1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 08/13/2018 02:46 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
Date: 10/26/2020 03:24 pm
Crane Cam
Date: 02/26/2018 07:50 am
76 drivers fender
Date: 07/20/2018 08:24 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
  • Online today: 506
  • Guests: 132
  • Total: 132
Flat spot with Holley 350 carb
Started by kerryann, April 17, 2014, 07:31:40 PM
kerryann
im actually only 27 years old.  nowhere near old enough to have enough experience or have gone through the learning experience most others on here probably have with the old american made stuff.  the pinto is my girl friend's car (that's why the name kerryann).  The car and all the technology used here was made long before we were born.  It's also the newest vehicle we own, and we have many cars and trucks.
Hope I havent come across the wrong way to anybody.  we got this holley 350 for $20 at a swap meet after reading peoples experiences with the swap on this forum.  wanted to see if i could make it work.  it's been a fun project so far.  fairly simple and purely mechanical which is what i like.  think i am on the right track now, just have to put the time in.  we work on this one outside and weather up here in new england has been awful, hopefully it warms up soon.
As far as the 8" rear, im sure it wont be a bolt in, but i dont mind chopping the mounts and moving them.  fabrication is another aspect of the hot rodding hobby i really enjoy.  supposed to end up with 3 mini stock 8" rears out of pintos and the one from the mustang II all for under $100 so i'll see what i can come up with from the pile.
Well, I'm not quite that young, LOL... Well, I've always known them to be called dash pots even the dealers called them that, back in the 70's we ran a tunnelram on the Altered for a while and the damn thing would never shut down right away so we put one of them on end of problem, I used them on a lot of vehicles after that they work great..
http://www.autozone.com/autozone/parts/Duralast-Dashpot/_/N-8ve9e?itemIdentifier=615831_0_0_
Oh, and you took that rather well, most young people now will get all in your face over the slightest perceived slight, not that I was trying to, as I was not. And not that I know how old you are either. Just like to give credit where due. So hard to find people who don't freak out over every little thing now................the people here onsite are by and large quite reserved I've noticed. I probably fly off the handle more than most of them (not my better side unfortunately).
Actually dashpot more accurately describes the rubber damper that just slows down throttle falloff for decel emissions or to stop stalling at throttle rolloff. But yes I have heard the term bandied about. How about 'sol-a-dash' or combination solenoid AND dashpot? Ain't heard that one in a while.
Those are called dash pots, I love them things..
FYI, you can run a simple manual choke cable easily to the 5200, I drove one like that for years.
Thinking the leaves on M II rear are different width than Pinto, could be wrong. Affects mounting pads. I had one around for a while, considering using it until looked at that. Rear won't be 8" if 6 or 4, rather the 6 3/4" one. Someone will jump in to correct me..................
BTW I made good use of a solenoid on the throttle that dropped the idle speed setting to completely closed throttle when key cut off. I had no pinging but the very dickens with after running (dieseling) after motor killed.
Don't worry about initial total is critical, run the total as close to 36 as you can go before it pings(no vacuum), if you can't go any more than 27 total before it pings then you'll have to run better gas, either that or you're running very lean now??. Have you read the plugs after a good run??..
kerryann
understood.  but pinging hasnt popped up until i got greedy trying to get close to 34-36 total.  if i back initial down to 6-8, it goes away but my total suffers (around 26-27).  haven't changed vacuum advance at all yet.  i would like to limit it as talked about before.  if there any way to know that youre close to a reasonable range of vacuum + initial by checking initial timing in park with vacuum advance hooked up?  or even in drive at idle with someone else holding foot on the brake so im able to check my initial timing?  im sure i can limit vacuum, but how much is too much?
this is my first 4 banger ive tuned.  spent a lot of time over the years with holleys on small block v8s.  yes carbs with smaller primaries like edelbrocks, rochesters, carters, etc might get better gas mileage but ive never been able to match performance.  i persoanlly hate the edelbrocks, just good for cruising around.  im pretty good with the rochester 2 barrels just because i have to be for some of the circle track classes ive run.  as far as holleys, most people just instantly go for a holley that's too big.  the best combo ive used on a chevy 350 is a 450 cfm holley mech secondary 4 barrel carb with no secondary accelerator pump (non double pumper).  it required swapping to a 1850 model 650 metering block to get the right fuel curve.  that carb was dead reliable and could hit full throttle from any rpm, dead stop to 3/4 throttle cruise with no hesitation or flat spot at all.  cruised and drag raced with it.  got very good mileage for a 350 v8.  i like tuning and having all the small parts interchangeable.  only thing that kills them is throttle shaft bushing wear.  once they are worn they will never perform right.  there are a lot of ill performing holleys driving around but when they are right they work.
