74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 02/08/2018 02:26 pm
Date: 01/19/2021 03:56 pm
Date: 02/27/2017 10:10 pm
78 hatchback
Date: 03/12/2023 06:50 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 08/13/2021 10:39 am
Sunroof shade
Date: 06/19/2019 01:33 pm
Date: 08/09/2018 11:09 am
  • Online today: 529
  • Guests: 448
  • Total: 448
i just have to get the front and fred say he can deliver
Thanks Phil.  As i said befoe Fred was already planing on stopping here as he has some hood bumpers for me.  Maybe it will work out, thanks for the effort.
sent fred a pm  we will see what happens
Actually I have my eye on a 77 Rallye Pinto that does indeed have the aluminum  bumpers.  I plan to make new bumper brackets and do what you did by tucking them up close.  I am also toying with the idea of have the bumpers look like brushed aluminum.  I too like the idea of losing 100lbs.
At this point I have to give credit to my friend Glen up the street who has a repair shop/used car lot.  Typical little town deal.  Without his help I could have never gotten this far as there are somethings i just can't do any more.
It appears that my dash piece for the speedo and gauges is broken as it just rattles around in there.  I am going to leave itfor now and just make sure the tank is full.  I need this running because i need to get to joliet/RT66 July for the meet to see all the other Pinto owners.
have you given any thought to looking for the 77 aluminum bumpers for it? i got a set for mine and then tucked them up close like the early small bumper pintos and it looks great and dropped a good 100 lbs off the car. nice progress by the way.
This is about replacing the front springs.  The car originally had A/C and all of that is gone but still had the extra strong springs which jacked the front end up almost solid.  We put in new [to me] front springs along with a ball joint and shocks and now it is lowered just a bit and rides really well.
Here it is before.....
and here it is after.  Not too much different but later plans are to rememdy that.  it rides really well and i just need the front end aligned.  the Camber is off.
here is the link to the whole set...
http://s93.photobucket.com/albums/l66/hellfirejim/coil%20springs/
next... On to the gas gauge.
As promised here is the last picture after the paint.  Not the best but way better than black.  also this is just temporary [can you say that knowing full well it might be another year or two?]
anyway here is the picture.
I also painted the back inside body work black.
here is the link to the rest of the pictures.
http://s93.photobucket.com/albums/l66/hellfirejim/body%20work/
next post the front spring replacement
I was not even going to start body work until the mechanical part of this deal was done.  However the oprtunity to use the shop for three days and the need to remove all the chrome trim studs and mounting wires because of the hazard they would be at the car show.
Here is what the studes look like:
I used a cutting wheel to grind them all down and remove all the clips.  Here is a shot of the paint prep.
I just could have primered every spot but I thought that would look stupid and pokadot so I figured I might as well have some fun so i made the stripe.  The black is the primer.  I also primered around the windows.
When i pulled the tape off i realized just what an impact that stripe had on the car.  Since I don't need the attention I thought I would go get some matching yellow paint and just paint over.  naturally nobody had anything close so i just got some yellow as that would be a lot better than the black.  Here is a shot of it while still taped.
By the way I am really starting to like the darkern window frame at the bottom and considering blacking out the door frame.  might just try it while everything doesn't count.....
More to come tomorrow and a lkink to all the pictures.  Yes it has been fun and great.  Damn i wish i had a garage as it sure would have been a lot easier..  Oh well such is life........
later
Since we are waiting on parts {sound familar?} and my buddy who owns the shop up the street is goen for all three days AND I have the key to the shop I am going to do some body work.  i am taking off those clips and springs for the trim.  They are all have rivets so I am going to grind the heads off the rviets to pull off the cips.  they are really ugly and dangerous.  Since i am entering my first car show on the 26th I need to get this done.
I am going to be so spoiled, 3 days in a SHOP.  that's right inside!!!!
heading out
Well not much of anything goes smooth.  When they started to tear into the front end they found a bad ball joint but also the shocks were frozen inro place.  I had to pick the shocks i wanted so the old one are gettuing cut out.
BTW: I have 98 ranger 3.0 that just turned 250,000 miles today.  Runs just as good today as it did 11 years ago.
Sounds like a blast! Either way you will pobably get quite a few looks since there might not be another Pinto there. Have fun & good luck on the repairs
Just a note to bring you up todate.  The car will go in the shop today or tomorrow for the front spring swap and check out of the front suspension.  Fix the gas gauge [I hope} and service the rear end.
This holiday weekend will be spent driving and working on the body.....
I got up the nerve to send in my registration to the local car show  for july 26th.  I hope they have an under construction class. :lol:  They have between 800 - 1000 cars every year.
Well the sensor in it's current location doesn't work.  I am betting it is a location problem and not getting a reading or flow to trigger the fan.  Luckely I retained the manual switch setup.  I re-wired the fan to manual and when i tested it last night it was 90degrees and high humidity and the highest i could get it to was 190 degrees on a manual guage.  So now I am looking for another location for the sensor as i really would like it to be an automatic function.  So if you can come with a suggestion?????????
Next step is the front end and new [to me] front springs.
