Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 07/20/2017 01:23 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 08/13/2018 02:46 pm
Date: 04/12/2017 06:57 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 08/03/2018 09:19 am
Date: 08/17/2022 06:27 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
  • Online today: 586
  • Guests: 530
  • Total: 530
New project... 1980 Runabout
Thanks, me too. It'll be easier to run once the exhaust is on the car so for one the garage won't fill up with exhaust, but two the car won't be so loud. That'll be the easy part. the hard part will be pulling it off the 77 in one piece, then transferring it to the 80. The exhaust on the 80 was some rigged up welded up nightmare that was cut & spliced & crimped I really don't know how it ran decent. Hard to breath with crushed lungs. and the exhaust was so bent I'd think it would have been hard to flow
Glad to hear it's running, keep it up you're just about there. 8) 8)
Thanks Dwayne. I'm thrilled. I had a good pedal before so I know there was no air in the system but there sure is now since I had the caliper fail when I tried to push the piston back in the bore. I will hold on to the old one so when I get a replacement it will go right to the parts store as a core, and then will keep the old 77 caliper as a spare.
Hey, you got her running!!!  Way to go!!!  Smart to make sure she can stop before you make that trip around the corner; definitely don't need an accident at this point!  Keep up the good work - you're almost there!
Pulled the pump off and it was bad. The plunger inside did not function, so no fuel pressure. New pump fixed that problem but new issue. Still no start. I'd pump the pedal and see it barely squirting from one nozzle, and not at all from the other. So knowing the engine ran when it was in the 77 I took the 77's carb and installed it. Took a few squirts of starter fluid  but the car finally ran and stayed running. I couldn't run it too long since it doesn't have any coolant or exhaust but was nice to hear it run. Tomorrow I will install the exhaust from the 77, as well as add coolant so I can set and adjust the timing since I changed the distributor. There were no fuel leaks from what I could tell so it's somewhat mission accomplished.
The brakes need gone through before I even consider driving this car. I knew the RF rotor was bad, but found a bad RF caliper, and brake hose as well. I now need to replace it, and will also be replacing the LF hose. Both were done in 2009 on the 77 so they are good.
I also installed the side marker bulbs from the 77, and will also be seeing if a bad bulb is causing no right tail light. When I say no light, I of course mean the bulb does not function. Tomorrow I will see what I can do about finishing the RF brake assembly, fixing the right tail light, and possibly installing the Kraco radio I have. The Clarion is the one I want in the car but the Kraco was already wired & just needs finished to work. I will worry about swapping later once I'm sure the car runs & drives.
No start still. Found the car is not getting gas to the carb. I've replaced the fuel hoses, and fuel lines but the pump won't put out. It's a different pump than the engine had since the one that was on the engine broke when I installed the line. Replacement seems to not be working. The engine ran like a champ when in the 77 so I know the intermediate shaft was good. Now replacing the pump to see what happens.
Oh well, start over, just like I do, that's why I buy the stuff by the rolls, LOL..
Quote from: russosborne on October 13, 2016, 12:15:03 AM
At least  you are about at the driving stage with this one.
And THAT is a major accomplishment!  Here's to a successful trip around the corner!
Quote from: r4pinto on October 10, 2016, 09:50:13 AM
This car I bought cuz it was a running, driving car with what I thought was a good body, and no rust underneath. I somehow missed a lot underneath and are not happy with myself.
Bottom line is I made a mistake with this car but I will do what I can do to save it. Will I keep it? I don't know. I feel to keep a car I need to have a feeling about it, and it's not there. For granted I had the fire a week after buying it and have yet to drive it but only time will tell after I get the car running and driving.
Matt, are you sure we aren't related?
I did the exact same thing with my Ranchero. Same issues, lots and lots of rust, apparently I knew some was there from reading my old posts, but no way no how did I realize just how bad it was. I think I have built in blinders for some cars.
The engine runs!!!!!! Turns out the engine was 90 degrees out of time. The engine ran great before so I knew it was fine mechanically so I rotated it by hand and found instead of firing on #1 it was #3. The car didn't want to stay running but it was also running out of gas. I set a goal to get her running today and I met it. Tomorrow I will put gas in her, change the RF brake rotor, hook up the exhaust, top off the fluids, and hopefully drive her around the corner.
The car doesn't want to live. So I got the fuel lines routed, connected the vacuum lines, and installed the battery but no luck. Found a bad ground. Also charged up the battery. Cranked but no fire. Found out I forgot to install the rotor button. Got it installed and the car backfired immediately through the carb. Scared the tar out of me since the last time it happened I had a fire on my hands. I got to admit I am a little more paranoid than some might be but after the fire I don't want another.
I'm going to rotate the engine to TDC to see if it's out of time and will also pull the plugs if needed.
Thinking I might get what I can and then use rubber fuel hose to finish it off
Wasn't anywhere close. Unfortunately
Well, as long as your close tweak it by hand.
Yup that's what I'm using. Just having issues with getting the right bend to it.
I use this stuff to make brake/fuel lines it's the easiest stuff there is to use, it flares easy and it can be bent easy by hand for a final fit. Just about all parts store carry it and it's not expensive either.
http://agscompany.com/product-category/brake-fuel-transmission-lines/poly-armour/
Ran into issues with the fuel line from the pump to the carburetor.  I was bending the replacement line but then had a thought. I might be using space that isn't available. Sure enough the line was right where the power steering pump went. So I decided to install the power steering pump on the car. I also got the electrical wires cleaned of any grease & oil, and reinstalled them. I just couldn't leave them the way they were. I've put so much time in the engine compartment I needed to clean the harness. Now I do have a major issue with the alternator connector being long gone thanks to the fire and not being taken care of. For now I will plug it in and tape it up to prevent arcing. Not what I want to do but a harness I have from a 1980 wagon also had a broken connector that was previously siliconed up.
