Date: 07/17/2018 09:49 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
72 pinto
Date: 06/23/2016 12:40 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 03/18/2020 01:30 am
Date: 12/31/2017 09:03 pm
SVO SWAP
Date: 03/15/2018 03:12 am
Date: 04/14/2023 06:15 am
Date: 01/28/2017 12:30 pm
  • Online today: 548
  • Guests: 326
  • Total: 326
Well, just about to get started on my 79 hatchback-long
Started by russosborne, June 23, 2010, 04:44:42 PM
Quote from: russosborne on July 25, 2010, 11:17:46 PM
Well, you never know. In a few years these could be the new Mustangs as far as collectors go.
Or not. :-)
And the less you ask those types the better, in my opinion. Why give them reasons to look closer.
On another note, I got the engine and trans out of the Blazer tonight. What a pain. ended up having to have my wife drive the Blazer forward while I held on to the hoist. Didn't break anything, but came real close. I didn't have the engine hoist chain on the right places, and when it was free of the Blazer the engine rotated and almost hit the driveway on the top. But finally got it back right side up and in the garage and safely on the ground.
Boy is this thing huge! This is going to be interesting.
Sounds like you have your work cut out for you! :surprised:
Or not. :-)
I agree with Dwayne. Your car isn't a Ford Mustang that was junked, & you are just making sure the VIN stays with the car. If you are in doubt you may want to check with your local BMV or police dept. They might be able to give you some info as to what to do..
Just a though.
Nothing you've described doing should be considered VIN tampering.  What you are doing is making sure the right VIN stays with the right car.  Shouldn't be an issue.
Something else dash related, I need to figure out how to include the vin from the Pinto dash into the new setup. I was thinking about cutting off the part of the dash that goes along the windshield, and using the Pinto piece there. Another minor detail. I really don't want to be arrested for vin tampering. :-)
Which reminds me, I need to keep the upper part of the fender aprons that have the vin stamped. What I am thinking about doing is cutting the aprons out from the frame rail up to about 3 inches from the top. I have some either 1.5 or 2 inch angle steel that I would run underneath the top for reinforcement, and I was thinking about folding the extra apron that is left around the bottom of it, making it smooth from inside the engine compartment.
Not the best way to go, would rather do something like a 12 point roll cage, but that ain't happening, plus you lose the vin's that way. I seriously doubt if I would ever sell this car, but you never know for sure what the future may bring. Plus, this is affordable and different.
I have to keep coming up with things I can do for free, like playing with installing the tank. I really would rather work on the engine install, but just the front sump oil pan is several hundred dollars. So that won't be happening any time soon.
Fitting the dash is something else that should be essentially free. I can buy bolts and nuts type stuff, just not expensive things.
Once I get the dash to fit (if I can do that) then I can start working on the wiring, which is fun for me. having the complete Mustang wiring harness, as well as the Pinto and the Mustang II harness will give me lots of ways to do things.
Quote from: russosborne on July 25, 2010, 12:54:55 AM
It is all from a 1996 Mustang GT convertible. Not that the convertible part matters as far as I know. :-)
That dash weighs a ton! I could barely get it out of the back seat of the Taurus by myself. It looks like it is several inches deeper than the stock dash, which may make this really difficult. I will have to get it somehow mocked up in the car and try sitting and getting in and out to see if there is enough room. And the console has the emergency brake hand lever on the passenger side, instead of in the middle. And that is one thing I didn't get, the Mustang ebrake stuff. But moving the Pinto one shouldn't be that hard, if that is how I go.
It would definitely be unique, if nothing else. But I am going for more than just that. If if looks cobbled together I won't do it. Hoping that I can make it look like something that Ford could have done.
Who knows? I will be doing good if I can get this car back together again in any configuration.
And how is this for an idea? The Mustang gas tank has a largish bump on the top on one side. I was thinking about cutting the spare tire well out and flipping it over and re-installing it, so the gas tank bump would just fit inside that. If I went with a fuel cell, I would have to do some modifying anyway, and I kind of prefer using the factory tank. There are tons of stuff available from new tanks, senders, to even covers (the factory one has a cover even) for them. Shoot, another thing I didn't get was the tank straps. But those are available cheap as well.
A friend of mine has a '96 Mustang Cobra SVT convertible.  That dash in your Pinto will be awesome!  I hope it works!
