1978 hatch back
Date: 11/29/2019 03:18 pm
Date: 11/08/2020 02:10 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Date: 04/06/2017 12:13 am
Date: 09/20/2018 11:01 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
  • Total Topics: 16,268
  • Online today: 175
  • Guests: 114
  • Total: 114
Pinto Powered Mustang Roadster
Started by rob289c, July 19, 2020, 06:19:07 PM
I think that will provide good contrast to the 1967 Mustang styling at the rear.
Dwayne :)
rob289c
Today I acquired a Mustang II header panel.  I am going to mount it like a nose cone and build a shroud around it to blend it into the radiator support.  I already had a grill that included the running lights and pony and will use them instead of what came with this assembly.  It is in better shape.  This one appears to have been from a Cobra II and the Cobra emblem is missing.  The grill and running lights have some damage.  There is also a crack on the lower part but I can repair it and it will be more than suitable for my application.  I am likely going to cut the headlight sections off and use what is known as Dietz Style headlamps instead to keep everything narrower.  I'm not 100% sure on that but I don't want the nose to be as wide as it would be with the factory headlights.  Pic attached and just sitting on the bumper mounts for a "what will it look like?" shot.  Any thoughts on this?
rob289c
rob289c
If I can get sufficient time on this I may be able to drive it around my circle before I put it away for the Winter.  It won't be painted till Spring but I may be able to get it running, rolling, and stopping in the next couple of months.  I have been working out of town and out of state at times so it's hard to stay on it for any duration.  My issues with my steering column are related to my sectioning (narrowing) the cowl and dash and losing that under dash space.  I had to shorted the steering shaft and the column is going to be a bit to the right so the ignition switch isn't in the way of the instrument cluster and dash.  I think I can "mask" it to make it look presentable.  Also, the position has to allow me to get in and out of the cockpit but not be so far forward that it's a long reach for the steering wheel.  ANyway, it has been quite a project...:)
rob289c
Good to see you making progress. Yes, I thought the site had seen its last post. It was THREE WEEKS between posts. I've often contrasted this site with the Corvair site I'm on. Both the Pinto and the Corvair have similar build numbers over same number of (nine) years. Yet here we had one post in three weeks. On the Corvair site we get about three posts in 15 minutes. And the irony is this is the ONLY Pinto site. Corvairs have two large sites and a number of lesser sites. If this site ever folds (hope it doesn't) I hope they offer and the Mustang II site accepts the historic posts from here. After all the Mustang II and the Pinto share a common platform.
I've also had to fiddle the steering column. I used the tilt column from my donor Turbo Coupe. It actually fit rather well but the adaptation of the column to rack was a bit of work. I found a more appropriate joint in the wrecking yard (newer Mustang) but had to hand grind the mating ends to fit. It will be interesting to see the final product. Hope you can post a video to YT showing it driving around.
rob289c
It's been a month since I last posted, mainly because the progress I've made on my project has been hard to quantify, but also because of lack of activity on the site.  I'm happy to see that there are some recent posts, so I decided to update you on my progress.  I have been working to mount the steering column. I ran the brake lines but the long one from the proportioning valve/distribution block to the rear.  Two years ago I cut about 3" out of each end of the dash, thinking I had to narrow everything but realized it wasn't necessary.  After realizing my mistake I have dreaded the reconstruction but I did it last week.  Luckily I saved the steel I had cut out...I must have known I might need it!  I put tiger hair over the seams and roughly sanded/shaped it.  Next will be regular body filler to hide my scabbed work.  It will look decent...I wish I hadn't cut it apart!  I also took 3" out of the top of the dash and welded it together.  That will also get some additional body treatment.  I have struggled supporting the steering column.  When I narrowed the cowl I lost some of the under dash space where the brake pedal mount was also the steering column mount.  I had to modify (cut) the mount, then put a spacer between the master cylinder and firewall to get the right brake pedal height.  I fabbed a bracket and used some threaded rod for the forward steering column mount, but I need to come up with another way to reinforce the setup at the rearward mounts.  It will come to me one of these nights that I can't sleep!  As you've heard me say before, everything about this project is an engineering (and sometimes re-engineering) feat.  Everything I am doing will have to come back apart so I can remove the firewall/cowl/trans hump so I can seam seal,, then prime and paint again.  I'll be glad when it is done.
