1976 pinto for sale
Date: 01/12/2017 02:08 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 10/27/2018 03:30 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 07/08/2017 08:25 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
  • Online today: 506
  • Guests: 248
  • Total: 248
Flat spot with Holley 350 carb
Started by kerryann, April 17, 2014, 07:31:40 PM
kerryann
yes thats what ive been thinking.  almost took the pump cam right out to see if i can pinpoint the spot.
as far as the transfer slots, once you set that idle screw with the carb off the car so you can see you really can't move it after that can you?  again i have no tach but have idle as low as i can.  the mix screws can be turned a wide range without affecting vacuum.from about 3/4" turn out to 1 3/4" turn out is where vacuum is the highest and stays about the same.  ive been putting them at 1 1/2" out to be on the rich side if anything.
Ill try some carb cleaner in the idle port and some compressed air.  ive gotten lucky that way before with blockages.
do you think im getting into trouble with the stiff 7.5 power valve?  even easing into the throttle you can see vacuum creep down to 5 or so then really drop right out to 0.  could be giving too much fuel at light throttle?
Hole size all that matters there, nozzle or no is irrelevent. If flat spot right above idle then transfers, hate to keep going there again. The idle screws should both have same effect, one not killing motor may mean a clog in passage somewhere. PV ratings do not matter if at light throttle and the problem, the power valve should not be open then. Power valve only opens with higher load. Only transfers and a slight (why cams don't matter) amount of pump shot until the main boosters activate at light throttle. Transfers will not work correctly if wrong on the slot or the idle screw messed up, the transfer fuel is the extra that curb idle port does not use. Idle mixture screw sets both the idle and off-idle (transfer) fuel. You could have a clogged idle restriction, that may be buried inside the main or idle well and hard to get to. Some are easy to see on metering block.
At very slight slow throttle increase away from idle the pump shot does nothing, it's all in the transfers jack. If correct there you need no pump shot at all on slow increase. Pump shot only for bigger quicker throttle changes. Like motorcycle, most have no accelerator pump at all, the transition circuits on those carbs do the same as on these.
kerryann
some squirters have little brass nozzles that direct the fuel a little closer to the booster vs just the drilled orifice.  they give you both types of each number with the trick kit.  theres a third kind called anti pullover squirters but theyre for spread bores
What do you mean with or no nozzles???, there's only one piece there???...
kerryann
was up to 31 with no nozzles but didnt make a difference.  went back down to 25 with nozzles.  have 28 and 37 as well but havent seen a difference changing them.
What size squirter do you have???..
kerryann
Now that my timing issue has been taken care of, im back with stumbling problems.  tried just about every pump cam today.  i have a chart that gives duration and lift of all the cams.  currently back on the white cam.  tried different size squirters as well to no avail.
I did notice one potential problem, the idle mix screw on the left side (opposite from side with throttle lever) can be turned all the way in and vacuum will fall but car will stay running.  By turning the other screw all the way in the engine dies.  I would assume theres something not letting that needle seat completely on the side that doesn't kill the engine.  i have already replaced the small cork gaskets before and checked the seat visually when i did it, didnt see any visual issues.
I drove around while tuning with the vacuum gauge on a tee on full manifold vacuum.  my problem is during light acceleration.  i can get the car moving smoothly but as load increases or if i try to give it more throttle vacuum drops just about to 0 and that is where the real bad spot is, motor ceases firing for about 1-2 seconds.  5-10 of vacuum is really smooth but i either have to get the car going very slow or flat foot it.  either extreme isnt favorable for street driving.  there is no flat spot going idle to WOT.  After the flat spot the engine will recover and speed up and start to pull vacuum again.  even only 2-3" of vacuum is enough to get the thing rolling again and recover.  Not sure if i should be seeing 0 vacuum under light acceleration.  Im not really sure how to fix this either.
Still have the 7.5" power valve in it.  have about 13" of vacuum at idle in gear so i am assuming that valve is close.  blew air through both racer walsh restrictors, they both flow.  I still can't tell if this is a lean spot or over rich, no backfires through carb like lean usually does just a dead flat spot.  Ive read that most people had better luck with 5.5" power valves with the restrictors but they also didnt mention what vacuum they were getting.  had a 5.5" before and then went to 6.5 and then 7.5 without feeling much of a difference.  Considering going up to 58 jets but i dont think jet size is affecting my part throttle light acceleration, i could be wrong there though.  Maybe this carb with the stock intake just isnt going to work that great?  i have a race cam 2.5" power valve i could try just to go to one extreme.  think i may have a 10.5" in the box too.
Any ideas?
kerryann
ive tried every position imaginable, just wont work.  i have finally noticed that when i turn the distributor counterclockwise spark cuts out.  it doesnt appear to be a loose wire going to the distributor, im not sure why its doing that.  getting ready to make the parts store take this distributor back.  i dont know how cam timing or anything could have went out of adjustment considering the car ran fine 3 days ago.  just doesnt make any sense.  going to look for a distributor out of a used vehicle i guess so i know that it works.
Well, you have other things going on then, is the cam timed right, how bout the plug wires are they on the firing order?, it don't matter where the distributor is at as long as you're on TDC on compression and the rotor is pointing at #1, again everything else has to be timed right also.
kerryann
i have achieved this and it will not even start, just hesitates and backfires.  i can tell its out of time but ive followed every duraspark timing thread ive found on the internet.  It truly doesnt matter what tooth distributor is on as long as the rotor points to #1 wire?
You're out of time, when the motor is at TDC(on compression) the rotor should be pointing at #1 plug wire.
kerryann
i don't follow.  there is a recess in the shaft that the plastic rotor falls into.  this keeps it in position.  i set the motor at TDC on cyl 1 and get the distributor to drop down.  now i can set the distributor so that the rotor points directly at #1 and it just still will not fire.
ive just tried 4 different consecutive teeth on the distributor gear, each advancing more.  and set the timing so the rotor points at #1 or slightly advanced.
it finally fired up but now it just surges and dies,  backfires every now and then.  i can keep it running by popping the throttle when it goes to die but it wont idle at all.  my gf tried to keep it running for me while i tried to see where timing was but i just cant get an accurate reading, its all over the place because of the surging.
can anyone PLEASE either tell me or take a picture of where their rotor and vacuum advancer are pointing on a car that is timed right and at TDC of cylinder 1??  ive never had this much trouble with a distributor before.
it is in the 16L slot and has a bushing on the stop, i figured that was a good place to start but im at a loss.  it has two light springs on it, the one that came out had one very heavy spring and one light, maybe theres an issue there.  i don't know what else to do.  just cleaned out the carburetor again and put in a new accelerator pump diaphragm.  made no difference.  carb worked fine before.  i just cant figure this distributor out
I don't understand why you're having so much trouble, as I said before just put the distributor in  if it don't drop just rotate the motor until it drops. Number 1 can be where ever you want it to be, but right now put the cap on and put a mark on the side of the distributor at #1 wire now put the distributor in where you want it with the rotor pointing at the mark, when it drops down bring it up to TDC and line up the rotor with the mark and you're at 0*.. If it ends up too far one way or the other just pull it back out move it whichever way and do it again.
kerryann
getting the rotor at #1 is where i am having the problem.  i never thought id have such a hard time getting the distributor to drop down and engage the oil pump driveshaft.  i turn the shaft with a socket and a couple extensions over and over very slightly and just seem to get nowhere.  i got it in once with what seemed like the right advance and it would not run just backfire.  took it out and got it in with the rotor pointing right at #1 so that i can still pull some advance in it and it still will not run, just misfires and backfires.
the picture shows the first position which i assume had too much static advance.  the small black sharpie mark on the vacuum armature represents where #1 is when the cap is on.  can anyone tell me where the rotor should be facing when it drops down?
That's no problem, if the the drive don't engage just rotate the motor when it lines up the distributor will drop down done deal, continue to TDC and set the rotor to #1..
kerryann
got it on tdc by pulling valve cover and watching intake valve.  used a stop on piston but its pretty easy to see by eye down the hole when it stops.
first time distributor did not fit at all.  checked old distributor with my vernier and sure enough it was bigger around on the machined surface than the last one.  i removed o ring and carefull sanded id down to match the old distributor.  blew it off with air.  put o ring back on.  lubricated it with engine oil.  now it drops right down to where the gear and oil pump drive have to mesh and drop all the way down.  won't do it.  ive been carefully turning the oil pump drive with a long 5/16" ratched with long extension on it.  what a pain.  i assume this must be my last problem.  it can be frustrating to do on the chevys as well.  just so far cant get them to go together.  all the lengths are the same and gear pitch and number of teeth on the gears are the same.  i'll keep working on it but the other one still drops right in.
The stock canister is not adjustable, you'll have to get an aftermarket one. To bring it up on TDC pull #1 plug out, rotate the motor with your finger on the hole, when you feel pressure on your finger you're coming up on #1, now line up your timing marks at 0 on the tab, to find "absolute" TDC you'll need a piston stop.
kerryann
i completely understand that, i didnt think the stock canister was adjustable with an allen wrench like the crane.  if it is that will be easy.  if not im not exactly sure yet the best way to modify the vacuum advance limit.
also, there is no easy way to find TDC on cylinder one without pulling valve cover is there?  im in the process of pulling the valve cover to watch the valves so i know im at the top of the intake stroke.
