Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 06/22/2017 07:19 am
Date: 09/09/2018 03:22 pm
Date: 10/10/2019 10:02 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
1971 Pinto
Date: 03/04/2017 11:28 pm
  • Online today: 529
  • Guests: 311
  • Total: 311
Well, just about to get started on my 79 hatchback-long
Started by russosborne, June 23, 2010, 04:44:42 PM
When i bought my engine hoist it didnt come with a leveler either so i bought one from harbor freight and used it only one time LOL guess i just like doing stuff the hard way.
Forgot. A guy at work is supposed to give me a piece of chain for my engine hoist tomorrow night so I can pull the engine and trans out this weekend. I bought the hoist used(barely) and it didn't come with any chain or leveler. Just the short section of chain that the other chain attaches to. Would prefer a leveler since I am doing this alone, but I am used to dealing with that sort of stuff. Just takes longer. I will get a leveler when I am ready to reinstall whatever engine is going back in.
Thanks. I ended up using some gas and it worked pretty good. Still need to get some rags. I used a couple of older t-shirts that I haven't worn in a year or more. Wife didn't like the color of one of them anyway. :-)
Did I mention I have no patience? I moved the Pinto into the garage after cleaning the floor, and took the hood off and the battery out. No pictures yet, but I did get my camera and got it charged overnight. I wanted to do more to the car, but decided I really needed to take pictures, so I know where everything goes in a year or so. :-)
Glad to hear you got the pumpkin separated! When I finally get an 8" to do a 289 upgrade in the 78, I'll keep this all in mind.
Honestly.....My dad and me use a great "solvent" to clean up oil messes from our car projects on the garage floor...
Gasoline!
I know it's not supposed to be used as a solvent, but it does a great job with removing any residue and if you get to the spill/drip quickly it doesn't get the chance to soak into the concrete. Giant metal drip pans have come in handy through out the years, we have three of them.
Just be sure to crack the garage door so you don't fumigate the garage. If you have your furnace in the garage like my parent's house does, it's even more important to do so to ensure the fumes don't ignite when the furnace kicks on!
Well, there are zoning laws, but I meant that I get to the point where I either lose interest or don't have the money to finish, or like the II I just had scrapped I find that it just is too much for me to do. In other words, I screwed up.
Although since we just rent here, I need to keep everything like this in the garage away from the landlord's eyes.
I did manage to get the pumpkin off tonight just now. Got home and found that there were those copper washers on the studs. Other than one they were pretty easy, bent them up and used tin snips. The one came off, then I realized that there was still just a bit of a ring left, just enough to hold the pumpkin on. but with a pry bar that problem soon disappeared. :-)
Of course there was still some gear oil in it, so I made another mess just after I had cleaned up most of the first one. sigh.
At least now I can plan on getting the Pinto into the garage tomorrow night. If I can find enough rags of some sort to clean up the newest environmental disaster on the garage floor.
Oh boy, do you live in one of those states where you can get your project car towed due to it being considered and "eye-sore"? ::) ::)
Dave, that sounds like a good plan. I have an engine hoist, so pulling the engine/trans won't cost anything. Well, I do need a chain or leveler(preferred) for the hoist, didn't come with one.
I am hoping to be able to upgrade to a later 2.4 with efi, and maybe a 5 speed trans. I really want the efi, at least. I am hoping to be able to find a rusted out Ranger cheap. Seen quite a few, but you always see the stuff when you don't have the cash. Otherwise I will go through the original engine. The auto trans needs some work, it is slipping a bit. I either want to go to a 5 speed or at least an A4ld or something with overdrive. I drive a lot on the freeway.
No matter what, I just want to make sure that this car doesn't end up getting towed away because I can't finish it. Had that happen too many times, sometimes my fault, sometimes not.
Thanks,
Here's what I would do russ...
Pull the motor, get the car on stands and pull the tank, lines, axle and everything you can. Get underneath the car done and then go to the engine compartment to get that done. That way the undercarriage and the engine compartment blend well. Then you can put the tank and lines back in, install the new axle, and drop the car to the ground again.
Since the car will be on the ground, it will then be easier to install the MII dash since you won't have to CLIMB into the car to get to the tough spots under the dash. Believe me, having the car on the ground for dash work is SO much easier than having it on stands! I've done that before, it's not fun!
Once you get the dash in, put your new steering column in, this will be easier with the engine removed, giving you more room to work with when lining everything up and connecting the steering rack again, you can even SIT in the engine compartment! :D
Once you have all that done, the BIG stuff is out of the way and you con concentrate on doing the motor RIGHT! If it were me, I would strip the block, take it to a shop and have it boiled out, have then shave the top, same thing with the head, then paint it. Once that's done build it all back up to how you want it, again this will be easier to do now since you have all of the CAR done and you can concentrate.