I also ran into an issue with the lower radiator hose. I bought new hoses in 2012 and when I went to install the lower it was discovered the hose I got was for an a/c car. Too long and it the sway bar. I cut it to make it fit, and still no go. New hose ordered and will be in tomorrow morning. I'm also going to figure what I need to do in order to make a functional fuel line. Once the car runs I will swap the RF brake rotor between the 77 & 80, as well as install the transmission mount bolts, exhaust, and tires from the 77. All goes according to plan it'll be driving tomorrow.
That will be a nice accomplishment.
Thanks Dwayne I hope you're right. It's hard to tell when most the time the car has spent sitting but we'll see once I take that drive to Plain City, Ohio to complete her first drive since 2008. ( Completing the trip from when I bought her. )
Knowing firsthand what miracles you wrought on Harold II, despite tremendous odds, I have no doubt you'll bring this car to a much higher level!  I think once you actually get it on the road, you might start to get that "feeling" you're looking for.  Keep up the good work!
LOL yup, I learned on each of my cars, and that's the important thing. I will fix this car, and if I don't have a good feeling then I will move on to the next one after I sell it. The car has its good points although being all filthy at the moment it's hard to see them. Only time will tell to see if it's worthy of my devotion and care.
Well, don't feel too bad I think most of us made that mistake at one time or another, lol..
Yup... While the engine was so covered it may have been from something else the alternator had no oil on it so I had my doubts.
As I sit here I think of the other cars I could have gotten. There was a green 74 sedan low miles car (40k miles) in North Carolina, a blue 78 wagon with a/c in North Carolina, a green 75 Runabout, and a few others. This car was what I thought was the best of them. Looking back I should have gone with my gut and got the 78 wagon. It had a big dent in the back but after everything that has happened with this car I am not sure I made the right choice.
My first Pinto was a runabout and while I liked it I never had a love affair for it. The 77 sedan I loved which is why I can't bring myself to get rid of it until I know for sure it's dead. This car I bought cuz it was a running, driving car with what I thought was a good body, and no rust underneath. I somehow missed a lot underneath and are not happy with myself.
Well, in that case you did the right thing to just replace it..
Quote from: 74 PintoWagon on October 10, 2016, 07:42:30 AM
Could just wash it down good and watch for a leak, may not need replacing??.
The blistering on the reservoir was pretty drastic so I was concerned about the integrity of it. There was also a lot of grease around the pump shaft itself. While it may have been ok I was concerned besides the blistering on the reservoir the shaft seal was also bad. Not wanting to chance it I got a replacement from Autozone. It'll be going on the car HOPEFULLY today or tomorrow.
I did manage to get the fuel lines connected at the back of the car yesterday, and fabricated a bracket to hold them to the underside of the car. Made it out of some roll strapping I had in the garage. The original bracket was rusted away, but felt it needed to be there to secure it. The lines aren't perfect but functional. My 77 had rust galore but oddly enough the fuel lines were good on it. If I end up scrapping that car then its fuel lines will eventually go to the 80 when I pull everything off to wire brush and coat everything.
There were also wiring connections I had to repair due to the fire so I took those connections in the house, and soldered them. The only one I am having an issue with is the alternator connection at the harness. For that I might have to get a small torch to heat the thicker gauge wire so I can solder that . The connector fell apart in 2012 and needs replaced.
The car was a barn car. While some areas are in much better shape than the 77 was there are others that are still nasty. I will eventually drop everything from underneath, wire brush or wire wheel everything, and then use POR-15 to coat and seal all the metal. The car does have some weak points in the floor but has a much more solid floor than the 77.
Today I need to measure the fuel line under the hood to replace it. The one from the 1980 had a split and tossed, the one from the 77 wouldn't line up and was slightly pinched off in one spot.
I was cleaning the interior of the car some trying to locate a missing aluminum spacer for the fuel pump guard and did see something that concerns me. Cut wires. When I bought the car it only had one door speaker working so I removed the passenger kick panel. Behind it was a bunch of cut wires. I never cut anything in the car so I will use the 1980 Ford electrical guide to track down what those wires are for. When I was driving it in 2012 my Dad was behind me so I know he would have said something about no lights at the back.
Got the compression fittings needed to install the fuel lines. Still on the fence on the original power steering pump since it has blistering and signs of leaks, being all greasy. Now it could have been from the massive oil leak on the engine but I can't say for certain. Only thing is cash is low. In all reality I should be replacing it. Decisions, decisions
Well, not quite but done enough to drive. The 77 Pinto has good tires that will go on the 80. It needs a bit of work to be restored and driven regular but hopeful to get it on the road so I can park the Impala to fix her leaky oil pan & intake gasket
Sounds like just about done, that's great..
Ran in to issues Sunday. the 5/16" compression union to fix the fuel line was smaller than the OD of the line. Got the line routed but need to get a new union, and the 1/4" union wasn't a union at all. Gotta buy a new one. Once I do that I can plumb the fuel lines. I'm on vacation next week so my goal is to have her driving by next Friday.
