1980 Ford AM radio
Date: 12/22/2019 11:57 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Brake rotors
Date: 03/24/2017 09:02 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 05/13/2021 05:33 pm
looking for parts
Date: 06/19/2020 02:32 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 08/13/2021 10:39 am
  • Online today: 586
  • Guests: 255
  • Total: 255
New project... 1980 Runabout
Quote from: r4pinto on September 30, 2016, 07:33:49 AM
Thanks Dwayne. If all goes according to plan it will drive on Sunday to the spot where she broke down & was towed home with a blown tire in 2012. She has never had a complete trip & I want to change that
Sounds like a plan to me!  Good luck!
Quote from: 74 PintoWagon on September 29, 2016, 09:39:30 AM
Quite a bit of progress there, good deal..
Absolutely!!!  Keep up the good work Matt - I can't wait to see the finished project!
Got some more parts painted. The heater lines painted up, dipstick painted & installed. Had to use the ugly 77 dipstick tube since the 80 Courier tube didn't want to work. Dipstick in & oil level good. Also put on the oil filter, throttle cable bracket, and some of the electrical wiring. I still need to clip it to the fender, install the hood, install the fuel lines & an in-line fuel filter at the back of the car as well in case there is junk in the tank. This weekend I hope to be able to fire up the car. I will try to have updated pics posted.
I also polished up the air cleaner assembly, and painted up the air cleaner tubing that was nasty looking.
Quote from: dick1172762 on September 18, 2016, 11:26:42 PM
You should think about getting rid of the power steering completely. Pintos need power steering like they need a 6 speed tranie. And it will cost nothing. Just remove the hose's and connect the two ports with a short piece of rubber hose. That's all and if you still need power steering you can do it latter down the road. I've done this on all my Pinto race car since 1974. Try it/you'll like it. And take a look at the rag joint. I replace them with a U-joint. Same $$$$.
I don't like it. My 77 has manual steering & I was in the process of converting it to power steering since I didn't like it. Just personal preference. The car was pretty well optioned out and decided whatever it did have will remain. My 77 I was getting modded but my 80 is staying OEM.
It's been there. Life just got in the way. Once I refinanced the home loan and paid some bills I was finally able to get everything together to actually work on the car.
I just got done flushing the cooling system on the Impala, as well as replacing the radiator hoses and radiator cap. I'm not sure everything is OK with the car but time will tell.
Back to the Pinto... I had to get the ramps to work on the Impala, so I also went shopping for Pinto parts. I grabbed all the nuts and bolts I degreased in 2012, and some old steel lines I kept for a "just in case" reason. They are in really good shape so I will straighten then, degrease them, and use them to fix the bad fuel line at the rear of the car. I also grabbed some extra wiring, and my other power steering pump. Unfortunately the return line nipple was busted off the reservoir so it's junk.  I now need to get a power steering pump for the car. I'm not interested in spending $$ on a new pump so I am going to see what I can find on ebay, and see what car I can get one from since I know Pintos are nonexistent out here.
Just can't chance the old pump since there is a lot of blistering on the reservoir of the original pump
Matt,
I'm just happy to see your renewed interest in the Pinto!
Quote from: dga57 on September 18, 2016, 06:50:19 AM
Well, first things first.  As you said, you need the Impala to get back and forth to work.  It sounds like you're getting close with the Pinto, though!
I sure am Dwayne. I will be working on the Pinto a little today but it won't start for the first time in four years like I originally wanted. I will end up working on the Pinto while the Impala sits and cools so I can drain and refill the cooling system after flushing it out. I still need to cut off the rusted fuel lines at the rear and use new line to fix the bad section. I've found more rust under the car than I originally expected. It's not as clean as I would have liked but is leaps and bounds better than the 77. I only have one floor area with rust through. The rest will be coated with POR-15 to seal what has started. It's a 36-37 year old car with no undercoating so I'm not surprised. I will end up dropping the gas tank and sealing underneath but that will be later on. I feel much safer with this car than the 77 but it does need some work.
I do have bolts I cleaned in 2012, as well as the missing coolant line I have to pick up from Dad's house, as well as a replacement power steering pump. The old one has just a little bit too much fire damage to the reservoir. While it cleaned up ok it has extensive blistering, and I'm afraid if I leave it I will have an eventual leak. Better to be safe than sorry.
Today I got the carburetor installed, as well as the grille, heat shield, EGR valve and line, as well as the air cleaner duct that bolts to the inner fender. I was going to work on getting the car to a car show in Kentucky next week but my Impala had a collapsed heater hose. Pulled the radiator cap and sludgy so I have to fix that car so I can go to work, instead of working on the Pinto.
Quote from: r4pinto on September 15, 2016, 11:23:11 AM
Thanks. Lots of hard work but worth it. Especially when finished
Absolutely!  But, as you said, worth it!!!  Keep up the good work!
Got the intake manifold installed, and another coat of paint on the engine bracket. In the mean time here are some pics.
Still need to get up pics but I do have an update. Started to route the wires, and also found the right bracket for the engine lift on the driver side. While the engine won't be coming out again any time soon I want it done right. I scraped off loose paint, and degreased the bracket before repainting it. Tonight it should be dry enough to put the intake manifold back on. I also found a couple bare wires in the harness where there are some splices. What I am going to do is get the brush on electrical tape to cover the splices. Better to fix now, than chance a bad fusable link due to a short. If I had new wire look I'd replace the worn stuff but unable to at the moment.
Thanks Glen,
I'm looking forward to getting the engine to run. I got the engine compartment retouched, and Dad & I got the engine mounts bolted to the car. It now is sitting in the engine compartment on its own. I've also bolted the exhaust manifold on the engine, and once the paint is dry in the engine compartment I will fill the crankcase with fresh oil, and also install the intake manifold. I also replaced all the rubber fuel hoses, and ran in to a major issue with the fuel lines. One of the old lines snapped in two and is now needing replaced. Not too sure what my plan of attack will be but will get it done.  Better to find out this problem now than when I have a fuel leak.
PintoMan1
sounds like you should have it up and running soon! I hope all works out for ya and it starts right up! good luck! oh, and the engine compartment looks good too! pretty soon no more dirty hands, lol!
Glen
1973 pinto runabout
The engine is in the car. Today my Dad & I got the driveshaft reconnected to the car, then lined up the notches on the torque convertor. We moved the engine in to place and noticed things weren't lining up. The jack being used to support the transmission kept failing and had to be constantly pumped back up, and even then it would line up on one side but not the other. I decided to lower the transmission and look to see what was going on. Went ahead & rotated the transmission. Once I did that the bellhousing lined up perfectly after jacking it up. Started one bolt, and jacked the transmission up after the jack dropped again. We got the four bolts holding the bellhousing to the block started and snugged, then hit the bolts at the backside.  It fit perfectly, and the engine rotated afterwards.
Got the brackets bolted back on for the starter solenoid wire and dipstick tube bracket, and since the engine was off the mounts went ahead and bolted in the starter. Looks so good not having grease and oil all over everything. My dad had to leave and I though we were good to go but later remembered the engine mount to frame brackets needed bolted back on the car. Later on he will come back to help with that, and then the engine will be off the hoist. I will clean any grease from the engine compartment, and respray any areas that got the paint damaged.
Pics to come soon!
Thanks. Tonight when I get home after the gym I might pull the brake rotors off the 77 & put them on the 80 so that's done, as well as install the driveshaft back on the car so that'll be done. Maybe even fix my air compressor so I can use it for a quicker install of parts
Amazing how much better the engine bay looks with a fresh coat of paint.  On the engine locking up when the C4 is bolted up, the only thing that comes mind is that the torque converter may not have been fully seated in the C4.  After sliding the torque converter into the C4, rotate the converter until it in fully slides in.  My C4 torque converter snout measures about 5/8" in from the face of the bell housing (not proud of it) when seated (prior to bolting to engine).  Hope your real problem is this easy to resolve.
If the engine had come from a manual transmission car, the pilot bearing would need to have been removed.
Engine compartment painted.
No new progress today. It was issue after issue. Found out the threads in the C4 bell of my transmission were stripped at the dowel holes on both sides. Bought a heli-coil kit for it and that fixed that but ran in to another problem. We got the bellhousing installed to the block but when attempting to rotate the crank it was locked solid. For some reason the torque convertor seems to be binding so not sure what's going on. I had installed the torque convertor in the bellhousing before installing the engine but no luck. Pulled it out and the engine rotates fine. For some reason we are having issues getting it to fit flush against the engine. Don't know what's up. Got the engine out and will have to retouch some areas of the engine compartment, as ther are some scratches now.
Thanks, it sure does but it's worth it. Last night I painted the engine compartment the best I could. I wasn't able to mask off the grommets since I couldn't find the tape and was in a bind so I will clean them off later. The compartment is 100% better than it was before.
I also got the oil pan back on the block, and installed the distributor, and original starter ground cable to the engine. Also painted up the engine mount brackets, and installed new mounts. Looks 100% better
Pics to come soon!
PintoMan1
really looks good Matt! i know it takes time, but keep up the good work!
Glen
1973 pinto runabout
Thanks Dwayne! I am really amazed at the progress so far. The paint on the oil pan looks good, and today I will be cleaning the block before installing the oil pan to the engine. On the agenda today I will also be pulling the wiring harness and clean the engine compartment. I will then be giving it a fresh coat of Rust Oleum Harbor Blue. It really amazes me how close it matches to the OEM car color.
