Date: 03/25/2019 09:02 pm
Date: 03/27/2017 10:07 pm
Date: 01/12/2019 10:19 am
Date: 08/02/2019 04:18 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 08/01/2018 01:27 pm
Date: 01/23/2023 02:22 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
  • Online today: 586
  • Guests: 446
  • Total: 446
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
Did you stop at that location, shut the car off, and see if it restarted? :-)
Just got done with a 69 mile round trip and the only issue is an occasional speedometer issue probably due to an old cable, and wipers that kept quitting. I filled up and got almost 24 mpg. That is accurate for that engine and carb set up. The same engine and carb got about that in the 77.  The maiden voyage was to Plain City Ohio. Right past where she broke down in 2012. Mission accomplished
72DutchWagon
A few days late, but well meant congratulations from far away Europe on getting your Pinto on the road!
Nothing like getting an old machine functioning again, and having it do what it's supposed to do.
Thanks and sure will be. I am going to place a good spare tire in the car with my jack just in case and take the drive. The steering feels good, brakes solid, transmission shifting smoothly so no reason she won't do good. The headlights are actually brighter than my Impala and all other lights work. Did notice at first the wiper switch was iffy but once used a few times it never stopped working.
Thanks guys. Since she did good on that test I am taking her on the final test tonight and that is driving the car to Plain City on the exact route I took to buy the car in 2012. That'll be the real test.
Sounds like a winner to me!
Dwayne :)
First fill up in who knows how long. Not even 91k on the clock, although the engine has about 130k on the clock. Ran great on the freeway. Didn't miss a beat. And  the more I drive it the better it handles even with rusted out shocks
Gosh... I don't remember exactly.  I bought five (figured I may as well have a matching spare) and I'm thinking they were about $350, give or take a little. That was in April or May of this year.
Dwayne :)
So I didn't do anything to the car last night. It was a rough day & just didn't give a crap about much. Today after the gym I plan to pull the choke assembly off the 80 carb & mount it to the one on the car. Right now the choke isn't hooked up so I know cold weather driving won't be too good & noticed the choke valve isn't opening so I think it's not right anyway. I am also going to see about hooking up the Clarion stereo. Think it'll be easier than the Kraco I have. Only thing is I need to get a tap for the fuse panel so I can have the memory preset working. Only thing is finding the tap.
I also need to replace some blown fuses in the fuse box, including the radio fuse which blew the other day when on accident the ground wire touched the hot wire & popped it. Instant short to ground. At least I know the fuses did the job. If all goes according to plan I'll be driving the car to work starting next week. The Impala isn't doing to well. Mr Leaky Leak is getting worse & has developed a noise in the front end.
Quote from: dga57 on October 17, 2016, 02:54:54 PM
It will be exciting to take it to a car show after all this time!
I bought new whitewalls online for my Pinto - they sure gave it that "fresh out of the factory" look!
Dwayne :)
I lucked out in 2011. Only thing is I doubt I'll get full life out of these since they haven't been driven on. How much did they cost you? I know 13s are getting harder to get in the tire stores.
Dwayne :)
Quote from: dga57 on October 16, 2016, 10:47:06 PM
I love whitewalls on a Pinto!!!
Dwayne :)
Those are actually  the tires I got from the 77. The OE wheels for the 80 are the alloys, which will be refinished before I even consider mounting tires on them. For steel wheel and hubcaps I like the whitewall look. The spare tire I have is actually a white wall but facing in so I'm going to have it reversed, just in case I have a flat, and need to have the spare on.
10/29 there is a car show a few miles from me, and I will be going to it, as well as a car show in Springfield, Ohio 11/11. Don't see why the car won't go to that either. I still need to install a radio, fix the bad right speaker, and maybe replace the seat belts with the ones I got from a 1986 Tempo so the car will be better. Hopefully those will work. Worse case I'll take the black ones from the 77 and use them but I'd rather go with newer blue seatbelts.
Dwayne :)
Around the corner... and beyond!!!  Way to go, Matt!  Congratulations!!!
Dwayne :)
Now the engine compartment
Sounds like this will be a real cool ride, looking forward to seeing it finished..
Thought it would be nice to see a before and after of the car, as well as the engine. The pics were 5 years ago so just as a refresher...
Quote from: pintoman1 on October 16, 2016, 08:05:42 PM
Again, Matt job well done. looks good, sounds good too. looks like you are well on your way to having a good driver. just a few more details and your good. I like the hub caps you have on it too, goes good with the white walls.
Glen
Thanks Glen. I bought them a couple years ago off ebay for $12 for all 4. I do need to get new valve stems on the tires next weekend hopefully. It was a pain to get her on the road today. Planned on an easy fix for the front brakes, then bleed all 4 wheels. Nope, didn't happen. Bled the fronts until I got clean fluid out of both calipers. RF caliper was from the 77 due to a seized RF caliper found when replacing the RF rotor which was also from the 77. I go to the rears to bleed them and got the LR wheel bled until clean fluid came out but the RR would not bleed. I removed the bleeder screw but no luck. Before I drive the car on any distances I will be replacing it with the RR wheel cylinder from the 77. The RR brake stops but I want to be sure it's good. I put in fluids and when I shifted the car in drive it rotated but when I put in park it made a ton of noise. I feared transmission problems.
I don't know what prompted me to but I looked outside the car and hit the brake but the LR wheel would not stop. Noise found. the transmission not being happy when putting in park due to still spinning.  Took the wheel and drum off the car and saw the LR shoes were shot. Heat cracked bigtime. Replaced the shoes thinking they weren't grabbing due to being glazed over and still wouldn't stop. Thought maybe there was still air in the RR so I was going to re-bleed them. Last minute I decided to install the wheel cylinder from the 77 since I already took the shoes and hardware. Sure enough that was the right call. The old cylinder was rusted solid. Bled the brake, put on the wheel and perfection. The car stops on a dime.
Next weekend I will be replacing the rear shocks with a pair I bought for the 77 but never installed. I will then feel better about driving the car. With the beyond shot shocks on the rear it is all over the road. I've driven the car for about 3-5 miles today so if it had any fuel leaks I'd know by now. I think it might have a slight drip on the oil pan but the oil pan wasn't perfect and had a slight leak before when it was in the 77. I might check it out eventually but for now not going to worry about it.
PintoMan1
Glen
1973 pinto runabout
Before and after a bath. I need air in the tires and also longer valve stems in them as well. The wheel covers are from a 1984-85 Ford Tempo. Not correct for the car but I like them. Looks good with the white walls.
I will let the video do the talking for me.
Thanks! I'm sure it will. Checked for fluid leaks and none from what I can tell. When I first tried to run the car the timing was so retarded it wouldn't stay running. Loosened the distributor and tried to set it but found I needed to pull the distributor to get more advance to hit the 17 degrees BTDC needed according to the sticker on the hood. I will get more pwer steering fluid to fill the reservoir since the 1.5 bottles I had wasn't enough. It's a bit whiney. Once I bleed the brakes I can run the transmission through the gears so I can check and top off the transmission as needed.
The car does need a new transmission pan gasket since it shows signs of leaking but I'll order that from Rockauto once I'm sure the rest of the car is fine.
I'm going to be out of town all day tomorrow but will be sure and check the site when I get back tomorrow night.  I'm excited so I KNOW you must be!  Hope everything goes okay!
Dwayne :)
I also repacked the RF wheel bearing and got the caliper slide greased up so it won't stick like the other one did. Brake hoses installed up front, and went to install a new hose at the rear when I saw a nice surprise. The hose is in great shape. It's actually a newer hose, and was probably replaced in 2008 when the previous owner had it last running. I also noticed the rear line was replaced as well so it's good to go. I will bleed the brakes all around with fresh fluid to insure I have no issues stopping. Tomorrow the brakes will be bled, tires installed and air added as needed, transmission fluid, power steering fluid, and coolant topped off as needed, and will then take the car for the first drive in almost 5 years. I do also need to reconnect the speedometer cable, as it did become disconnected from the back accidentally. Feels so good to know the car will be moving under her own power, and runs as well as she does.
Here is an update that I am glad to do. The car is running and very smooth. I set the ignition timing and the car idles flawlessly at 800rpm. It actually starts up easier than my 2004 Impala.
I hear ya, I've bought vehicles before with a pipe nightmare with anything from flex pipe to copper tubing, and hung with bailing wire, lol..
