Custom Pinto Project
Date: 06/12/2016 07:37 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 08/01/2023 06:53 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 07/21/2017 11:49 am
Brake rotors
Date: 03/24/2017 09:02 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
free transmissions
Date: 11/28/2019 10:21 am
  • Online today: 535
  • Guests: 388
  • Total: 388
Well, just about to get started on my 79 hatchback-long
Started by russosborne, June 23, 2010, 04:44:42 PM
Quote from: russosborne on August 07, 2010, 10:23:45 PM
I think by mounting them from the inside, they will work. If I mounted them the way the Pinto ones are, they would look too huge.
BTW, no boom from the welder. No nothing. Probably a good thing, since there is no muffler on it.
Either the battery is dead, the cables on the welder are bad, or there is a real problem. The cables do look pretty bad, and I couldn't find my old battery terminal cleaner. I didn't check the battery itself, I need to just put it on the charger and see what it says. Hopefully between those two it will at least crank. It does crank by hand, so it isn't locked up. Just like on a car, get it to crank, then check for spark, then check for gas.
Or I could go and read the manual for it, and make sure I didn't have something off that was supposed to be on. :-)
Oh, for Heaven's sake, Russ... don't read the manual!  Don't you know?  Real men NEVER read the manual until they have  exhausted every other possibilty!   :lol:
One thing I forgot about the tail lights. I am going to have to remove a lot of the support bracing behind the panel. I will redo it after I get the tail lights mounted, but it will be with either angle or tubing. The back side of these tail lights are huge (compared to the Pinto ones) probably at least 4 inches in depth.
I will be leaving the center area, where the hatch latch is, and out as far as I can.
Call me crazy, but I kind of like the tailights.  I'll be anxious to see those completed!
forgot about pictures of the new welder. not that it looks like one at the moment.
I am actaully thinking about going out and throwing some gas in it's tank and hooking up the battery from the Pinto and seeing if it will start.
What's the worst that can happen? hahahahahahahahahahahaha
Well, today was interesting. I went to the all mustang show at Summit Racing in Tallmadge this afternoon. Met a few people from the mustang forum I still hang out on.
Got to feeling bad seeing the 69 Mustangs there.
So once I finally got home I felt like being destructive.
So I got the grinder out and finally cut the straps on the gas tank, and got it off the car.
Still feeling destructive, I took the grinder to the screws holding the trim on the quarter windows, and finally after much cussing got them out. Damaged the stainless, but at that point I didn't care. At least I didn't cut the gaskets or break the windows.
Still not done being destructive, so I was going to cut out the spare tire well. Couldn't find the corded jigsaw, and the cordless needed charged. so I took a break.
Went back out, and decided to work on the tail lights instead. Did some preliminary cutting on the tail panel on the passenger side. need to cut more, but got too late to make that much noise. Plus the cordless needed charged again(I hadn't fully charged it before).
Pictures below. The one of the tail light clamped on is just to give an idea of how it will look. the plan is to install them from the inside. Oh, and they will be changed to all red lenses. One of the tricks I learned from the II sites. :-)
So I got to be destructive yet constructive and the same time.
Dwayne, already told her, pretty much had to. She does the bills, and keeps track of the bank account.
She is ok with it, just can't spend anymore for awhile. That was my birthday money from my parents, plus a little.
Quote from: russosborne on August 06, 2010, 03:40:38 PM
Well, things might get slowed down a bit or ten.
I just got home from buying a welder. Or at least it will weld once again once I get it working.
Bought a Lincoln WeldanPower(spelling?) gas powered ac/dc arc welder. Has a 16 HP engine. needs a bit of work. The head gasket might be bad, not sure. There is a broken wire going to a bank of capacitors, which the seller thinks is why you can't get it to start an arc. I don't have a clue at the moment, if that is all that is keeping it from welding great. I don't expect it to be that easy. It didn't come with cables, but I can get cheap ones for now, once I get the engine running.
I am on a welding site, www.weldingweb.com, and have read some interesting things there in the past about these welders, which is why I bought this one. It would be the answer to my dreams (welding dreams) if I can get it to work. No worrying about if I have 110 or 220 or neither around. :-)
While it may be a bit much for sheet metal, I was looking into the Eastwood stuff, they have a stitch welder and a spot welder that attaches to an arc welder, so that will work.