that being said, i know there is nothing wrong with the factory carbs.  i wanted to clean the car up, get rid of the 1980 vacuum mess, and use something im familiar with.  we now have a header, no catalytic converters (took out two) and no smog pump.  wasnt sure what small parts id have to buy to rejet if necessary or tune the stock weber.  some of these old carbs like rochesters can be a pain to get the small parts for and for me to be satisfied with the weber i would have had to eliminate all fast idle, choke, or any other annoying automatic mouse traps on it.  i warm my cars up with my foot in the colder months.  can't stand something that chooses rpm for me or locks out my throttle blades.  no offense to anyone on carb preference but i was just intrigued on here with the success people have had with the 350 holley.  so far i am pretty happy with it.  the stock weber is still sitting around but i doubt i'll try and go back.  i supposed if i get a spare moment i'll do some investigation and figure out where the issue with it is.
im more interested in getting a better flowing intake now.  and i may also switch to an 8" rear that a friend has out of a mustang II to go from 3.08 in the little 7.5 to a 3.40.
i type too long of posts haha, thanks for all the help, all opinions and ideas are much appreciated, this is one of the most helpful forums ive been on so far.  i will report back once i make some progress on this thing.
X2..........
'holleys are all pretty much the same and the easiest to work with............'
I for one do not agree, if you truly understand how a Holley works then you already understand how others work as well, it becomes simply a take-it-apart-and-see-how-they-do-it exercise after that. The 32/36 is mucho more adjustable than the Holley and dead reliable. It will get better mileage too. The flat spot here may well be Holley induced, or the difference between calling one booster online vs two, four cylinders will initiate flow faster at a single venturi than two of them.
Start simply switching metering blocks out on Holleys and quickly find out about how they are 'all pretty much the same'................taint so. I've certainly straightened out enough of them that were butchered by so-called 'experts'. Correct metering block on carb is check #1, you'd be amazed how many mess up a block and swap wrong one to have the carb go to crap, then they cannot figure out what's wrong. Or piece one carb together from five then want $150 for junk. If numbers don't match I don't touch them, a waste of time. Having a Holley on it is much more likely to run into trouble later, they always want to screw with it. The other brands highly likely to have a virgin carb, they are scared of them. You have no idea how many Holley sales I stifled back in the day by simply changing or fixing a $20 issue on a carb the person was afraid of. They always wanted to 'put a Holley on it' (sound familiar?), much of the time they realized later it was a mistake. Holleys never get as good mileage as OEM carbs, they are metered rich for performance and utterly destroy emissions levels. When they insisted I always added 'keep the old carb!', often it went back on the car.
Holleys are great for power but almost nothing can repeat the driveability of an OEM carb in proper working order on almost every vehicle out there. They don't spend millions in carb/engine research for nothing there.
The initial won't help the pinging, if it only pings at cruise you need to limit the vacuum advance. First thing you need to do is set the centrifugal vacuum is last, get the right curve and set the total where you want it, drive it without vacuum hooked up, it shouldn't rattle through the rpm range if it does you'll have to back it down some, after it's right then set your vacuum advance.
kerryann
hey thanks for those links, thats exactly what i needed.  going to fine tune the centrifugal advance next chance i get.  should solve my timing problem.  the car must be set on 10L right now, or have a problem there thats not allowing it to fully advance.  i'll worry about the speed that it all comes in at after.  the pinging should go away if i can limit the initial.
im never going back to that 36/32 carb. still have it sitting in the basement if someone is interested in one.  car was undriveable with it.  i know they can be fixed.  just don't want to learn those carbs, don't care for the dozens of vacuum lines everywhere either.  holleys are all pretty much the same and the easiest to work with.  flat spot is just about gone.  i'll get back on that issue as soon as im happy with my timing curve.  might be on the hunt for a better intake soon as well.  thanks for all the help so far.
