Date: 07/01/2019 12:23 pm
80 pinto original
Date: 08/04/2019 10:45 am
Date: 02/18/2017 04:44 pm
postal pinto
Date: 06/03/2020 09:31 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Clutch Fork
Date: 03/31/2018 09:12 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Clutch pedal needed
Date: 01/11/2024 06:31 am
  • Online today: 586
  • Guests: 431
  • Total: 431
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
Drove her to a car show. Hit 65 and not a shake at all
Well, there's an obvious difference!  That, along with the new tires, should make her drive better!
Dwayne :)
both old rear shocks and last new to car shocks. Other is already on the car.
Got the fuel leak fixed. Turns out when I installed the compression fitting I forgot the barrel on one end. New fitting and all is well. Also got all five tires replaced. They didn't have white walls but safe tires are more important.
Getting five new tires on the car. Four plus the spare since it is dry rotted and showing micro cracks around the bead. Gotta be sure she is safe for the road. Car show today but Ohio State football at the same time so will skip that car show and go to one that is going on tomorrow at 10:30 am. I am also replacing the shocks on the rear today with newer units so she will drive smoother.
Sortof had a mechanical failure today. After having a trying day at work and having issues with my cat I go to the gym & get out of the car. I smelled gas. I look underneath to see the left rear shock soaked in gas. The compression fitting on the fuel line failed & was leaking. I will do a temporary repair to it so I can get new tires installed this weekend, and after I will get the lines from the 77 and put them on, if they aren't bad either.
Yup. Although she does need new tie rods and ball joints to align right. The toe is out and the tie rod is rusted on the passenger side. Suspension is solid but is 36 years old so will need gone through
Now that all the big stuff is done, you can relax and have fun with the little details!
Dwayne :)
Yeah I pulled the air cleaner cover off on the side of the road after it came off and hit the alt pulley. So at the gas station I popped the hood and it's moving freely. I will try to readjust it to 80 specs when I get home since I gotta swap choke coils anyway.
Sounds like the sending unit is getting tired, might try lubricating all the choke linkage making sure it all moves freely and take off the cover and check for crud then readjust, that can make a difference.
I also need four new tires as all are cracking. Don't want to drive it but the Impala has a bad noise from the front and possibly about to drop a control arm
The car is running and driving good although the gas gauge is inaccurate. It showed between 1/8 and empty but when I put in 6 gallons it went above 3/4. Think the float might be bad. Will check into it later. Also not sure about the choke. The choke valve wasn't open too much so it may be too rich at full temp. Will pull the plugs to see how they look and go from there. Also need to fix a bad headlight connection since the passenger side keeps staying out. New plug is at my dads and will get soldered on.
In that case may as well just put a new cable in.
I might try it but it was rusted pretty bad on the outside of it so it's probably just gone. Especially with the rust all over the car.
A little lubrication probably free it up..
Thanks. It runs pretty good although I found the parking brake is junk. Cable is slightly stuck. Gonna try to free it but might have to cut the cable. Don't want to though since it is better than nothing for an emergency
Thanks I am
A true accomplishment!!!  Hope you had lots of fun!!!
Dwayne :)
Heat feeling better but decided to pop the hood to check everything out. Good thing I did. I forgot a hose clamp on the thermostat to heater hose. Slight coolant loss but not too bad. That explains the scent I had after I parked the car. Drove about 100 miles if not more since fixing her. She is doing very well so far.
Drove the car to work today. I had some bad rattling from the driver door previously due to missing bushings on the striker bolt so as a temporary repair I put tape on it. No rattle on the drive. I also replaced the lighter in the car. It worked but when I'd plug in a phone it wouldn't work. Turns out the socket was rusted at the back contact. One from the 77 did the trick. I did find out the exhaust on the car is a little low so I will be fixing that issue when I install the exhaust from the 77 which will include a new muffler that I bought five years ago and never installed, as well as a nos exhaust hanger for the rear. Steering feels good and the heat is fair.
cleaned out the car some and installed this radio. The right front speaker wiring was spliced in a couple different places but it still doesn't work. Problem inside the door. For now I have another speaker on the floor so at least I get stereo sound.
Quote from: pinto_one on October 20, 2016, 12:34:30 PM
at least the switch is easy to get too, I often see when you do not use some things for a long time you have to wake them up using them more often ,
Exactly my thinking. I think it is ok but I will be pulling it anyway since the 77 had a wiper delay from a truck I installed so it was planned to be installed on the 80.
Thanks! I'm thrilled about it. Tonight I'm going to install the radio after I get done at the gym, and tomorrow I will be driving it instead of my Impala to work. That'll give me a chance to see whether or not the exhaust is too low, which is a possibility since it was repaired temporarily with flex pipe. I hate using that stuff but it beats not having an exhaust at all. Hopefully it doesn't rain tomorrow since my wipers are iffy at best until I get the motor swap done. I figure I will pull off the old one, clean it up & put it back together. See if maybe it just had some rust or corrosion on the contacts in the motor since it works but not always
Quote from: r4pinto on October 19, 2016, 09:32:16 PM
Just got done with a 69 mile round trip and the only issue is an occasional speedometer issue probably due to an old cable, and wipers that kept quitting. I filled up and got almost 24 mpg. That is accurate for that engine and carb set up. The same engine and carb got about that in the 77.  The maiden voyage was to Plain City Ohio. Right past where she broke down in 2012. Mission accomplished
Congratulations!!!
Dwayne :) :) :)
Nope. The death in 2012 was a blown left front tire and fuel leak. It still ran, just couldn't drive or run safely. I did however make a stop on the way home. Needed to go to the store and pick up dinner as well as some glass fuses so I can get a working radio installed