Like I said you won't know until you try it. Again, vacuum advance has nothing to do with the initial or total, the vacuum advances beyond the total at cruise when the vacuum is up, if it rattles at cruise(full vacuum)then adjust the canister so it won't pull all the way, you back it off a little at a time until the rattle goes away, your total is still going to be the same on the centrifugal.
kerryann
crane also suggests sticking with stiffer advance springs due to the increasingly worse and worse gasoline.  i think some of my issue may be that i wasnt winding the car up to 4500 or so where they say full advance comes in with the very stiff spring.  may have been missing the boat altogether and actually had more total at high speed.  either way i will get it straightened out.  would like to see full advance a little sooner.  not sure i can go right to full advance by 2500 with regular gas.  if i get up to 15 or more initial i assume im going to have to greatly limit the vacuum advance to stop pinging.  id rather have a lower initial so that the overlap of vacuum advance puts it in a good spot.  we'll see, going to pick up new distributor now.
This has been explained in previous posts, lol, but you're getting the idea..
Every application is different you won't know until you try it, that's the reason for adjustability. BTW, nothing wrong with 15 initial.
kerryann
ok that is what i am after, with 36 total i dont want to have 15 initial like what happens currently.  there is also a thin bushing on the stop that i know i could have removed.  but its irrelevant now that i need to put in a new distributor.  im going to take the new one apart and verify whats in it first.
doing some more reading last night i found this interesting as well.
http://static.summitracing.com/global/images/instructions/crn-271e.pdf
these are instructions for the crane adjustable vacuum advance canister for fords.  heres the last paragraphs:
The curve you have achieved is designed to give you the best economy and performance.
In general, cars and trucks originally equipped with Ford Electronic distributors will be able to use a total advance of 45° to 55°. Some factors may limit the amount of total ignition timing your vehicle can use. These factors are increased compression, declining octane rating of gasoline, certain intake manifolds that will not tolerate increased ignition timing, lock-up torque converters, extremely heavy loads, and lean fuel mixture.
can you really get away with this much total on regular gas?
Quote from: kerryann on May 03, 2014, 09:42:52 PM
how will the long slot give less initial timing than the short?  i thought these slots were just limits on total timing.  and i thought the numbers stamped on them represented half of the number of total mechanical advance.  initial you set by turning the distributor until you get it where you want it correct?  then a 21R slot would allow the distributor to advance another 42 degrees (2x21).  Am I wrong here?  this is starting too seem too confusing.
I also noticed there's not much support for springs for ford distributors.  the mr. gasket kit only gives you one set of springs.
The total is the same regardless of the slot, it's the amount of travel. As an example say you have 36 total and 16 initial with a short slot, with the long slot you would still have 36 total but the initial may only be 12, if you widen the slot on the return side initial will drop more.
kerryann
ok i understand that distributor turns at half of crank rotation, so 21R should be giving me 42 degrees at the crank, just not sure why this wasn't happening.  springs were plenty stiff enough to pull weights back to the end of the slot.  any chance the springs would ever be too stiff to allow the full centrifugal advance?  since the stock distributor is now broke, i'll see what i can get with the reman.
can this type of ignition be statically timed with the ignition on?  i figure im going to have to get #1 at TDC and just get the rotor to point at #1 plug wire, then put a little advance in and see where im at.
kerryann
You only need the single the dual was for smog, the long slot will give you less initial than the short one.
kerryann
got a new distributor coming in the morning.  destroyed the old distributor trying to get to the advance plates.  last screw to take the plate off that holds the pickup wouldnt budge.  tried using as much finesse as possible but it still cracked.  then snapped off both bolts for the vacuum advance.  hoping these remans will last more than a few months.
now im really confused.  the advance plate was on the 21R slot.  this would mean 42 degrees of mechanical advance correct?  the other slot is 16R.  says 21L and 16L on the bottom when you flip it over.  has one lighter weight pink spring and one heavier red spring.
How am i only seeing about 20-21 degrees advance on the 21R slot?  I have no idea what will come in my new distributor tomorrow but im saving this piece with 21 and 16 just in case.  Are these truly half the advance numbers?  just seems very strange that 21R gives me 20-21 degrees advance even though it should be giving me 42.  i forgot to mark my rotor positioning also so might have a fun time trying to get the new distributor in the right spot.
i also ordered the single vacuum distributor, not the dual vacuum.  not sure if that was the right thing to do or not.
The engine revs a good 500 rpm more at 60-70 mph than a V-8 and normal.
$20 carb huh? It becomes clear and I'da done that for only $20 too. Price rules (right Dianne? please put down that brick.......).
I used to strip and toss solenoids and dashpots off everything, I wish I had kept a few. Them things come in handy for specific issues and expensive as heck now. If you can even find the particular one you need.
kerryann
good to hear on the 8"  i thought for sure we were going to have to cut the driveshaft or find a longer one.  what do you guys think of a 3.40 gear for the street?  we currently have a 3.08.  a friend of mine swears that that was the way to go on these cars and that he got the best mileage letting these little motors wind up into the power band a little more.  that was a long time back from the days of non ethanol fuel as well though.
8" rear end is a direct bolt in. Pinto backing plates / brake drums / drive shaft, all work as is. Couldn't be easyer.
