'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 06/07/2018 01:45 am
80 pinto original
Date: 08/04/2019 10:45 am
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Date: 07/17/2018 09:49 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 09/12/2018 12:33 pm
  • Online today: 586
  • Guests: 552
  • Total: 552
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
Quote from: dga57 on April 28, 2017, 01:37:46 AM
Sounds like you have your weekend all planned out, Matt.  Work safe!!!
Dwayne :)
I sure will Dwayne. Four jack stands supporting the car. That way I know she won't fall.
Dwayne :)
Got some packages from Rockauto. Brake drums, parking brake cable, and transmission gasket with filter. Repairs to happen this weekend.
Its just the arm on the motor on the motor itself , its so easy to install the arm in the wrong way .
Thanks for the tip. I'll be sure to remove the arms
When you put the wiper motor back do not put the wiper arms on yet , if you put the linkage on the motor 180 degrees out the rotation of the wiper shaft will reverse and the wiper arm will scratch your cowl to hell when it swings down and not up ,  Ask me how I know  :o
Took the wiper motor off the car. Not too hard to get to. For granted if Ford had any brains back then the cowl would have been removable with the wiper motor and transmission linkage mounted outside the car but can't change the past. Took it apart and the motor smelled of burnt electrical. Bits of burned brush material. And by bits I mean chunks. I will end up ordering a new motor for the car. Was going to go after the old one on my parts car but remembered they were a bit jerky most the time so doubt it was good enough to use b
Thanks I'll keep that in mind. I thought the same thing of the master cylinder which is what was puzzling. Solid pedal with no dropping which doesn't add up to a master cylinder failure. Only time will tell.
Well you have a leg up on it , if the pedal goes to the floor again change the master cylinder,  got a bad one a few years ago and hit the brakes and went down to the floor , pumped a few times and the brakes cam back , after that it would slowly go to the floor , scary,and if you need any carb parts let me know , got a few cores if you want them , I went to EFI a long time ago , later Blaine
I probably could leave the parking brake cable for now, but I'm paranoid. In 2011 the 77 Pinto had a blow out on the freeway due to a failed line, and the 80 had the brake issue. I don't want to drive the car without having that fixed. What has me concerned is the dash light didn't come on. I don't know if the bulb is good and will be checking that since it should have come on when the brakes failed on the 80 in my garage. The left drum will be kept as a spare. It has a little more material but is usable in an emergency. The right is junk. The only original parts is the master cylinder and lines. Oh, and the proportioning valve. Hardware was a newer kit from the 77 parts car, wheel cylinders brand new, RF was from the 77, and LF caliper brand new. Pads came from the 77 but were installed on that car in 2006. Hopefully she will drive ok soon.
Quote from: pinto_one on April 23, 2017, 06:05:03 AM
Oh well, I did not know you changed the carbs , it is common they stick if they sit up for some time , great you got a hand on it running and stoping , have a good one , later Blaine
Thanks. Yeah, the original carb wouldn't even get the car started after I installed the engine from the 77, so I installed the carb from the 77. I spent money rebuilding the carb from the 80 but no luck. It ran great before the fire but after the fire the car wouldn't run when I did the engine swap. Rebuilt the carb after the fire but no go. The choke opened before so just need to adjust it some.
In other news I ordered parts for the car. A new parking brake cable, two drums, and a transmission filter kit. The car has a leaky transmission pan gasket, and while I could probably just use RTV I'm not a fan and would rather do it right. Total cost for all parts is $67 shipped from Rockauto. Love that site. It's keeping my Pinto running. And the collection of magnets I'm getting is an added bonus lol.
Yeah all the hoses are newer hoses with no cracking. I ended up bleeding the entire system and its holding steady so unsure what happened. As for the choke I never adjusted it when I swapped carburetors. The one on the car was from my old 77. The coil is a different setup than what the 80 has so I need to change out coils.
