95 2.3l short block
Date: 03/18/2017 04:54 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
1972 Pinto for sale
Date: 05/19/2021 12:41 am
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Hatch needed
Date: 09/10/2017 09:16 pm
postal pinto
Date: 06/03/2020 09:31 am
McLeod Clutch
Date: 04/12/2017 12:08 pm
72 Pinto
Date: 03/07/2019 12:07 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
  • Online today: 506
  • Guests: 246
  • Total: 246
Flat spot with Holley 350 carb
Started by kerryann, April 17, 2014, 07:31:40 PM
Quote from: dick1172762 on May 16, 2014, 09:35:26 AM
     ART! Does that tool also work to remove the rocker arms?
Yes it does both jobs, check out my thread I started yesterday there's a pic.
The idle feed restriction is actually slightly misnamed, it should be called the OFF idle feed restriction, it regulates fuel to the transfers which should really not be supplying idle fuel. The curb idle or mixture screw cuts into that metered amount to meter it even lower for pure idle alone. As soon as you go to anything above dead idle the bigger pressed in restriction comes into use.
http://books.google.com/books?id=_fTHcnYMyywC&pg=PA13&lpg=PA13&dq=holley+carb+idle+feed&source=bl&ots=XFvtN-qh7h&sig=Cp0I6_lPOu09gGG1KVFjqqED4J0&hl=en&sa=X&ei=zsR1U7ejGYGRqgbs3YKIDQ&ved=0CGcQ6AEwBg#v=onepage&q=holley%20carb%20idle%20feed&f=false
Look close at the pics and the idle system split that occurs at the mixture screw. Also shows (just barely) the holes you drill in butterflies to keep the transfer slot and butterfly in correct position.
If the carb has a 'reverse' idle system then the transfer and curb idle fuel is the same degree of richness (screw meters air not fuel in that case) unlike the standard system which can be different from each other.
ART! I want one too.(spring compressor)
Yep, you need a spacer but at that price I'll just make my own, those manuals always leave the important stuff out, the Ford manual tells how but it's kinda self explanatory when you pop the valve cover and have the tool. There's different style tools but I like this one since I can use my ratchet in any position that's convenient for space, I'm about to start on mine now.
kerryann
i always preferred the center pull slide carburetors on the old jap bikes.  my vacuum carbs on my yamaha xs650 are a pain and have worn out throttle shafts that make tuning a nightmare.  the vacuum carbs on my cb350 work fine though.  set the center pull carbs on my sister's cb175 twin years ago and haven't even had to touch them since.
74 pinto wagon, i haven't read if theres a section on valve seals in my pinto manual, forget if its clymer or chilton's.  is there a step by step on doing those somewhere?  friend has a chevy small block style spring compressor, not sure whats needed for these little motors.
also the efi intake has a 4 barrel type plenum correct? with an odd bolt pattern.  how can i adapt (easily) the two barrel to bolt up to it?  or do i have to use the tig welder and bridgeport and make my own?
it very well could be guides, this is a stock ford motor, not a rebuild.  has 42k original miles, did a lot of sitting over the years.  can't really tell how loose guides are without taking springs off though correct?
Quote from: amc49 on May 13, 2014, 08:55:15 PM
the true feed restriction is the mixture screw.
It's only part of it and a lot of times it needs more, be surprised what happens when you change the hole size..
Sure the guides not dead? New motor in no way guarantees tight guides. If seals came in a budget all-in-one rebuild kit then often they cook way too early, often made from crap rubber.
Open exhaust=open header, I  figured you were cruising the dirt track 4 cylinder carb threads..........no matter, if their tune setups don't work you still dump the pony quick and go your own way. I've never followed any setup ever and had the jetting and other carb parameters be exactly as on the example. Even the area of the country you are in can affect that, I noticed on CV type carbs on my old CBF bike that I could run low restriction foam air filters with no issue but everybody else having hell with carbs not working right, big flat spots, I traced it eventually to geographic area that the user was in, upper north had more trouble, the bike was that sensitive to the CVs being messed with. If case you don't know, CV type carbs are another whole planet, they do not work at all like direct opening type carb (what cars use). Ford made one once, the variable venturi 2 bbl., most people do not understand them and dump them with any trouble at all. I've got one laying around and played with the idea of putting it on a Pinto. It should help the low and mid but probably limit top end, what CVs generally do. Kendig (later the Predator carb) made a big one, 900+ cfm for race cars. We had one on a 440 GTX and the word stump puller was made for that combo. No carb tuning parts needed at all, you adjusted the A/F with a simple cam/ramp adjustment on them.
Some Holley idle feed restrictions are buried in  uplegs in the metering block, you can't get to them. They are purposed slightly too big anyway, the true feed restriction is the mixture screw.
Lower EFI intake is the way to go got mine on E-Gay. Valve seals are easy gonna do mine this week as soon as this frikkin wind stops since I have to do it outside.
kerryann
not sure what you're referring to when you say open exhaust.  the threads i found of other people's jetting and power valve selection were on this forum on street cars.  open exhaust to me is no muffler.  we have the header and were running a single cheap turbo muffler and stock pipe size to the back, think it was a hair under 2".  No catalytic converters.  next time around i think i will go to a larger diameter exhaust.  really looking to go to a better intake but not sure which one to look for.  seen offenhauser, spearco, and some others, not sure what the best one to get would be.  don't really want to go to 4 barrel just because i have the 2 barrel already working.
couldn't find any 61 jets, going to order some.  i've noticed the car is in need a valve seals.  either that or the guides are really worn but the motor only has 42k on it.  how hard of a job is changing seals on these motors?