When finished, drop the motor and transmission back in, connecting the drive line, wiring, fuel lines, gauges, etc. and start her up! :D
That's what I plan to do with my 78 when the motor dies again.
Well, garage is clean. Except for the work bench. haven't gotten my tools organized yet.
Started tearing down the 8 inch rear from the departed II. Should have gotten my tools done first, but patience has never been a virtue of mine. As soon as I get it fully apart, the Pinto can move in. Of course there is a problem, I posted about it in the General Help section.
And no, I didn't take any before or during pictures of the rear. See above about patience. I need to get my camera charged up. I promise I will take pictures of the car as I go along.
Can't decide what to do first. Part of me wants to pull the engine/trans and start cleaning up the engine compartment. Part of me wants to start working on swapping the II dash and steering column in. Another part wants to put the car on jack stands, pull the tires, gas tank and lines, and rear end off and start working on the bottom of the car. Still not having taken a real good look at the bottom, not sure that I will be doing that first. The last part of me wants to do all of the above all at once. I kind of want to keep the car within say a week of being at least rollable/steerable in case something comes up, but I don't know what could come up. Dropped the insurance on it and won't be renewing the registration, so no real point in keeping it driveable. But I also don't want to get it so far apart that I feel overwhelmed.
I have a slight tendency towards ADD, so concentrating on just one thing for very long is somewhat difficult. Plus, taking things apart tends to be the most fun part to me. So who knows right now.
YAY! Mustang is gone and I sold the tires.
So now I need to clean the garage and get my stuff organised so I can start on the Pinto.
you wouldn't want this one. it is rusted so bad that the driver's side upper control arm came off the crossmember, with part of the crossmember still attached.
Would be a good candidate for putting on a 4X4 frame or something. :-)
OK is someone removing my posts?!  I put in a reply yesterday afternoon and now it's missing. >:(
Russ, if I was nearby I would adopt your MII. They are getting pretty rare and I've always wanted one. ;D
Quote from: russosborne on June 23, 2010, 07:19:46 PM
Well, so far my personal black cloud is still right above me.
The guy didn't make it today to get the II out of the garage. sigh.
Maybe tomorrow.
And the guy buying some rims/tires from me didn't show either.
double sigh.
Your luck sounds like mine :rolleye:
Maybe tomorrow.
double sigh.
Supposedly somone is coming to tow away the II in my garage, so once that is gone and I can clean up from the mess it made I can pull the Pinto into the garage and get going on it.
Not going to be a quick job though. No real money to spend at this point.
Plan is to tear it down(free), look for and remove rust(free, unless I have to replace stuff), put the 8inch rear from the II on the Pinto(free, if you don't count what the II cost me originally), see if the II dash I took from the II will fit (with or without mods)(again free), if the II dash fits see if I can use the II steering column(free, and it can be converted to a tilt fairly easily using a granada tilt column),
make subframe connectors(not free, but hoping that I can use a piece of rectangular tubing I bought years ago for one side at least), clean and redo engine compartment(free, couple of cans of paint maybe, unless I go the por-15 type of stuff).
Things that will cost money are: brakes and suspension. Took off the front tires yesterday to put some others on(selling the set of 4 that was on it when I bought it) and saw some scary stuff. Rotors totally shot, most rubber stuff looked shot. Was going to redo the stuff anyway, but didn't realise it was this bad. Some rust(not anywhere near as much as on the II) in the front area. Bottom of battery tray gone. Looks fine from under the hood. I would really like to move the battery to the back, but am leary since this is a hatchback. Going to see if I can come up with a box that vents out the bottom, or similar.
Gas lines need redone. Need to buy tools for that. Having summit racing 10 minutes away is nice. :-). Would like the really nice Eastwood set, but don't have a couple of hundred dollars to spend. Got to pull tank and see what shape it is in. I don't think it has any leaks.
Needs lots of body repair. I hadn't realised until yesterday just how bad the quarters had gotten. the rear corners of the wheel well openings are totally gone. The rest of the openings are pretty rusty as well. Both doors are very rusted. So is the hood. One fender is still bent from the deer last year. Not real sure how good the other one is. I am really interested in using the bumper cover/spoiler thing that Map351 is making. Otherwise will look into shortening the bumper shocks at least.
Hoping to find a 2.3 with efi cheap. Would like to get the 5speed manual trans also. But that is a not free or cheap thing, so it is way at the bottom of the list.
Think that is if for major stuff. Should keep me busy for a couple of years.
I'll get some pictures and update this as things get moving.