Have you replaced any of your brake hoses , or looked at them , I redone my brake system when I had the engine out for overhaul three years ago , replaced all the hoses when I found one that had cracks and was seeping , replaced everything , lubed the parking brake cable too, I do not want a future problems with brakes when I need them when towing my camper , or like a old Chevrolet when the brakes get wet , you hit the brakes and it goes faster , I also flush all of my cars brake system every four years , you would be surprised how dark the fluid gets over time , as for you choke it may just need a clen and lube on the linkage, if your choke coil does not work check the alternator for output , if it good check the wire the plug on the back of it to terminal marked STA ,  or sater , its white with a black stripe , it is hooked straight to the choke coil , that way it only heats up when the engine is running , hope this little info helps , later Blaine
Well, the car is fighting me. Fires right up and runs but choke needs adjusting, as well as the choke coil installed on it. The choke doesn't open currently. I started the car and moved it but noticed the brake pedal went clear to the floor. Was solid before so gotta find out what is wrong. Pretty sure it's the front since it was the rear reservoir that was dry. Installing the new brake shoes as well as the new right rear wheel cylinder. The left rear wheel cylinder was replaced before I drove the car so it is newer. The right front caliper was swapped from the 77, left front caliper brand new, all hoses newer, and no visible leaks. Aggrivated as all
Brake shoes and the wheel cylinder came in today. This weekend I will install them on the car. If all goes well I will take her on a test drive. Remaining parts needed to be a good driver... Transmission pan gasket, wiper motor, door and hatch seal. Not too much.
Just went on to Rockauto.com and ordered a new wheel cylinder and set of brake shoes. Shoes are a closeout set of riveted Wagners for $6 plus shipping  and the wheel cylinder was the remaining amount. Total cost of $22 shipped versus about $32 in store. I can then take the drums and have them checked. They are probably out of specs but if they can be turned it will be $9 per drum at O'reily Auto. Next will be replacing the leaking transmission pan gasket.
Quote from: r4pinto on April 11, 2017, 07:31:42 AM
With all luck I will be getting her to many car shows this year.
I sure hope so, Matt!  Maybe we'll cross paths somewhere along the way!
Dwayne :)
I did a little work on the car. The battery was going on 6 years old and died. So I found one that would work and installed it. Not the right one but at $20 you can't go wrong. The car fired right up with a few pumps of the pedal. Future plans include transmission pan gasket and filter, wheel cylinder for the right rear, shoes all around, parking brake cables, possibly new drums, and new weatherstripping. Found the hatch leaks water badly, and the driver door seal is shot. I also need to install the correct choke coil. The one on the carb is from a 1977 with blade terminal.
Thanks guys. I'm going to mix some color to match the paint as closely as possible so the original blue is covered up. But that'll be in the spring lol. Mechanical issues first though so she can drive safely.
I recently parked the car back in the garage. Here she sits for the winter. Insurance suspended with comprehensive put on just in case something happens while stored. I didn't disconnect the battery since it's on its way out anyways. She is hibernating until spring time. When it warms up I may go ahead & have the battery load tested to make sure my thinking is correct. At least she looks much better than when I first parked her in the garage. The winter will give me a chance to save up to replace the brake shoes, drums, RR wheel cylinder, and parking brake cables.
When spring comes I want to be able to get all that done and take her to many car shows, including one possibly in Carlisle. I am going to talk to my Dad about that one. I will also replace the front shock absorbers, springs, driver door seal, and hatch seal. I want it to be right for the big unveiling which will be Carlisle. What year is unknown but she will get there some year. At least the fuel system is good and safe after replacing rusted lines and dry rotted hoses before I even tried to start her up.
Make sure to replace the dip stick tube O ring. Seen them leak lots.....
Well today is the last day the Pinto registration is current so I will be putting her in the garage tonight. Not going to register the car until spring and will be suspending the coverage for now and putting comprehensive on it. Until the brake issue is fixed the car cannot be safely driven. Spring time will bring a brake repair, exhaust rework, and transmission service. The pan leaks badly.
Well, keep in touch and we'll all look forward to a renewal of the project in Spring 2017!!!
Dwayne :)
I've given up the battle for now. I am going to call my insurance company and have the coverage suspended. I will then put it back in storage. I have to pay bills & put money in to my Impala to drive it so the Pinto will have to wait until Spring. Parts needed for brakes:
drums, RR wheel cylinder, shoes, parking brake cables. I just don't feel like dealing with trying to fix something that doesn't want to live at the moment
Probably. Which is why I'm cutting the cable. Don't have the money for a new one and tired of issues with the cable.
Had a truck one time. Replaced whole brake system, including E brake cable.
Back brakes did much the same as yours.... turned out the E brake cable was the problem.
Measured up the same as the old OEM one. No idea why it caused a problem. Just put the old one on & was good to go.
May or may not be your problem ?
