Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 02/18/2017 04:41 pm
Date: 09/15/2019 08:30 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Date: 01/10/2022 03:41 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 10/24/2018 07:41 am
1980 hood needed
Date: 04/23/2020 10:41 pm
  • Total Topics: 16,268
  • Online today: 175
  • Guests: 108
  • Total: 108
Pinto Powered Mustang Roadster
Started by rob289c, July 19, 2020, 06:19:07 PM
rob289c
Last evening I removed the old bushings and washers form my re-acquired OEM strut rods and placed the old one on top of the Speedway rod to see what the difference was in the angle.  I knew if was different as the Speedway arms won't line up with the frame mounts when attached to the lower control arms.  The attached pic shows how much they differ.  It was more than I thought it was.  There was quite a bit of exfoliation corrosion under the bushing area on the OEM rods, so I have decided to bend the Speedway rods to the same angle as the OEM rods and use them rather than using the 40+ year old OEM rods.  I will transfer the sway bar link brackets from the OEM to the Speedway rods so I can use the new, factory links that I already own.  I have been warned that heating the rods to facilitate the bend will weaken the rod, but there isn't much stress on them and I don't think it is going to cause a catastrophe so that's how I plan to make the bend.  I will bolt the two rods together so the lower control arm mounting holes are lined up, then clamp them in a vice, heat the new rod, the bend it to the same angle as the OEM rod so I can use it with my stock crossmember.  As with everything with this project, I engineer it as I go.  I also will be removing the steering rack mounting bushings and installing the offset bushings so I can use the 15 1/2" mount T-Bird rack on my 16" Pinto crossmember.  I don't know how difficult it will be to remove them, but will find out this weekend when I go out to play in the garage.
rob289c
rob289c
Yesterday I went to visit my old Pinto...it looked pretty sad sitting in the field.  Mice chewed up the rear seat bottom.  The interior was in really great shape.  It's a shame it has gone to waste.  I was able to get what was left of the two front suspension assembles.  This morning I removed the strut rods.  Penetrating oil, heat, and impact got the nuts off.  I had forgotten that the sway bar end link mounts were attached to the factory strut rods so now I have them back too!  I should now be able to use the factory end links I bought.  I had to go to a VFW function today so I had to stop playing with my Pinto stuff at 11:30 to get ready.  I didn't have a chance to compare the angle of the OEM strut rods to the Speedway arms, or wire wheel them, but I will get to that.  See my "treasure" in the attached pics.  I made an ebay purchase today...a Mustang II grill assembly.  I am going to build a nose cone around the grill.  It has the light assemblies so I think the Pinto running light/blinkers will  pop right in.  It has the Pony and looks to be in real nice shape in the pics.  I would like to find an inexpensive header panel so I don't have to build my nose from scratch but it looks like I may have to.  The header panel includes the headlight surrounds which I really don't need and they are fairly expensive, or at least more expensive than I want to spend.
rob289c
rob289c
Glad to see the 'Vair runs!  That will motivate you to continue on it!
I am hoping my steering rack offset bushing kit arrives today or tomorrow so I can get the rack bolted in.  I am going to try to find sway bar end links that mount differently than the stock ones, utilizing the lower control arm mounting brackets I bought from Speedway.  It will save me fabrication time and effort.  I already bought stock end links so I would have liked to use them, but may not.  If I find a suitable substitute the brand new Moog end links will become available.  They are a somewhat hard to find part in case someone is looking to score a pair for use or for stock.  I contacted the guy I gave my factory strut rods to and he hasn't used them so I will be going over to get them from him tomorrow.  I will see if Speedway will take the ones back that I bought from them and give me store credit.  In order to use them I would have to heat and bend them as the angle is different than the factory rods.  I really don't want to modify them.  I don't recall my old ones having any defects so if I can use them after wire-wheeling, prime/paint, I will.  My weekend is a little full:  Saturday 0800 haircut, 1000 funeral that is an hour away, run to get the strut rods, then home.  Sunday I have a VFW gathering to attend that involves adult beverages and a dinner, so I may not get much done on the project but I will keep you apprised.  I'm on borrowed time anyway so anything I get done at this point is a bonus.
rob289c
Congratulations on getting it running!  Quite an achievement!!!