I'm really surprised that the width of the two dashes is so similar.  I hope that swap works... it will be interesting to see a totally unexpected dash layout in a Pinto!  What year Mustang did this stuff come from?  I know you probably said somewhere before, but I don't remember.  I'm anxious to see the end result!!!
and the last for tonight. I am not going back out, too muggy.
first is comparing the Pinto dash to the Mustang dash. I thought that the Mustang one would be way too wide, but they are very close. There is a lot of difference in the depth, though. I am going to have to tear the Mustang dash apart to work with it, it is really heavy all loaded up. Hate to do that, but I can't even begin to try anything with it the way (weigh) it is. :-)
Second one is the gas tank from the Mustang. I got it and all the lines even.
Third one is the steering column and wheel from the Mustang. Both of the airbags were deployed when the car got hit in the front. I wouldn't even try to use them anyway. Not too sure about the column, it is a tilt, which would really be helpful for someone as old and fat as I am. But I really don't like the steering wheel. But it has the cruise control controls in it. Not too sure what to do there. Cruise control would really be good, helps keep me from getting tickets. And I have a steering wheel I REALLY want to use, it is the one I have had on the car since the first couple of days I had it. It was originally meant for my 69 Mustang, but it works well on here. One of the old style 3 chrome spokes with holes in the spokes and a soft foam type black grip. The only wheel I really enjoy. Had one on my high school 69 Mustang even.
Speaking of which, I just found a place that still sells the bare foot gas pedal pedals. :-) Yes, had one of those on my high school car.
He honestly gave me everything he won't be using on his project, to use or sell or give away as I see fit. Going to try to use it all, but some of it just might not be physically possible to use in a Pinto. ABS brakes, for one. Hoping to be able to use the cruise control. Since I am using the engine, trans, and computers from the same car, it should work, if I can figure out how to change the controls around.
And a few more.
First is most of the wiring harness laid out. He gave me the entire harness.
Second is a lot of the stuff I got installed in the Pinto. :-)  I really have run out of room in the garage.
Third is the console from the Mustang.
Fourth is the dash.
Well, I had to go out and get the Taurus cleaned out at least so we can go shopping tomorrow. So here are some pictures of stuff other than the engine and trans that I got.
Top picture is of the Mustang driveshaft. The second one is of the Mustang and Pinto driveshafts together, Mustang on the left.
Third one is of the Mustang carpet, he gave the whole thing to me. Might come in handy, stock Pinto carpet won't work for me except for the area in front of the bucket seats, if that.
Last pic is of the wiring harness still in the Taurus trunk.
I never liked that shift. Mainly cause most places made you come in Sunday night, and I like having Sunday night off. That's my relaxation night.
Plus it was always hard for me to go to bed that late in the day and then get up that evening. Never seemed like I got any real sleep. All in my head, I know.
But at least you understand how things are working "off" shifts. People who only work day shifts usually don't get it.
Quote from: russosborne on July 24, 2010, 09:27:52 PM
My usual response to that is
"I AM positive. I am positive things will get screwed up"
But I am too tired to even make that response right now. I had to get up at 9am. that is more like 2 am to you day shifter types. I don't usually get up until close to 1pm.
thinking about going to bed right now, which is like way early. I don't usually go to bed until 3am or later. It is 10:27 here right now.
I've been called a lot of things, but never a day-shifter.  In fact, I'm the consummate night-shifter!  30 years and counting on the third (graveyard) shift.  I normally go to bed around 9:00 a.m. and get up around 3:00-3:30 p.m..  I work 10 p.m. til 8:00 a.m. during the week and 7:30 p.m. til 8:00 a.m. on weekends (every other weekend).  Probably couldn't function if they put me on any other shift after all this time!   :lol:
Quote from: russosborne on July 24, 2010, 09:03:53 PM
What a long day. But successful. Got the engine/trans and misc. home without any issues. Getting them out of the blazer may be a different story, but not going to try tonight.
No pictures yet, will take some tomorrow. I still have to find a place to put all this stuff.
Russ,
Glad to hear that the Blazer got you there and back safe and sound!  Maybe things are going to go better... starting now!  Think positive!
I don't know whether it will work or not, but if you're making modifications anyway, I think Mustang II tailights would be awesome on a Pinto!
Ok, take two.
Taillight mounting.
I was thinking about mounting either the stock taillights or who knows what ones from the inside. At least on my 79, they look like they were added at the last minute the way they are mounted.
Might mean having to do some cutting on the rear panel, but what is a little more modifying? :-)
Probably going to be adding a higher floor to the back, so there wouldn't be any worry about hitting the lights when doing stuff in the hatch area.
I have actually thought about using the ones I kept from the II. Haven't taken a serious look at if they would be even close, but I do like the 3 section look they have. 69 Mustang taillights are my all time favorite, the way the 3 sections stick out on each side. Maybe I can come up with something similar.
