Date: 07/13/2018 02:21 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 01/24/2021 07:54 pm
Date: 05/13/2021 05:29 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
  • Online today: 586
  • Guests: 213
  • Total: 213
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
sedandelivery
Absolutly replace the pump. I had a similar situation and I took off my pump to find the impeller was almost completely rusted away. A new pump only cost 30.00 I think for a new one.
I would put a water pump on it. New is better than rebuilt but a rebuilt will be cheap insurance against it failing. Once the rest of the system is up to snuff that old one isn't gonna last a month.
I swear when you think you are gonna get somewhere someone pulls you back to reality and proves you wrong...
I went outside planning on pulling the radiator, replacing the timing belt & after a few other repairs having the car running this evening. Well, I was proven wrong again. I started by loosening the radiator petcock to drain out the old coolant & it wouldn't drain. I thought there was something wrong so I kept trying but only a few drips. I got out a wrench & ended up removing it, to see nasty, brown, cruddy antifreeze coming out. Flushed out the radiator with a garden hose until I got clear water but was concerned. Looked at the petcock & it was packed with so much dirt & crud it wouldn't drain. No problem, I figured I would replace it. Got to thinking what else is plugged, so I went ahead & pulled the upper & lower hose. Interesting find with the upper hose. The t-stat housing was so corroded there is 1/4" of the housing gone at the top where the hose goes. The  t-stat was also stuck in the housing. More muddy coolant in the head... I went ahead & checked the hose & it is mushy so that is gonna be replaced. Also removed the lower hose, which is also crap, as well as the hoses going from the heater core to the t-stat & water pump. All those rubber hoses will be replaced. I went ahead & removed the fan from the water pump & fortunately the bearing is still good. Just as a precaution I am gonna remove it & make sure there is no debris in there, as well as get a new gasket.
All this corrosion & crud in the coolant is now making me wonder about the condition of both the radiator, and head gasket. The radiator is a no brainer. Remove it & have it pressure tested, as well as professionally flushed. The head gasket, that is a little different. I'm not sure about tackling that just yet, as I wasn't planning to at this time but might end up doing it anyways. It's also got me concerned of that heater core. Wondering what kind of crap is in it or if it will leak as well.
So the day started off with me planning on having the car running by the end of the day, now with the realization that it needs more than I thought to get the car running, and with no cash to do it with. Not a good day at Matt Manter's house. First the tranny goes out on the 77, now the 80 needs more work than thought in order to be driveable.
Thanks Becky, As soon as I saw then I had to get them. Too good a price to pass up.
Now for updates on the car. I removed the char broiled fuel pump & looked at the hoses. Well, it looks like one ruptured since it was very much charred and blown out. There were two hoses & one was still in one piece, just a little cracked.  The other one was all charred with a hole in it. I think the hose blew out & possibly caused some of the fire. Regardless I am replacing all the hoses, as well as the metal like that would not come off the pump. Before I attempt to start the car I will replace the rear fuel hoses as well. I was gonna take the car to the Ohio Pinto meet but I wanna get the car right before taking it on such a long trip.
Quote from: r4pinto on August 30, 2012, 07:09:37 PM
Pics of the center caps
I saw those on ebay a few days ago. I was considering putting a bid on them, but I'm on the search for Civil War crap, so I didn't. Good get, Matty!
Update:
I went to "Swappers Day" in johnstown, Ohio and found a pair of speakers that I am gonna try to install inthe door. not sure how they will fit since they aren't flush mount but not bad for $4.00. I also went ahead & tore into the nightmare of the fuel pump. Wow is that car an oily mess down there. Time to degrease everything. The fuel pump may not have been a problem, as I found a burst fuel hose. Either way I'm not gonna chance it since I have a spare fuel pump & the old one shows fire damage. In addition the metal line would not come off the old fuel pump so I am gonna bend a new line going to the carb from the pump. I hope to have the car running by tomorrow, but we will see.
Just got a pair of the aluminum wheel caps since my alloys didn't have any. I got them off ebay for $22 shipped. They aren't perfect but neither are the wheels. Regardless they will look better than wheels without the centers.