I am not going to have 2 cents to spend on either of these for awhile. I will still be working on the Pinto, trying to fit the 96 dash in to it, etc, but if anything costs money it will have to wait.
My wife is going to kill me. I had started out telling her I was going to spend $55 on a used 110V 70A arc welder, and this is over budget. But if I can get it to work it will be worth far more than the cost I paid, and far more versatile than that $55 one.
It is still in the back of the Blazer, I need to go out and take pictures. I don't have a clue where I am going to put it, the garage is still full.
This might be a time for some quiet discretion.  If she hasn't already found out differently, I'd be tempted to let her go on believing it IS the $55 welder!  What she doesn't know probably won't hurt either of you!
Hmmm, maybe my computer at home is different then this one. I could have sworn there were 6 pages already.
Oh well.
Thinking about going wild this weekend. My wife is going to be in Myrtle Beach SC for her son's wedding. Her mom paid for her trip, we couldn't do it. I am glad she is getting to go.
Anyway, been looking on Craig's List. Found a small and affordable (for me) arc welder that I am going to go look at Saturday morning. It is a Campbell Housfield(spelling?), one that WalMart used to sell. It is just a 115V unit, welds up to 70amps. Which is about all my house electrical can handle. :-(
thinking it might be easier to use than my mig that doesn't have gas. Plus Eastwood has some neat things for arc welders, a spot welder attachment and a stitch welder attachment, both of which will work with this arc welder. This way I can actually get some work started on the welding stuff I need to do.
Really wish I could get a used Lincoln tombstone, but they run on 220V, and the cheap ones on Craig's list are all about 150-200 miles from me. Plus they are still about double what this one will cost. $55, figure I can afford that. Already have gloves and a couple of helmets, need to get some welding blankets. Need to get the gas tank off the Piinto FIRST!!!! :-)
Going to WalMart tonight, wife needs a few things for her trip, and I am going to see if they still sell the ford stereo removal tool. Funny, this 96 has the stock radio and cd player, and it has Ford's theft deterrent mounting(the holes you have to put the tool in) yet you can buy those tools all over, or even use a bent coat hanger. Some deterrent. Mainly deters the owners from changing the stereo I think.
Another sign of my stupidity, I am working on taking the 96 dash apart while it is in the Pinto, instead of cleaning off the work bench.
hmm, apparently you can't preview any pictures you add, and then once you post, you can't remove them if you made a mistake. So here is take two.
got a question.
On my car there is what sort of looks like something supposed to be a cross member on the inside of the car, behind the front seats, where the bottom of the rear seat bottom sections bolt on to. These are not quite touching the transmission/driveshaft tunnel, but do go out to the inner body panel. They are spot welded. See picture.
I am thinking about doing two things with these, and don't know if it is a good idea. Well, one idea is questionable.
One is I am going to use these as the mounting points for the front part of the box I am going to build. Inside this box will be the battery on the passenger side, and the fuse box and assorted electrical stuff. If you cant picture this, the battery will be in one seat well, the other stuff in the other one. This will be my electrical room.  :lol:
This I have no questions about. Pretty straight forward.
Now, for the real question. I am thinking about adding some metal and welding these to the tunnel. It is only about a quarter of an inch, maybe a half. Also will seam weld them. Ok, that I am doing regardless. Sorry, brain dead right now and getting cramps from typing.
The question is I am thinking about using these as the rear connecting points for my home made subframe connectors. If I decide to do this, one thing I will be doing is to use a fairly thick piece of metal as the front of the box for the electrical, like 1/8th inch since that is the max my welder can handle. This would be one piece going along the floor from inner panel to inner panel. And there will be some added bracing at the top at least for the top of the box to rest on. probably like 1.5X1.5 angle, since I have lots of that. The height will be however high I need to clear the battery and stuff. Not going to be very high, hoping about level with the hatchback floor area.
Thoughts? I want more than just a small area for the rear to weld onto, which is what the leaf spring bracket seems to be to me. And this should be pretty close to that same area. I might go ahead and make a small piece to go from there to where I would have the main subframes at just to add some strength. Hell, I would like to frame the rear of the car at least, but that isn't happening.
Oh, the battery will be in a sealed box that is vented outside the car, probably using one of the rear seat belt bolt holes.
well,take 2.