Dwayne :)
You were at it deep into the cold weather so that has to bring a degree of accomplishment . Spring will come soon enough.
We still have 70 degree days here in So. Cal. The bad news about that is mosquitos. I am SO susceptible to getting bit that I use to joke that there were only four mosquitoes in California, and they all knew where I live. Meaning, there are VERY few mosquitoes in California..., until last year. Now we have some mosquito from Asia and here it is late November and the other day I had 9 bites on my foot even though I ALWAYS wear sox and shoes. Regardless I was able to get the Corvair engine running after its refurbishment. My son was in town for Thanksgiving and shot a You Tube video of it.
https://www.youtube.com/watch?v=Sx7eY6y1EQ0
rob289c
I found an offset bushing kit that allows the 15 1/2" mount rack to mate to the 16" crossmember.  I will hopefully confirm this with the Speedway Tech Support person tomorrow and order it so I can continue...
rob289c
rob289c
Yesterday I made some progress and hit a speedbump.  I installed the sway bar mounts and sway bar except for attaching the end links to the lower control arms.  The sway bar bracket I bought from Speedway doesn't allow for connection to the factory-style end links.  I will have to fabricate something at a later date.  I also mounted the caliper adapters to the spindles, but only finger-tight.  Pic attached.
My speed bump is that the steering rack that came with the kit has mounting holes that are about 3/4" to narrow.  My subframe has 16" on center mounting holes; the rack mounting holes are 15 1/4". I have e-mails to Speedway and am hoping that tomorrow (Monday) when they get to work they have a different rack that will mount to my factory crossmember.  I am finding that even when Speedway claims that parts are for a 1974-80 Pinto or 1974-78 Mustang, what they really mean is that you must use their crossmember, not the factory crossmember.
I will update on the steering rack.  In the meantime, I decided to cover it and push it into its Winter spot.  I wasn't ready to put it away but will have to see what Speedway can provide.
rob289c
rob289c
Happy Thanksgiving All!
This morning after some food prepping and dish washing I snuck out to the garage and installed the coil springs and spindles.  I cut 1/2 coil off each spring.  Not sure if that was enough but I didn't want to cut off too much.  I can always cut off more later.  I had to go back in to help the wife so I didn't do anything else out there.  Saturday is supposed to be a nice day so I will install the steering rack and tie rods and probably install the rotors, wheel bearings, calipers, sway bar and other related parts.  I am going to have to heat and slightly bend the strut rods to get the bolt holes to line up at the lower control arm and get the rod to go through the frame as it should.  The strut rods are from Speedway, not the factory rods.  I am going to have to grind a little material off the strut rods too so they will fit with the sway bar mount in place.  The mounts need a little massaging with the grinder too.  I'm surprised they didn't fit out of the box.  Anyway, pics attached.  I haven't tightened/torqued anything yet.  I am still on the front caster so no weight on the front suspension yet.  Once I have weight on it I will see how the suspension sits.  It looks a bit off right now and the springs look somewhat bowed so I may have to cut some more off.  I am looking for anyone's opinion on this...
rob289c
rob289c
I did practically nothing on my project this weekend.  I went to the office both Saturday and Sunday mornings to try to get caught up on things.  The heating season is here and the ops-tempo is fast and furious.  The threat of the Lake Effect Snow in Buffalo and Watertown puts panic into our customers so they all think they need propane deliveries.  While Buffalo gor over 6' in some spots, we had next to nothing for measurable snow in the Rochester area.  I spent Saturday and Sunday afternooons hanging the exterior Christmas lights.  I did the ones that require the 28' extension ladder yesterday and the lower ones today
Pinto content:  I placed the firewall/cowl in place to get it off the sawhorses it has been on for the last couple of months.  I'm trying to make space for Winter parking.  It isn't sitting correctly as the ratchet strap that holds the tranny tail shaft in position prevents the tranny hump from sitting down into position.  It is tilting forward but I think it is coming together and looking kinda cool!
