Date: 08/24/2018 02:50 pm
Pinto for sale
Date: 04/19/2017 10:15 am
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 11/23/2017 05:44 pm
Date: 10/25/2019 03:30 pm
Date: 11/12/2020 08:28 pm
Date: 03/06/2019 06:40 pm
Date: 04/30/2023 04:31 pm
  • Online today: 586
  • Guests: 253
  • Total: 253
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
Lastly a friend from high school was by my car last night and it reeked PIG rich while running. Possibly from weak spark not burning the fuel but unknown.
As for the cylinder leak down any suggestions on how to do that.
Oh it's beyond frustration. I'm trying to drive this thing so I don't rack up miles on a car with broken heat so I can trade it in April and it keeps acting up. I've even tried to look for vacuum diagrams to see if they were never hooked up right on the 77 but can't get a straight answer.  So I will try to describe it. The EGR line is running to the bottom port on the carburetor, and the distributor is to the intake vacuum port on the front port of the intake. Is it possible the previous owners of the 77 had it hooked up wrong? Yep. But being as I have nothing to compare to I had to hook it up the same way since it's the 77 carb on the 80.
Matt, I do feel your frustration..
Let's assume that the new electrical components eliminate "temperature" related tuning from the ignition, and you have consistent spark at all temps. The next logical issue is fuel supply and metering.  Fuel vapor lock? Sending unit/pickup clogged with contamination?
Hook a can of gas to the fuel pump( safely), eliminate that possibility. Back to the emissions related "leaks " that allow the system to bleed air into the intake. If necessary, set the car up temporarily minus all emission and evaluate all operating temp situations. You will find the gremlin.
The Last is a complete multi temp leakdown  test of the head gasket integrity (you could do this first and save a bunch of time and grief if it's the problem)  :o Nothing will save a poor seal at the head, you can tune yourself into an asylum, if it's the problem.
Have faith, the answer is there..
Pintosopher , been there, done that, and paid the price :P
Stupid car is now stalling and running like crap after it sits. When cold it's fine except for that issue with the fast idle not working for no reason. Ordered a new ignition module and will also replace the distributor although I want to tow this thing to a field, pour gasoline on it and set the damn thing on fire.
Well I'm not actually rebuilding the rack, just replacing the tie rod ends. The car steers good or should I say as good as it can with worn tie rods lol
Great to hear that the whole banana is going to be eaten ;D  If you can find one to rent, I recommend the OTC Spring compressor (7045b) that goes inside where the front shocks reside normally, It is the Safest one to use, and that's why I bought one for My 72 work (future project) and a must have for My Dakota that I recently O'hauled the frt susp. Never worried after seeing the Turns that tool used to make the Springs loose enough for removal. and it worked great. Bought on Amazon...
While you have the rack dismantled, the pinion should be checked for excessive play, and shimmed as necessary for proper play on the rack teeth. Unfortunately , there's no Cam/locknut adjuster like many cars for this. If it's too tight, the rack will bind at either extreme of the full travel, so you may have to settle for some play to avoid the binding zone. This is where it could become a wash on just getting a new rack. :o
The car will track so much better when all of this is done, and you might even see more fuel mileage, and of course, peace of mind on tire wear/ bearing adjustments, etc... :D
Pintosopher,  loose ends are for wandering ,  directions are for folks with a fast horse ;D
Well I went ahead and ordered the inner tie rods from Rockauto, as well as a new driver side rack and pinion bellow so I can properly fix the flame broiled one. After the fire I used an old one from a 2004 Impala rack and pinion core I had lying around. Lost the core charge since I didn't return it in time, so I got my money's worth by using the boot.
Additionally I got two power steering TRW outer tie rod ends off ebay which will be installed as well. The steering feels good but I am getting a little odd tire wear from the bad passenger side inner tie rod end. That's no big deal since I have a 5th tire in the trunk for the spare I can rotate to the car if it gets severe enough to where it can't be fixed by driving the car properly aligned.
I am on vacation in a couple weeks, so what I will do is get a grinder to cut through the rivets on the old ball joints, and replace all four ball joints, all tie rods, front coil springs, and shock absorbers. I'm sure the car will drive much better after I do that, even though it drives pretty good now. Since the rear end is not alignable being a solid rear axle I will just get a front end alignment to save me some money.
That's why I'm not tacking it just yet. While I have a suspension kit I ordered for my old 77 I don't really want to replace the ball joints at the moment
Quote from: r4pinto on September 29, 2017, 10:01:41 PM
Vacuum modulator was definitely shot. Pulled the line off under the car and fluid poured out. New one on and smoking stopped, as did a little of the poor running. I did however find the passenger side inner tie rod is worn and needs done sooner rather than later. I will price new inner and outer tie rods and while I am at it replace the bad driver side rack and pinion boot. The rack really should be replaced but it's not in the funds. Heck new tie rods aren't either for that matter. Will do it as I can afford to.
Good to hear that the Modulator was the issue. Tuning can now proceed  :D  On the Rack , be sure that when you set up for the new ends that you have verified the rack is in exact center of travel, or it'll be tough to get accurate alignment later. Measure 5 times before you cinch those inner links, ( ask Me how I know :P) Then proceed to set up for actual center to center on the outer tie rod ends. One noteworthy issue, Camber and Caster should be set before Toe, as they will mess up that measurement. I know you were planning on the front end rebuild, soooo think about that horse before the cart as the budget allows :o Loose bushings & Ball joints will sabatoge a reverse alignment.
Ackk it will cost more money!!!  :o
  Pintosopher, debt laden tools keep my wheels turning, but the ride is straight, and the tires love it! ;)
I actually cleaned a piston on my old Impala by putting ATF on the head. Cleaned it right up before I replaced the head
I have known several really good gear heads that would put a quart of ATF in their engines to clean them out before they drained the oil out. Don't see how it could hurt.
Well the vacuum modulator didn't hold out after it started to go and she was going through transmission fluid. Smoked like crazy once it failed completely. I ordered on through Rockauto and it got delivered today. I've been driving my dad's car the past couple days and will get my car fixed tonight. It will be nice to have it back on the road and save money on gas. I may blow out the line with carb cleaner to get as much fluid out of the vacuum line as possible. The bright side is that transmission fluid will clean the carbon right out of the engine.
Quote from: dick1172762 on September 26, 2017, 11:28:48 AM
   It makes steam in the cylinder which attacks carbon build up. I've used it all my life with no problems at all. DO NOT try this with a water hose. Use only a spray bottle with a fine mist. You can not use too much as it pass's out through the exhaust pipe. You may have to up the rpm while doing this.
I have a squirt bottle for my cats so I can use that. I will give it a try. Couldn't hurt
Quote from: r4pinto on September 26, 2017, 09:14:31 AM
I’ve not heard of that. What does it do?
I've not heard of that. What does it do?
Found some info. Interesting reading. May have to try it
Quote from: dick1172762 on September 26, 2017, 09:10:06 AM
Have you tried spraying water down the carb while the engine is running? You don't need much water. I use a pump spray bottle like a Windex bottle. Work's very good and you will not believe all the junk that the exhaust will blow out the tail pipe. The spray of water will not rust or in any way hurt the engine. Work's for me.
Quote from: r4pinto on September 26, 2017, 07:05:15 AM
One thing I've noticed... no smoke when idling unless cold with the choke closed, but in that case I know it is running rich because the choke is closed. Plug checks showed clean plugs and I'm getting 23-24mpg. If I speed 21 mpg. When revving I will see if anything is coming out when I work on the car this weekend. I'm at the point where driving to and from work I need it better. For car shows it was acceptable but for daily driving it needs to be right.
I appreciate the suggestions and hopefully will find something to get it right.
Quote from: pintosopher on September 26, 2017, 07:00:48 AM
When you get a vacuum gauge, see if the reading jumps erratically in sync with the flat spot. Still could be a air leak related to vacuum controls , but you'll have to isolate those when you change carbs. Black smoke while the flat spot is there, is over rich flooding from the Accelerator Pump circuit.
Quote from: r4pinto on September 26, 2017, 06:51:25 AM
I am also going to do what you suggested and check the vacuum. My vacuum gauge may be MIA. If it is I will go to Autozone and rent one. I need to have one but my garage is a nightmare currently, and I will lose it, like I lose everything else. Hard to believe I can fit a couple cars in there  :P
Quote from: pintosopher on September 25, 2017, 08:36:16 PM
OK, will retreat until you check back in  8)
It gets more interesting. Seems there is a "flat spot" on the carburetor. Don't know how else to describe it. Cold or warm if you give it gas it stumbles and nearly dies before accelerating. I almost got hit twice this morning because it just wouldn't go initially. I may see if I can get the original carb unclogged and functional this weekend. It has all new gaskets and been rebuilt but a plugged jet somewhere so no fuel flowing. I would spray starter fluid in and she would start but die. I found gas in the bowl but wouldn't spray. A shame since she ran great on the old carb.
Regardless I will do a carb swap, whether it be with that carb or another spare I have cleaned up. I will also change fuel filters since that one is from the 77 when I got her ready to go for Carlisle 2010.
Quote from: pintosopher on September 25, 2017, 08:29:46 PM
Check for any temp sensor that ties the vacuum system control to the cooling system jacket. This will affect timing and even carburetor system controls. Of course. an electrical component failure related to temp underhood. could also be in the mix too.
Pintosopher ,Looping the TVSS into lunacy :P :P
It's not hooked up actually. Due to the way the vacuum lines are hooked up. The 77 did not have it but the 80 did. This weekend I hope to get it closer.
Quote from: dick1172762 on September 25, 2017, 01:06:00 PM
What ever you do, keep up the good work. Car looks better every time I see a picture of it.
Thanks. Plugging away at it one issue at a time. It's not as easy to work on currently since it's my current daily driver due to no working blower motor on my Malibu which due to being an electronic blower controller will cost about $200 to replace. Back to this car though.
I drove the car Friday and something was off. It just seemed off and with the higher temperatures I drove my Dad's car to a football game. Sunday I drove my car and was fine. This morning it was fine as it was also after work. But after I left the gym it was not responding to acceleration as well, as if fuel or spark was off. Whatever the issue it doesn't affect it to where it's not drivable but to where it misfires more and can be felt. I am thinking possibly an issue with the distributor, ignition coil, or module since it happened after the car sat for a couple hours. This weekend it is cooler so I will find out later on.
So this weekend it was too hot to work on the car after I cycled for 9 miles and cut the grass which left the car not touched. Drove to the store and it ran ok. I let it warm up 3-5 mins and all was ok. Still has the messed up fast idle but at least it drove fine. This upcoming weekend it will be back down to the 60s and 70s so I can work on fixing it.
