Date: 02/11/2020 12:09 am
Date: 03/17/2019 10:15 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 10/24/2019 01:45 pm
Date: 06/22/2017 07:19 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
74 hood
Date: 07/03/2017 03:46 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
72 pinto
Date: 06/23/2016 12:40 pm
  • Online today: 584
  • Guests: 355
  • Total: 355
2 things.
1, got my dash done and will post some pictures as soon as I have time.
2. heading to springville, Il [about 3 hours] to the RT66 mother load road car show event and plan to meet pinto people and take pictures.  yes of course i will post them.
Taking the ranger as the Pinto is close but not ready yet for that type of drive.
later
Just a quick note, i got my new [to me] instrument cluster in the mail from Bill[thank you sir].  It is a beauty and this weekend it will go in.  I als now have an extra bezel and I plan to make some changes in it to see how it looks..
Quote from: smallfryefarm on September 15, 2009, 03:01:48 PM
i know the trunk model makes a difference but i cut a square hole and made a cage and droped my cell thru 7 inches and left 5 inches sticking up that let me have a 20 gallon tank i used the aluminum tank that has a ball valve and a vent and a heavy duty screw on alum cap. it also has a 90 ohm gm sender in it. i would think it would be safe in a hatch car also. I really like being able to pack on the 20 gallons. just sharing.
Nice install!!!  I would normally have done that but as i said this will eventuaqlly be nm grand daughters car and i wanted to go the extra step for her which means I mount it underneath the car so all gas fumes and such are not in the hatch area.
But that is what makes ford Pinto. COM the special place it is.  The open exhange of ideas and why we did what we di on our cars.  The our cars is the important part of the sentnence because we all build them the way we want to and that is cool with everybody else on the board.
Nothing earth shaking, but a decision to go in a different path in regards to my gas tank.  I would have to drop the stock tank, replace all the gaskets and seals, replace the sending unit and modify the tank for a return line for my conversion to EFI.
Instead I am getting a 12 gallon fuel cell [factory tank is 13 gal]that already has a sender and foam in the cell and all the fuel out and fuel in place.  Once I pull the original gas tank I will cut out the spare tire well and weld in a circular top piece.  Then I will attach the tank under the rear floor boards [hangs down about the same as the stock tank] and cut a square in floor for one of those double seal flap doors so when I fill the tank I open the hatch and open the flap and there it is.  Keeps the gas out of the hatch area.  If it was a sedan car i would have mounted it on the floor in the trunk.
The reasons why i am going this way are fairly simple. All new parts, safer, better match for what I need and for the EFI conversion and eventually my grand daughter will be getting this car and i want it right for her.
Quote from: cossiepinto on September 10, 2009, 09:24:48 PM
I like all the projects going on here.  Sometimes I can't believe the patience some of you have, then I look at my project, started in 1988, put away, restarted, done over, put away, and restarted again.  I even built an extra two-car garage, just to have somewhere to keep this lump out of the weather! (Did I tell you my wife is a saint?)
When I'm finally done with the Cosworth Pinto, I'm going to have a "garage sale".  I have stuff in the attic, waiting to go back on the Pinto, that I've not seen in years.  I have personally dismantled at least five Pintos and a Bobcat, saving what I need and putting much of the rest aside "just in case".
I have an old Craftsman toolbox full of the little nit-noy thingies someone may really need to complete their project/restoration, and I'd be happy to send it on for the cost of freight.
I also have a whole box full of tail light assemblies.  None of them were "good enough" or the right model, so here they sit.  Like I said, there's going to be a garage sale/giveaway someday.
Paul (Cossie Pinto)
I have noticed that I am starting accumulate a lot of parts too.  :look:  I even have enough parts to build another motor that will EFI and turboed [BIG Turbo] but that will go into something else.
i hope everybody remembers to post up the pictures when they are working.  I know it can be a hassel but you learn so much more that way.
Quote from: popbumper on September 10, 2009, 02:39:40 PM
Not to diverge, but that is what I enjoy about the folks here - we're all different in the way we do things, and all appreciate what the other guy is doing.
I am like Jim - I really dig the mods guys do - which is way beyond my capability level. I am also just the opposite of Jim - I can't stand to NOT restore my car, which is why it is taking so long to get done. The hardest part of restoration is the "wait"  :-\ - I can't drive it until I have all of the work done, and I really miss out; it gets depressing sometimes, but I still forge on to the goal.
I have lots of pics to share soon; right now my dash is out, heater box is open, and steering wheel is on the floor (I have another steering shaft I am restoring on the side). I bought a new inner fender, and it will be grafted in by a local HIgh School metal shop this fall (mine is BADLY corroded). Lots and lots of work, but it will be like new when done.  ;D
That is one of the benefits of modifying it.  When I finally got it up and running it made such an improvment in my atitude about working on the car. My wait was close to two years but it has been worth the wait as it is just so much fun to drive and will be even more fun when I get the next set of goodies this spring.
yeah i too have a corroded right inner panel where the battery was.  Actually I have a whole lot of body work to do but that will wait untill 2011 as 2010 will devoted to getting it to be as close to mechanically where I want it.
Like I said before I respect the time and effort it requires to restore one of these little babys but just not my style.
Quote from: smallfryefarm on September 10, 2009, 01:43:49 PM
Jim i am with you on that i like to watch every ones projects see how they are progressing and get new ideas. And i like the 4.6 and really like the independant rear.
I watch them go thru the highs and also the lows which believe me i have experianced full spectrum of very high to snake belly low. But its all fun lots of fun. Dont give up on yours yet still alot of good weather before winter. Theirs always something to tinker with.
Yes there is some time but I have more time than money.  Right now I am redoing my instrument cluster as the white plastic crumbled.  Other than that I got my aluminum bumpers and I am going to try to see if I can get them from chrome to a brushed aluminum look.
Give up???? I doubt it, if she hasn't driven me away by now It just ain't going to happen. I can't wait till my income tax check next february, have I got plans to finish the mechanicals.   :smile:
cossiepinto
Paul (Cossie Pinto)
yeah if you have been following then you know it has not been a trip down the yellow brick road.... :lol:
I enjoy reading about other peoples cars and what they are doing and I especially enjoy the unusual stuff.  Though I have the greatest respect for thoses that restore their cars, it is not for me.  I need to make it mine and the way I want it.  Looking at the 4.6 swap into a Pinto and the Cobra independent rear that grumpy is doing.  Imagine the two of those together in one car:hypno:
cossiepinto
Just want to say I feel your pain.  Twists and turns and changes are all part of the game, when restoring/modifying one of these things.
Thanks for the nice comments/encouragement on my Cosworth Pinto, too!  I've been following your project, as well as popbumper's.
Paul
Well someday i will learn to leave well enough alone. :embarassed:  The actual dash lights were not working so i pulled the instrument cluster and the white part just feel apart.  Yeah i need one, I put in a request in the parts wanted.
As for the other deal it fell through so no matter I just wait till spring and the income tax check.
Not a whole lot to talk about at the moment as today sunday, it is raining but tomorrow i plan to go out and find out why the speedo does not have dash lights and if possible change it to red to match the the other gauges.  i am going to try and get a picture of what they look like.  I also plan to do the tach the same way.  I know it is not much but at least it is something as we get closer to the end of the season and i have to put her up for the winter.
The good news is that i drove her for about an hour Saturday, life is good.  Can't believe the lift it gives you when driving the car and I really needed it.
PS: working on something i can't talk about but if it does work it will mean more new pieces before winter.  I will let you know.
Number of Misc items today.
First is the gas gauge.  It is installed in my three pod and looks good but doesn't work, sorta.  I grounded the gas tank and the needle came off pegged up to empty.  i know that is not right as i filled the tank so obviously the sender is bad and most likely the float is full and on the bottom.  Not going to do anything now, will wait for spring when we pull the tank for all new gaskets, a fuel return line and a new sender.
Next is the front bumper area.  Since the front bumper is off and never to return, the front beam was just sitting out there all rusty and looking like hell.  so i wire brushed it, coated with rust converter and painted it flat black to improve the looks.  You decide.
last item is a tool i needed but couldn't find.  I have a lot of chrome trim holes to weld shut.  the easiest way to do this is with a mig and a copper plate behind the hole to fill it in.  The weld does not stick to the copper and supports the weld while it is filling in the hole.  Pretty cool.  anyway i just decided to build it.  I got a copper cap [hasto be substantial] and a hammer handle for $9.  I cut out a slice of the cap, stuck it in the handle ,and drilled a hole for a bolt and there it is.
Rest of the pictures
http://s93.photobucket.com/albums/l66/hellfirejim/tools/
So that was my weekend........
Did I mention I am still working on the gas gauge???????? :mad:  I know the tank is full and the ohms read 70.  Tomorrow I am goin to ground the tank and see if that is it.  If not then obviously i need a new sender.  if so it will wait for the spring when i drop the tank to put in all new grommets and such.  also to put in the retune line.  In the mean time I will just have to watch it close and keep at least a half a tank in it.
is that zero empty or full?  right now I am readying 70 ohms and it is 3/4 full.  but even so chouldn't it have at least read something?????  peg stayed below empty and didn't move.  If I have the wrong one so be it, I will get the right one.