I plan to try to install the coil springs and spindles on Thanksgiving.  It is supposed to be in the mid 40's.  Today it was in the upper 20's.
rob289c
rob289c
Good to hear there is progress made on the Corvair.  I wish our Winters were warm enough to continue on my project.  Of course my job success relies on cold weather so I can't complain about the Winter weather.  Our highs are in the 30's now so it's only a matter of time that I will be forced to put it away.  If I can get the front end together and on 4 wheels I'll be satisfied.  I'll have to see if I can use the floor jack to compress the springs of if I have to use a spring compressor.  I'll know on Saturday...
rob289c
"I keep saying that I should put it away for the season but I can't stop myself while I continue to make progress! "
I hear you. I have a 61 Corvair station wagon that has sat for nearly 28 years. In the Fall of 2019 I told my wife I'm either doing something with it..., or getting rid of it. I slow down my car activity in Winter (I get cold REAL EASY). But the Winters in So. Cal. have been rather mild and dry. So, starting with the Winter of 2019 I adopted a "Winters Only" approach to working on the car (as whether allowed). Well, Covid came and I just kept going, all seasons, all years from 2019 to present. This week I hope to start the rebuilt motor, but still a lot more to do. But, yes, I know the drive to get (just) one more thing done and it just keeps rolling.
rob289c
I don't plan to get crazy with cutting.  I am going to try to get this done next weekend in between working, hanging Christmas lights and whatever other activities that present themselves.  I keep saying that I should put it away for the season but I can't stop myself while I continue to make progress!
rob289c
Take your time cutting the springs. Better to cut numerous times then to cut them too short. Remember too that you are cutting for compressed height equivalent, not free length. Lastly every time the spring gets cut it makes it stiffer. So what measurement had one effect, the next successive cuts will be somewhat different. Given the weight distribution of this configuration I would also put equivalent weight in the seats of the driver and passenger.
rob289c
I had a busy weekend doing other than Pinto/Mustang work but on Friday I painted the upper and lower control arms.  Today I mounted the upper and lower control arms.  I haven't installed the coil springs yet.  When the lower control arm is horizontal, the compressed length of the springs are about 9".  The new springs are 13.5 inches.  The instructions say they need to be cut but they don't say how much to cut off.  I am going to start by cutting 1/2 of a coil off and see how that sits.  It could be trial and error...I don't want to cut too much off.  The only weight on the front end will be the frame, bumper, headlights.  There will be no hood, fenders, doors, so I won't have much weight to compress the springs.  I ordered the 300 lb springs with the kit.
rob289c
rob289c
Over the weekend I fabricated my bushings that returned the lower control arm mounting holes back to 1/2" after enlarging to 5/8" for the control arms I wasn't able to use.  I made two trips to the hardware store to buy the bolts to mount the lower arms.  I initially went to there to buy 1/2" x 5" but made a call at the line of scrimmage to buy 4 1/2" as the 5" looked too long.  I should have stuck with my first idea as I went back to exchange the 4 1/2" for the 5" bolts.  Today I found the original bolts that are perfectly serviceable but too late now.  I also found the one steering rack mounting bolt that I was able to salvage.  I had to cut the other one off as no amount of penetrating oil, heat and hammering would budge it.  I need to buy another one:  5/8" x 7 1/2" or x 8", Grade 5.  Today I screwed the ball joint into the right lower control arm.  I had to use a 24" pipe wrench with a 2'+ pipe for extra leverage.  Speedway sent me two right lower control arms so I am waiting on the left arm.  I hope it will be here before Friday.  I took Friday off (Vet's Day) and it will be warm enough to paint the arms and other misc parts black.  Today I sprayed primer on the two upper arms and the right lower arm.  I wire wheeled the sway bar and attaching brackets, and the brackets that mount the front brake hoses to the frame.  I sprayed all those parts and the driveshaft with rust converter.  They will get painted on Friday.  By Sunday the paint will have cured so I should be able to get the front suspension assembled.  I am eating the elephant one bite at a time!
