99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 09/26/2019 05:31 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 07/04/2017 03:26 pm
KYB shocks
Date: 02/08/2017 07:09 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Date: 07/17/2019 05:23 pm
  • Online today: 506
  • Guests: 252
  • Total: 252
Flat spot with Holley 350 carb
Started by kerryann, April 17, 2014, 07:31:40 PM
Good deal.
The power valve plug is ONLY FOR TESTING, I NEVER advocate leaving them out FYI. A major mistake, leaving it out severely curtails your tuning options and always compromises the carb setup. You plug only to do low speed easy driving to determine your idle, off-idle and cruise setups.
I personally never use any gap in pump cam, I want it on as instantly as I can get it, regardless of what the carb or the car. You will always have a spot in there where suddenly opening the throttle will drop vacuum unless very slowly doing it, the lag in pump shot just adds to any potential flat spot. Most of my experience though was with ball check valve in pump and not much with the silicone valve, the slight gap may be necessary to stop silicone valve from feeding as fuel bowl warms to hot. In my view the ball check taking a millisecond to seal made up for the gap so I didn't set with a gap. Any weight under shooter means less or no gap either. Again, takes time to override the weight.
You may be right with manifold vacuum, I've run into that as well vs. ported. Go by the engine and screw all the theory. Believe what your eyes and ears show you. Ported vacuum was developed simply to kill vacuum at idle to kill NOx emission, NOx raises greatly at any timing before TDC. Old emissions passing trick if failing NOx, you back timing down, car runs like crap of course, pass test and bring it back up again. Backing it down makes HC go up (when tuning the two always go opposite each other) but it can be brought down other ways. Try like 10 and 34-36, higher at idle helps any flat spots provided it doesn't ping. Your vac advance unit may determine your range. Since you're after curing a flat spot then set at idle and let top end power suffer if needed till you sort the flat spot out.
kerryann
thinking about it further i think the the transfer slots being open too much may be an issue here.  im going to check that first.
kerryann
it is the stock 1980 intake, not sure exactly which one it is.
i havent tried any different plugs yet.  it could probably stand a heat range colder
i welded up the factory ports on the header so cant do air/fuel unless i added a bung, didnt think id have to be that precise going by rough suggested guidelines for this swap that i read on this forum.
ive never had any luck with the power valve blocker on street cars, only on circle track stuff,  i see what youre saying though.  i will try setting idle screws with the vacuum gauge.  i did it starting at 1 1/2 (factory recomendation) and listened for increase in rpm,  seemed to like around 1 1/4,  i'll verify with the gauge this time.  would you ever this small of an engine like more than the 1 1/2 turns out?
i always tend to set idle speed lower than you probably  should, like the lope sound on a v8, im new to the 4 cyl world but always thought they liked a little more idle speed to stop the shake and vibration and make it a little easier on them off idle getting going. this assumption could be wrong.  we have no tach in the car but i could probably borrow a tach dwell.
accelerator pump shot timing has had an effect on the issue,  i suppose i should focus there, havent tried any bigger squirters yet.  tried a bunch of cams in both positions.  a friend thought maybe going to a 50cc pump might help.  ive tried the holley suggested .015" gap, no gap, 1/16" gap, has been best with slight gap right around the suggested .015"
the plugs were in the car when we bought it.  i was planning on replacing them once i got the carb right but i suppose i may need to get a set now to get an accurate reading.  i will check timing as well.  not sure what to set these motors to.  im used to setting total ith the chevy small blocks at 34-36.  i tried ported vacuum as well as manifold vacuum.  seemed better at manifold.  ive had it explained to me before that manifold vacuum is most beneficial to a street driven motor to have the advance at idle to keep temps down, while ported vacuum was an early emissions strategy to keep exhaust temps upand nothing more than that.  with that being said, what is acceptable initial timing if i run manifold vacuum and what is the number im shooting for total?
What intake used there?
