the rear seats.  Since that isn't where it normally would have been, the seat cover needed a slit cut.  He did a nice job of building up material around the slit to create more integrity.  As a side note, it was almost impossible to find rear seat-only upholstery for a Mustang.  I had no need for the front seat upholstery as there are no front seats in this ride (will be driven from the rear seat) so I didn't want to buy an entire kit.  What I found wasn't high quality, and not even a proper reproduction with correct ribbing, but it was all I could find so that's what I got.  Take a look below.  I have the interior quarter panels but they are green and not ready to be installed.  I hope Winter is over soon so I can get back on this project...
rob289c
rob289c
The upholstery shop called today.  My seat is ready to pick up.  I can't get to it until Saturday.  I'll post pics after I get it and set it in place.  Spring can't get here soon enough...for several reasons!
rob289c
Quote from: rob289c on January 02, 2023, 07:03:54 PM
So there you have it....an off-season progress report.
Way to go!!!
Dwayne ;D
rob289c
Although my project is on Winter Hiatus, today I replaced the right motor mount.  I purchased two mounts months ago and when I installed this Fall I found that one had an M10 stud (correct), and the other had an M11 stud (incorrect).  The incorrect one, M11 - 1.75 needed a nut that I couldn't find anywhere.  The mounts don't come with nuts so I couldn't use the one from the old mount.  I temporarily threaded an SAE nut sloppily on to hold it in place, then ordered another so I could get one with the correct M10 stud.  Now I will return the incorrect one using the more recent order...the other one was from well over 30 days ago so I couldn't return it without buying another.  Thank God the recent order came with the correct stud!
rob289c
Quote from: Wittsend on December 18, 2022, 11:41:28 AM
Always good when a DMV story turns out right. Glad it worked out for you.
Ain't that the truth!?!?!? :P
rob289c
I got lucky...when I first got the back half of the Mustang the plan was to make it into a trailer to tow behind my 67 Fastback.  It was to provide more cargo space for travelling when the kids were small, plus be a novelty for car shows and cruise-ins.  It didn't have a title or registration but I figured it would be easy enough to register it as a homemade trailer.  As time went on and I decided to make it into a drivable vehicle, I had some concerns but did research what I would have to do to register it as a homemade car in NY which I figured would involve jumping through a lot of hoops.  When I got the Pinto, I titled it in my name so I could have titled this vehicle as a 1980 Ford, but pursued other options to get a title for the Mustang portion.  I was able to get the vehicle abstract form the PA DMV which included the VIV and previous owner and after contacting the guy I got it from (not the last registrant), said he found the PA title.  The previous registrant had passed away but had signed over the title to the other guy.  I compensated him for his troubles to register it in his name, then transfer ownership to me.  Long story short, I now legally own it and should have no trouble registering and getting it inspected when I get it ready for the road.  The stars aligned for me... :)
rob289c
Well, congratulations on becoming the legal owner!  Some states can make titling/registering an older car an absolute nightmare.  Virginia is one of them, and put me through hell before finally titling my '79 Continental Mark V.  It took almost a year from the time of purchase until I had it legally on the road.  So much nonsense!
Dwayne :)
rob289c
Yesterday I went to the DMV and registered my project as a 1967 Mustang.  I had to insure it, then register it, then cancel registration and turn in the plates (Pay $1.00 to turn in plates), then cancel the insurance and wait for my refund.  It it was a 1973 or newer, I could have titled it in my name without having to insure it.  Anyway, I am officially the owner and now I can put it on the road once it is roadworthy.  That had been a concern and I had a backup plan but now I feel better about getting it on the road "legally".  ;D  Also, my steering rack bolts arrived but I haven't gone out to install them.  I worked today so no garage time.  I may go to the office tomorrow too; I have a project I need to complete so likely no garage time this weekend.
rob289c
firepinto
I'm thinking the same, too cold for these bones in Wisconsin.  I used to like the cold in my younger days.  I'm eyeing up Florida myself.  The hot humid days will be bad, but at least my body will function correctly lol.
rob289c
Winter is finally upon us and being in the Propane business, we pray for cold.  I don't expect to do much on the project until Spring.  Maybe some day I will live in a warmer climate so I can play with my cars and motorcycle for more of the year, not to mention, maybe get away from the NY politics...
rob289c
Here's hoping for a few warm days so you can get a good nights rest. LOL   I know the feeling. Our 35 night/60 day California temps are freezing to me. How I ever survived my New Jersey childhood I don't know.
rob289c
Yes, I did...and got a bit more done than I originally planned.  I'm looking forward to Spring so I can get this thing done and drivable.  When I wake up in the middle of the night I can't get back to sleep because I lay there engineering the next steps in my head.  Once it's don I won't have to think about it other than to just enjoy it (I hope!).  I know I will be tempted to do a few things over the Winter nd will keep y'all updated...
rob289c
Quote from: rob289c on December 12, 2022, 07:47:39 PM
I am pretty much done working on this thing until Spring.  I covered it back up, pushed it back into the corner, and backed the Ranger up to it so it's "trapped" in its spot until April or May.
Well, at least you've had a productive summer!
Dwayne :)
rob289c
Yesterday (Sunday) I returned the 5/8 x 8 steering rack mounting bolts hoping to find some 5 x 9 1/2 bolts.  8" was the longest they had.  I ended up ordering them on line.  Not cheap...$32 including shipping.  I also put together the strut rods and bushings so I could see everything in place.  My next issue is figuring out a way to adapt my new, stock, aftermarket power steering hoses to the T-bird-style rack that came with my Speedway kit.  The T-bird rack has o-ring to 6AN flare fittings, and the Pinto hoses are inverted flare.  I don't know if there is some sort of adapter fitting or if the inverted flare can be cut off and the end flared and use a 6AM flare nut.  I will post the question on the Ask the Experts forum.  I will also enlist the guidance of my local hydraulic shop.  I don't want to have to buy new hoses or pump.
I got good news when I opened the mailbox tonight...the transferrable registration arrived in the mail from the previous owner.  In NY, vehicles older than 1973 do not get issued a title.  Proof of ownership is with a transferrable registration.  I can now register this thing in my name as a 1967 Ford.  I plan to do that ASAP before our governor decides to make it harder to register an old vehicle.
I need to check with the upholstery shop to check on my seat frame and cover.  He's had it since August.  He knows I don't need it back right away, but I would like to get it back so I can check seating position and for adapting the steering wheel/shaft to the rack.  I am going to have to shorten it some but until I get the seat in place I can't do anything to it.
rob289c
rob289c
Some progress made today...Last week I ordered and yesterday I received a Mustang II grill.  I think it will look cool.  I will need to fabricate a surround to make it look like it belongs on there.  I mocked up the steering rack to my crossmember.  Even with the offset bushing kit that was supposed to allow the 15 1`/2" on center rack to bolt to my 16" on center crossmember, it was still about 1/8" off.  I had to resort to removing a little material from both mounting holes on the inside edges.  It is in place but I need to buy longer mounting bolts.  I bought 8" Grade 5 bolts but now know I need 9".  I'll have to see if the hardware store has them that long.  I also heated and bent my Speedway strut rods to match the OEM strut rod angle.  I test fit them to the lower control arms and through the frame and the sway bar end links to the brackets I salvaged from the OEM strut rods.  Everything seems to line up.  I am only doing finger tight.  I will anti-seize everything when I do the final assembly.  I will do a little more tomorrow...
rob289c