rob289c
rob289c
Update on my front suspension setback...the lower control arms that came with my kit were not meant to be used with a stock Pinto crossmember.  I was crystal clear when I called to inquire about a font suspension kit that I was using a stock Pinto platform, yet the recommended the kit that I purchased.  It was a $200 upgrade to the kit I originally had selected and the selling point was that the tubular arms were better than the stamped steel arms, and best of all, they eliminated the need for strut rods, providing more clearance for a header.  I felt it was worth the extra $200 so that's what I got.  After calling Speedway on Monday, I have a set of tubular, but stock mount lower control arms coming and should be delivered tomorrow.  That will solve my problem but is costing me more $$$, engineering and work.  The first step for installing the original arms was to drill out the 1/2 mounting hole to 5/8.  You guessed it...the arms I now have to use use 1/2 bolts.  Now I have to close the holes so I can use the 1/2" bolts.  I have a plan that includes using 7/16 Grade 8 flat washers (opened up to 1/2"), welded to a 5/8 OD x 1/2 ID sleeve.  The sleeve fits nicely in my enlarged mounting hole and the washer will be welded to the outside of the crossmember where the mounting bolt goes through.  I will send pics after I do the work that will better explain.  I have layed awake the last three nights trying to come up with a good way to return the mounting holes to 1/2" and came up with this plan.  I will do it on Saturday and am confident it will work.  My next challenge is that I don't see the mounting tab for the sway bar on the control arm.  I have reached out to Speedway to see if they sell a bracket that I can weld to the arm.  I'm pretty sure they do.  I don't know why it wouldn't be included if these are supposed to be tubular, stock replacement arms.  I'll find out soon enough...
rob289c
PintoTim2
Sweet Tiger!   My friend Randy has a super nice Alpine (the 4 cylinder version of the Tiger) and had a Tiger that came disassembled with the parts in bushel baskets!   After 20+ years he finally realized that he'd never get to it, so he sent it all to a restoration shop.  After they stripped the paint off, they discovered the whole bottom of the car was made of pop rivited heating duct metal.  He was so disappointed he sold it off.
rob289c
Your Tiger looks cool.  Hopefully you can finish it some day and also the Corvair.  I like the 1965 and up COrvairs more than the early cars but they are all cool.  There s a 327-powered one that goes to a cruise in that I go to.
rob289c
The Tiger is an early car, the 101st one made. Originally it was a 260 car but somewhere in life it got a 289 (5 bolt). I did a lot of work on it between 2000 (when I bought it) and 2004. Then for one reason or another I always had some other car (including my Pinto Turbo engine swap) that I felt I could get done faster and the Tiger always sat. Family obligations got in the way too. I retired in 2014 but that didn't seem to change anything. In 2019 I actually did some quarter panel repair but as winter approached I again got diverted.
I have a 1961 Corvair Lakewood station wagon. I actually have had it longer than the Tiger (since 1995).  So in the winter of 2019 I decided that I would work on the Corvair ONLY IN THE WINTER and only when the days were nice. Then Covid came and the Corvair just kept rolling into Spring , Summer etc., etc. and here we are with 2023 staring us in the face and nothing done on the Tiger and the Corvair with significant done..., but still a long way to go. Such is life.
rob289c
Wittsend:  I would love a Tiger.  Poor Man's Shelby.  Is yours a 260 or 289?