Thoughts?
(let's see if this posts THIS time)
Yeah, mine is/was a glue in. Why did they use a gasked at all? Seems like Ford finds a better way of doing stuff, and then they insist on going back to the old way. My 69 Mustang windshield was a glue in. It also had a removable cowl panel, which was a change from the earlier Mustangs, and then on the II's and Pinto's Ford went back to the welded in place ones that make cowl rust repair extremely painful.
may or june of 78 they stopped using the gaskets and switched to glue in. So if you have a later production 78 model it's a glue in. The glue in glass is also larger than the gasket glass. Gasket glass is the same for 71-mid 78, after that you have bigger glass. Glue in type windshields cannot be used with a gasket, they are far to large. You CAN glue in a late model windshield into an earlier model, but you will need the outside AND inside trim for the late model. The inside trim from a late model fills in where the gasket on an early model would normally be. I've done a lot of research on the two if you can't tell....;) :P
Quote from: russosborne on July 23, 2010, 01:48:25 PM
Chris, I hope you don't look like me. That would be awful for you.
It did take 2 years before I took it apart.
Definitely going to Dayton tomorrow. I really am worried about my Blazer making it both ways without any problems, but how do you turn down a free deal like this? Looked into renting something, but we just can't afford it. If you are in Ohio and between Akron and Dayton tomorrow and see a metallic dark red Blazer 4 door and a white Ford Taurus alongside the road, that will be me and my wife.
Russ:
  Fraternal twin then, perhaps. Besides, I ain't no prize anyways, so no biggie. I just like the parallels between these projects.
  Now, first, if I saw you on the side of the road I'd stop to help. And second, the wife is from Toledo, so the next time we visit the area (next year probably), I expect an invite - er..., would appreciate visiting with you!
Quote from: dave1987 on July 23, 2010, 01:01:38 AM
Hey russ! I removed my windshield this spring and cut the gasket away from the windshield, then pulled the separated the cut section away from the windshield. I cut down into the gasket around the edge of the windshield and just pulled up the gasket that was on top of the windshield, was pretty easy. A sharp razor is the key here!
This link takes you to the post in my project log that has pictures of the glass still on the car after cutting away the top of the gasket that holds the windshield down and in from the outside.
http://www.fordpinto.com/index.php/topic,7356.msg94946.html#msg94946
That will work on 78 and down car im pretty sure in 79 they started glueing the windsheilds in.
If i lived anywhere close to ya id just go pick that motor up for ya in my dually so you wouldnt have to worry about not making it.Hope the trip goes welll with no prblems though.
Quote from: popbumper on July 22, 2010, 05:25:34 PM
Russ:
  Just STOP it. Now I know you ARE my long lost twin - you were looking for cheap transportation.....next thing you know the car is coming COMPLETELY apart.
Oh my. This is like looking in a mirror in so many ways. It's somewhat painful.... :P
Russ:
I guess I just got lucky. I wasn't even looking for a Pinto when I bought this, I was just looking for cheap transportation that I could work on myself if it broke. Found a whole lot of early 90's stuff that you couldn't see the engine with all the stuff in the way and most wouldn't pass emissions(which we have in Akron). Then I found this on Craig's list over near Findlay. I didn't even look underneath it, was too scared too.
The seller had it on here for sale, but I didn't even know this site existed then. He is the one that told me about here.
There is lots of rust on the outer body though. Hood and doors are shot, and quarter panels need replaced as well. But yeah, it is pretty solid for a midwest car. Think the seller told me he got this one either in Indiana or right on the border.
Russ I just have one question.... How did you find a Pinto in Ohio that didn't have much rust underneath?? Mine is a rust bucket & so was the one I got in Alliance lol. I saw the pics on car domain & it looks like you got a good base to start out with. I am jeaulous! Can't wait to see the finished product.
Quote from: russosborne on July 22, 2010, 02:38:30 AM
Well, might be road tripping to Dayton this Saturday after all. The guy giving me the engine and stuff says he will have it all out of the donor car by tomorrow. Waiting to here back from him.
Hope my Blazer can survive the trip. Can't afford to rent anything.
Yes, I can find something to stress about in any situation. :-)
Have done nothing to the Pinto. Been stressed at work, so much so that if something went wrong I might revert back to my old ways of throwing stuff and beating on stuff. So I am avoiding the Pinto for now.
Avoiding the Pinto is probably a wise decision.  Hope things become a bit less stressful for you soon!
