Date: 02/05/2020 11:06 am
Clutch Fork
Date: 03/31/2018 09:12 pm
Date: 01/28/2019 05:15 pm
Date: 12/09/2018 11:35 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
Date: 07/01/2019 03:17 pm
Date: 01/28/2021 03:49 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
  • Online today: 586
  • Guests: 272
  • Total: 272
New project... 1980 Runabout
Glad to know you made the trip and got back home safely.  When I finally have my orange '74 Runabout finished and home, that show/meet is the highest priority for me!  Looks like a gorgeous setting and who could resist the rivalry between the Pinto/Bobcat guys and that poor Maverick/Comet bunch?
Quote from: pintosopher on August 23, 2017, 07:07:25 AM
Looking pretty Sharp Matt, Keep up the good work! :)
Thanks that's the plan. If things improve and not get worse I will be happy lol. I also found out the horn is very weak and will try to replace it with a spare I have in the parts bin.
The car did ok. It has a death rattle from the front end so it will be getting all the front suspension replaced. New shock arrived while I was out to replace the one I couldn't get off the 77. The car has no fast idle and runs like crud until warmed up and yes it was cool enough for the choke to function. The speedometer also broke on the car. It showed me going 85 but not always. At the same time the odometer was fine. I found it is possible the speedometer needed lubricated so we'll see what happens when I reinstall the cluster.
On the way home I was on I71 south when I heard something hit underneath. I pulled over and didn't see anything so I got back on the road. Turns out it was a bracket that went to the hood latch from the lower radiator support. Got a replacement from someone on Facebook already being sent to me. Time will tell how hard the suspension will be to be rebuilt.
Quote from: r4pinto on August 23, 2017, 07:04:13 AM
Just a couple pics from the trip
Quote from: dick1172762 on August 17, 2017, 05:25:32 PM
I don't know if I missed this in the past, but the only way the fast idle will work is when the choke works. Plain and simple.
New choke assy are on E-gay / ford pinto nos / 2.3L choke / for around $20.
Interesting. Might have to do that. First winter project though is that aged suspension
Intake only requires work if used for racing, otherwise it works just fine. Several members on here have gone that way. Good winter project.
I was under the impression there were issues with the intake manifold plenum fitting without modifications. I've had a love/hate relationship with carburetors. I love to hate them. Get in the car, turn the key, and go. drive with minimal issues. If there is a problem hook up the computer and track it down by the sensor readouts. Even without a computer to test it I have always had a knack for diagnosing fuel injected. Carburetors not so much.
BTW! FI is supper easy on a 2300 Pinto. Just get one off a 2300 Mustang. It will bolt right on and the smaller ports of the FI intake will work even better with no mods necessary.
The unfortunate truth is most people are on Facebook any more. Knowledgeable people exist in both places however most the time very few people post on here which is why Facebook is looking like a better option.  I've torn the carb down and rebuilt it and yet no fast idle. It's not worth messing with. If I had a way to and the money I'd rip the thing off, throw it away and go EFI. Give me EFI and I know a lot. Give me carb and I don't. And this seems to be something that has to be seen in person to fix since I have followed directions perfectly. It runs great when warm but ZERO fast idle. If it was junk inside it wouldn't run. I've been there in 2006 with the 77 Pinto and its original carb. But in other news the car will drive ok to the car show. Just not much more since the suspension is rattling. The car will be parked after the car show season is done so I can tear apart the entire front suspension, including new rack and pinion.
I've seen many on farcebook that didn't know were to put oil into their Pinto. Some didn't know if the thing under the hood was a 2.0L or a 2.3L, I think the people that could help you the most are on this web site. I know you have been fighting the carb issue for a long time. The holley / weber is a very simple carb when you put them along side a carb or FI for a new car. Here is what I know from past over hauls of the carb. #1 Remove the linkage from the choke.  #2 Remove the screws that hold the top of the carb on.  #3  Remove the complete top of the carb and turn it over so the float is pointing upwards.  #4  See where the float is located. There should be aprox a 1/4 (.250) of clearance between the float and the carb cover.  #5  Remove the main jets one at a time so you don't put them back in the wrong hole. Make sure they are clean. Then zoop the remaining gas from the carb. I use a plastic bottle with tube sticking  out of the top. Mash the bottle and stick the tube into the gas. Look in the holes were the jets go for trash. Use low air pressure to blow the holes out. Now look at the power valve in the bottom of the float bowl. If damaged replace it.  #6  Remove the idle mixture screw and blow it out with low pressure air.  #7 Pray its fixed. #8  Put it all back together. It takes very little trash to screw the carb up. Hopes this helps.
Then again maybe not. The linkage is there. I quit. Screw the d@&$ thing. It isn't right and won't be. Will drive it as is. Maybe someone in person can shed some light. Nobody on here can seem to figure it out. And have better luck on Facebook getting responses since most are on there. It runs and drives just not as well as I would like. For now this chapter is at a standstill. I ordered a new left front shock absorber and once the car show season is over the car will go on jack stands for a complete front end rebuild. Some knocking from the front end is starting so I know I need ball joints. I have a complete kit I bought on eBay years ago and also have new front cool springs. Add a new steering rack and it will be able to be aligned as well. Not giving up on the car, just going to put it to rest while the suspension is rebuilt. Rear leaf springs are solid as a rock so those are good. Cool springs may be also but brand new in box I bought for the 77 and never used. I have one shock currently and a second ordered. It'll drive stiffer after with no noises
Car was cold this morning so I tried to start the car. No luck. No spark again. pushed the wire and connector on the coil and it started to fire up. Plugs  got a little fouled but once cleaned off it ran fine. No fast idle when I got to thinking... The choke assembly came off the car too easy. Missing linkage from the assembly to the carb. Hard for the car to run right without it. It runs ok when warmed up but the choke doesn't do its job currently, and no fast idle without that part. I have the linkage on my spare carb so I will put it on the main carb for now. Better than nothing.
Nope just me. Told him about it but didn't seem too interested
It sounds like you're about ready to roll!  Should be an exciting trip.  Is your Dad going with you?
Quote from: dick1172762 on August 16, 2017, 01:03:26 PM
Make sure you have a spare fuel filter, timing belt, and fan belt. Those three items should cover 90% of what could go wrong.
Sorry if the response was a little short. I know you're trying to help.
Anyways the test drive went well. New wires and choke adjusted made for a happy car. I also found the choke coil I was going to use was bad. Lastly I adjusted the curb idle to 800rpm and now she runs very smooth.
Ain't my first rodeo. I got it covered.
Quote from: phils toys on August 15, 2017, 07:28:49 PM
Lots of good work. See you soon.
Thanks Phil, you had seen Harold II and knew of the issues I had with the fire back in 2012 on this car. It'll be a treat to drive her to the car show Friday night.
So last night I started the car, and it took quite a bit to get her fired up but she ran. Didn't idle too well but I still need to adjust the carburetor's fast idle, and choke. I have an old Sears engine analyzer so I will be able to get her adjusted to 1980 specs. The carb was adjusted to 1977 specs, and ran well once upon a time. When the 77's days were numbered the carb got quirky. I never adjusted it since at the time I was going to use the car's original carburetor. Well, even after cleaning it never ran so I was forced to use the 77 carb.
I am going to make sure I have plenty of fluids in the car, as well as tools so if anything happens I'm covered... In theory. Looking forward to her debut to the Pinto community. Got some 0000 steel wool so I can polish up the trim, as well as clean the windows. There is plenty of overspray on all windows, and read from many sources this will take care of it.
Think of all the Pinto story's you can tell at the car show. Have fun / that's what its all about.
Update. New Walker Thundercore Ultra wires have the car running a little better. She gave me a fit with spark but found out it was an issue at the coil connector opposed to a wire issue. Still no fast idle so got to read up on how to fix that. Curb idle feels good once it warms up
Had the primary side of the carb plug up. It would idle but only run wide open on the secondary. Drove it 30 miles home that way, Idle / wide open / coast / idle / wide open / coast / etc etc. Never got stopped even after 30 miles thru Denver.
Yeah, the 77 Pinto I used to have left me stranded on the side of the road in 2006 with a plugged up carburetor due to rust, this Pinto left me on the side of the road with a blown left front tire and leaky accelerator pump (day I bought it ). My parents had an 85 Celebrity that lost a fuel pump in PA, the previous mentioned Cavalier problem, 86 Tempo had a bad lead going to the ignition coil, 86 Olds Calais lost a radiator side tank, Headlight on the 77 Pinto, rear brakes blew out on the 77 Pinto.... I've had too many break downs to not have tools and spare parts. Luck is not something I have lol.
Only time in the past that I had trouble was a float sticking in the carb. Had to raise the hood and bang on the carb with a wrench. Drive 10 miles and do it again, etc, etc.
Quote from: dick1172762 on August 13, 2017, 12:18:05 PM
We seem to be reading each others mind's. X files? Keep up the good work. Not only can you never have too many Pinto parts, you can never have too much information.
Haha you never know. The other three wires will be kept for spares. In 1997 I had an issue with a bad plug wire on a 1984 Cavalier wagon. Broke and had no spares. Ever since I've kept spare wires when swapping wires. A coworker things that's stupid but he's never had a break down due to a simple wire, carburetor, v-belt, etc. The car runs good but if I break down I have a few spare parts to keep the car going.
Quote from: dick1172762 on August 13, 2017, 12:02:29 PM
Get a tube of dow coring compound from your parts store. It looks like clear grease and it will not conduct spark.  Smear it into the boots and you will never have a problem removing the boots in the future. Does not melt or run off ever.
Already ahead of you on that. Got that covered. The boots on the old wires came off the plugs with no issue. Just the bad wire itself where the electrical connector broke off the wire. Could I have fixed it? Possibly but the wires were last replaced in around 2008 on the 77 the motor came out of and didn't want to chance it.
I pulled out my 1980 Ford manuals and went ahead and tested both the spare coil, and one on the car. Both tested good which made my day. I will see what I can find on testing the modules so I can make sure they are good as well.
I also swapped the choke assembly so it's ready of adjustment. The car should start up much better with the choke and fast idle cam adjusted since the car had no fast idle.
