Date: 11/11/2019 04:49 pm
pintos for sale
Date: 12/11/2018 04:29 pm
Date: 03/14/2020 01:52 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 07/01/2019 12:23 pm
Date: 02/18/2017 05:55 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
  • Online today: 586
  • Guests: 464
  • Total: 464
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
I'd bet your heater core is nearly plugged as well & that antifreeze became acidic & ate the aluminum. It has something to do with electrolisis in the cooling system. That's the reason for bi-annual flush & fills or 5 year coolant. That is OLD coolant.
I would pop the soft plugs out(I'm betting they are nearly rotted through) and flush all the water passages in the head & block. Your water pump & thermostat housing are gonna be nasty as well. Use brass freeze plugs & a good brass thermostat, trust me....
Yep, the manifold is done for. I scraped at more corrosion that was in there & underneath was some nasty wear inside. Considering the facts that it is a greasy mess, combined with the corrosion inside I'm gonna be getting a replacement manifold.
Anything worth doing is worth doing right and I don't feel using a corroded manifold would be right, let alone a good idea.
That's what I'm thinking of doing. I'm not too sure it's gonna be good considering how plugged the intake was.
I did manage to poke & scrape at the manifold & got the blockage taken care of but considering how bad it was I'm pretty sure it's gonna be done for.
cromcru
i say replace the heater core. i went thru the same thing when i bought my 74 in jan of 2010. it well save you major headaches later on.
Three more. With this I'm starting to question whether or not to replace the heater core while this is all apart.
First pic is the goop that is in the manifold cooling port
It seems this car hates me soooooo much.
I got the carb all back together & decided to start cleaning up the intake manifold. I sprayed it with some degreaser and sprayed the ports down. I wasn't gonna remove the cover where the coolant runs through since it wasn't leaking but after seeing the nastyness in the coolant port I went ahead & removed it. That was so disgusting that I'm not sure how the coolant was flowing from how plugged it is.
What's so irritating is that as frustrating the 77 was one thing I can say without a doubt is the cooling system was not a mess. I only drove the car about 3-5 miles before the LF blew & I don't even know how the car made it that far with this plugged cooling system.
I'm highly considering looking for another intake since this thing is so plugged I don't know how it will even come clean.
Thanks Dwayne, The polish I'm using is called Royal Blue. I bought it at the Ohio State Fair and it's doing exactly what they claimed. the 1980 and the center caps are proof of that.
I'd say that's a major improvement!
Dwayne :)
Thanks Dwayne & Pinto5.0  ;D . I hope to be able to take the car on the stampede this year since I won't be going to Carlisle since I'm buying a house this June.
Since it's in the 20s today and I don't have heat in the garage I wasn't able to work on the car much so I went ahead & grabbed the alloy wheel caps from the garage. They aren't perfect but turned out pretty good.
The one on the right is how they looked when I got them off ebay, and the one on the left is the end result after polishing.
It really is starting to look good, Matt.  Keep up the good work!
Dwayne :)
All the work payed off. It cleaned up nice.
Forgot to mention something interesting I found when I was polishing the paint on my car. Rivets evenly spaced on the rocker panels, one every 5 or 6 inches down the center, and on the lower fender as well. From what I found out my car prolly had the lower rocker panel moulding from the factory, as well as possibly the wheel well trim. Farther investigation will be done tomorrow in the day time and I will then decide what to do later on. If the car had that stuff from the factory I would love to get the exterior accents back but I know they would be very very hard to find.
Did a little more work. I went ahead & used some Meguire's quick detail on the metal dash & it cleaned up nicely. I had removed the old headlight switch so I went ahead & installed the NOS unit I bought on ebay a few months ago, and re-installed the instrument cluster. The car is slowly coming together with what I can do while without a working air compressor.
I also went ahead & checked the process or the carb soaking, as well as the soaking bolts, and degreased the valve cover. The spare valve cover I have in the garage looks in worse shape than the original valve cover so I chose to go with what I had. The head bolts are also soaking, and come tomorrow I will be checking the threads, as well as running a tap through the bolt holes. If all goes according to plan I will be reassembling the top end of the engine.
I have a brass wheel I wanna use on the combustion chambers, and want to change out the bad valve stem seals as well before installing the head.
Pics!
I was bored & since my air compressor is dead I couldn't do much to the car. With that in mind I decided to polish it up. The paint is really rouch & some areas are crusty, rusty but for now she looks better than before. The name Fred seems to keep popping in my head for some reason so her name is Fred. Fred is now as shiney as she can get for the time being. I hope that I can push the car up the driveway soon and get the tires swapped over. Otherwise she will look pretty ratty with those 14s lol.
From where I'm sitting she's BEAUTIFUL!
Even though I washed it I still can't believe how much better the car looks.
Results of first bath the car has had since at least 2008, if not longer
Pics of the polished paint
Today I washed the car & she already looks a lot better. I went ahead & was cleaning up the carb & decided to work on the engine some. The inside of the rear timing cover was nasty with oil so I removed it to inspect the intermediate shaft. I removed the gear & the first thing I noticed was a groove in the shaft. Not good that I would need to replace the intermediate shaft but I went ahead & checked a spare engine block that came from a 1980 Ford Courier. I still had the shaft in the block so I removed it & found it to be in perfect shape! Went ahead & cleaned it up, lubed up the bearings with assembly lube & installed it. I wasn't able to remove the crank pulley, since my air compressor decided to die on me. The starter is still on the car & it is at the bottom of a slanted driveway, so locking the flexplate isn't an option. I gotta either pick up a new air compressor or think of another way to remove the crank pulley bolt.
Major brain fart with the carb. Not good to let the parts soak for almost 7 months. Everything in the cleaning solution is gummed up & will prolly be junk. Stupid mistake but oh well. Time to start from the beginning & try again. Good thing I got a couple parts carbs to replace the parts that are too far gummed up.
When it rains, it pours. Literally!!  >:( >:(  First nice week in a long time & I can't work on the car due to the rain. I was able to get a little work done though. I degreased the driver side of the engine block, removed the radiator, started to scrape the block, found another carb to install, found a water leak inside I didn't know about, and buffed the paint on the front clip.
The water leak I'm talking about was found on accident. I was in the car looking at the fuse box when I noticed water coming down the passenger door speaker. Not sure where it's coming from but I think it's from either the loose door mirror or bad door seal. Not much else has been done to the car because of the rain but I did also find a bent up radiator core support. It was so bent up the center bracket that supports the grille & hood release was twisted. I figure to remove it what I will do is take off the bumper for better access and heat up the core support before beating it out with my BFH.
The car isn't gonna be perfect by any means but I don't wanna chance anything happening to the radiator, which was a little jacked up at the bottom anyways. When I get a moment I will post the pics of the work on the front clip. The paint sucks but at least it shines up a little.
Installed the radio antenna from the 77 to the 80. The one on the 80 looked like crap, being all pitted & nasty. Stupid aftermarket POS. It's not hooked up but looks better than the old one.
Went ahead & swapped out the lock buttons & the turn signal stalk on the 80. There were some jacked up aftermarket crap installed on the 80 so I installed the OE styled ones that were on the 77. May not be much progress but it's better than nothing.
First day back in a long while... Anyways, haven't had the time or patience to work on the car lately as I've been working on myself lately. Had some issues to take care of financially & actually got out & enjoyed life for a while. Anyways, I plan on soon rebuilding the cylinder head & getting the car running. Eventually an entire rebuild is in the car's future & while I am rebuilding the original 91k mile engine the 77s 124k engine will be in its place.
Went ahead & got back to the junkyard to see if I could get the cam from the Ranger. Well, I wasn't able to get it from the Ranger but found a 93 Ranger that was willing to give up its cam. Got the cam & later on got to work on the car. I managed to get the exhaust manifold and intake manifold off the head. When I looked at the water jacket on the intake it was pretty much plugged with all the  crud & corrosion. I was so pissed at what I saw I went ahead & pulled the head. That engine didn't want to give it up but eventually lost. Got the head off the car, to see a nasty looking head gasket but it was still in ok shape. Some places looked a bit bad but overall fine for a 32 year old head gasket. I also checked out the timing belt tensioner & it spins way too easily & is rather noisy. No shocker there as it was the same way on my 77 when I tore into it. I gotta see what I can do to get this thing fixed but know that won't be an easy task as of yet. This car was not taken care of mechanically & it shows.
Went to the junkyard to get a roller cam & followers. Managed to get the roller followers but the Ranger didn't wanna give up the cam. Don't wanna do this but will be buying a new cam & use the followers I got from the junkyard. It will be in Tuesday. While I am waiting for it to come in I am gonna get the gaskets & other parts so I can start getting that stuff all taken care of. I got a way to pressure test the radiator so I will do so to make sure it's fine. Once I get the water pump, cylinder head & water outlet installed I will be flushing the entire cooling system out to make sure all the crud is out of the engine.
Today when I got home from work I dove into the Pinto's engine.  The engine had a bad oil leak & what caused it was the fact the valve cover bolts were not tight. I didn't even need the ratchet to loosen them. I removed the valve cover & the inside was immaculate! Not one bit of sludge whatsoever. I did notice a nearly new gasket ruined by clear silicone. the gasket even came off in one piece. No cleanup there. I will be degreasing the valve cover & repainting it, as the original paint has seen better days. I checked out the cam & no suprise, it is worn out. All the lobes were worn so I will be getting a replacement. I will look for a Ranger roller cam but if I can't find one I will go ahead & install another slider cam. Next I removed the water pump & found it is okay. No corrosion to the impeller at all! I will degrease it & reinstall it on the block, once I remove all the old sealer that was glopped on so thick the bolts were sticking in the bolt holes.
What was supposed to be an easy fix is turning into more with every turn of the wrench. Oh well, cars will be cars.
Quote from: sedandelivery on September 08, 2012, 08:42:25 PM
Absolutly replace the pump. I had a similar situation and I took off my pump to find the impeller was almost completely rusted away. A new pump only cost 30.00 I think for a new one.
That's another reason i will be pulling the old one. I wanna make sure there is no corrosion to the impeller. I'm thinking there has to be some since the corrosion was bad enough to eat away at the t-stat housing. That's also why I am considering replacing the head gasket. It's my fear that if one part is badly corroded how will the rest be.
