Date: 06/07/2021 08:14 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 12/31/2017 09:03 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 02/27/2017 10:10 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
  • Online today: 506
  • Guests: 253
  • Total: 253
Flat spot with Holley 350 carb
Started by kerryann, April 17, 2014, 07:31:40 PM
The only way you'll know is to set the butterflies dead correct on the slots and then put carb back on and see where you are idle speed wise then work from there. How I start with any carb. I use 1 1/2 as a starting point on idle screws too. Where they end up can tell you if idle feed restriction is close or not. Both need to have an effect, if one does and one doesn't then indicator of something wrong in that circuit.
What speed is engine comfortable at idle wise, i.e., what cam in car, affects that greatly. OEM around 700-800, longer cam will be higher (up to 1500) and how those slots begin to cause trouble, the idle has to be set too high and gets into them.
Power valve vacuum value is usually one half what idle vacuum is, a good starting point.
Assuming accelerator pump is working well............
kerryann
that method of figuring out the power valve restriction size makes sense.  as for the idle transfer slot setting, i'll check it again, but ive tried it from as low of an idle setting to stay running all the way up to too fast to comfortably stop the car while in gear.  no change in flat spot.  this is without adjusting the idle mixtures screws.  i tried adjusting them as well without changing the idle speed screw.  I tend to try and leave the idle mix screws at or close to the baseline 1 1/2 turns out.  guess i should try setting them with a vacuum gauge.
one of the racer walsh restrictors is pressed in farther than the other.  There could certainly be a blockage somehwere in the wells like you said.  Im afraid that may be the problem whether the drilling caused it or something else.  im going to see if i can remove the restrictors and find anything.
My take on porting with the one inch adapter is that it is to help make up for the lack of depth, the short distance there makes for issues with fuel distribution, the throttle plate angles interfere with mixture getting to the other side of them since all fuel comes from one side of a 2 bbl. non-progressive carb until the boosters start up.
Just me though and I can't back it up........................LOL
You block the power valve while checking the main jet and NOT UNDER HEAVY POWER, you can fry motor doing it. The valve should not be opening when main system (boosters) start up, rather, somewhat after that. If you are getting the flat spot while driving around like normal cruise then problem is NOT the valve. Could be trash in a main well from the drilling or the brass insert in too far to make a restriction. Going to the full size restriction of a dead stock carb should not work either, they restrict them for a reason, it being too big for a four cylinder. They are usually up around .040"-.055", these will like around .020"+.
You end up with two main jet choices with a blocked PV, one is good driveability at cruise and low demand throttle and the other is high demand full throttle power. There will be a separate main jet that motor likes for both, then you figure the difference in cross section of the holes and that ends up being the power valve restriction size. The power valve supplies the difference in fuel between low demand and high demand requirements. The jet size the motor likes for full power will be too big for creeping around in slow driving and the motor will be too rich then. Why the system was created to begin with.
Think kickdown on an automatic transmission, power valve comes on about then, the demand for extra load. Maybe a wee bit sooner but not until then, it needs to be closed for clean normal light load driving. Why blocking it to test drive at low load is useful.
If the idle is still set to make the throttle plates go higher in the transfer slots it never will run right, the transfers should be barely showing like maybe .020" of the slot and no more when carb is pulled to look at that after normal idling speed has been set. Too high in slot makes for too rich an idle, you cut back on the screws to cure that but then when you increase throttle no fuel left for transition load because the high slot condition has used it already. So, too rich, then instantly too lean right around normal cruising spot. The entire lower rpm/load workings of the carb are set up based on that idle transfer slot relationship and many mess up there.
If an old carb can always have some sort of blockage in a metering block well. A few of the carbs they put idle feed restrictions on the tip of a long tube that presses into the well, if those block up the tip almost impossible to clean.
kerryann
up to 61s on the jets, that's stock jetting for  7448, i have a power valve blocker, i'll have to give it a try.  Yes it will probably need more jet to compensate, i think i have some low to mid 60s i can try.  also this intake is unported and i have the ACE adapter off ebay.  after reading through other posts some suggest porting with the short adapter.  This car is just a cruiser and were not looking to eek every bit of power out of it we can get, just smooth throttle response all through the range would be nice.  I plugged the injector holes with brass plugs.  My drilling and tapping job wasn't a precision job but they are tight and sealed up.
I would try it out with no power valve. Take an old one and remove the rubber, then melt solder into it. I've done them both way. You may need to put bigger jets in.
kerryann
Back again, haven't been on here in awhile.  I finally got around to putting on the efi intake on the 1980.  Bought the nice billet cnc machined adapter to make it easy.  Installation of the new intake was a challenge getting the lower bolts in and out without removing the distributor but i managed.  I didn't realize until I went to put it in but the upper most bolt towards the front of the car doesn't match up (newer intake on older head).  I'm sure the rest of you that have done this swap have run into this.  if i hadn't got so far i would have considered drilling a new hole in the intake but i left it as is.  I figured missing just one won't cause a leak.  Actually when i removed the old intake that bolt and the one next to it had fallen out long before and were gone.
The car fired up and has a slightly different idle tone too it now but the flat spot is back and is worse.  The car makes plenty of power and is actually pretty quick with the new intake on it.  It just seems to be a really bad transition flat spot from idle circuit to main circuit.  I'm convinced that something is wrong with the power valve circuit, maybe something i didn't get out after drilling for the racer walsh restrictors, maybe something wrong in idle circuit, the main circuit seems to be spot on.  The carb makes no response to power valve change.  It does get better when warm but now it doesn't go away when hot.  I'm going to look for a fresh 7448 from some of my circle track friends and start over.  already have the restrictors but I wan't to try one without them first and see what the difference is.  Then I will see what I can figure out.  I am convinced this is purely a carburetor issue at this point so I will see what I can find out once I can get my hands on another carb.  The one on it was an old swap meet carb so who knows what its history is.
-ian
kerryann
ok, simple enough.  i was considering porting some of that lump off there but didnt know if it would hurt anything.  this motor is a 1980 so i would assume its the oval port right?
If head is oval port use oval port gasket, or any before 1982. If D port then '82 Fairmont or others later can work.
The original hole is sized right to run a drill bit up in there suited to the size needed (7/16" bit) for 1/4" pipe taps and use like socket head plugs there. Don't tighten real tight to avoid cracking and seal threads with something. That way you don't have to worry about welded holes warping the head flat. I'd port the plugs and the lump there a bit to smooth them into port.
If it's never gonna be used for EFI again that's the way to do it..
I drill them out / tap them / install pipe plugs. That's all.
kerryann
put 61 jets in the carb.  this is stock recommended size for the 350 holley.  up from the 59s.  no change in flat spot. i think ive hit a wall with this particular carb on this intake setup.
i did get an efi intake from another circle track friend.  they collect them.  whats the best way to plug the injector holes on these?  just weld shut?  and also which intake gasket should i order to put this intake on?
Just joking of course...............torque cams are usually pretty small, by no cam I mean anything under .500" lift. My last post concerned flat tappet only, no roller.
You're welcome Dick, I thought the same thing too when I got mine, you could compress 500lbs springs with that easy,lol..
Got the valve spring tool and its built like its for use on an 18 wheeler. It'll be around a lot longer than I will. Thanks for the tip Art.
Quote from: amc49 on May 21, 2014, 07:21:29 AMYou got no cams there if flat tappet lasting that long,
Oh really!, Well, my 86 Toy(22R) I bought brand new didn't come with a roller cam, and when I rebuilt the motor in my 73 dually I put a Melling torquer(flat tappet) cam in it, I never said anything about race cams with a gazillion lbs of spring pressure.. And just FYI, I DO KNOW the difference between  roller and flat tappet cams....
STP took out the zinc as well. I bought several cans of the last zinc stuff they made. It is illegal as said to sell the zinc, it is the phosphate needed to carry it that has the EPA all in a tizzy. At the last at the parts store I saw an oil that O'Reilly claimed it could special order, Champion I believe. They advertised a lot of zinc, it's sellable with an 'off road use only' label on the can. The Valvoline specialty MOTORCYCLE oil has zinc as well or did, the high price. Motorcycles have to have it as the friction modifiers that replace the zinc commonly mess up motorcycle starter one way clutches and cannot be used. The smaller motorcycle market as well allows the sale of it. Or did anyway.
You got no cams there if flat tappet lasting that long, the big ones die if you don't break in with half the spring needed there. BTDT. We commonly left some of the spring off of them when breaking the big ones in, then put full spring on after done. The 16V engines Ford builds now have no spring pressure, you can push valves down by hand. Why the flat tappet lasts so long now with no resetting valves. You don't need to break in cams there at all even the hi-perf ones. People commonly change cams and don't even change the tappets running against the lobes.
I been using off the shelf Castrol GTX for the last 25yrs or so on all my street stuff with flat tappet cams, I got one with 462,000mi and one with 126,000mi and still running strong... Just sayin...