Where'd my post go? My fat fingers strike again.
The best thing about the vin this way I can go back and weld and grind the cut piece back on to the dash if needed and no one will be able to tell it was ever cut out.
Becky is a purist, huh? Boy, she isn't going to like me one bit. :-) I was thinking about getting a 79 Ford factory service manual, then thought for what? except for the suspension almost the entire car won't be covered in that manual.
That heart attack you mentioned would belong to Pinto Purist Becky (blupinto), but she'll get over it!  I prefer my cars pretty much stock too, but somehow this idea of yours appeals to me.
P.S. - I think what you're planning to do with the VIN should work just fine.
and what I am thinking of doing with the vin is to cut out the vin on the stock dash, with a large amount of the dash still attached. Then cut a vin sized slot on the driver's side front of the 96 dash and mount the vin from underneath. So if you look through the windshield you could see the vin, it would look like I had just put the 96 pad over the stock dash at that point.
Oh, if you can see the smaller vent on the driver's side top, just near the edge, that is about where I think I will have to cut the dash. Just at the outside edge of the vent, but of course this is just eyeballing it. The passenger side isn't quite as bad, but I think I may need to reposition the dash first, something isn't centered. Either the dash or the Pinto. :-)
yeah, I think so too, although I am sure that somewhere someone is having a heart attack just thinking about this. :-)
At least it seems that Pinto people are more willing to accept things like this than a lot of the vintage Mustang people. Granted there are a lot more of them, so even if percentage wise it is the same, number wise there are more there.
I had a horrible thought today. Transmission. I don't know if the II that had the 4.6 in it had a manual or auto, but looking at the size difference between the 4L70W and the C3 is scary. I am really concerned about that now. I don't mind doing some minor adjusting with a sledge hammer, but if I have to cut and weld, that is another matter.
I sure hope you can make that work!  Somehow or another, that Mustang dash looks right at home in there... and I really didn't much figure it would!  Will be nice to see a Pinto with a more modern dash setup.
a few more pictures.
The guy still hasn't shown up or called or anything.
And the 96 dash IS a bit too wide, but still going to try to make it work. Since I am using the engine and trans from the same car, it would be nice to have the tach and gauges all work. It also seems not quite equal on both sides. Might be the Pinto, but the driver's side of the dash seems wider than the passenger side. At least more is sticking out on the driver's side.
Thanks. Yeah, you have had a lot of what I had a little of.
Well, I can understand the guilt feelings... and they are probably justified to a point, but it's not easy dealing with a special needs person.  I've had about fifty years experience with that.  My sister was born with Spina Bifida when I was three years old.  Her needs are many and varied, and raising her was a family effort.  She turned 50 this June and as she ages, her needs have become even more demanding.  This has proven out to be good training for what was to come later.  Sixteen years into my current marriage, my 46 year old wife suffered a major stroke.  Being in the pons area of her brain, it has affected her vision, memory, balance, and speech.  This was a seemingly healthy, active woman who was a nurse by profession.  She can no longer walk unassisted, obviously can't drive or work, and she needs assistance with pretty much every aspect of day-to-day life.  Even with a lifetime of care-giving experience behind me, it sometimes threatens to overwhelm.  Believe me, I know where you're coming from.  If you could no longer meet Paula's needs, returning her to her parents was probably the kindest thing you could do.
Keep plugging away at that Pinto... I'm still betting you'll have success in the end!
I don't know about the mechanical skills thing. to a point, yeah, but not at the level lots of people here have. Been taking stuff apart and putting back together most of my life, but normally it would be right away, not taking apart and waiting who knows how long. I used to regrease my pedal crank ball bearings about once a week. :-)
I don't have the money to do this "right". Don't have the proper tools, etc. But I am stubborn until something hits me in the face hard enough to make me come to my senses, like what happened to the Mustang II project, I couldn't ignore that the front crossmember was shot after seeing the control arm mounting point had rusted and came apart. Even then, if I had a real welder and could use it, I would have kept going.
The guy who gave me all this Mustang stuff is putting a 66 Mustang body on the 96 GT frame(ok, floor). Now he has energy. :-)
Here's a link to the mustang site where he is posting his progress, if anyone is interested.
http://forums.vintage-mustang.com/great-lakes-vmfers/602812-latamud-ii.html
I am just trying to keep going with this, between boughts of depression and pain. Have a bad back, among other things. It always hurts, sometimes just a little, and sometimes more.