Don't mess with the restrictors, if it occurs at low amounts of throttle then you are nowhere near the power valve open. If you can get it to hiccup while sitting in drive then have someone do it while watching the exhaust pipe for any possible puff of black smoke. If concerned about PV opening then plug the hole with commonly available plug and then test for the flaw again, but DON"T PUSH THE ENGINE HARD, you can damage it. It will drive at light load and low throttle though so you can test more. If plugged at least you know it's not PV. You can disable the accel pump as well and SLOWLY ramp rpm up to see if it does it. Which accel pump check valve in the fuel bowl under pump cover, the ball check or a silicone disk type? Has to do with how fast the accel pump activates.
You need to verify the timing, timing slow will make it flat spot. The plugs often cannot be read for a while until they color up, it doesn't happen instantly. Look up very high inside, they begin to color up high where the porcelain meets the steel first. You really need to know idle timing and total full all-out as well. The vacuum advance is closely hooked to that depending on which unit you have, it may or may not need to be manifold vacuum. If less vac adv, you use more initial timing lead if more vac adv you need less lead, the two are hooked together and have to add up to make sense on the total, why you need numbers of all of it. If you don't have enough timing you could easily be working on a carb with nothing wrong with it.
Leaving carb where it is idle setscrew wise, pull the carb and look underneath to see how far up on the slots the throttle plates are, you are only supposed to be either just barely exposing the bottom of the slot or maybe .020" or so, if higher you are too rich then it goes super lean when you run out of transfer slot, think of it as mini-accelerator pump until both the shooter gets working. You don't have the mixture screws very far open which leads to believing  possibly too far up in the slot, a common mistake. The mixture screws are not set by turn amount, rather by vacuum, one may end up different from the other but if too far one circuit is clogged.
If truly right off idle most likely the transfer slots are too exposed. Drop the idle speed back down too low to get the slots right (while carb is off) and just test to see if the flat disappears, you can bring up idle speed in other ways later.
You can adjust pump cam to have a big space and then none at all and take careful note of what changes. Or bigger shooter vs. smaller and the same. The vacuum gauge WILL drop when the motor dies, normal, an effect not the cause.
If the exhaust manifold has an O2 port you can put an O2 in there to tell if rich/lean by using an A/F ratio gauge.
jeremysdad
That insulator looks cracked...have you tried a heat range colder?
Thanks for all the good info! Someone better versed in the 2.3 will be along shortly.
Welcome aboard! :)
kerryann
another picture
kerryann
hi, we have a 1980 pinto, 2.3, automatic.  42k original miles.  i did the holley 350 swap and also the ranger header.  we have the aluminum ford carb spacer under the carb and we also used the racer walsh power valve restrictors.  i read that good baseline jetting is 56-58, we went with 57 since i didnt have any 56s.  started with a 5.5 power valve as that was what i read to have the most success with this combo.  we have a flat spot off of idle through the mid range.  most noticeable when you ease into the throttle vs flat footing it from a stop,  once its on the main circuit it recovers and runs smooth.  the plugs are clean with slight white residue indicating we are pretty lean.  i tried many different pump cams and now have the orange in position 2 which gives quite a bit of pump shot and long duration.  went with a 25 squirter with the extensions to try and lengthen pump shot as well.  have idle mix screws set to 1 1/4 turn out.  i played with the accelerator pump timing and air gap on the lever, it helped initially but cant cure it.  we went to a 6.5 power valve to no avail and now today went to a 7.5.  no change.  ive attached a vacuum gauge, we have 15" in drive with brake on with motor hot.  this would indicate the 7.5 is right on the money.  driving around with the gauge i notice the flat spot occurs at part throttle once vacuum drops just about to zero, the car seems to flatten out and then recover. it is driveable but it bothers me that its not right.  im worried that the racer walsh restrictors are cutting the mid range fuel flow too much, i dont want to drill them and be stuck if it wasnt the right thing to do.  they will be fairly difficult to get back out as well. when installing i drilled the metering block, cleaned out burrs, and blew out chips with air.  we then pressed the inserts all the way in until they stopped.  hoping that was the right thing to do.  if anyone can help please let me know.
also vacuum advance is on full manifold vacuum, both catalytic converters are removed, smog pump is removed, pcv is hooked to port on the spacer.  valve cover has only a breather.  the kick down works as i should as well.  the only thing i have not done is put a timing light on it.  i have no reason to believe the timing is off as the car ran fine in stock configuration with the weber but it is worth checking.  ive attached some pictures of one of the plugs for reference.