rob289c
rob289c
Yesterday (Sunday) I performed surgery on the steering column.  I cut 5" out of the middle of the steering column tube to account for the 8" I cut out of the cowl.  I did this in order to move the column mounts closer to the steering wheel.  I had to weld the two parts together, then grind smooth and prime/paint.  I had to section it in the center has the lower end of the tube has the steering shaft bearing and has dimples that hold the lower mount in place.  It's hard to describe if you haven't gotten up close and personal with your steering column.  Anyway, I think what I did will provide me with the clearance I need.  I received my u-joint so now I need to attach the u-joint to the steering tack input, then position the steering wheel where I can comfortable reach it while still being able to get in and out of the cockpit, then weld the shaft and u-joint together.  Again hard to describe if you aren't here to see it.  This coming weekend I will test fit it and figure out how I am going to secure the column into its position.
rob289c
rob289c
Of course, nothing on this project is cut and dry or easy.  Since I removed 8" from the center of the cowl and 3" out of the center of the dash, the brake pedal mount didn't fit and impinged on other under dash components.  I had to cut the mount to get the brake pedal up and in place.  I have a little more trimming to do on it but it all has to come back out anyway so I will do it later.  The next issue is the brake pedal mount is also the steering column mount so now the mounting points on the column are in the "wrong" spots and since the brake pedal mount has been modified (cut), I have to engineer a way to mount the steering column.  I spent time yesterday disassembling the column and brainstormed a way to modify the tube to move the mounting points up the shaft closer to the steering wheel to figure a way to make the mounting point not impinge on the brake pedal travel.  It is going to involve cutting a section out of the steering column tube then re-welding.  I need to figure out a way to secure the column it the proper position  I am going to have to cut a section out of the steering shaft but not going to do that until after I receive my u-joint and mount it on the steering rack input.  I will use my best effort to measure and hopefully not mess this up.
I did make some other progress yesterday.  I installed the rear shocks.  I installed the front brake hoses.  They are 18" and another 4" of length would have been nice.  I'll have t see how it works and will change out if necessary.  I wanted to install the rear section of exhaust, but unfortunately, the single exhaust I removed from my Mustang years ago was from a V8 and the single exhaust intermediate travels down the left side of the car and I need it to travel down the right side of the car.  I'll get that figured out.
Heading out to the shop now.  Hopefully I can report success on the steering column project.
rob289c
rob289c
I think the next mission will be to mount the brake pedal assembly, mainly so I can secure the steering column in place so I can figure out what I'll need to connect the shaft to the steering rack input.  I need to see if the u-joint will have to be 3/4 round or 3/4 double D at the column shaft end.  I was wracking my brain on how the column was mounted and was looking through all my Pinto parts and didn't find what I was looking for.  Finally I looked at the brake pedal assy and saw that it is what the steering column mounts to.  I will try to mock up whatever I can under the dash so I can figure out how all that will go together and see what I have to modify to make it all work with the narrowed cowl and dash.  More to come...
rob289c
rob289c
All I got done today was to torque the control arm mounting hardware and the steering rack mounting bolts.  I test fit the steering wheel/column and realized that even after removing the factory u-joint and 3/4 round shaft, I may have to cut it even shorter.  I didn't have time to mess with it but will have to put my engineering cap on to figure out how to connect the shaft to the rack, but also how to mount the column to the dash.  I also have to re-engineer the way the brake pedal assemble mounts under the dash.  I modified the dash and cowl so I have less room than a stock Pinto.  Where there's a will, there's a way...