Today was to be the day I assembled the front suspension.  It didn't go as planned.  I enlarged the lower control arm mounting holes to 5/8" as the instructions stated, but that's as far as I got.  I thought that if any part of this project would be a brainless, bolt together process, but I was wrong.  The lower control arms do fit as I would have expected.  The front tube hits the horizontal flange of the crossmember so it doesn't fit as it should.  I also tried to install the steering rack.  The mounting bolts are 4 1/2" long.  The cross member alone is 4" and there is about 2" of the mounting bushing on the rack so the 4 1/2" bolts aren't even close.  I will be calling Speedway tomorrow to talk to their Tech Dept.  I need this to work.  Maybe whoever picked the parts off the shelf for the kit pull incorrect parts.  I was hoping to have it on 4 wheels today but it wasn't in the cards.  I'll find out more tomorrow.  I did put the rims and tires on the rear to see what it was going to look like.  The good news it that I will have the paperwork I need to register it this week.
rob289c
I have to say I'm envious of you guys that have all that garage space. I have a 2 car garage that between counters/workbench and laundry is more like a 1-1/2 car garage. My long unattended Sunbeam Tiger has sat on jackstands in the middle for 22 years. You sure are diligent. All the best in the completion.
Congratulations on meeting your goal and good luck on assembling that front suspension.  It would, indeed, put you in a good position for next year!
Dwayne :)
rob289c
A little more progress...i reinstalled the engine this morning.  My goal was to get it back in before November 1 so since I met the goal a bit early, I am planning to assemble the front suspension.  If I don't get to it, I made good progress.  If I do, I'll be in better shape to get it done next year!
rob289c
Now, THAT is progress!!!  I'm impressed!
Dwayne :)
rob289c
Today after doing a PM, Tire Rotation and Rear Brake Job on my daily driver Mazda 6, I removed the header from the 2.3 and re-installed the factory exhaust manifold and rear lifting lug.  Then I removed the engine from the stand, installed the ring gear and plate, the torque converter, then bolted the engine to the tranny.  Then I bolted on the starter.  I removed the tranny pan and cleaned out the green oil that was in there.  I had previously drained the fluid...not sure what the green stuff was. I installed a new tranny filter, then cleaned, primed and painted the tranny pan.  I installed the new trans mount.   Tomorrow AM the engine-trans assembly will go back in the chassis.  I have to wash the two Harleys, the Mustang, and the Mazda.  I need to start arranging the garage for Winter storage.  I think I am going to have enough time to assemble the front suspension before the cold sets in.  That will put me ahead of my goal for this year.  At some point I have to run the mower around and zoop up leaves tomorrow so I may not get to the front end...I have a couple of weeks before we start mandatory Saturday work days so I think I can get it done.
rob289c
rob289c
The pics below represent the progress I have made to date.  I installed the fuel pump, fuel pump bracket, thermostat, motor mounts, intake, carb, distributor, power steering pump, alternator, belts.  I degreased and wire brushed/wheeled the exhaust hangers, rear tie downs, tranny mounts, accelerator linkage and the line from the fuel pump to carb.  I sprayed them all with rust convertor.  I will spray them all black over this week, although it is supposed to be cold so I may wait until next weekend.  The header, air cleaner and valve cover are just on temporarily.  The header will come off before putting the engine back in the chassis.  I will bolt the stock exhaust manifold and lifting ring back on for the installation.  Next weekend I will change the tranny filter, then bolt the engine and tranny back together in preparation for reinstalling the assembly back in the chassis.  If I have time I will assemble the front suspension, brakes, and steering.  If I run out of time, I will just roll it into the corner until April/May.  I have an issue with one of the motor mounts and will post my question/concerns on the "Ask the Experts" forum.  Moving right along...
rob289c
rob289c
Mine was not AC so I don't think I have that same type of valve.  When I get to that point I will investigate further and see if it is something I can easily do.
rob289c
davidpinto
CAR HAD AC,GOT RID OF THAT, SO HEATER VALVE IS VACUUM OPERATED.NOTICE VALVE IS ON THE HOSE FROM WATER PUMP.
D BARHAM
davidpinto
D BARHAM
rob289c
Is your heating system otherwise stock or is that an aftermarket heater valve?
rob289c
