Built 2.0
Date: 10/07/2018 05:27 pm
Date: 05/13/2021 05:33 pm
Date: 01/23/2017 07:41 am
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 01/24/2021 07:54 pm
Date: 08/09/2018 11:09 am
Automatic Wagon
Date: 06/14/2019 11:22 pm
TWM Intake
Date: 08/15/2018 08:20 pm
  • Online today: 586
  • Guests: 260
  • Total: 260
New project... 1980 Runabout
Perhaps Dwayne, you're right which is a shame. I couldn't believe it. I thought I was missing the holes so I crawled under the car and saw only two holes. Grabbed my drill and let the self tapping scfews do the work. I also went ahead and used some engine blue paint and it's helped the carpet look better. It's brighter than I'd like but brighter is better than faded. I might go ahead and remove the seats so I can paint the rest of the carpet. It isn't the best match but will be much nicer than faded.
Speedometer cable fully installed, dash cluster reinstalled, and U-joints replaced on the driveshaft. Had an Oops moment and smashed my thumb which caused a mess but it's much tighter than it was before. I am going to pick up a new tailshaft seal for the transmission to make sure it's good. I know it's not original to the car because the transmission was replaced some time in the car's life but I don't know when. Did find I need a new neutral safety switch, as the wires as broke. The original connector is long gone but will figure something out when I decide to replace it. For now it's fine. It wasn't connected for quite a while, and the only issue is I don't have reverse lights.
The only thing I need to do at this point for the car to be mobile is replace that seal, add transmission fluid and gear oil, bleed the brakes as a precaution since I installed a new master cylinder, and that's it. Hopefully all will be well with the car.
I had a goal to take the car to a bootcamp my personal trainer held in 2012 but never got the car drivable. Now she has a bootcamp again, so my goal is to have that car there at that bootcamp.
Sadly, build quality for American cars was at rock bottom during most of the 1970's and '80's.
Dwayne
Electric issue gone. Appears to be a short in the seat belt buckle. Unplugged it and no more blown fuses. It will stay unplugged.
I also replaced the speedometer cable and decided to change rear end fluid. I've never changed it but it seems to be pretty good.
I also installed a new driver door switch so now the light comes on.  Lastly I've found out the poor assembly Ford did in 1980. The parking brake lever cover has four screws. Two never went through the floor. Inexcusable and pathetic. No wonder the carpet wasn't staying under it. Makes me wonder what else they didn't do right
I just LOVE progress!!!  Keep it up, Matt!
I picked up the master cylinder as well as brake fluid and when I got home realized I didn't have a brake bleeding kit, so I got a couple spare lines that I bent I formed to put them in the fluid. Bolted the master cylinder to the car & hooked up the lines to bleed the master cylinder. It was just me so I got smart and used the video option on the cell phone. Pumped the brake pedal until I had no more air and reconnected the brake lines. Didn't bleed the lines on the car but it felt good. I will re-bleed the car later... As in after debris isn't around the car.
I was motivated so I went ahead and installed the wiper motor I bought. Now I have wipers. Next will be installing the speedometer cable I got from the 77, which wasn't that old. Once I do that I can install the instrument cluster and diagnose the issue that keeps blowing fuses when the key is turned to the "on" position. My money is on it being a short in either the parking brake switch, or the seat belt buckle. Process of elimination involves both being unplugged, then plugging them in, while seeing which blows the fuse.
I replaced the parking brake lever, and seat belt buckle so it could be either.
Got the master cylinder. It's been leaking for a while apparently. Crystallized brake fluid and rust at the end. Going to pick up the new one then bench bleed it to make sure I have a good pedal
In another subject I called O'reilly auto parts and they don't have it but can have the master cylinder by 11am eastern. Brake fluid is brake fluid so I might go to Dollar Tree to get a couple bottles of Dot3 for a buck each. Still odd the car has a Honda Civic battery in it but as long as it is still good I will be a happy camper lol.
As long as my mechanical brain doesn't think... "While I am at it let's do this as well  ;D " Master cylinder has been ordered on the car. The rest of the brakes are good and pedal is solid but so was the pedal on a 1994 Ford Taurus which had bottles of brake fluid in the back for the same reason. My dad did not like that car but it got him to work.. Until the body rusted out, transmission started to fail for the second time, engine leaked oil all over the place, electrical gremlins took over, and lost coolant from time to time.
Quote from: r4pinto on July 21, 2017, 06:48:15 AM
Not too much to do, but enough. Got a month to do it & I am on vacation the week of the car show, so I should be OK. This will be the car's first car show of the year & want her to do well.
I think you should be fine, time-wise... and I'm sure she'll do well!
Dwayne
So last week I didn't get the master cylinder due to costs but getting it this weekend. I have my hotel booked for the Ohio Pinto/Maverick meet so it's on. List of the following will get done, starting this weekend:
Brake master cylinder, install new speaker in passenger door, put speaker grills back on doors, paint carpet, install new hatch seal, install u-joints, speedometer cable, and transmission fluid, find short that keeps blowing fuses, re-install dash cluster, install wiper motor & switch.
Quote from: r4pinto on July 14, 2017, 07:31:51 AM
Convinced it's the master cylinder. In stock at AutoZone for $19 so I will get it today.
Sounds like a plan!  Happy wrenching!
So I popped the lid on the master cylinder this morning and the fluid is low. The car has been sitting on jack stands and no sign of leaking at any wheels. I bled the brakes a couple months ago so I will be getting a master cylinder for the car. That's getting done this weekend. Only old hydraulic part is the right front caliper and that was a spare from my 77. Also the metal lines as well. No sign of leaking though. Convinced it's the master cylinder. In stock at AutoZone for $19 so I will get it today.
Unfortunately I haven't been able to even touch the car. Life got in the way in the form of my Dad's Grand Prix that was at my house for three weeks, my Malibu which needed brakes, a trip to Dover Delaware, and a damaged deck on the house. I hope to get back to work on the car soon but at the time it's unknown when that will happen
Hey, Matt.
Any updates?
Hope all is going well.
So I haven't been able to work on the car due to an evil Grand Prix called Christine 3, but I did get a new hatch gasket by  ordering a door seal from a 3 door Focus. Too short but the bulb looks more like the Pinto one, so for now what I will do is use the Focus seal at the top and the existing seal elsewhere. The top was leaking due to wrong seal, so hopefully it'll work  for now. Contrary to popular belief a single Focus 3 door seal WILL NOT work. I also decided while the car is in the air I will be replacing the loose universal joints. They were a bit floppy and one of the caps fell off. No needles fell out which made me concerned of their condition. Rockauto here I come.
Quote from: russosborne on May 13, 2017, 08:34:51 PM
speaking as an electronic tech, that is normally the best way to troubleshoot something. Isolate it to the circuit, then the branch of the circuit, and then down to the actual fault.
Unless you can just see something obvious. :-)
You know it. I love diagnosing auto electrical because I'm good at it. Give me a wiring schematic, digital multimeter, 12 volt test light, and I am a happy camper. One of the first purchases for the car when I bought it in 2013 was the factory Ford Pinto electrical book. It's served me well.
Got the replacement motor and went ahead and ran a wire to ground from the motor. It worked off the car so now I just need to install it. Today I was working on my Dad's Grand Prix all day so I didn't have a chance to work on it. I did go ahead and get a pack of 14 amp fuses so I can diagnose the electrical issue. I am going to start by unplugging both the emergency brake light and the seat belt buckle. I will work on isolating the issue once the fuse doesn't blow
Installed the replacement motor and it doesn't work. Thought to myself... perhaps the switch acted up. So I took the intermittent switch  setup from the 77 and installed it. Didn't fix the issue. The switch turned on the governor but no working motor. Seems I got a defective motor. Ordered a replacement from Oreilly auto parts and it'll be in Thursday. In addition I found the moment you turn the key on the fuse for the warning lights on the instrument cluster blows. I didn't have any other 14 amp fuses so I couldn't further diagnose the issue. It may be the seatbelt buckle, may be the parking brake switch, or may be a wire. Since I had to pull the instrument cluster to swap switches I will also change the speedo cable. The speedo bounced a little, and had the speedo cable from the 77 which I already replaced. We'll see what happens.
Bought a new wheel cylinder from Autozone, and reinstalled the shoes, then adjusted the brakes. At first it was dragging but noticed the adjuster was all the way backed off, so I backed off the parking brake cable adjuster. That was the ticket. Once I did that the adjustment was perfect. I also found a can of medium blue vinyl/fabric paint in the garage. The carpet is badly faded so for now I will use that paint to make it look better. Doesn't look bad in the spots I sprayed.
I also found in theory an early model 3 door Focus door seal will work for the hatch so I bought one off eBay for $15, as well as ordered a wiper motor.
I need to add transmission fluid, as well as charge the battery. I left the passenger door open too much when trying to bleed the brakes it drained the battery.
Once the wiper motor comes in I will hook it up and hopefully be with functional wipers for the first time since I bought the car in 2013.
Quote from: pinto_one on May 01, 2017, 06:56:26 AM
Wow , it blew apart , now that is what I call a huge defect, those suppose to take a ton of pressure, make sure the box did not say made in China ,
It was actually an AutoZone one so probably was . I thought about putting it back together and bleeding it but my concern is if it blew apart that easy then it may be damaged. I don't play around with brakes
Quote from: pinto_one on April 30, 2017, 09:15:49 PM
When you took it apart back then did you change the shoes ? , a long time ago I had a friend of mine do a rear brake job on his mustang , after about a week the brakes did some odd things , have to pump them up for them to work and later found out he by accident swapped the adjusters left to right and right to left , instead of self adjusting they were backing themselves off untel one of the whelk cylinders popped off one end , just check to make sure , they are marked on the ends left and right , hope this help you figure this out , Blaine
No the issue is the whee cylinder blew apart when I was putting the left rear back together. Don't know why it did that but it did so now I have to replace a wheel cylinder I did in November. It was fine before so dunno. As for the shoes they had all of .5 miles on them.
Today I jacked up the car and got cracking. Got the transmission filter and gasket done, as well as the parking brake cable. I was going to take care of the drums but had a wheel cylinder blow out on the left rear. Not sure why but now need a new wheel cylinder to replace the one I replaced in November.
Great that it fits , going to Order one for a spare just in case , got two pintos that I plan on keeping for life and do not want the hassle later if I need one , other parts as well like wheel cylinders , front calipers extra brake hoses , Ball joints etc , i keep also just in case , if it last another forty years I will be 😊
Part number pioneer. Ca5207. At first it seemed the housing was short but when I took it off and put back on it was fine. Nice to know the 80 will stop perfectly. Had an incident with the left rear wheel cylinder so now I need to replace it but once I replace it the car will be good to stop.
The parking brake cable fit good.
Quote from: pinto_one on April 28, 2017, 08:52:11 AM
The brake cable , is that a replaceiment or a universal one , and let us know how well it fits ,  thanks ,  Blaine
Supposed to be a replacement but we shall see. I'll let you guys know how it fits.