IIRC used to be Ford and GM used different advance springs. Mr. Gasket made a set of earlier curve ones for each. We used the GM ones on AMCs since the distributor was a GM Delco-Remy one.
Quote from: kerryann on April 28, 2014, 09:48:17 PM
i'll try and find a tach and see when im getting total in.  if i need to change can you use the different color springs like crane sells for the chevys?  not sure if the ford is a different size,  already have some if the chevy springs fit.
im all for altering what i have.  im sure i can limit the vacuum easy enough.  if i set this thing at 36 total, what is an acceptable range for initial?  i was told 10 earlier in this thread.  i just can't do that without modification. that's 26 degrees centrifugal advance. i'll alter the weights/stop if i have to, just curious if its even necessary if some of you are running a very high initial without issue.
Check the advance slot if you're on the narrow one rotate it to the wide one, if you're on the wide one grind a little don't take much though to make a difference. Don't remember about the springs just take one off and compare them. I just bought a reman Duraspark for mine and it's out to lunch, my initial is 18 and all I get is 32, gotta dig into that soon..
AT this point, you would be better off going back to the stock 36/32 carb unless you just want all these problems.
kerryann
You should be at 36 get yourself an adjustable canister or one with a shorter slot. BTW, what rpm does your total come in?? it should be all in by 2700-2800...
kerryann
it is pinging very little.  just frustrated that my total is only at 32 and initial is at 11.  i figured if a lower static centrifugal number could be achieved, when combined with vacuum it might not ping then but still advance to 34-36 range which ive been told is optimum with these motors.  i can bump the timing back to 8 or so initial and probably be all set but then my total is back to 29 or so.
I got the lower EFI intake seems like the one to use. Changing the centrifugal will not change the vacuum advance, you need to limit the travel of the vacuum unit that's why you get adjustable ones, or one that has less travel, if it's pinging very little you could back it off a degree and try it don't take much sometimes.
kerryann
74 pintowagon which intake are you going to use?
i do have what i think is a slight ping rattle at light cruise, especially up a small grade so i think i may need to either limit vacuum advance or increase my centrifugal range higher than 21 degrees.
Quote from: amc49 on April 28, 2014, 02:01:38 AM
How do they feel here about copyrighted material from a company that is still in business? Some places get pretty uptight about it, you can be sued over it. I see this in the onsite registration agreement...........they refuse responsibility in the standard disclaimer and put it all on me, don't really wanna go there.
'You also agree not to post any copyrighted material unless you own the copyright or you have written consent from the owner of the copyrighted material.'
I do see some stuff in the onsite articles from Car Craft and Hot Rod. Is Car Craft magazine still around?
Yep they're still around, if articles are on the net and you can copy/paste than it's not copyrighted anymore, you see articles pasted on every board around, every time I run across something copyrighted it won't let me copy it, so far I haven't been able to anyhow...
http://www.carcraft.com
Clydesdale80
ok, I hadn't thought about that.  I sure don't want to get anyone in trouble.
Bought a 1978 hatchback to be my first car.
You always have vacuum at at idle that's ok, it idles a lot smoother and the throttle can be closed a lot further exposing less transfer slot. You can get aftermarket canisters that have an adjusting screw and some have a shorter slot to limit the travel, but if it don't rattle at cruise you're ok. I'm new to these little motors so I'm learning this stuff, but just looking at these intakes the lower EFI gotta be way better, already have the intake and header for mine just need the carb, the Autolite I want seems petty hard to find but as soon as I find one I'll be doing the switch, adapter don't look hard to make, already found a chunk in the scrap, er, I mean material bin to make one.
kerryann
74 pinto wagon, i have read that article before, straightened me out on where to run the vacuum.  my only reason for thinking ported may work here is because of the very high advance saw at idle. it's most likely fine under load.  i didnt know if there was adjustable vacuum canisters for the ford distributors. ive used the crane adjustable canisters on the gm distributors and they work well.  i still feel as though i may need a bigger range of centrifugal advance.  i only get 21 degrees out of it.  to get 36 total that gives me an initial timing of 15 degrees.  Should i grind the weight or look for a different set?
After reading about some other distributors on the early models, a 1980 2.3 wouldn't have a timing retard port on it would it?  i only see one vacuum port and it definitely advances the distributor.
As far as the intake and carb, i only switched to the holley 350 for ease of use.  Wasn't so much concerned with increasing hp.  The stock weber is an octopus of vacuum lines and it kept sticking throttle position at half to 3/4.  Must have been some fast idle setting issue or something wearing out, but wouldnt go away even when warm.  these little cars can be hard to stop at a stop sign on wet pavement when the throttle doesnt return.  that is one thing i cant stand so we just switched to the holley since i already now them inside and out and all tuning parts are readily available.
A 2.0 intake is the way to go?  What about late model intakes off mustangs and rangers?  Isn't the EFI intake a good swap?  I think those use a 4 barrel throttle body but an adapter could be used for the 2 barrel right?
Clydesdale80
Quote from: amc49 on April 26, 2014, 07:36:51 PM
Found what I was looking for-the 350 Holley may well be a moot point.
June 1983 Popular Hot Rodding, '2.3 Liter Ford Power Tricks' article by Dave Vizard.........
The stock 2.3 intake is a bottleneck past about 250-275 cfm carb. He flow tests the stock intake with stock 5200 and then same intake with 350 Holley, both flowed while bolted to a head. The 5200 carb flowed 117 cfm including air filter, the 350 flowed 119.
That's TWO measly cfm for the bigger carb, it doesn't help there at all, the manifold kills it.
The article also shows the Offy plus 390 Holley 4 bbl. does not flow as well as the 2.0 intake with adapter on the 2.3 plus a Holley 2 bbl. Even with the 2.0/2.3 mismatch that occurs there because of different runners.
Does anyone know where to find this article online? If not, would it be possible for you to scan and upload it?  I'm sure many people on this site would find it interesting.  I searched for it but google didn't turn up anything this old.
I did ever thing I could think of to 2.3 intakes and it only made them worse. I welded them, ported them, added dividers, cut-welded-beat-ground and in ever case, it ran the same. Then I talked to a Ford tech who told me that on the dyno it made no difference what carb was used, the 2.3 put out the same HP. Why? Cause that's all the intake would flow. JUNK!!!!
While one of the first things you look for is for the runners to be even, it is more about area. Shorter runners can be slightly bigger in size and have the same area as longer ones with smaller diameters. How Edelbrock made millions with the Torker intakes, the runners were all different sizes. They assured you in every set of instructions that if you matched ports to head you just destroyed the manifold. The engine sees the area more than the length since they are all too short anyway, tuned length has them more like EFI manifolds now, or much longer.
I do not know if the 2.0 intake has different areas in runners or not but Vizard swore by the fact the manifold was also very efficient runner to runner. Like 93% or so. So sometimes appearance can be deceiving. Part of it to me is the much better plenum shape, which just blows a 2.3 plenum all to h-ll. The 2.3 has jagged points sticking out and dead flat with no room to turn at all. EGR plate just makes it worse. Worst of the worst there. The 2 & 3 are even worse, half the port is missing inside the plenum so maybe 2 inches long. All hard angles and calculated to not flow smooth. Airflow loves gradual turns, i.e. the 2.0.
Motors can be funny things, sometimes what looks right is not, that article pointed that out about the stock 2.3 intake as far as just viewing it from the outside. It's a real disaster once you look under the carb and there's no fixing it.
Quote from: jeremysdad on April 26, 2014, 11:07:03 PM
IT IS a pretty good stock intake...but the short 2&3 runners...it should be even...the runners need to be even! :)
i had a manifold that came over from europe (don't know if it was from the UK or Germany) on my 2.0 that had the #'s 1 & 4 runners meet the plenum at the inside (cylinder head side) and the #'s 2 & 3 runners meet the plenum at the outside (fender well side).
made for a more favorable combination of runner lengths.
it was a Ford OE part but from what i haven't a clue.  in my case it did help with fuel distribution issues concerning #'s 1 & 4 running lean at high boost levels.
the occurrence of melted pistons in those holes was darn near eliminated.  prior to the use off this manifold those two rascals were draining my wallet pretty fast!