Correct. I got about 5 ohms to 72 ohms on mine.
jim, the ford gauge is a 0 to 70 the 90 ohm is a gm.
My momma told me there would be days like this..... :amazed:
i started by ulling the center gauge panel and put in the red ite cover.  not much of an issue so on to the A pillar 3 pod.  When i put it in the first time I just stuck it in so this time I took it apart and sanded and painted it.  this will hold until i blow the car apart for final prep and paint.  i added to the two gauges with the red light covers and installed my fuel level gauge.  I got it installed, turned on the power and the gauges does NOT work!!!  :rolleye:
I go back and check all the inputs through the wires and all is right.  Now here is the part that bothers me.  The ford gauge is 0 ohms fuel and 90 ohms empty.  I measured the ohms and it was about 70 ohms.  That fact plus the fact i know there is more than 1/2 a tank of gas in the car, more like about 3/4.  So I have to go to auto meter and sort out it I have a good gauge and/or I bought the wrong one....Right now it looks like maybe wednsday after work will be my only chance to stop over at autometer.  If not then it will be the last of next week.  Frustrating but it is all part of messing with these cars.
Just a quick note.  I tried my lights the morning at about 5 am and some of my gauges havw lights that work so i have a swtichable source of power for the instrument lights.  Also going to install the gas gauge.  yes i will take some pictures.
At work we have a fair amount of car guys and we are planning a get together on sept 12th at a local car show.  Should be cool.
Good news, my gas gauge came today.  I wil be putting it in the empty hole in my A Pillar 3 pod from MAP.  I also got some of those red caps that go over the lights for the instruments.  Since the 3 pod sits at eye level I am thinking that the red light will have less effect on night vision than the white lights.  While I am at it I will also cover the lights in the dash. Might look cool, who knows.  Additionally I have to wire in the actual power to the instrument lights.  Looks like this is going to be an electrical weekend.
For those wondering, the plastic behind the instrument cluster is typically coming apart and since I have an Tach on my steering column it covers up the gas gauge anyway.  Putting it in the 3 pod makes the most practical sense.
very good story  hope fully every time she drives it she will rember  the "first drive"
Thanks.  Knowing that the car is going to end up with someone who truly cares and will take care of it motivates me even more.
ypur lucky to have a grand-daughter that appreciates the car, and im very sorry for the loss of a good friend of yours.
Life has Balance.......yeah it is going to be one of those posts..... :lol:
This saturday i buried a friend of 9 years who i worked with and for the last 4 years we were each others support system in our battles with cancer.  He got tired of the fight and his lack of quality of life and layed down is sword. He was a very good friend.
But as i said before, Life has balance.  Saturday afternoon my daughter and son-in-law brought my 15 year old grandaughter to visit.   They had to run an errand so i took my gandaughter out for a ride in the Pinto at her request.While we were out we talked and she told me how cool old cars are and in particular my Pinto.  I made a stop on a dirt road and got out and told her to do the same.  I then told her to get in the drivers seat.  When we both got back in she said she had never driven a car and I told her i knew that.  I had her leave it in drive and just idle down the raod to get used to the feel of the car, steering and brakes.  After she got comfortable I told to give it a little gas to where she was comfortable. (20mph)  Long story short she is SOOOOOOO hooked now on the car.  I am going to leave it to her when my time is up because she would drive it and appreciate it.  it make me feel good to know it will be going into good hands.
The second part is what my kids brought me.  Bryon found it at a flea market he was working.  Pictures below.
Life is good!!!!!!
I have a little more info on the throttle body fuel injection.  The company I have been talking with has done about 200 of these 2.3 conversions.  They are best known for their 300 Ford six conversions and have done about 2000 of them.  The kit is complete with every thing except a return line and high pressure hoses.
This is not a tease because that is all I am going to say at the moment as it will be spring when i go buy one and put it on my car.  At that time I will talk about the ease of installation and how it performs.  It is not cheap but about a 1/3 of a regular after market EFI port injection but I feel this is the way to go.  And for those interested in boost it can be converted to blow through but in does increase the cost by about another 1/3.
Chris,
You are a lucky man.  Havng a place inside makes all the difference.  When winter comes for me the car goes up on jack stands and a car cover. Frustrating to lose that building time but such is life.
