Date: 02/16/2019 10:46 am
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 12/20/2016 10:47 pm
Date: 10/05/2017 02:26 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
  • Online today: 500
  • Guests: 314
  • Total: 314
Always enjoy your reports, Jim. My efforts have been on furlough with the heat of summer, I will be deep in it once the weather cools off.
It is also important to mention that I have a friend with a shop that is allowing me the use of it this fall. This will change my capabilities, progress and challenges a great degree. I anticipate a far deeper and thorough restoration since I will be able to have the car in secure shelter. More later.
This post will be a little different.  During the course of any long term project there are times when you just have to sit back and see if you are drifting off course. This is one of those times.  My original goal with the car was to have a fun cruiser for around town.  That has not changed but i have drifted from that.  The most obvious example is the motor.  I originally wanted a turbo and then at least supercharged but since i have been driving it around i realize i don't need all that power to have fun.  The result of this is a re-alignment of objectives.
My goal for the last of 2009 and 2010 is to complete the mechanical portion of the projest.  To accomplish this I will be doing the following:
1.  The cylinder head will be sent out to be mildly ported and polished, better than stock cam and have the head shaved a bit to raise compression.
2. Since I have a 4 barrel manifold that is proving to work just great i will be swtiching over to a throttle body fuel injection setup.
3. There is supposed to be a new bell housing coming out this fall that will mate a 2.3 to a v8 C4 trans.  I will purchase one of those and a C4 trans.
4. I will have the new rear center section [4:10-posi] installed.
5. the front end will be dropped about 2 inches.
6. The rear tires will be replaced with taller and wider tires
7. Rear wheel opening will need to be slightly modified to accomplish the new tires.
So what does this really do for me and advancing the project?  Going down the line it looks like this.
1.  This will give me about 150or so real horsepower.  More than enough at 2500lbs.  Compared at a power to weight ratio it will fall between a new Mustang gt at 300hp and the V6 at 200hp.
2. The objective of the car is to be a trouble free cruiser and TBI will give this to me at a cost of 1/3 the regular EFI and cost is very important.
3.  This will give me a chance to make my driveline bullet proof.  i can save money because i don't require a "built" C4 since a stock V8 C4 trans can easily hold the power i am making.
4.  The new gearing with posi will add to the effect of more horsepower around town where i will be driving 90%+ of my time.  Most likely a 1 hour time frame will take me to most places I want to go to.
5.  this will be doine with dropped spindles.  It will be to achieve the look i am going for, ealy Pro Stock Pinto.
6.  The tires now are about 26 inches tall and i will be going to a 28/29 inch tall tire.  That will fill up the wheel well better, give better traction and ease the gear a little.  It will raise the rear of the car an inch.
7. Due to the increase down in front angle and the larger tires the front of the wheel well will have to be moved back to provide more clearence.
So there you have it.  Sorry for the long post but i wanted to explain the shift in direction and why.
Actually it will be more like gas gauge, wiring of the lights for the gauges and installation of the a/f meter.  Also have to get the holes left from the trim removal welded shut before the winter.  My granddaughter is coming out this weekend and she loves the car so i will spend some time with her and then oin to the electrical work.
yeah it was great.  You know that this is probably the biggest outdoor car show i know of short of a national meet as we had between 800-1000 cars all parked in this town.  They literally shut the whole town down.
So I start again making it better.  Right now my next step is to dis-assymble the blown motor for good pieces and get it out of my buddy's shop and add to muy collection of motor parts.  Got enough parts to put another turbo motor together..... :rolleye:
I guess the gas gauge is next....... :read:
Jim,
Looks like a really nice show - glad you had a good time!
I posted about the cruise and car show in the General pinto talk area.  Here is the photo link in case you missed it.                                                  http://s93.photobucket.com/albums/l66/hellfirejim/sycamore%2007-25-09/?start=0
On the cruise the car performed great.  I have not enjoyed it more at any time.  Oh i am so sunburnt..... :lol:
next weekend i go back to work on the car as this is a never ending job.  I often wonder what will come first retirement or finishing the car???????
Went on a cruise today.  what a great deal of fun. :lol:  i wil post more tomorrow after the car show.  i will try and get some pictures.....
PUNCH IT!!! :fastcar: :lol: :lol: :lol: ;D ;D ;D :) :) :)
Keep your eyes peeled for the 'fuzz' you know... :police:
Chuck :afro:
This car is going to make me crazy.  My buddy was going to take care of the carb problem for me and he told me when he got into it, it ran perfectly.  After the carb bowl came off there was no dirt or anything.  So did some research and found the using a carb like i have where 80 -90% of the time i am on the front two barrels, the back too barrels needle and seat will sometimes stick or not seat right and leak.  So the obvious answer is i have to use the back two barrels more.... :lol:
Hopefully will do my first cruise on Sat night.  And don't forget my first car show on Sunday....
yeah they are ruff and probably not of use to most but remember I am going to scuff down the finsh to look lke a brushed aluminum finsh so that should take care of most of the surface problems.  as for the corrsion. i have this mexican guy who is a fantastic welder and really likes the pinto and has done all my welding work.  they look good enough to give them a try.
Jim
http://s195.photobucket.com/albums/z206/Philstoys/parts/
here is the pictures of the bumpers
i was not going to make them perfect   just tried to get some of the years of dirt off  :lol:
the rear is rough   let me know and we go from there. phil
Quote from: phils toys on July 20, 2009, 02:38:42 PM
jim bumbers ar off  front weight 15 pounds rear  11 pounds  should be a big differance i will try to clean them up some and git a pic for you
Phil,
You don't have to go to that much effort.  I plan to make them look like brushed aluminum instaed of chrome shiny.  I think the look will be cool and not the standard chrome deal.  At that weight my current bumper brackets weigh more than that, not to mention the impact bar and the shock mounts.  All of the afore mentioned pieces will be gone and replaced by light weight brackets that will pull the bumpers in closer to the car.  i think it will change the whole appearance of the car and drop about 100 lbs off the car.
thank you sir I appreciate your efforts.
Quote from: discolives78 on July 20, 2009, 12:50:05 PM
Hey Jim!
Sorry to hear about your car trouble! It's good to know that you're making effort to correct it, though.  :)
Glad to hear you had fun at the show. It would have been nice if you could have taken the Pinto, but at least you had problems at home, and not half-way there.
I'm sending you prayers of health, energy, and motivation.
I hope you don't mind my plagiarizing your signature, but you've really been a big inspiration to me over the last few months.
Best wishes!
Chuck :afro:
Mind, I am honored.  Feel free.  it is tuff to do this with no money and limited physical resources and no garage and by yourself but if you want it bad enough and you are hard headed enough you can get it done.
BTW: I looks like I am going to be an owner of a 77 Rallye Pinto with the special instrument package and the dash instrument package.  Floors are ruff and parts of the bottom are rusted through but it will be good for parts.  it also has the ralley wheels too.  so if you hear of anybody looking for parts like this let me know.  When i actually get it i am going to look real close at all that is available.  it even has the big class hatch in good shape.  Oh and the stearing column and steering wheel are already claimed for ME.  LOL
If I have helped in  any small way then the effort to keep this thread updated is worht it to me as that was the sole purpose for doing it.
Hey Jim!
Best wishes!
Chuck :afro:
Well I have fund out what was causing the problem or i should say the problems.  I first reset the fuel pressure which was a little bit high.  I think that was the result of a better pump and a POS holley regulator.
Then I started searching for the ignition problem. I replaced the cap and rotor and the plugs which did help some but not the whole problem.  I went over to my buddys and borrowed a coil to check mine.  When i switched them it got a lot better.  So I thought I had found my problem, bad or dying coil.  Not so as when I went to pull the coil wire out of the spare coil the wire came off and left the metal piece on the coil.  That was the source of my ignition problems.  It is true, it usually is the simplest things.
it was so much better at this point but still not right.  The idle was low so I was going to raised it a bit and took off the aircleaner.  When i was looking down the throat of the carb I could see that gas was coming out the back two barrels.  I will have to pull it another day as right now i am tired.  tomoorrow is another day.
Well i went to the show anyway and only saw one pinto which was a V8.  when i went back to get pictures of it i couldn't find it.  I got some shots of Turbo 2.3s.  I met some people that I had know on the internet but never met in person.  that was cool as they are good guys.  here is the link to the pictures:
http://s93.photobucket.com/albums/l66/hellfirejim/nmranmca%20rt66/
heading out to find out what happened to the pinto.  later
Too bad :(  and I know you're disappointed, but as you said: it's a lot better to have happened at home.  I'm sure you'll have the problem resolved soon!  Have fun at the show!
Sorry guys to disappoint you but the Pinto is going no where.  I went out to prep it for the trip, checking fluids and such and fired it up.  It started  to chug and not clear up.  it did that one other time.  so i figured new plugs.  helped but not the answer....Was going to put in new cap and rotor but it won't be there untill tomorrow.
Soooo here are the possibilities:
1. Coil going bad
2. Fuel regulator allowing too much fuel to go in the carb, flooding
3. possible ford ign box going bad.
4. possible wiring problems..
anyway i am still going but I am taking my ranger as it is just too far to go with a possible problem.
Sorry, i am disappointed but better to happen at the house and not on the road or in chicago.
jim  :(  :mad:
Have a GREAT time, Jim!!!  Don't forget to come back and tell us all about it!
this is not a post about what I am doing to the car but what i am doing with the car.  The car is finally to a stage that i feel comfortable in it and because of that Saturday i am taking the car to the superbowl drags at Rt66 in chicago.  it is about an hours ride from my house.  As i understand there are going to be a number of other pintos and turbo 4 cyl cars there from all over the midwest.  A lot of these people I have "talked" with over the internet but now is an opportunity to actually meet them.
To say the I am excited is an understatement.I am just so jacked at being about to finally drive this car like it is supposed to be driven.  are there still some issues???  You betcha, BUT i am not letting this opportunity go by.
All of you out there, drive your cars and enjoy them.  that is what they do best.
ok this is just too cool, i am so jacked.... :lol:  We replaced that holley POS fuel pump with an inlne fuel pump from CarQuest.  It was one of their generic ones.  They have two.  One is 2.5 to 4 lbs and the second was 5.5 to 9 lbs which is the one I got.  It comes with a prefilter and mount brackets for $55.
I took it out and I could barely hear it.  And this is with almost no interior so once i get some padding and interior in it i won't be able to hear it at all... Life is really, really good.  This makes the car a pleasure to drive and takes a way a really big problem.
A couple of neat things.  First while i was running some erands i was driving the Pinto.  Out on the road I got a couple of thumbs up from a harley guy and a pro street style duster.  That was really cool.
If you have been reading this you know that the noisy fuel pump is driving me crazy.  when i am driving and i turn off the fuel pump the car is as quiet as any new car.  Well i may have found a soulution.  An inline fuel pump that puts out 5.5 to 9 lbs of pressure.  Since my car right now is carbed this should work out well. I will know this week.
This Saturday i am going to the track for sure now and I will report back on any pinto's i see.  i will try and remember my camera and extra batteries....
just a short note as i have a ton of things to do.  I got the front end aligned and what a difference.  it really brings the confidence back into driving it.  Got more stuff going on, will post later.
I have sold a few cars because they were 'finished' or I got so-called writer's block (what do I do next?) I tried driving new cars, but got bored cuz there was nothing to fix. No soul in a 95 Metro. Not a bad car, was just hard to justify tearing apart a one-year old car with 8,000 miles on it. My Pinto is still for sale, the deal fell thru, so I may get some more done before she goes. I had a 78 wagon a few years ago that I changed to the 79 front end, I ground all the studs for the chrome trim off that car. What a PITA! I agree though, not something you want to snag yourself on.
Chuck :afro:
It appears you are like me and that even though I really enjoy driving mine I really enjoy the building and creating one of these little monsters. ou really have to be creative on these cars as parts are not available at your local store to buy and just bolt on..... bolt on, what is that??? :read:
I thought about if somebody offers me money for this car.  I don't know the answer, probably depends on the amount.... :lol:  It would have to be a lot.
Hey Jim:
Down to tying up loose ends, looks like this one is sold and going to a new home this weekend. Will be replacing (hopefully) with a 79 wagon.
Chuck :afro:
Thanks Chuck, still kicking.  How about you? Still working on the Pinto?
Glad to see you're still at it, Jim!
Chuck :afro:
