72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 11/29/2018 10:26 am
Date: 01/30/2017 01:48 pm
Date: 04/27/2018 10:28 pm
Date: 03/18/2020 01:30 am
6.6.75 carrier
Date: 02/14/2018 06:47 am
Radiator
Date: 05/27/2018 06:07 am
Date: 09/01/2017 07:52 am
  • Online today: 586
  • Guests: 532
  • Total: 532
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
If you still need weather striping for your Pinto with a trunk, go to  http://www.weatherstripspecial.com  They have it in stock.
It smoked all the time. The engine had massive leaks all over and when I pulled the head the head gasket showed age. The car currently has an engine from my 77 parts car and it had 3k approximately after a rebuild. It's ok but higher miles than the car and original rings. The 80 on the other hand smoked the entire time it ran. There is no crosshatch pattern in the cylinders so it will be getting honed and new rings, as well as new bearings. Top end was tore apart for new valve seals in 2012 but not finished.
On a high mileage 2300 that smokes when its started after sitting over night, the problem is the valve stem seals most of the time. Easy fix and cheap too.
Well the leak has returned on the car. I went to a car show & parked it in the garage afterwards. I noticed a puddle under the car, but not horribly big. When I was leaving the car didn't want to go very well until warmed up but finally was OK. I haven't checked the fluid level yet but when I was at the garage I looked & it's not big but not small either. It leaks from the front and RF corner, same area as before. I think the pan may be warped but will find out more when I pull the pan tomorrow. Additionally the oil pan has also developed a leak at the rear. It's not the rear main oil seal from what I can tell, and seems to be coming from the back. For now I will monitor the leak & figure out what to do later. On the upside her brakes are good, her power steering seems sealed, and the rear differential is good.
In the past I've said I don't particularly like the squared front end of the 79-80 Pintos. While it is not my favorite it is seeming more like my car. I think her issues stem from her current heart. She has the heart of Harold II and is acting like the little B*** that Harold II was the entire 11 years I owned her lol. Soon I will be tearing in to her engine and inspecting it so I can start the rebuild. I already have the Ranger cam, rockers, and followers. I just need to get some new rings and bearings. Since she smoked I will also get a bore gauge, and engine hone to remove any glazing. I had the head off at one time and there wasn't any bad damage in the cylinders.
Since her original engine only had 91k miles hopefully she won't need a new crankshaft. I will also get a micrometer so I can inspect her crank journals.
As far as I know, there on the passenger side on both tranies. Easy to spot too.
Is that on the c3 c4 or both?
Quote from: r4pinto on July 29, 2017, 07:52:06 AM
Drove the car today to my workout as I wanted to and it did good. The speedometer is ok. Found it was possibly unplugged and works as far as I know. I need to have someone go 70 and see what mine is registering to see lol. I did however find a slight issue with the transmission. On the passenger side it drips a little. We'll find out. Tomorrow I will jack up the car and inspect it. It's only a couple drips but that's it. Not too bad but want it fixed if I can. If it involves pulling the pan I will leave it for now.
Passenger side is where the lines to the cooler are. Leaks there are common.
Glad to hear you had her out for a drive this morning.  Good work!
Dwayne :)
Quote from: pintosopher on July 28, 2017, 09:00:52 AM
Good to hear that you are being prepared, that being said , you'll do well the show.
BTW u can never have enough spare parts or enough special tools, (Ask me how I know!)
Pintosopher, a biological anomaly with gearhead propensities :o
I'll second the part about never having too many parts. I have now sold off all of my 2.0L stuff to SCCA racer mostly. Never see an ad anymore for 2.0L stuff. Still there in merry old England but for $$$$. Those of you with 2.0L Pintos, take VERY good care of them.
Drove the car to work today after having to jump start the car. I think it just needed to charge back up after draining, although I'm concerned about the condition of the battery. When I tested it this morning it showed the battery to be weak but had a good charge. The starter previously tested good so don't think that's bad.
Anyway, besides the battery issue I did find the speedometer has failed. When I drove to work I got a few miles away from home and it started making an odd noise & stopped reading. Occasionally the needle would bounce to around 45 & then drop back down. I couldn't turn around and get the Malibu since I would be late to work so I kept up with traffic. I have a spare cluster at home and will swap it out so I have a working speedometer in the car.
Still, not a failure since I knew there was a chance the speedometer was going bad, and since the cable is from 2011 and spun freely I know the cable is good. I changed the cable thinking that was what caused my issue & found out it was not. I will keep the old cable as a spare since it apparently wasn't bad. Can never have too many spare parts
New transmission dipstick tube o-ring. It apparently was leaking at some time. The previous owners used RTV on the dipstick tube. I used to be surprised with what I saw but now not so much. The leak however was from a piece of gasket that was stuck to the transmission case, and a big one at that. cleaned the gasket off the case, wiped off the pan gasket, and put it all back together. Took the car for a drive and all is well. The brakes feel great with a good, solid pedal, and besides a speedometer that may not be accurate all is well.
Quote from: Reeves1 on July 27, 2017, 07:48:38 AM
I've seen leaks from the dip stick holder O ring failing....