That is a good point but I have done that by manually grounding the the ground wire at the end of the sensor and the system works perfectly.
I reassembled everything last night so i will take it out for a test drive tonight to see if it works.  I am beginning to believe it is a flow problem or having the sensor in the right place.  If it gets warm and the fan does not come on, I will turn on the heater to get the water flowing through the area and if the fan kicks on then I will know it is a flow problem.  Since the car has a 85 t-bird turbo motor in it i will get another thermostate housing and set it up of the sensor and just be done with it.  In the mean time i still have the manual switch and wiring in place so i can bypasss the sensor system and just return it to manual until i get the thermostate housing setup for the sensor.
Does anybody have a thermostate housing for the t-bird?
jim have you checked the relay for the fan? sometimes they can be bad. just a thought.
Thanks for the kind words and............the tattoos. ;D
The only thing I can tell you is what I do.  When I am getting burned out or frustrated or out of money for the next fix, I go find something small to work on and get fixed and then with a sense of accomplishment it keeps me going and of course you the people that read this.  If I can help or inspire just one person to complete their car then this has all been worth it.  Remember I don't refer to this car as "That damn little car" for nothing.... ::)
Right now my major frustration is the temp sensor for the electric radiator fan.  I tested the sensor last night and it works just like it should.  So if I jumper the ground wire off the sensor the electric fan comes on and works great.  It really cools the car down right away.  If the sensor is good and the wiring is good then it has to be in the installation of the sensor which I did not do.  It has an adapter and then the sensor.  I am thinking there is something on the threads.  The plan is since the sensor is already out I will clean it's threads and then pull the adapter out and clean it's threads and the manifold.  I am also going to look at the flow of the water and make sure the sensor placement is in the best place.  Might move it, don't know.
I will post what I found.  Almost forgot.  With my combination I have a holley fuel pump that sounds like I am re-fueling the space shuttle.  While I was out driving I shut off the pump for a second and man did it get real quiet inside. Got to fix that.  My buddy says he has a thick rubber isolator from an a/c unit that just might work.  We will see.
ok enough for now.
Becky's got tatoos? Sweet. You must be the little rebel lmao  :lol:
Matt's probably thinking of my John Lennon tattoos... ::) :P :laugh:
Oops.. I fixed lol. I was thinking Jim but for some reason John came out & I didn't even see it
Jim, it's times like this that I get inspired to work on my car.  I wish there were more stories like this so I could get more motivated to work on my own.
Jim:
  It's great to see such progress. I can understand where you have been, because I am there myself. There are just some days when I want to "throw in the towel", because the effort is so overwhelming. Your effort is inspiring, I am driving towards getting everything done myself, and it's a LONG process. Congrats on your success, I have enjoyed watching this unfold over the last year.
today's work was chasing down electrical gremlins.  I got the front parking lights to work.  In the rear I had to pull the tailight to get to a completly rusted outside bulb holder. Sure would explain why it is so dim.  Anyway went to autozone and got a 2 wire bulb holder and it fit well.  I also added a little sealer around the the holder and the body.  I also used di-eletric rease on the bulbs.
So i got that fixed.  Don't know why only the left front turn signal won't work..Got to work on that too.
The eletric radiator fan is not working properly.  I can jumper it at the sensor and it works fine but for some reason the sensor doesn't work right so I need to get that right.
Also going to install some new [to me] front springs to try and get some front end travel and lower the front 2to3 inches.  I will take the opportunity to look at the front suspension while we are there.
PS: still smiling......... :lol:
Sounds like it's all gonna be nice for ya. Lookin forward to more updates as you go along
To follow up on what I was posting, I went and picked up the Pinto and got a pleasent surprise.  The bill was half of the estimate.  i had to ask and he said that after the front part the rest just sort of fell into place.  I used 2 1/2 inch pipe but not mandral bent so at the tightest it is probably a 2inch which is perfect for my needs.  Maybe one day it will be mandral.
They did a very good job, all nice and tucked up out of sight.  As for the exhaust tone, it is really nice and mellow at cruising speeds but when you step on it, it really starts to bark.  OH Yeah!!!!
After all the work and time on this car [about 9 pages worth] it is finally at a stage where I can drive it anytime I want.   :fastcar:
So was all the time and effort worth it????   After that first drive the answer is a resounding yes.... :drunk:
I also wanted to take a second to thank all of you reading this stuff.  If you look there are over 10,000 views.  There were times that I didn't have the ambition to go out there and work on the car but then I thought about all the people reading this that i didn't want to disappoint.
This is just stage one completed. [almost  :lol:] Next stage is working on all the little stuff to make sure all systens around the car are working right and are dependable.  Next spring will come some more work to make the drivetrain bullet proof and then we work on adding boost.  And did I mention body work and interior work and, and, and......
:rolleye:
So now it is off to start on the little stuff... :read:
Just a note that if all goes well the car goes to get it's exhaust made and installed tonight.  They are going to do it first thing in the morning tomorrow..  yeah I am excited about it as this is the last piece that is keeping me from driving it on a regular basis and without looking over my shoulder. Yes I have other things to do but this is major.   :lol:
