76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 08/08/2018 12:26 pm
74 pinto
Date: 09/11/2016 06:32 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 02/04/2018 08:26 am
Wanted hood hinges
Date: 02/17/2020 05:30 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
  • Online today: 515
  • Guests: 411
  • Total: 411
Quote from: hellfirejim on June 03, 2009, 08:43:37 PM
Progress report on the tranny swap.  They had to fabricate a new shfter cable mount to fit but with that done the trans is in the car.  Additionally the 4 spd driveshaft fit perfectly behind the C3.  More good news is the trans hole is covered by a plate which doubles as a shifter mount point.  The shifter is installed and adjusted.
Next come the mounting of trans cooler and the lines.  A few other items like the removal of the clutch pedal and cable.  After the trans part is done we still have to put in the new front springs.
To tell the trutch I am going crazy waiting to get it all done.  here are few shots.  the bracket is hard to see, sorry.
PS: The white ball is going aay to be replaced with my T handle with lineloc button sitting in the tray in front of the shifter.. ;D
Evening all.  Been a long day.  I quoted the picture above so you can see what i did.  The electric radiator fan was not coming on properly [poor ground] so i figured the easiest solution was a ground ring and spacer.  Here is the picture, mostly self explanatory.
This other picture is of my paint booth as i painted and re-installled my swing out side bars for the roll bar.
:lol:  Just finishing up odds and ends before saturday and the exhaust.
i did realize that my fuel gauge doesn't work so i will need some ideas on that.
Well Howdy Do!!  Life is good.  I took ther Pinto out for it's first test run and yes with open pipes.  it did very well and only has two small problems that can be fixed easily.  BTW: I have an appointment in 2 weeks to get the exhaust done.
The pictures are of the tranny cooler and lines.  Yes i have already made some changes but no pictures yet.  Here is just one of them.
This picture is of the interor after I clearanced the consol, painted it and mounted the T handle w/line lock button.
The rest of the pictures are here.  http://s93.photobucket.com/albums/l66/hellfirejim/First%20test%20run/
Life is Good.
I said more when it happens and it is happening.  On the way home i got a call from my buddy to stop by the shop.  Since i am not using a stock shifter there were issues to solve.  Some good fabrication should solve it.  I also had to locate where i wanted the shifter to go.  by the time i get home tomorrow from work they should be pretty far along....  I hope. :lol:
PS: I didn't say it out loud but the car is in the shop for the tranny swap and the front coil spring swap.  when it comes out it should be a different car..... ;D
No the trans swap has not started yet..... :rolleye:  However I did do a little something.  I got a set of front coil springs used from Chris (POPbumper) and i cleaned them by hand.  The first thing was to spray them with PB blaster tolossen the rust.  I then rubbed them down with a grey scrub pad.  yes by hand.  After that i then took to some sandpaper and went over the coils springs.  i cleaned them and degreased them to spary with flex primer.
After that I sprayed them with a flexable bumper cover paint. Better than nothing while i wait for the trans swap....[did i mention that the wait is driving me crazy.......
More when it happens.
First is the trans cooler is here and it is so cool.  This is one made at least 10 to 15 years ago and is it sweet.  Not one plastic piece in the whole damn thing..  Absolutly first class fabrication.
This weekend i installed my spoiler.  At first I was going to use double sided tape but after talking with someone who has done it before, it doesn't really work all that well. So what to do?  Silicon Adhesive.  Oh yes and make sure it is clear.
I first laid the spoiler up on the rear deck and it fit well.  I then laid tape around the spoiler to give me a layout area.  Oppss forgot, I carefully pryed up the Pinto emblem and the Ford letters.
Ok back to work.  Since I knew the deck under the spoiler was going to be under there for about 2 years I took the time to prep the deck under the spoiler.  I sanded and spreaded with a primer/sealer.  When that dried I layed out a beed of silicon around the inside edge of the tape.  I then laid on the spoiler and clamped the bottom and across the top I took a bowed piece of wood and put the bow down on the center of the spoiler to hold it down while it set.
After it had set, I cleaned up the extra silicon with a razor blade and it was done.  Alright i can't leave well enough alone.  Remember the Pinto emblem i took Off?  look at the picture of the spoiler.
link to other pictures
http://s93.photobucket.com/albums/l66/hellfirejim/spolier%20install/
got the fuel pump rewired.  Now just waiting for the trans cooler to get here.... :read:
hell i am paddling as fast as i can.  i got the rest of the wiring for the safety switch done and it works.  i also got the the ground strap from the engine block to the body.
my shifter arrived along with the trans cooler install kit.  just waiting on the trans cooler and the package goes in the car......
Turbo Toy
Enough of this foolishness. When we gonna ride in this thing? I'm not going to put the 4.10, posi together until you drive it down here. It's coming along nicely considering all the setbacks you have had with the motor and trans lately. Git er dun. :showback:
Short update.  The trans came in and it is a C3 which is just fine for my needs right now.  Decided on a new flex plate [chewed teeth $24].  I ordered my new shifter and install kit of the trans cooler.  Speaking of the trans cooler it is on its way too.  With parts coming i will finish the saftey switch wiring and begine the fuel pump re-wire this weekend if the weather cooperates.
More pictures later.
Ok back to your regular warm weather posts.  Today is pictures of my new inertia fuel pump shut off safety switch.  A mouthfull.  The first picture shows the parts required to put this together.  It is amazing the amount of time it took to do this right.  Basically I put the switch into a plastic box and mounted it next to the battery behind the pass seat within easy reach from the drivers seat.
The switch is from an escort and is relatively cheap $20.  The pigtail for the wiring which you will need is over $30+ dollars. :hypno:   Nuts and bolts about $10 and the aluminum was some scrap I had left over from another project.  It just takes a lot of time to sort it out but worth it.  The second picture is is installed.
Here is the link for the rest of the pictures.
http://s93.photobucket.com/albums/l66/hellfirejim/safety%20switch/
Depending on the trans and such I may rewire the fuel pump next weekend.
Just a quick note before i head back out and work on my Pinto.  I just heard that i am getting a complete autotrans out of a pinto that was on a 2.3.  I don't know more than that and until weds when it is supposeed to arive.
Why is this important?  Down the road i was going to swap to an auto for health reasons and strength this fell into my lap for $100.  As i said i don'r know idf it is a C3 or C4 but either for now will work just fine.  more info as it comes it.
Great story!  I am working on something for the Pinto that is not quite far enough along just yet to say anything but I think it will be cool.  More when the time is right.
This weekend if it doesn't rain is installing the inertia switch for the fuel pump and maybe a re-wire of the fuel pump harness.
Back in my dirt track racing days I had a 2300 that was set up just a little too loose (they turn up better when they're loose!) It had so much blow-by that oil blew out of the valve cover breather and caught on fire! I solved that by putting a Ford anti-backfire valve in the exhaust at a 45 degree angle and hooking a silicone hose from the valve to the valve cover. The exhaust flow created a vacuum that relieved the crankcase pressure. As long as I kept it around 7800 RPM everything was fine. At 8000+ I would get a tad bit of ring flutter and when I came off the corner the oil had gotten sucked into the exhaust and the smoke would roll for a few seconds!  :lol:  :lol: I told people it was just an old worn out junk engine and it didn't run good until it started smoking! I won a lot of races with that ol' worn out engine!  :laugh:
You know that is why I created this thread that seems to have taken on a life of its own.  If somebody sees something that they can use then so much the better.
This is another reason for working on my pinto is I can exchange ideas and thoughts for $$$$ which are in short supply.  I really enjoy trying new things and simply doing it my to make me happy and it does.
Glad it was of some help.
PS: Next is the install of the fuel shut off switch for my electric fuel pump.
Dang...I missed it by ][ that much ;D  But you gave me an idea :amazed:  I'm staying wet sump but I'm going to install a petcock valve on the bottom of the catch tank with a high pressure return hose feeding into a fitting that I'll install in near the top of the oil pan or feed back into the oil cooler return line (more likely). Then I can let captured oil back into the engine when I'm back at the Paddock cooling it down. You just saved me A LOT of messy hassle between races ;D :drunk:  My Lotus engine was burping about 1/2 of one of these tanks each race (regularly hit 8000 rpm). I slightly overfilled it with oil for safety before each race (Paranoia). I am not using my AccuSump because it messed with me one time and cost me $$$. I don't trust it anymore and it's heavy >:(
Actually that is pretty close to the truth.  what it is is an oil / air filtration unit for a dry sump oil system.  It lets the oil drop out of suspension [if there is any] and the excess air breathes out the filter which keeps all the mess [oil] inside.
The system lets the engine breath which will be important when the boost is added.
Not to jump on anyone's post, it is an oil overflow or catch tank that is required by race rules. HIGH RPM engines can and do burp oil on to the track just in front of YOUR own rear wheels 1st!!! FUN :hypno: :accident: Pictured is what I bought on Evil-Bay for under $20 delivered about a month ago for my Hanto Pinto race project...
Hellfire, what is that setup going from the valve cover cap to the fender????
Well I am back at it again.  Yes the tranny is shot but I have a line on at least 3 maybe 4 boxes to put in.  I have decided that right now i need to just get it up and ruinning and worry about it later.  Down the road i am going to swap out to an automatic for health reasons and to hold the power when i boost the motor as this little trans may take one or two shots at the higher lever and scatter itself.
So what do i have for you today????  Well I installed my SPAL Thermostatic radiator electric fan controller.  First i would recommend the SPAL kit as very high quality. i got it all wired and here is a picture of it.  Most of the wiring is hidden but you can make out the relay in the pass corner by the hood hinge.
Here is the link to some more pictures of it.
http://s93.photobucket.com/albums/l66/hellfirejim/new%20motor/
So what is next?  I just ordered the Ford inertia shut off switch for an Escort that i am going to wire in for my electric fuel pump.  Depending on how that goes I am also planning to re-wire my fuel pump with a bigger gauge wire like it should have.  The idiots put in 18 gauge wire and I  know that won't last.
PS: I almost forgot, that is the new motor a 85 Factory turbo long block.
Damn these little cars, if it is not one thing it is another.  On the last test run of the new motor the trans is not able to select first gear.  I saw that the adjuster ring had backed off and the shifter was just wobbling around.  Now I need to find out about that.
Also working on installing the temp controlled on/off for the radiator electric fan.
Jim:
  Good to hear from you, Godspeed on your project >and< your health! Thanks for keeping us up to date!!
Glad to hear things are going well all the way around Jim! Sounds like you will be crusin' in the Pinto very soon.  :fastcar:  ;D  ;D  ;D
Well more good news.  I stopped back at the shop and they fired up the Pinto.  It fired at the touch of the key, idled smooth, had good oil pressure and almost 20 inches of vacuum.  So the thermostatic controller for the fan gets installed and then off to get the exhaust done when i can come up with the money.  When that is done I am going to install my wideband that I have and then drive the hell out of it to sort out any bugs.
glad to hear jim, keep on truckin, errr pintoin.... you know what i mean!! ;D
No pictures today just some good news.  I still have a job and they started back in working on the motor to stick back in the Pinto.  Also the latest results for the cancer tests show a very little activity.  So life is good.
The oil pan and pickup came today.  looks real good.  here is picture:
here is the link for the new [to me] motor on the engine stand and a picture of the blownup motor.
http://s93.photobucket.com/albums/l66/hellfirejim/Engines%20and%20oil%20pan%20new/
Until more happens or this weekend when i take the short block out of the truck and pack it away in the shed.
I forgot to tell you about the oil pan.  It came from a friend of mine on the delayed payment plan until i learn it I have a job or not by the end of the month.  It is the real deal and you can see the rest of the pictures at the above link.  It will go back into the box until i can build "the" motor.
