Pinto for sale
Date: 04/19/2017 10:15 am
Date: 08/01/2018 01:17 pm
Date: 06/30/2018 09:48 am
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Date: 06/05/2018 09:13 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
pinto for sale
Date: 09/11/2016 09:47 pm
  • Online today: 586
  • Guests: 428
  • Total: 428
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
Thanks Dick, I thought about it and figured why not try it. The car is far from perfect and it got the creative juices flowing. Best part is it used material I already had in the garage
postalpony
Way to go Matt.  Don't let the little things stop you. I like the way you solved your grill problems.  This what I have done all my life, & It still works.
Good luck!    Dick
Now all we do is HAUL!
Well it is better than no progress. I was looking at the grille and trying to figure how to attach it to the car. The bottom passenger tab on the grille was broken and the upper on the same side was broken on the headlight bucket with no center bracket which left only the left side of the grille supported. I bent an old shelf bracket for the center and made an extension for the upper passenger side. The grille now is supported ! Will take pics of the work later
Quote from: 74 PintoWagon on October 04, 2015, 07:53:00 AM
Does that ever sound familiar.. ::) ;D ;D
Well it looks a little better. I wiped down the windshield but then ran out of paper towels lol. It's got some overspray on it so I gotta get that cleaned off so  it's better. Still, some progress better than none
Quote from: r4pinto on September 19, 2015, 09:47:17 AM
So tired of things not going my way. I really gotta clean this car out. Maybe that'll give me some motivation if it looked better & didn't have junk piled on the roof. Just once I wish things would go my way.
Going to get some insulation for the garage, and hang the cabinets I have. From there I will move the lawn mowers to my shed for the winter so I have room to work. Thank god for thick chain since it has no doors. I can then get the car off the wheels, and on all four jack stands so I can remove the driveshaft, tires, and go from there to pull the engine and transmission.
Haven't touched the car. Life has been kicking my butt, preventing me from even touching it. The car is covered in grime inside & out, doesn't run, and my clean floor pans aren't as clean as I originally thought, with the RR floor rusted away. One section rusted not as bad as the 77 with everything rusted. So tired of things not going my way. I really gotta clean this car out. Maybe that'll give me some motivation if it looked better & didn't have junk piled on the roof. Just once I wish things would go my way.
Thanks. I was gonna get the front end jacked up last night so I could unbolt the driveshaft and start demo but then realized I had only one jack stand at my house. Went to my dads and got a second. Car will be in the air soon  and might go ahead and jack up the rear as well since I have four stands
Here's the pic of the radio I was gonna install, and the radio I am gonna install. Both in the Pinto dash bezel
Quote from: dga57 on August 16, 2015, 10:16:44 PM
Seems to have been a worthwhile project!
Dwayne :)
Definitely. When I got the wipers from Pick N Pull they didn't even charge me for them. All covered in dried moss & crud but worth the soak & scrub time & they look very similar to what I remember was on my parent's 77 wagon. I like original wiper look. Even searched junkyards for OEM style wipers for my 85 Omni. Just a detail that is minor to some but important to me.... Says the person that is putting a digital radio in his Pinto lol
Dwayne :)
Car after new wipers
Car before new wipers
Went to my Dad's house & found an unopened pack of wiper blade refills. I bought them for his Taurus originally so they needed shortened but once done they came out nice. I cut the frame with a hack saw and miter box so they were nice & even & the rubber I was able to cut with a pair of scissors.
When I had recently gone to the junkyard I found a set of 16" wipers on a 1985 Chevy Cavalier that were just what I was looking for. They were in horrible shape with rubber all dry rotted and the wipers themselves covered in crud & dried moss. Well I put some carwash soap & hot water in my kitchen sink to soak them in & they cleaned up nicely. Now all I need is to find new rubber refills, and they will be ready to put on the car.
Ok , I see what you mean , been though that a few times myself over the years , cars that had converters when I got the car , a did not have a converter when I sold the car years later , guess your useiing two cars to make one useable,  very doable, pick the best stuff and install, guess invest in a case of gunk to clean all the oil and Greese so when you work on it you don't give yourself a lube job every time you open the hood😜
Quote from: pinto_one on August 09, 2015, 08:25:08 PM
Yep those can be a real pain , even with the right tools they can take time to remove , not counting the busted knuckles and leaving your DNA all over that spot , and since you said you had the head off of it you could remove the pipe from the catalytic converter and slide the whole pipe out from the top, and use a propane torch and heat the nuts up and then spray some Kroll on them ,use a six point scoket, always worked for me , and also you said the bottem of the car is covered with oil. Bet the rubber elbow to the transmission modulator turned to goo, that would give you a no high gear
Well not exactly accurate. I believe I was a little confusing with my previous statement. I should have specified... The engine compartment was what was covered in oil. Underside is actually very clean and dry. Under the hood was very very greasy. I see what you're referring to about the convertor located under the car, and may give that a try before fighting with the part under the hood that I was referring to as the convertor. my 77 has no converor so I dunno what part is what on the 80.
Quote from: 74 PintoWagon on August 09, 2015, 07:53:17 PM
If I ever take out a full set of exhaust studs/bolts without any being messed up that is one huge VICTORY for me, lmao...
Funny you say that, cuz I can't even get a wrench or socket on the top one.
VICTORY!!!! Ok, not a big one but victory none the less. I actually got something accomplished. I removed the lower exhaust manifold to catalytic convertor bolt. The top one is being a pain and won't come out too well. Still, progress is progress. This is the first bolt removed from the car in a long long time.
Everything on this car is a complete and total nightmare. It was rigged and aside from no rust underneath is in rough shape. Well that and the interior is fair. Thus why it was a bad fire. Oil everywhere fueled it
Pulling the engine out with the head off is easier, use a short chain that's large enough to put short bolts with washers into the head bolt holes , if you leave the transmission in place bolt in the middle , if you pull trans and engine as one the second to last holes will work, as for not going into high on your transmission you may have a vacuum line problem, make sure the steel line is not clogged up or has a hole in it from rubbing on something or from rust , also the rubber line could be hard and split , these are very common problems, had my share of them ,
I been thinking... The 80's current engine doesn't have the cylinder head, and the cylinder head isn't exactly ready to install but i'm not sure I can pull the engine without the head.. Hmmmmm
Today I'm gonna have some much needed fun at the Ohio State Fair, and later on I will clean around the car so I can start working on the car. I've got to get her on the road one way or another. I'm gonna yank the engine and transmission as an assembly, and then separate the 80s block from the transmission, before repeating the process on the 77s engine and transmission. I would just drop the assembly from the 77 in to the 80 but the 77 transmission only has 1st & 2nd gear. 3rd decided to go MIA when I was driving the car home from work one day about 3 years ago. Never found the problem but I think the band or clutches went bad. Still shifts good 1-2 but no 2-3 shift. I also will take the radiator from the 77, as the one from the 80 wasn't the right one.  I'm not sure how long the process will take but it will be a learning experience. I've never done an engine swap on my own, let alone on a car that doesn't run due to engine fire. We'll see how it all goes.
Thanks. Can't wait to install it & see how it sounds in the car
Looks good, haven't seen one of them in quite some time..
