Seeking parts
Date: 10/18/2020 10:35 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 04/20/2017 10:10 am
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 04/04/2020 09:38 am
Date: 10/24/2019 01:45 pm
Bell housing
Date: 08/23/2017 05:41 am
Date: 10/01/2020 02:00 pm
  • Online today: 529
  • Guests: 393
  • Total: 393
Well, just about to get started on my 79 hatchback-long
Started by russosborne, June 23, 2010, 04:44:42 PM
Maybe I should fit the 4.6 and trans first.
NAH, why do anything like that? :-)
I am like the cartoon character who is walking on air. As long as I don't know it is impossible I am going to do it. :-)
What's the worst that could happen? I waste my time and kill a Pinto. At least I won't be demo derbying it. And I am having fun(most of the time anyway). And I want to be different than everybody else.
(although if I had been given a 302 I would have been just as happy with that!)
(yes, I have been reading other threads)
The crossmember thing is in this picture. It runs from roughly the door post to the trans tunnel, on both sides. I want to add to the top of it, and have one piece going from side to side.
I had wanted to run one under the car at that point instead, but decided that it would be easier to modify what is there. Plus I won't have to figure out a way for the driveshaft to go through.
I am going to be making a box essentially on both sides of the tunnel from that point back to where the floor goes up to the hatch floor. The passenger side part is where the battery is going to go, and the driver's side is where the electrical stuff will go, fuse box, etc. The top is going to be hinged. I think I am going to be using the back of the rear seat(the metal plate part). Who needs a back seat anyway? Besides, once the roll cage is in, there won't be room for one.
essentially. I am not sure yet where I am going to have them end up in the back. I think I am going to just have them go straight back to the little crossmember thing where the lower rear seat goes, and then see about running something to the leaf spring mounts if needed. I am going to reinforce that crossmember as well. But for all I know that could be where the leaf spring mounts are. I honestly haven't looked that much yet. The II leaf springs actually mounted to a plate that bolted onto the floor, with the bolts coming from the interior side. Wish the Pinto had a similar setup. Would be a lot easier to do the subframes. I do have those plates from my II, but I really doubt if they would work, the floors are different at that point between the two cars.
I also am going to try to add braces for where the seat mounting bolts go. It may not be needed, but why not. I know it is pretty important on the fox body cars, and it can't hurt.
My right hand(mainly the thumb) is killing me. I used a pair of tin snips to cut the floor. Worked pretty good, but it takes a lot out of the hands. Not sure how I will do the rest when the time comes. Advantage of the tin snips is they don't make any noise, so I can use them late at night when I am usually out in the garage. But I am having a hard time just typing right now from the pain.
extending the subframe to the front leaf mounts, or across to tie the two together for a more "uniframe" vehicle?
well, spent a little time out in the garage today.
Found something rather scary. Pictures attached.
This is the top of the subframe and floor support on the passenger side, from about the front of where the seat would be forward just about to the seam where the floor pan meets the firewall.
Now, you may be asking, just what was he doing cutting the floor there? I'll see if you can guess for a bit. The one picture should pretty much give it away.
Btw, to answer a question I had asked a while back, the subframe/floor support has an internal width of about 3 inches.
not a problem for me. I don't own this thing. :-)
it's here for everybody.
Cars aren't the most important things in this world.
Wow... talk about hijacking a thread!  My apologies, Russ... didn't mean to do that!
My sister was born in 1960 and learned to walk with the assistance of leg braces by the time she was four.  Believe it or not, she managed to go to public schools.  A series of operations were done to fuse the bones in her feet together so that when she was fourteen years old, she was finally able to walk without the braces.  She worked as a computer operator for many years before her health declined to a point where she was no longer able to do so.  She retired on disability in 2006.  She is still able to take a few steps with a walker, but is more or less confined to a wheelchair nowdays.   Considering how little was known about Spina Bifida fifty years ago, it is a miracle she survived, let alone growing into a productive adult.  My very best to you and your family... especially to your daughter.  How old is she?
bolubeyi
Quote from: dga57 on August 01, 2010, 01:04:22 PM
Well, I can understand the guilt feelings... and they are probably justified to a point, but it's not easy dealing with a special needs person.  I've had about fifty years experience with that.  My sister was born with Spina Bifida when I was three years old.  Her needs are many and varied, and raising her was a family effort.  She turned 50 this June and as she ages, her needs have become even more demanding.  This has proven out to be good training for what was to come later.  Sixteen years into my current marriage, my 46 year old wife suffered a major stroke.  Being in the pons area of her brain, it has affected her vision, memory, balance, and speech.  This was a seemingly healthy, active woman who was a nurse by profession.  She can no longer walk unassisted, obviously can't drive or work, and she needs assistance with pretty much every aspect of day-to-day life.  Even with a lifetime of care-giving experience behind me, it sometimes threatens to overwhelm.  Believe me, I know where you're coming from.  If you could no longer meet Paula's needs, returning her to her parents was probably the kindest thing you could do.
Keep plugging away at that Pinto... I'm still betting you'll have success in the end!
I also have a daughter of spina bifida.  able to walk .  We live turkey .
web pages: http://www.spinabifidaturkey.com/smf/index.php
You know, I used to enjoy math. Now it makes my head hurt.
Thanks!
1 mm = .03937"
9/32 = .28125
.28125/.03937 = 7.14 mm, so a 7mm socket would be closest (might fit).
well, that is what I had thought. 9/32nds works. If it is metric I don't have that size either. 1/4 is too small, 5/16 is too big.
Not sure what 9/32nds is in metric land.
9/32 socket to take apart a 96 dash? if its a 96 everything on it should require metric sockets?  Or did ford do sumthing crazy again?
be careful, you may end up with a whole car.
seriously, things aren't quite that bad. yet.
be glad when this friday gets here. payday. I can then afford to get a new 9/32 socket so I can get the 96 dash apart. I really need to get something done as far as going back together. Might work on the tail lights some more. Need to buy more cutting discs for the grinder.
Then I need to get the rear axle off the car. Been delaying that thinking I may need to roll the car around, but I will just worry about that if it happens. Actaully, I think it is more of a psychological thing. Once there are no wheels, it isn't a car. Yeah, stupid, I know. But that is how my mind works (when it manages to ).
I also need to get the welder welding. Got the wiring diagrams yesterday from Lincoln, they have great customer service, even though I bought this used and it is almost 30 years old.
i have 2 or 3 i can practice with  but i put a cap on mine and i am very satisfied with it. but i will take all the parts you dont want or need.
Phil, I just saw the post on dash pad recovering, and realised that I didn't give you the dash pad. I know it is in the garage somewhere, will have to find it before you come to get the engine and stuff. It needs redone, but could be a good practice one for doing it yourself. ???
Well, the weather isn't in the 100's. But the humidity sucks. I will be out there and hardly do anything and my shirt is soaked in sweat. I am probably a bit dehydrated, hardly drink any water, mostly diet soda or diet koolaid stuff. Maybe I should get some diet gatorade, except they don't have my flavor in that. Or at leaast I haven't seen it. Fruit Punch.
Phil, I am not going back. That stuff is yours. Don't try to give it back. :-) I am at the point of no return on this thing. 4.6L or bust!
Wish I could find my darn dvm. I can't troubleshoot the welder without it. I should take a picture of it. I cut off the Pinto muffler, and have it on the exhaust pipe of the welder. I need to go from about 1 inch to whatever the muffler is, maybe 2 inch. Maybe use a soup can as an adapter. :-)
As the old saying goes, "Rome wasn't built in a day!"  Clinical depression is difficult enough, but I'm sure it has been exacerbated by the recent loss of your beloved dog.  Until some of that passes and the meds start to kick in again, my suggestion would be to step back for a few days.  Sometimes we are too close to a problem to see the solution.  I'm sure there are lots of things you can still accomplish without funding.  Do those things first and dare to believe that the funds will become available someway, somehow when you reach the point where you can't  go forward without them.  Good luck, Russ... and whatever you do, don't give up.
come on  russ lets keep this going  i also understand the money situation i think most of us do  that is why you do what you can if toy need advice  we are here to help and you will still be doing it on your own  we would love to see the car at carlisle  but if it is not done  oh well  if you decide you go back to a 2.3  i still nave the peices and you can have them back.
just rember some  progress is a great thing  every little thing  gets you closer to the end result.
it was great meeting you and look forward to seeing this project in person.
Oh yeah....you ARE my twin.
Standing back and asking "what have i gotten into"?
