rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 03/06/2017 01:24 am
Date: 12/31/2017 09:03 pm
V8 rear end
Date: 04/12/2018 10:57 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 07/13/2018 02:21 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Rear Bumper
Date: 07/26/2021 01:08 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
  • Online today: 586
  • Guests: 448
  • Total: 448
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
Pics of the  oil pan.
No new pics today but I got some more work done to the car today. Well started to anyway. I've been soaking the oil pan insides to make sure it was good and clean before bolting it back up, then followed up with the wire wheel to clean up the outside. for paint. The pain is in ok shape and while the paint I sprayed on in 2009 held up the outside did have some bubbling from rust. I also got the gasket surfaces cleaned up and noticed some scratches and minor pitting. While I don't like to do this normally I went ahead and put a small film of gasket maker on the pan to take care of those minor imperfections, and hopefully prevent a future leak. One of the mounting flanges was also slightly bent so I flattened it out to make sure it will have a good seal on the block. Once the sealer is dry I will put the oil pan on an old box or other support method and primer it before painting it with Old Ford Blue. Once painted I will clean the mounting flange on the block and install the oil pan. Monday the engine will be installed in the car. Can't wait.
Forgot to put the pic up last night but I repainted the battery tray with the Rustoleum Harbor Blue. The bottom side was painted in a darker Dupli-color blue I had in the garage so I didn't use all the Harbor Blue on the tray. Looks 100% better. Tonight I'm hoping to pull the wiring from the engine compartment and move it out of the way so I can finish degreasing & painting the engine compartment. The Harbor Blue isn't a perfect match but close enough for now. I can always repaint it later on if I feel like spending $20 per spray can for the original 3F paint code.
Due to the heat I wasn't able to get much done to the car. Too hot in the garage without any fans so I did what I could. Got the battery tray pulled, rust ground off with a wire wheel, and both sides sealed with self etching primer. Next step will be painting both sides of the battery tray. It won't go back in the car until after I finish with the engine compartment. Hopefully that will go ok.
Thanks! I went to respray the engine, and ran out of paint so I grabbed the next can. It was the darker, Old Ford Blue. So I went ahead & resprayed the entire engine. Looks better anyways since that was what it was originally painted in the 1980. I also did a trial spray with Rustoleum Harbor Blue in the engine compartment. It's very close to the original color and will look much better once done. Just got to remove the wiring & other parts, and finish degreasing, while repriming where needed. I also removed the battery tray and started to use the wire wheel on it. I will give it a couple coats of self etching primer, and then repaint the entire thing with the Harbor Blue paint.
It's looking good, Matt!!!
Dwayne :)
Engine pics. After primer, after painting
Got some painting to the engine done. Engine primered. Once the oil pan is clean and installed I will primer it and get it ready for paint as well. I can also primer where the hoist is holding up the engine. Unfortunately I can't put the engine on my stand since it is occupied by a 1980 Ford Courier engine block.
So I done some thinking. While the engine is out of the car I am going to go ahead & repaint the engine compartment. While I don't have the time to wait for the actual color to come in if ordered online I will locate a color that is close & use it. The color won't be an exact match but close enough for now. It will look a lot better than it does now with thin paint. I don't know if it was the combination of the scrubbing or thin paint in the engine compartment but it's something I can't let go. I have a month before the car show and anything worth doing is worth doing right. There is enough time to get it done... In theory.
That sucks, some people shouldn't be allowed to own tools let alone work on vehicles..
Quote from: 74 PintoWagon on August 25, 2016, 07:25:57 AM
May as well put inserts in all of them at one time and be done with it..
I plan to inspect the threads and do just that if they were stripped. My Dad & I have found that the previous owners of this car did some messed up stuff. The starter bolts were out by about 1/4", bellhousing bolts not tight possibly due to stripped threads on the bellhousing, rigged hatch seal, 14" wheels from a Tempo on the rear that had center bores smaller than the hubs- had to beat them off with a sledge hammer. Radio was wired funny when I removed it, holes drilled for various LEDs in the instrument cluster and wood insert above the glove box, messed up wiring under the hood before the fire. Good stuff. At least it's getting fixed right.
Quote from: 74 PintoWagon on August 24, 2016, 07:52:14 AM
I've seen a lot worse, you're coming right along keep up the good work..
Thanks. The new motor mounts arrived today so those will be getting installed in the brackets tonight after I clean & paint them up. I might also clean the engine up some. Haven't decided on that yet or not. I also gotta check the threads in the bellhousing. My Dad reminded me the threads may have been stripped, as we found. removing the bolts
Thanks. I got some more scrubbing but it looks good for the most part. I'm glad since I was afraid I wouldn't be able to save any of it. I looked under the car last night & saw the fuel lines & brake lines are badly rusted so they will be changed before starting the car. The first time I run the car I want it to not have a leak. Right now it might. The 77 brake lines were redone in 2007 so I will use them. The fuel lines are in better shape so I might use them also. The sending unit also looks sad so I will change it out as well
Amazing what a bath will do, looks pretty good..
Engine from the 77. I will be cleaning it up a bit, which will include fresh paint and new oil pan gasket and rear main seal.
Engine compartment is partially degreased. Wanted it to be safe since there was a lot of oil from the massive oil leak.
Another update. Engine is out. Gonna do a little cleanup on it before installing the engine. Did notice the car has blue paint inside the bell housing and outside as well. Not sure if that was oem or an indicator of a replaced transmission
So I went ahead and jacked up the front of the car and got the old oil drained from the engine. Since the car had not had an oil change since I owned it the oil was real nasty. Who knows how long it was before then. While I was under the car I checked the rotors and found the RF wheel to barely turn. I unbolted the wheel and the bearing is almost completely seized. I also noticed the rotor itself is junk. The rotors on the 77 are in much better shape so they will be going on the 1980. I had already replaced the front bearings on the 77 back in 2010 so I know those bearings are good.
I also looked underneath and saw it has a little more rust than I recall but the car sat and appears to be solid. I will be sealing the floor eventually. I also found a nice surprise. I looked at the transmission and noticed the pan looked deeper than the 77's transmission. I counted the bolts. 11 instead of 13. Turns out the 80 has the C4 transmission instead of the C3 like the 77. I'm a happy camper with that find, even with finding the bad brake rotor, and locked up RF wheel
Doesn't look too bad now that she isn't covered in junk. A bath will happen as soon as she runs.
Thanks. I'm having issues with figuring out the wiring as I look at it since the wiring was destroyed in the fire. Parts were fixed in 2012 but I didn't complete it & now have a bad situation since my before fire pics don't show the harness. I don't know why on Earth Ford decided to make wiring changes in 1980 when they were killing off the car but they did. Tonight I'm going to my Dad's house to grab the rear main oil seal from my Dad's house, and will see if I can find the 1980 vacuum & electrical Pinto book. Too late to buy another one off ebay to get it here before the weekend. It's a shame I have a good running 77 but can't use the harness as a template but it is what it is. I will also get the car jacked up tonight & remove at least the front wheels. The rears are 14" rims from a Ford Tempo and don't want to come off. Those will be going on the 77 but only after I file the center hub of the wheel so they go on. that car will never see the road again so doesn't matter much.
Quote from: r4pinto on August 16, 2016, 11:37:50 AM
The moment I have been both dreading and waiting for. This weekend I will be pulling the engine from the car and installing the one from the 77 this weekend. It's bitter sweet. I've owned the 77 sedan since 2006 and don't want to part with it but the car is unsafe at any speed. Cancer claimed her but she will live on through the 1980. I rebuilt the engine back in 2010 so it's strong. Only exception are the rings. Had great compression so I didn't. While the engine from the 1980 gets rebuilt I will run the car with the 77 engine. My dad and I are going to pull it Saturday. Next in line is the mess of wiring burned in the fire and brake inspection. It will also get the wheels and tires from the 77. Wheel covers are from a 1985 Ford Tempo. With any luck the car will run again very soon.
Hope everything goes smoothly!!!
Dwayne :)
Now I will say I DON'T like to make repairs to parts like I did to the headlight bucket, but right now cash is tight, and the cost to fix using the radio bracket was perfect. FREE!!! As for the center bracket, I don't know what the original was like but if I had bought the car I would have never known it wasn't original. Before I painted the center bracket I went ahead & filed down the sharp edges that were left from cutting the bracket.  I had a piece of cardboard that I used as a template when the grille was mounted, and then transferred the bend to the shelf bracket using my dad's vice that I "borrowed". Overall I am very pleased with even the little task that was accomplished. The grille is far from perfect but it looks much better than  the black grille with the chrome buckets, and I don't like the black look anyway.
The brackets all painted & installed
So I finally got some pics of the work. I ended up painting the brackets with some flat black paint and they came out ok. I also went ahead & hit the buckets with the flat black as well so they look a little better.
Necessity is the mother of invention.  Well done!
Dwayne :)