Don't live in no vacuum, learn everyday, nothing new about converting to 4 corner idle either. And BTW, metering blocks also have idle feed restriction that can be tuned.. :D
LOL, I know but...............
'Just thought someone has wondered about that in the past. '
Surely you guys don't live in a vacuum. The learning never stops. And can lead to you even figuring out a simple 2 bbl. Look at how many 302 freaks are here as well........
I built 4 corner idle Holleys before they were offered by Holley...............you drill the idle air bigger and block the grooves that run front to back in the base plate to sever the two circuits. Drag racing ATX cars liked them better, the response when the secondaries dump open was better.
If idle to wide open is fine leave the pump alone and jet richer. You were comparing the usual jetting with other cars, they have open exhaust, you may need more jet since closed exhaust makes carb signal pull less. Go with what your car tells you, often that may fly in the face of what others are doing.
If carb is manual choked with cable you can roughly replicate bigger jet by partially closing choke to increase booster pull, same as increasing jet.
FYI, the outboard idle air feeds in top of carb are bigger in front of all Holleys because of the idle mixture screw in the metering block, the screw sets the restriction there instead of the top air hole. The back barrel holes are small since they are the limits there. Only on 4 corner setting idle carbs do they get bigger like the fronts. Just thought someone has wondered about that in the past.
kerryann
left the 7.5 power valve in it but went to 31 squirter and 59 jets (two sizes up from 57).  flat spot didnt go away but got better.  once hot it no longer has a dead flat spot but more of spot where it pulls a little weak then recovers.  this is a check ball accelerator pump vs the newer rubber plug pump. id like to try the newer style rubber plug if i can find a center hung bowl that has this style in my pile of holley parts.  not sure if it will make much difference though.
pretty sure there is just an issue getting off idle circuit to main circuit.  don't think i have a power valve issue, idle to WOT is fine, just transition under light throttle is weak.  stock jetting for this carb is 61.  since going to 59s improved it i think i should probably keep going and see what happens.  problem is i dont have any higher jets than 59 until about 66.  gotta try and track some down to borrow in case it's the wrong direction to go. making progress though.  been putting some miles on it.
You can move the idle speed screw a LITTLE bit, just not much. Any more and you start looking to drill holes in butterflies to let more air pass. Or rig like I've done before-use like V-8 PCV valve with bigger opening to let more air butt or aquarium air valves for aquarium air pumps, run vacuum line and then through air valve, then you have a variable air leak you can easily tune with.
Quote from: dick1172762 on May 10, 2014, 05:36:26 PM
ART! See why I'm using a Autolite / Motorcraft.
Yep, that's why I'm looking for one myself.. :D
Best thing would be to put it back to the way it was out of the box and start over, at the bottom of the page of the instruction manual pick your list number for the specs.
kerryann
looks like i have the right gasket.  maybe i have to jet up.  kind of at a loss here.  i don't see any real suspect issues.
Here's the right gasket for 2300. Slot almost all covered is good..
http://www.holley.com/108-91-2.asp
Maybe this might be of interest too.
http://www.holley.com/data/Products/Technical/199R7950-7rev7.pdf
kerryann
almost forgot i took pictures too
kerryann
did some disassembly.  all ports seem to be clean and flow air.
One thing i have stumbled upon is that the gasket im using does not have a hole in it for the outside (larger) air bleeds in the main body.  this is a trick kit gasket and im running out of all the different variations.  i could have swore that this was a direct match to the old crusty one i took out when i rebuilt it but i could be wrong.  Should this air bleed passage have a hole in the gasket on each side? the kits i see for the holley 350 on ebay do not have this hole in the gasket.  and again im almost certain that i matched up the gasket with the one that came out perfectly
also the slots are completely covered just barely.  nothing showing.
Sounds like you could have clogged up passages wouldn't hurt to clean them out, you want the least amount of transfer slot exposed as possible.
kerryann
i currently have a 7.5 in it.  had 5.5 to start and then 6.5 and none of them had any effect on this stumble.  i was concered that at light throttle acceleration that vacuum drops down to 5"  thats opening the power valve circuit and could be too much?  especially since there is no hesitation when throttle is flat footed wide open.  the car starts to pull from idle (13") to maybe 1/4-1/3 throttle (13" down to about 5") then at a certain degree of throttle opening or sooner if on a hill it drops under 5" and goes right to 0" and flattens right, recovers and you start to see about 2-3" vacuum on the gauge as it climbs in rpm.
since its so early it must be an idle passage/mixture problem.  im going to try and clean it and set the blades right.  barely visible transition slot to about .020" is correct right?  and after that you can't really play with the throttle screw correct?
Quote from: kerryann on May 09, 2014, 09:36:08 PM
some squirters have little brass nozzles that direct the fuel a little closer to the booster vs just the drilled orifice.  they give you both types of each number with the trick kit.  theres a third kind called anti pullover squirters but theyre for spread bores
Ok, you're talking tube type and they don't really mean much it's the volume(hole size), the number on them is the hole size in thousands, and big is not always good you can get the same effect from too much fuel, I always start small and drill them one size at a time until the stumble goes away, but if it stumbles without whacking the throttle then you have other issues, it could be the power valve, the number on them tells the amount of vacuum it takes to hold them closed, so whatever your vacuum is at idle you want the next number that it will hold it closed, so say you have 15in of vacuum you don't want one that won't open till 5in, that will take too long for it to open and you'll get a stumble.