The thing with my ex wife is that I divorced her still loving her, and her me. She was born with some brain damage, and it took me quite a while to realise that I couldn't deal with it the way I should. so I dumped her back on her parents and feel like sh#t for doing that. I still sometimes see something and think " I bet Paula would like to go there", Paula being my ex's name. We were married almost 14 years, kind of hard to just let that go. At least for me. I have always tended to live half in the past.
Oh, well, enough of my problems, pretty sure I have bored you guys to sleep. Or else made you want to avoid me like the plague.
Sitting here waiting for the guy to come get the Pinto engine and stuff. he is already over an hour late, no word if he is even coming.
And the update must have caught me. Can't post this, so I copied and put it in word to post later.
Russ,
I think it may be fear of that "holy S#$% moment" that prevents me from starting on my Pinto.  I know deep down inside that if I EVER disassembled it to the point you have, it would never be put back together again!  But... that's me.  We're talking about you.  You obviously have more mechanical skills than I do and either more time and/or energy than I do, so I'm betting you'll get it back together this time!
As for the wife thing, I know how you feel.  My first wife and I would have been married 28 years now.  Y'know what?  I don't care.  I'm far happier with my second wife, and from what I can tell she's happier with her latest husband (#3) too.  Concentrate on your relationship with your current wife and put the past behind you.  You recently celebrated five years and that's an accomplishment!
Have a great weekend!
Been there, done that Russ! (the holy S#$% moment) and yea, it's damn scary! :hypno:
All you can do now is press forward, I have been reading this thread with much intrest and from what I have seen so far you have strong mechanical skills and are doing a fine job!!
Oh, and BTW,  :happy_bday:
well, went out to gather all the stuff for tomorrow. decided to do a little bit more. took the passenger side seat out. cleaned up the garage some, got almost everything that was on the roof of the Pinto off.
took off the steering/brake support bracket. got the gas pedal off. only thing really left in the interior is the ebrake handle and the brake pedal and it's main support.
Then I took a good look and had an "Holy S#$% what have I done" moment. One of those where my overall lack of success in the past rises up and stares me in the face. Will this car ever run again? Am I over my head?(probably) etc.
Been kind of a lousy week. Wednesday would have been my 20th anniversary if I had stayed with my first wife. That still haunts me badly.
That added onto my already depressed state about my job and finances is almost enough.
If you have to ask almost enough what I won't tell you.
oh well. oh, my 51st birthday is this coming week. At least I am well over half through with life.
Not much done today. Got the back bumper off, finished getting the wire harness off, had to take the driver's seat off to do that.
Wanted to take the gas tank off, but the strap nuts didn't want to cooperate. think I am going to have to cut them, but the tank has gas in it still, and once I jacked the car up it started leaking. So no cutting for a while.
Last picture is of the stock engine getting ready to go bye. Hope I am doing the right thing.
Yep! It looks like there done be a 4.6 engine down there, underneath all them there hoses!  ::)
Side note-can we edit images once we post?
Let's try this one again.
Well, I need to remember just who is doing this. Me. I need to expect problems.
Was out getting some stuff together for the guy coming to get the engine and trans, if he wants this stuff as well.
Took a good look at the 96 dash. Kept thinking it just looks bigger than the Pinto. I put the two together again, and while the top along the windshield is just about perfect, the 96 has about 2 inches extra width on each side. I don't think this will be a show stopper. Then again I always screw up when I think. I may have to cut off the ends. I need to get the dash stripped so I can put it in the car and see just what I need to do.
here's a couple of 4.6L engine pictures.
Well, nothing new to report. I have been so tired lately I am not getting anything done when I get home. Think this past weekend was a bit much for me. Getting old sucks.
I need to get out in the garage and get my work bench cleaned off, so I can start taking apart the 96 Mustang dash. I am anxious to see if it will fit in the car. 20 years or so ago I wouldn't have to take it apart to find this out, but now I can barely move it by myself.
Was looking at the engine while it was on the hoist. I think that at least for installation purposes I can just flip the oil pan around and make it a front sump. Doubt it will work for real, but at least that will let me start test fitting the engine. I can't afford several hundred dollars for the Canton Racing front sump pan.