Reeves, funny you say that. I just got off the phone with O'reilly auto parts to order one. I think I may have to junk the car after this though. I don't know if I can afford it... That whole 29 cents might bankrupt me  ;D
Well I have more issues to worry about than that. I come home and go in the garage to add differential fluid. Transmission fluid all over the ground. Not sure where it is coming from at the moment. I am going to get a bite to eat and start diagnosing the issue
Those air compressor are dirt cheap at Harbor freight. I've never had a tire they wouldn't inflate too. Walley world has them too.
I've seen those before as well & may have to invest in one eventually. For now brake fluid in the bottle with the line in the fluid will work fine lol.
As for the car I got the transmission seal and driveshaft installed. Had to jump the car, since the battery was low but once I did the car ran somewhat decent. I really need to replace that carburetor. The 77 never did run too well on it but better than nothing. Once I got the car to stay running I got transmission fluid added to the car. I also added gear lube but need to get another bottle. The hatch seal I installed did not work so I will be buying one with a bigger seal area. The one had no compression to it with the hatch closed, so hopefully a different one will.
If all goes according to plan I will be driving that car to work tomorrow. It's suppose to rain & I want to test out the wiper motor. I replaced it but want to make sure all is well before a long trip. If it's going to act up I want to be close to home.
I've used one of those little air compress'r that you carry in your car to add pressure to the brake system for brake bleeding. Worked like a charm. Just make sure the master cylinder does not run dry.
Quote from: Reeves1 on July 25, 2017, 12:25:58 PM
If I were you ... bleed the brakes at least twice. Lots. Make sure it flows CLEAN !
I use the clear tube into a jar method.
Tried and true method. Been doing it that way for years.
As for the fluid flowing clean I had previously bled the brakes before multiple times at each wheel to get ALL the old rusty fluid out. All that remains is clean fluid. Only have to bleed them since the master cylinder failed and got air in the lines when I replaced the bad master cylinder.
If its not fun you shouldn't be doing it. If you plan to fix it up to sell, forget it because you'll lose money. Been there and done that although yes, I should have kept them. This is a hobby plain and simple, so if its not fun find a different hobby. I've been working on Pinto's since 1972 and the fun is still there even though there were bad times along the way. If you really hate working on it, sell it to some one who will enjoy and have fun with it like I have. This post is not directed at any one person. Its just one of my rants. It is directed at all Pinto owners. And please post on the Pinto web site to insure its long life. We the members really need this site as both of the Mustang II sites have gone under. Lets not be the next one to fold. PLEASE!
Pretty much what happened. Ran outta cash, brain overloaded, had to work on my Dad's daily driver for a month. Fun stuff. Now his car needs more work. But I'm putting my car first this time. His car sits most the time anyway. Didn't get the seal last night but plan to tonight. I will then install it & reinstall the driveshaft, as well as pull the wheels & bleed the brakes. It has a solid pedal but since I disconnected the lines at the master cylinder I want to be sure it's good. I can then possibly remove the seats so I can paint the carpeting. I might not since I will be driving the car this weekend but might. We'll see. Most important is getting the car drivable & passing the first test drive since all the repairs.
Sort of the same way I work on my cars.
Go hard till brain hurts and/or money runs out.
Pause
Back at it.
Gotta keep the fun in it !
Thanks. It helped having my Dad's car distract me, and my house distract me. I get going, then stop when I get annoyed. Since it's a project I take a step back and come back when I have a clear head. Although I hate tripping over the car's original engine as it sits in front of the car lol. I think it's safe to say I got more done yesterday than the rest of the year.
As for what's next I will pull the seats so I can paint the carpet. it's engine paint so not ideal but the carpet is garbage anyway. It needs new but floors need patched so gotta make do for now until I can repair the floors
The way your doing the work sound like a great way to prevent burn out that kill's many Pinto projects. Keep up the good work. The car will be worth it.
I also replaced the speedometer cable with the newer one from the 77. Spun the old cable and could feel it binding in the housing. It'll be nice to test that cable when I go down the road and hopefully have no more bouncy speedo.
Quote from: dga57 on July 24, 2017, 09:37:46 AM
With all you've accomplished, that sounds like a reasonable and reachable goal!!!
Dwayne :)
Thanks Dwayne,
I'll be hitting the gym tonight after work, then going to get a new tailshaft seal for the transmission. I just can't take a chance of a leak due to not replacing a $3 seal while the driveshaft is already out.  Once I do that I will charge the battery, add transmission fluid, some gear lube to the rear differential, and be good to bleed the brakes.... All theoretically of course.
So, in 2012 I bought the car only to have a fire. Didn't do anything from 2012-2016. Since 2016 I've done the following:
engine swap, repaint engine compartment,  rebuild entire brake hydraulic system & parking brake system, fix electrical short, install new radio, fix bad door pin switch, differential fluid & U-joint replacement, transmission fluid and filter change, power steering pump replacement, fuel line repair, rear shock replacement, paint carpet.
Quite a bit in a 12 month period.
Dwayne :)
