Date: 01/21/2023 04:19 pm
Date: 05/28/2017 03:20 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 01/23/2017 07:41 am
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 08/20/2017 01:34 pm
Date: 09/01/2017 07:52 am
Wheel cap
Date: 04/25/2022 11:21 pm
  • Online today: 586
  • Guests: 551
  • Total: 551
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
Get a tube of dow coring compound from your parts store. It looks like clear grease and it will not conduct spark.  Smear it into the boots and you will never have a problem removing the boots in the future. Does not melt or run off ever.
So I got a new set of Walker Thundercore Ultra spark plug wires from Jegs. Regular price is $25.99, on sale for $15.50. Ordered them Thursday, then went to the store to pick them up Friday. 8mm wire vs 7mm wire, better insulation for less radio noise. Seems to be a better overall wire. Today I will install them, as well as adjust the carburetor and choke assembly so it actually functions. When I'm done the car will have fast idle, which is more than I can say at the moment.
Currently the car starts and runs but no fast idle or working choke. That'll change very soon.
Quote from: dick1172762 on August 12, 2017, 01:19:06 PM
Get one of those little compressors that plugs into the lighter. I never leave home with out mine.
Already got one. Had one for years.
Quote from: dga57 on August 10, 2017, 09:14:18 AM
That SHOULD take care of the problem; hope so anyway.  I'm excited for you finally making it to the Pinto/Maverick show.  Whenever I get my orange '74 Runabout finished up and home, that show is going to be one of my top priorities - it looks like a beautiful setting.
Dwayne :)
Thanks Dwayne. I ordered a set of plug wires from Jegs and they will be in tomorrow. They are rated better than OE and are on sale for two bucks less than oreily auto parts. Only $15 bucks with regular price of $30. I have a week to do additional test drives so I'm not worried about it too much. I am also going to get my Pinto tool box in order so I have plenty of spare parts and tools just in case.
Dwayne :)
Well last time I drove the car I noticed that at higher speeds the car had a noticeable misfire. I pulled the plugs and 1-3 looked really good, but 4 was another story. It seemed to not be burning too cleanly. The cylinder wasn't rich, but at the same time not fully burning either. When I pulled the plugs all four were over .040" with specs of .034". I didn't gap the plugs before since I didn't have a wire feeler gauge, and they were platinum plugs. Well the gap should make a difference in how she runs.
The bigger issue was the #4 plug wire was broken at the plug itself. I did the usual twist to break it loose and gently pull but that's when I found the wire was damaged. I will get a new set of plug wires for the car and keep the other three as spares for the toolbox for when I go to the car show next weekend.
I'm glad to have found this issue before driving to the car show instead of during the drive. The car was running ok except when cruising and since I will be mostly cruising around 65-70 I need it right.
Quote from: dick1172762 on August 07, 2017, 10:52:04 AM
Please post more pictures showing your work. I'm sure they will help anyone with a Pinto that is less than perfect including my own 80 model.
I'll be sure to. I've always loved Pintos, and posting the progress is enjoyable. I may have to step away from time to time when I get annoyed but if my project post will help others it's worth it.
The car will be getting driven to the gym tonight after work, and can then see what other adjustments I need to make to do well on the trip to Geneva, Ohio. A little buffing on the paint should help as well so she shines up nicely.
Pics of the interior work to the car.
When I got rid of the 77 sedan I kept the door seal I installed on the 77's driver door. The picture shows just how bad the old one was.  I'd say it was amazing it wasn't leaking but when I washed the car I found it was leaking.
Sounds like a day well spent!
Dwayne :)
I got busy on the car today. Previously I installed a remote sport passenger mirror and finished the installation. Yesterday I removed the door panel to replace a bad speaker and wiring so while I had it apart I went ahead and ran the mirror cable inside the car. Like most it doesn't fully function but it is at least done correctly. I also scrubbed the door panel and pieces, as well as replace a worn window crank. With the panel cleaned, speaker grill installed and door accessories cleaned up it looks better. I also reassembled the rest of the interior and it is much better.
I went ahead and also vacuumed the back since I never did. There was a bunch of crud inside but much nicer now that it's cleaned up.
Well I had to unfold and tape some areas but considering she was a barn car I'm surprised the mice didn't get it
Always cool to stumble onto the build sheet!  Doesn't appear to be in bad shape at all!
Dwayne :)
So when I had the seats out of the car I found the build sheet. The paper was very brittle but I managed to reconstruct it
New starter and she runs good. Also tightened the exhaust so no more banging pipe. Ran good although her carb needs adjusting before the trip.
Took the starter and battery to AutoZone to be tested. The battery tested good but starter kept blowing their breakers. It was locked up.  I had a feeling it was on its last leg when I did the motor swap but it supposedly tested good. I know they can go bad quickly but seems odd to have failed and never seemed to crank very well. $56 for a lifetime warranty unit versus $34 for a one year warranty. Could the one year work? Perhaps but don't want to chance it going bad on month 13 of 12 months and have to buy another.
Yeah, I was doing a quick diagnostic last night by feeling things. The coil felt very warm so not sure but it might be overheating. When I did the motor swap I took both the ignition coil, and the ignition box from the 77, as I replaced them previously. I have a Pinto toolbox, which is a metal tool box with a Pinto emblem on the outside. Inside there are going to be tools, a couple clamps, and a few easy spare parts like timing belt, distributor, cap, rotor, couple plug wires, ignition coil, and ignition box.
First things first though.... Pull the starter and get it replaced. I had it tested last year when I did the motor swap and all was well so I'm not thrilled about this but can't do anything about it either.
Re: I also noticed occasionally the car would just shut off as if I turned off the key. When it happened the car wouldn't restart for a couple minutes, then fire up like nothing happened after a couple minutes.
1st thing I would suspect would be the electronic ignition box, had a couple different ones do exactly the same thing over the years. Never fun getting them back to reliable but when you do sure is fun to enjoy the fruits of your labor. Keep at it Matt :)
Another road block. Her starter died. New one at AutoZone or remanufactured unit. She will get a remanufactured unit
Matt,
I'm glad you're still making progress!
Dwayne :)
Well the transmission leak returned. I looked, and it seemed to be in the same area as before. I know the old transmission pan was causing some issues, since it was leaking all over, mainly in the right front corner. Well, it was sealed everywhere EXCEPT the right front corner. I inspected it and it didn't seem to be leaking from the pan or anywhere else, but noticed it seemed wet in the area of the dipstick tube. I tried my best to repair it but may end up replacing the dipstick tube. I couldn't tell but thinking there may be an issue with the tube itself.
I also went ahead and put the interior back in so I can take a test drive with the car tomorrow. A week from next Friday I hit the road so I want to make sure it's good and safe. Worst case scenario I monitor the transmission fluid and add as needed.
I will be pulling the passenger side door panel off the car so I can replace the bad door speaker and wiring. I found the original speaker is dead, so I will be installing a Sony speaker I got from the salvage yard a while back.
I also noticed occasionally the car would just shut off as if I turned off the key. When it happened the car wouldn't restart for a couple minutes, then fire up like nothing happened after a couple minutes. I pushed the connector back on the coil, as well as the coil wire and all was fine after. We'll see what happens. If the coil is bad I have a spare.
Since I have the interior pulled to paint the carpet I tried to replace the rear seat belt buckles that were badly rusted with the ones from a 92 mustang convertible. The bracket on the driver side one needs modified slightly and the passenger side broke the torx bit. Can't get it off so for now I did a repair job. A little sanding and testors silver model paint and it looks much better.
Far from perfect but much better I think. Once it dries I will bolt the seats back in
carpet before and after paint. The spot I didn't hit was where the seat will be. And I was running out of paint
Today was productive. I started off going to Jegs to pick up the transmission drain pan for my car. Pulled off the old one and found it was dimpled and warped all over. Now it was leaking before I did the initial fluid and filter change so my guess is it was overtightened before. Hopefully this shiney chrome C4 drain pan will seal up and stay sealed.
Since the car was up in the air I also went to remove the shifter from the car. Unfortunately the clips holding the 8mm bolts broke so for now it is on the car and doesn't want to come off... stupid clip nut things. While I was at it I also removed the seats from the car so I can vacuum the interior, as well as paint the old carpet. It looked better after vacuuming but still very faded. It looks much better than before. I also scrubbed the seats, as well as the interior trim panels since everything was grimy. The back seat belt buckles are rather nasty so I also went to remove them. The replacements are from a 92 Mustang and slightly different in how they mount but they should work nicely . The passenger side seems fused to the car, and badly rusted so I'm not sure how I will get it off. Perhaps jack up the back of the car and soak the bolt in blaster. Since the gas tank is back there I really don't want to heat it up to loosen it.
I also found the build sheet, and will be taping it back together to keep with the car. Not in bad shape for almost 40. Once the phone is charged I will post pics of the work done.
Yeah. Pretty pricey compared to what I can afford. Fortunately the  one I got is working for now.
They have it for a hatch too if you do need it some day.
Quote from: dick1172762 on August 01, 2017, 03:47:58 PM
If you still need weather striping for your Pinto with a trunk, go to  http://www.weatherstripspecial.com  They have it in stock.
Thanks. That pinto has been sold off for scrap though. My current one is a hatch. For now it seems to have stopped leaking after beating the hatch in to submission