rob289c
rob289c
Yesterday I got it on 4 wheels and removed the caster.  I had to use wheel adapters to get from the 5 lug 4.5 hub/rotors to the 4 lug 4.5 rims I am using.  They are two piece adapters,  I had to cut about 1/4" off the hub studs so the two halves would mate properly.  They widened the front track a bit but from what I have read, it should offer more stability in turns which is good considering the short wheelbase.  I bought 225 60-15 tires for all four corners.  In retrospect I should have bought a smaller, narrower tire for the front.  My thought was that with all 4 the same, I can rotate properly for maximum tire life.  I don't think this will get many miles and it would look better with smaller, narrower tires up front.  Let me know what you think.  Anyway, I loosened the upper control arm pass through nuts and the lower control arm mounting bolts and bounced the suspension several times as advised in the kit.  I will torque to spec this AM when I get out in the shop.
I also plumbed in the rear brake lines and secured the rear axle vent hose through the grommet that routes and terminates the end into the frame.
I don't know what's next.  I have a abbreviated garage day today.  We are hosting my father in law's birthday party so I can't get into anything too deep or too dirty.  I may test fit and fab mounting brackets for the grill.  It's starting to look cool so I want to see it in a more "finished" state.  I need to get the steering shaft universal joint.  I think I can use a 3/4-36 end at the rack input end and a weld-on 3/4 round after I cut the original Pinto rag joint mount and get it to the correct length.  I may mess with that a bit too.
I will continue to report progress...
rob289c
rob289c
Last weekend my focus was the Impala paint job so I didn't do much (really nothing) on my project.  With the Impala paint behind me, I made good progress on my Pinto-Mustang Roadster this weekend.  Yesterday (Saturday} I fabricated, test fit, welded, and painted my transmission lowering mounts.  I used 1 1/2" square tubing and 1" flat stock.  They fit perfectly and will do the job is intended.  Today I assembled the front end.  I had fit everything last Fall and left everything finger tight.  Today I torqued the T-bolts that hold the upper control arms in place, torqued the upper and lower ball jpoints, re-installed the strut rods, sway bar links, and caliper brackets (all painted last weekend with the Impala).  I also packed the wheel bearings and installed the rotors.  I installed the front shocks.  Earlier in the week I cut about 24" out of the center of the '67 Mustang front bumper and welded it together in an area that won't be seen.  I will mount that at a later date.  I test fit the steering column.  I think it is going to work just fine.  I am going to have to get a u-joint to adapt the rack to the column.  I may have to get a section of Double D shaft and adapt a bit.
Next weekend I need to install the front wheel spacers/adapters so I can install the 4-lug front rims.  It will then be on four tires so the front suspension can settle.  I hope I don't have to disassemble it and cut more off the coil springs.  I think it's going to be good.  I need to keep after this so I can get it done or almost done this Summer.  I still have to do some metal work and body work on the dash, then some seal sealer, then more primer and paint work.  I'm getting there...
rob289c
rob289c
I'm a little bummed that I have to do the Impala paint job.  It's going to tie up portions of my Saturday, Sunday, and Tuesday.  (Monday I work and it will be the day I let the primer cure).  It's a small job (only the front clip) but it is going to chew up time that could be spent on my project or other tasks.
Anyway, some small project tasks I will attempt over the weekend are to fab and install my new transmission lowering blocks.  Due to driveshaft interference issues I had to drop the tranny a couple of inches.  All it really did is to allow the engine to tilt rearward a bit so I need to fab pieces that will allow me to attach the trans mount to the mounting points in the transmission hump.  The other small tasks I can complete are to install the rear brake lines and mount the rear axle vent hose.
Since I will be spraying primer and black enamel I am going to remove the strut rods and brake caliper adapters and spray them while doing the Impala.  They are uncoated and I don't want them corroding.  The steering knuckles are also uncoated but I am not going to remove the coil springs and control arms to get them out.  I think trying to spray them with the gun will be a challenge so I will mask and carefully prime/paint with rattle cans.