Put a Ranger roller cam in it and you'll not need zinc any more. I've used STP since the 50's and never had any problems with it. It has a high zinc content in it (blue can) according to the label on the can.
kerryann
we used the rotella 15-40 for awhile until the zinc was gone there too.  guess you have to depend on additives for flat tappet longevity.  is the STP stuff any good?  ive read into a few different ones that can be ordered but not sure which if any have the good stuff in them
It's illegal to have oil on the shelf that has Zinc in it, only exception is the Schell Rotella which is for diesel engines, and even that has been cut down to a minimum.
kerryann
i hear ya.  always used straight weight oils until i lost my first flat tappet cam at break in on a 400 sbc.  was most likely due to faulty lifters but after that i started doing some reading and chasing the "zinc" oil.  zinc and phosphorus is supposed to be what youre after im told.  like you said, if its cheap it's not there anymore.  a guy on a nova forum used to do lab tests every month and report PPM of all important ingredients.  that was a handful of years back and he was down to only valvoline as far as over the counter.   guess they are out now as well.  brad penn is good stuff but very expensive (just payed $89 for a case for race motor).  haven't tried additives in awhile, didnt know which one of those i could trust either.
i guess i should shoot for a straight 40?  we've used a lot of 20w-50 or straight 50 in the worn out chevy v8s we drive around with no issue.  valvoline sells a "racing" 60 but never tried it.
since parts store 40 weight won't have any zinc or phosphorus what additive should i also buy?
I ran straight 30 in winter and 40 in summer all the time I ever drove my SOHC in Texas. Do it with later zetecs too now. Conventional had more zinc in it back in the day but not anymore, nothing does now unless buying the dedicated race oil, you'll know by the price, the oil will greatly increase in cost. With Valvoline I believe it is motorcycle only. Like $5+ a qt. Regular racing pretty sure has no zinc now. The price is the key, they pay a penalty to EPA for higher zinc levels.
I go 9K oil changes, the multi-vis wears out the additives fastest, that is what makes a 10 weight cold oil a 40 weight hot. I prefer the single weight, the oil is actually that single weight before additives ever added to it. So an extreme OCI still has fairly thick oil, it does not thin as much.
I snatched an AMC oil filter center fitting to put it in the 2.3 block then used AMC V8 filters (same size as FL1) and with no bypass in them to filter 100%. Worked great.
You really can get away with murder as far as oil weights on almost all motors. Everybody warned me of the VCT issues and not using correct oil, never had any issues at all and 200K miles. Here they start up just a bit slower on coldest day of winter but they always start. I probably give up a small amount of fuel mileage but I don't like thin weights. I have actually cured startup rattling on cars by thickening the oil up even though the conventional wisdom says no. No matter, I have my own wisdom for why it works. People talk about dry starts but it just doesn't happen, the thicker oil does not run out of bearings when it cools down like the multi-vis does especially when the multi-vis is worn out. Ergo, more there at the cold start. Nobody wants to talk about that of course.
Sounds like valve seals, that's what mine did..
kerryann
still waiting on jets so no tuning has been done as of lately.  been driving the car here and there.  it puffs smoke at startup while idling and also after a half hour or so trip when you come to rest and idle.  so most likely it puffs the whole time.  it is using oil.  down almost to the add a quart line.
what viscosity oil do you all recommend?  i know this is a heavily debated question.  i run valvoline 20w-50 race oil in my flat tappet small block chevys in street cars and tow vehicles for the supposed zinc levels.  my engine builder doesn't like the valvoline and says he's had it give up on the dyno in new motors.  he uses brad penn 20w-50 and i do as well in my race motors.
but back to this little street 2.3 ford that puffs smoke.  after reading a little on here seems most in warm temps run 10w-40.  wont be cold around here for awhile so just trying to figure out what would be best and what brand.  it's overdue for an oil change.  i run a fram racing filter on the race motors but i know wix k&n and bosch are supposed to make decent oil filters as well.
I used to carry a small hammer and screwdriver in the M II there for a while when the 2.3 used to pop rocker arms out. Simple light whack and non-roller rocker out or in in like a second. I got to where I could fix the whole thing and back running in like 3-4 minutes. I disassemble head same way now.
The guides got redone slightly tight and the exhaust built up carbon to stick the valve when cold and valve swelled too quick, problem gone as soon as engine warm. Yanked head for valve freshening up, found the problem and simply running a reamer into the guides by hand only to knock out the carbon fixed it forever.
Yeah, I can imagine what a pain it would be with screw drivers, wouldn't be too much fun either if they slipped with your fingers in the road, lol..
jonz2pinto
They do make the job easier.sure beats us two long screwdrivers,one on each side of rocker.when I got mine ten or so years ago it took awhile to find who had one.maybe someone on here lead me there.
Pinto-is short for pint-o-fun.
