FREE PARTS!!
Date: 01/10/2017 02:38 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 06/24/2020 06:12 am
free transmissions
Date: 11/28/2019 10:21 am
Date: 10/10/2019 09:42 pm
Date: 10/31/2018 12:00 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Electrical
Date: 03/29/2017 11:37 am
1979 pinto
Date: 04/19/2018 02:02 am
  • Online today: 586
  • Guests: 463
  • Total: 463
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
Haven't done anything to my car but one thing I got that will be going in this car is a different radio. My dad once had a 1982 Plymouth Reliant and the car had a radio in it I liked. When he sold the car for $50 he kept the radio. At one time I installed the radio in a Ford Tempo I sold him. When he sold the car the radio went with it. Well, while on ebay I found the same type of radio. Paid more for it than I should have but I don't care. It's the exact radio I want.
I hope you're right Russ.
I gotta get my butt in gear if I'm to make the Ohio meet. Wednesday I'm golfing in the morning but then focusing on getting the engine yanked from the 80 & the engine starting to be yanked from the 77. Let the good times roll.
Hey, Matt.  ;D
Sorry to hear about Harold II, but glad to see you got another car. Sounds like you are on the right track. The new car doesn't hate you, it is just giving you tough love. Making you prove yourself worthy. ;D ;D ;D
We moved to Phoenix and now I have a 74 wagon.
Wish I could have gotten another Pinto while we were still in Ohio, I miss being able to go to the Ohio get togethers. Doesn't seem to be much of Pinto following here.
Quote from: Pinto5.0 on June 24, 2014, 08:47:57 PM
I know they made several different length starters so maybe you are cursed with a long version.
All 3 racks I've pulled have required me to burn the bushings out then slide the rack off & heat the steel sleeve cherry red to get it off the rack bolts.
I guess in some ways I was lucky on the 77 then. A major rust bucket to the point where if I hit a pot hole or speed bump hard enough the RR leaf spring could come separated from the car one of these days, & yet I was able to drop the rack low enough to get the starter off. We'll see what happens when I tackle it next.
Interesting.. I'll just have to see what I can figure out & maybe get lucky. On the rusty 77 I was able to drop the rack to get the starter in & out of the car with little problem. On the 80 it's VERY clean down there thanks to a nice leaky oil pan & rear seal lol. We'll see what happens. Just a little too frustrated to mess with it today.
I'm not sure. Both were 2.3 cars & I never dropped the rack. On an Ohio car that rack ain't coming out anyhow due to rust & corrosion. If necessary I'd take out the motor mount bolt & jack the engine instead.
Quote from: Pinto5.0 on June 24, 2014, 07:46:35 PM
I've changed starters without dropping the rack before.
What's your secret?
I was cleaning my garage up today so I can get the engine pulled & went ahead & got the right side tires off the 77 Pinto. Got the RF tire on the 80 but couldn't get the RR off the 80. It's on there so tight it wouldn't come off kicked & kicked at it but no dice. Need to get a big hammer to knock that sucker off the car. Went to my workout tonight & when I came home I was gonna pull the starter. Wrong!!! I ran into another problem. I need to get a couple wrenches & sockets from my Dad's house to drop the rack & pinion. Once I do that I can get the starter off & check into the exhaust pipe.
Got the hood pulled off the car & also noticed the bracket the hood latch was mangled so I removed the latch & straightened it up. It's now straight & ready for me to continue the repairs on the car. If all goes according to plan I will be pulling the engine and getting ready to install the replacement engine by the weekend.
Quote from: dianne on June 22, 2014, 04:20:32 PM
I'm sorry to hear about your setback. I loved those seats... Hope you can get it fixed up!
Pics of the damage?
Thanks. 2 years ago the engine fire happened but it didn't take out the whole car. Post 8 on page 2 has the damage of the burned parts. I know that once I get the engine in from the 77 I should be able to get the car running. Gotta install wiring harnesses & other parts to it but as long as I have fuel & spark it should fire right up for a test run.
dianne
Quote from: r4pinto on June 24, 2012, 09:05:29 PM
Had myself a setback today. I replaced the accelerator pump diaphragm & was doing some other work to the car. Tried to start it but it didn't wanna go. Finally the carb backfired & next thing I knew the engine was on fire!!!  :o  I ran to the garage & grabbed the fire extinguisher but couldn't get it working! Dad  saw me freaking out so I yelled at him that my car was on fire & to call 911. He ran outside  & ran to the back yard & got the garden hose. He got the fire out & within 15 minutes we were looking over the damage.
I now need a set of plug wires, various vacuum lines, and parts of the wiring harness repaired. We'll see what happens now.
Pics of the damage?
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Quote from: Runabout75 on June 16, 2014, 03:08:14 PM
Great save. Sorry about the engine fire. Hope you can bring it back.
Thanks
The car currently sits in my garage but later on tonight I'm gonna get the shop light from my Dad's house, remove the hood, and start tearing into the engine compartment to get it ready to pull. I figure I should be able to pull it rather easily. The 77 donor car will fire right up with the push of a button- rigged starter system. Gotta move the mowers out of the way so I can get the engine hoist in there. Then I can go ahead & yank the engine block. The old engine will sit on some old tires until I can get my engine stand from my Dad's house & mount the bare block that is currently on it, in the 77. There is so much to do to the car before it makes the trip to Michigan. Hopefully I will have the majority of the work done before the trip. If the car runs and stops I will be a happy camper.
Runabout75
Runabout75
The car is at my house, as is the 77 parts car with the engine that will go in the 80. In the next day or two I'm gonna remove the hood, and start to get the engine pulled on the 80 so I can get the engine compartment ready for the 77s engine. When I went to Carlisle this year I got the car a grille, as well as the rocker panel trim I need. Hope to get those parts installed soon, as well as the tires from the 77 on. I got a set of hubcaps from an 84-85 Ford Tempo that will be going on the car. Not exactly the right ones for the car but nicer than the steel wheels.
The car pretty much looks the same as it did at the beginning of the year but 2014 will be the start of a new year. The car is still at my dad's house but I am going to figure a way to push it to my house to swap the engine with the 77 sedan. That car is being parted out due to severe rust and rather than do a half way rebuild I am going to yank the engine out of the 78 and install it on my engine stand, and drop in the engine from the 77. Since I've pretty much got settled at my house I hope to start the work in 2014.
Now for the mirrors
Pics of the head & block:
Since I decided I am going to Carlisle this year I have kicked things into high gear so to speak. I have gone ahead & got me a little work done on the car today and hope to get more done, provided the weather stays nice. We're supposed to get snow so I'm not sure what else I will be able to get done in the next few days.
Since it was nice enough I decided to clean up the cylinder head and get ready to reassemble it. I degreased it completely & got it all scraped of any old head gasket material & then took it by the garage door to give it a fresh coat of Ford Blue paint. While I was at it I also painted the block so it looks a little better. Not as good of a job as my 77 but better than it was.
In addition I also took the time to install the mirrors I had in the garage. The paint doesn't match & they need cleaned up but they look better than what the car had before, which was nothing.
While coming home from some errands something popped off in my head. The radiator cap looked ancient & is a cheap fix so I went ahead & got a new radiator cap. At this time I'm gonna prolly end up installing it & leaving the heater core alone to save a few bucks. Worse case scenario I gotta disconnect the heater core for now but I'll cross that bridge when I get to it. The carpet is shot anyways so I can't ruin it.
When it rains, it pours.....
Tried to work on the car some since it was so beautiful out today. Got the engine deck scraped down of any gasket material & fired up my compressor hoping to be able to remove the crank bolt. Luck was not on my side today, as it decided not to come out. Not because it doesn't want to, but because my impact decided to die on me. Not good considering I haven't had it long. Nope, can't return it since I got it at a flea market. It worked fine before but I had it on the garage floor. Apparently it floods to the point that water got to it & killed it. Same thing that happened to the last one. I wish Dad would friggin listen to me & fix the dang drain that is flooding the garage!!
Anyways I went ahead & tried to pressure test the radiator & it won't hold pressure. It was one out of an older Pinto anyways so I'm not too heartbroken but now I gotta track down a darn radiator since I can't pull the one from the 77 just yet. It gets better. Because of that now I am in complete doubt that I can save that heater core, especially with the crap that was coming out of it when I was flushing it. I officially think the Pinto Gods hate me, sending me this piece of junk to get back to running shape. I am beginning to think the only good thing on it is the fact that the floors have no rot & the interior is the deluxe interior. Not much else good about it at this time.
Especially since today I found out my rear window is leaking water at the window seal. I peel back the seal a little bit & there is some rust forming, indicating it's been leaking for some time.
Lastly I was going to install my spare water pump since the original is nasty & prolly no good considering everything else on the cooling system is shot, and couldn't find it for anything! At that point I gave up since the car clearly wants to piss me off. Was thinking of pulling the cylinder head off the work bench & giving it a quick coat of paint but with the way my luck was going with the car today I would prolly drop it on my foot & end up in the hospital lol.
I wish I had pics of it before I fixed it but too late for that now lol. Here's some of the repair
Today I got motivated big time so I started to work on the car. First thing I wanted to do is straighten out that crumpled mess of a lower core support. It was so bad the hood latch bracket that went from top to bottom of the core support was twisted up. I got out the torch & started to heat it up. I was heating & hammering but no luck. My Dad came out to give me a hand but still no luck. Then the lightbulb went off... Why not use a hydraulic jack as a ram to push it back into shape?
No luck. All the fluid would drain away from the cylinder & not pump. So Dad had an idea... Why not use the spare jack I had from the 77 Pinto? He got it in place wedged against the back of the bumper with the notch lined in the hole for the latch bracket. With the help of a Toyota lug wrench, and a little heat that sucker bent right back into shape!
I went ahead & filled up a pan of water & clinched the lower core support to keep it from bending back when I removed the jack. I let it cool for an additional 10 minutes & removed the jack. SUCCESS!!!!
The core support is now fixed so all I gotta do is put the hood latch bracket back on. Since it is all wet & dirty I can't paint it or anything but I will be doing that when I can so it looks better. Not seen much but I want it to look as good as possible.
Couldn't find my valve spring compressor so I picked one up from Harbor Freight for $15. When I got home I used it to remove the valves from the head. The valves are now soaking on cleaner, and tomorrow I plan on going over them with a brush to finish cleaning them. When I removed the valve stem seals they were cracking & crumbling bigtime. About half of them broke off in two pieces as I removed them from the head. Tomorrow I will also degrease the cylinder head so it'll be nice and clean once the valves are reinstalled in the head.
Got some work done to the cylinder head. Went ahead & cleared a spot on my work bench & scraped off the old dirt & grease, as well as any old gasket material. The engine had never been apart & the intake manifold gasket actually had the Ford logo on it. Next I removed the bad cam followers & camshaft. The lifters didn't want to come out too well as they were a bit varnished. I have them soaking over night & will make sure the lifter bosses are grime free before reinstalling them. The cam gasket was shot & leaking bigtime. With a sharpie I marked the valves & will soak them once I have them removed from the head. There is a lot of baked on carbon & oil so I gotta take care of making sure they are clean. Tomorrow I will look for my valve spring compressor & remove the valve springs so I can soak them & clean the head before reassembly with the ranger roller cam & followers.
Taking another cost cutting measure. For now I'm gonna bypass the heater core so I can get the car driveable & make sure the radiator is ok. I'm gonna pressure test it but have my doubts that it will be alright. The other cost cutting measure is I am gonna try to salvage the intake manifold even though it was corroded bigtime inside. We'll see what happens.
Well I figured out how to save a little money. What I'm going to do is take the heater core from the 77 parts car & install that in the 80. While the core is prolly the original one from 77 I always had good heat from the 77 so I might as well use what I have instead of buying new. Depending on weather I will be pulling the box from the 77 to get the heater core for the 80 this weekend.
Since it was so nice today I went ahead & painted the valve cover & timing cover I'm going to use for my car's engine. It wasn't necessary but it will make it look better. The timing cover was a spare unit I had in my parts selection & the valve cover was the original cover. I pulled the clean rocker arms out of the cleaner & set them on a clean rag to let them dry out some so I can inspect them. On Thursday I get paid so I can then get a can of brake cleaner to make sure they are clean of any residue and the bearings spin freely.
The toriginal so I hermostat housing was actually rusted about half inch down so I have a replacement housing. The t-stat was the original so I got a replacement. The water pump is ok but I'm prolly gonna use a spare pump I have in the garage & replace it with a new unit when I pull the engine to be rebuilt. I'm not sure about the condition of the core plugs or the heater core but I'm more than likely gonna replace the heater core. I'm not even sure about the condition of the radiator. I ran water through it until it was clear but not sure of what to expect of it. Hopefully it's not shot as well.