Oh yeah. They come apart easily, not so much together the same. And they cost money.
Sorry to hear your troubles, I TOTALLY relate. Right now I am also in a "could care less" attitude, especially with the weather being 100+ degrees every day. Hopefully I'll get back in the swing myself once it cools down.
well, still taking a break. maybe that has been a bad decision. I am having major "wow are you thinking" about this whole thing. Hey, wowisn't what I wrote. I wrote W. T. F. without the spaces or periods. Even the forum software doesn't like me.
I don't have money to do anything. $10 is a major expense. yes, I was given the 4.6 mod stuff, but it is still going to cost money to get everything done. I don't really feel like doing anything. A pinto is not "the car" to me, it is just the car I have available. Yet here I am in the middle of a project that many people are saying is impossible. I feel I will most likely prove them right. Should I put a 302 in this? It would be a lot easier. But then it would just be another Pinto with a v8. I want to be the leader once instead of a follower. Problem is I don't have the tools, money, or really the experience. And I really want to do this on my own. I don't mind helping other people on their cars, but I have found out that when it comes to my car I want to be the one doing all the work. I realised this many years ago after a friend was helping me sand the body on a GTO I had bought from him said "that is good enough" and I didn't think so. I didn't say anything, but it made me think.
Part of this recent being in the dumps has been the dog stuff. But part of it has just been from standing back, taking a deep breath, and realizing what I have started here.
I recently sold the 8 inch rear end I had bought when I first bought this car, because I had the 8 inch from the II, and it was a bolt in, no problem installation and I thought that would be the right way to go. Well, it was when I was going to just do a 2.3 engine again. But now that I need a 5 lug rear I am really regretting selling that one. Going to need the 5 lug to match the front. I will need real brakes on this car if I ever get it done, and the little 9 inch brakes just aren't going to cut it. And the II rear is difficult at best to find better brakes for, since ford in their wisdom made the II rears(and the Pinto ones, since they are the same) unique in the ford 8 inch world.
And no, I am not drunk. I wish. I haven't had any alcohol in over 20 years. I do have clinical depression, and right now the meds aren't doing their jobs. Obviously.
Quote from: russosborne on August 11, 2010, 02:27:03 AM
well, I thought it might be "I didn't think you would REALLY do that" kind of thing. :-)
I may be taking a break from posting/working on the car for a bit. We just got home from unexpectedly having to put one of our dogs to sleep. I might want to go out and do lots to the car, or I may just want to sit and cry. Probably some of both.
So sorry to hear of your loss.  That's a decision that is never easy to make or to accept.  Please know you have my deepest sympathy and will be in my thoughts.
Dwayne
I'm sorry to hear that. We had the scare of that this last week with out cat Louis,(louie) i wish you the best, and you have my sympathies and condolences. not an easy thing to have to do.
Quote from: russosborne on August 10, 2010, 02:25:25 PM
No comments on the Mustang II tail light? Good/bad/horrible?
I already told you... I like them.  I find them rather intriguing for some reason, although I normally prefer maintaining a stock appearance!
look fine too me im still trying to figure out if i wanna leave stock bobcat tails on mine or if i wanna do sumthing crazy like led strips.
Are the pictures this size ok?
I just noticed that I can about double them here. I have them set for another site that has a 50kb max.
My camera is set to 2Mb, so I have lots of room to play with.
Well, it is sort of working, I have "Brows" instead of "Browse", but there is enough to click on. :-)
The last picture shows where I cut part of the support. OOPS. Oh, well, that is what angle and a welder are for. :-)
Well, this isn't finished, but it gives a good idea of what it will look like. Of course I got some areas cut too much, and others not quite enough, but not bad for eyeballing it.
I won't worry about getting it exactly into position until I am ready to do the real installation. Not sure yet about using the chrome trim that goes with these, if I do it would be more cutting most likely.
I forgot to take pictures of the inside of the trunk showing what all I cut out.
I am also going to have to trim the plastic housing that goes behind the lens, but no biggie. Or just make some rectangular boxes for the light bulbs. I will try trimming the II parts first. I think that will work fine.
Just realised I will have to come up with some sort of gasket between the lens and the body. Silicone might be the answer.
Shoot, I  can't attach any pictures right now. for some reason the page is missing the right hand part that has the "browse" button for attaching. ???