Of course, removing and painting the strut rods and caliper adapters will prevent me from getting the thing on four wheels but that can wait till the following weekend.  I want to get it on 4 wheels to put some weight on the coil springs so they can settle into their "normal" position.
Another task I will start figuring out is how to un-do my mistake of narrowing the width of my dash.  I never should have done it but I can't turn back the hands of time.  It will be a little cutting, metal fab, welding, and body filler work.  I hate fixing mistakes but I will get through this.
In case I don't post anymore this weekend, a Happy and safe 4th to all!
Rob
rob289c
I totally agree that the mock-up would be motivating.  I've enjoyed watching this project progress.
Dwayne :)
rob289c
The Dash, Dash Pad, and inner rear quarters are going to be black.  The orange and green are going away!  I've got a lot left to do but mocking it up to see how it looks is motivating.  Everything is an engineering work-around.  It's "figure it out as you go".
Depending on how my Impala Paint job goes next weekend, I may try to get this buggy on four wheels.  I'll get it off the front caster.  I am going to have top figure out how to shorten the steering column shaft and get a universal of some sort.
rob289c
rob289c
I forgot this one...
rob289c
rob289c
I decided to see how it was going to look.
rob289c
rob289c
I did a few things to my buggy today.  I installed the transmission dipstick.  I finished the rear brake job.  That included new shoes and wheel cylinder and painted drums.  I also mocked up the dash and dash pad to the firewall/cowl assembly.  I re-mounted the assembly back on the frame so I could see what is is going to look like.  I made a mistake a while back (2 years ago?) when I narrowed the width of the dash.  I thought it was going to be necessary, but found out it isn't.  I am going to have to do a little more fab work to fill in the ends to get it back to proper width.  I think I am going to modify it to house small front speakers.  I'll make a silk purse out of a sow's ear (old saying).  Anyway, it is coming along.  Lots more to do but it is taking shape.  Another post coming...
rob289c
rob289c
Progress today:  Primed and painted the firewall brackets that I welded to the frame last weekend. Difficult to see in the pic as it is all black.  Painted the transmission dipstick tube black and the handle of the dipstick red.  Spent the bulk of the day applying and sanding body filler on the cowl.  I'm just not that good at it so it takes multiple applications and sanding effort.  I got it pretty good.  There are a couple of spots that aren't right that I will attack during the next bodywork session.
It was supposed to rain today.  I was doing the bodywork in the driveway and expected to have to move the firewall/cowl/trans hump inside when it did and I planned to finish my rear brake job.  Since it didn't rain I stayed on the bodywork mission and didn't do anything on the brakes.  Maybe tomorrow.  I ordered the rear brake lines from CJ Pony Parts earlier in the week and they are due to arrive on Tuesday  They will be installed next week.  I also figured out how I am going to build the transmission mount lowering blocks.  I cut some 2x2 square tube into appropriate length sections and will weld tabs to them.  That will be a future project and pic.
Next weekend I have to sand/prime/paint my son's (really my) Impala front clip.  It is a black car but has a red front bumper and white hood and fenders due to a deer hit.  We are going to paint with black Rustoleum.  I will use hardner and it will shine nicely when done.  It will look better than it does today.  With 280k miles it is far from a show car.  That is going to cost me time on my project but it has to be done...
I will report any progress I make tomorrow.
rob289c
rob289c
I can't quit now!  There is light at the end of the tunnel and I want to drive this thing.  Even if it becomes my neighborhood "golf cart" I ned to get it to completion/.  I think I'm in Year 4 with it.  The Mustang in the previous pics was a 14 year project!
rob289c
What you are displaying, and I have found to be true is to just keep going. Even if it is only little things. So, often people start a project..., but never finish it. While doing my Corvair wagon project there are days when I ask myself, "Why did I get involved with this???" But then I'll go out and do a little something and the next time it gets easier to do 'a little something more.'
If it is any inspiration I got my homemade floor replacements finished and a fair portion of the interior done. Keep at it, there is light at the end of the tunnel.
rob289c
Some, but not much progress:  I removed the firewall and trans hump assembly so I could gain access to weld my frame spacers properly.  The first pic shows that the right side needed taller spacers than the left,  Two attaching points on the left side didn't need spacers at all.  I drilled holes in the frame large enough to put nuts down into the frame and welded them in place.  I need to prime and paint to prevent corrosion.  I also tack welded a piece of the driveshaft tunnel back in place.  I had previously cut it out as the driveshaft was hitting the tunnel.  I thought cutting the forward section would give me the clearance but it didn't.  When I have the engine and tranny up into the correct "Pinto" position, it sits too high.  I creates to steep of a driveshaft angle and the forward end of the driveshaft hits the tunnel.  The fix is to build lowering brackets so the tranny tail shaft is angled downward.  I haven't done this yet but it is on the docket for a near future project.  With some engines the rearward drop could cause oil pooling under the valve cover but the is an oil return at the rear of the head in the 2.3.  I know it's not ideal but I don't have a lot of choice and this is not going to be a race car, or a daily driver so it will be fine.  I need to test fit the seat to see if I need to trim off the bracket I had previously welded onto the driveshaft tunnel. I didn't get to the rear brakes.  That will have to wait.
I did a lot of yardwork today.  I trimmed hedges, bushes, the entire back hedgerow.  I weed whacked and mowed.  I did some weeding and mulching.  Tomorrow I will be at a 600-700 car car show with my Mustang.  I have about 500 fliers to pass out for my club's August show.  No project progress tomorrow.  Happy Father's Day to the Fathers out there and to the rest, I hop you celebrate a Father or at least have a great Sunday!
rob289c
rob289c
Every bit I do gets me closer to completion.  I'll get some done on Saturday but nothing on Sunday (Father's Day).  I think I will finish he rear brakes and put off the cowl bodywork for another weekend when I get both days to work on it.
rob289c
It's coming along nicely!
Dwayne :)
rob289c
I made pretty good progress Saturday and today.  The Floor of my donor Pinto was all but gone right up into where the firewall met the frame.  When I disassembled, there was essentially nothing left so I had to build it with scrap sheet metal.  I fabbed and welded off the frame and didn't get it perfect.  It didn't sit on the frame as it did from the factory.  I had to put spacers between the firewall "floor" and the frame so it would sit in position.  The right side was off a lot more than the left side.  I welded nuts to the underside of the spacers so I can bolt the firewall in place.  I've got everything in place and it's solid!  I do need to remove the assembly so I can weld everything up good and solid.   That will be next Saturday's project.   Some parts are just tacked in place due to access.  That was yesterday's project.   This afternoon I fabbed and installed radiator support rods.  It helped triangulate and stiffen the cowl and firewall.  I am going to have to remove the whole assembly and do some more body/prime/paint work.  I'm glad this part is behind me.  I have spent considerable time trying to figure out how I was going to get the assembly in the proper position and make it solid so now I can move on to other project needs.
I received the correct rear wheel cylinders but didn't get around to installing them or the right side brake shoes.  That will be for another day.  Next Sunday is Father's Day and I attend a car show in my home town so I will get done what I can on Saturday  but will make no progress on Sunday.
rob289c
rob289c
I didn't do as much on my project as I originally planned.  I did install the rear axle cover along with the original axle tag.  It is a 2.83:1 ratio...I wish it was at least 3.25 or 3.50 but it is what it is.  I filled with lube and reinstalled the 23 1/4" driveshaft.  It's more like a propeller shaft.  I put the tranny in neutral and found that with the rear wheels off the ground, I can spin the driveshaft in the forward motion but can't in the reverse motion.  Is that normal?  I did push the vehicle rearward but it was much more difficult than without the driveshaft in place.  The front is rolling on a 6" caster so maybe it would be easier if on four regular sized tires?  I check my firewall position and trimmed one of the shims but didn't do any welding.  That will have to wait till next weekend.
I did do the PM on my Ranger.  It is rarely driven so a few years have elapsed since the last PM.  It got oil change, greased outer tie rods, lower ball joints, and rear driveshaft u-joints.  I lowered the spare tire and inflated.  The spare tire carriers can seize up if not exercised periodically.  The underside of the bed is pretty rotted due to NY Winters.  I will have to find a good used bed or make it into a flatbed.  Otherwise it's a pretty good 20-year old truck.  I have a 6 1/2' plow on it so it is useful when we get heave snow, or for returning bottles and cans, getting mulch, taking stuff to the scrap yard, etc.
More next weekend...
rob289c
rob289c
Progress today: I removed the rear axle cover, drained the old gear oil, cleaned out the housing and cover.  Cleaned both mating surfaces.  Primed, then painted the cover and bolt heads silver.  Tomorrow I will install the cover with new gasket and fill with 75w90 synthetic lube.  This was done in between the oil change, tire rotation and inspection of my Mazda6 daily driver and mowing the lawn.
I also started working on getting the firewall and transmission hump in place.  I have it "shimmed" with pieces of wood and steel to get it it the correct position.  I took measurements at key places and I think I have it where it needs to be.
Tomorrow I'm going to have to do some metal fab, welding and bolting in place.  I need to fabricate radiator support rods to tie the radiator support to the firewall.  Then I need to tie the rear of the transmission hump to the forward section of the driveshaft tunnel.  At that point the cockpit should be fairly solid.
I will do this in between doing the oil change, tire rotation, and general maintenance on my Ranger.  Another full day in the garage.
rob289c
rob289c
I'm glad your brother made it back.  I have a high level of respect for Viet Nam Vets.  My war (Desert Storm) was relatively easy.  I did 6 years Nave and 17 years Air National Guard.  Overall it was a good career as an Aerospace Ground Equipment Technician.  Met good people and went to cool places.  Learned god technical and leadership skills.
rob289c
I catch a lot of military shows on Smithsonian Channel. As I get old it makes me grateful that I was never called to fight. So many died young. My older brother did two tours of duty in Vietnam. One with sentry dogs and one on river boat patrol. Thankfully he made it back and also survived a career as a Federal Agent (he was Military Police in the Army). Both the draft and the Vietnam war ended just before I graduated HS in 1975. I had considered the military given the peacetime aspects but I had to have surgery right out of high school due to a track injury and my life took its own course from there.
rob289c
Today I decided to change the rear brakes on my project.  I purchased the parts months ago.  Remember, the rear is a 6 cyl 67 Mustang with drum brakes.  The car must have had a brake job not long before it was put out to pasture.  The hardware actually looks good and the linings on the shoes are quite thick.  The linings were bonded, not riveted and have separated from the shoes so they are getting replaced.  In addition to the shoes, I am replacing the wheel cylinders.  That is where a problem surfaced.  Since the front brakes are Pinto disc, I bought rear wheel cylinders for a front disc/rear drum Mustang.  Of course, they don't fit.  I should have bought wheel cylinders for a front and rear drum Mustang.  I ordered them today.  I replaced the left side shoes and cleaned everything up.  I will have to take them back apart when I replace the wheel cylinders.  While I had the drums off, I wire wheeled, primed and painted them silver.  They look nice.  I also replaced the rear brake hose.  I'll have to finish the job next weekend.
Tomorrow I will be changing the Harley oil and primary lube.  Weed eat and lawn mow.  A few other chores and a party to attend.  I have a Veterans MC run on Monday.  Probably won't get much more done on the project this weekend.
I hope y'all enjoy the holiday weekend and remember those that gave all for our freedom.
rob289c