Well the metal lines are in good shape. It's just the rubber hoses that are needing changed. Replacing them as a precaution. Only one fire per car allowed in my household
Alpine615
Hey Matt, it's been a while! What are you thinking for replacement fuel lines? Are you going to re-use Harold's? Or go aftermarket?
1980 Runabout
The end is near for Harold II so it is time I get my butt in gear and get this car back on the road. The goal for this weekend is to remove the timing belt & put a new one on, install the new distributor, rebuild & reinstall the carburetor, replace the fuel pump & all the fuel lines, change the oil, clean the interior, swap the tires from the 77, and adjust the exhaust pipe on the back. I have a little more than two days, as I am gonna be working on the car all I can from the moment I get home tonight until there is no more light Sunday. When I get done the car will run and will be ready for the first drive on Monday morning.
What to do... What to do... What to do...
Haven't really worked on the car much but today I walked around it & spotted a little hole in the left front fender. It's got rust in the usual places & while I have patch panels for the rear quarters I am thinking I might have to go ahead & replace the front fenders. Not too sure and for now I am gonna go ahead & finish polishing the car but more importantly I have to get it running. Hopefully tomorrow evening I will be setting the timing on the engine so I can index the distributor. We'll see what happens. Gotta decide if this car or Harold II is going to the Ohio Pinto meet.
Cool, I will let you know. It's the Holley 5200 carb with all the emissions junk connections. Ran really well before the fire, hopefully it will do the same after I get it all back together
78_starsky
what size/style carb?  i might have one that i can send you free for a parts carb if you need it.  I have to check to make sure that i have the carb from the 2.3 in the box of parts still. that was a nasty fire.
Sure will Thanks Bill! Just gotta get it all cleaned up & a carb mounted under the air cleaner. It's really nasty & parts have been soaking for 2 days.
blink77
Matt
Got your check today. If you need anything else that I might
have let me know.
Bill aka blink77
I got one thing done to the car today. It was sort of out of sync with what the car needs but what I went ahead & did was replace the wipers on the car. Over at Ollies Bargain Outlet they have off brand wipers for $2.99 each. I had got a pair for my 77 when in Carlisle & they worked pretty well so I went there & got a pair for the 80 as well. I would have just taken the ones off the 77 but they are a month and a half old, and if I drive that car in the rain I sorta need them lol.
I started to demo the carb to clean it & that thing at the EGR port was so plugged up that I came to the conclusion that I needed to get a can of carb/parts cleaner to soak the parts in. One thing that I did not see inside was rust so I'm glad of that. I got parts soaking currently to take care of all the carbon & dirt that was inside & outside the carb. Needless to say it was supposed to rain all weekend so I did not even try to work on the car outside. At least I'm one step closer. I might go ahead and try to set the timing on the engine so I can install the replacement distributor, as well as the new plug wires.
Got paid today so now I'm going to get this car running, hopefully by the end of the night! When I get off work I am gonna get the cap, rotor & plug wires. I will also get some carburetor cleaner to rebuild the carburetor, as well as replace the fuel pump & hoses. Wow... that sounds like a lot on "paper" Maybe not running tonite but I'm gonna give it my best. Then I will drive the car around the block & sound the horn in front of the nosey neighbor's house & drive the car away.. Take that jerks!
Thanks to blink77 today was like Christmas for me & the Pinto. I got a big box today & in it was the air cleaner & air intake box. He told me I would be pleasently suprised abou what else was in there & all I can say is thanks!! Vacuum lines!!! YAY!!!!
I was so happy to see that in there that I went out to the car & installed them. It's so nice not to have to worry about figuring out where they hooked up since they are just the way they should be. There are still a couple other pieces the car will need to be right but at least it is getting closer.
Tested the radio hook up & so far so good. It appears that I have either bad wiring or just a dead speaker on the passenger side, as no sound. I'm gonna have to check in to it some other time but at least I know the radio works.
After receiving a violation in the mail regarding the Pinto not being registered I went ahead & got to work on the car. The car has temporary tags on it so the violation was pretty stupid.
Anyways, I went ahead and worked on replacing the bad wiring in the engine compartment, but it was really hot so I went ahead an moved indoors to work on the radio. The car had a Sony digital radio in it but the right channel didn' work so I decided to install a different unit. In the garage I had a Kraco AM/FM weatherband radio, as well as a replacement radio bezel. I filed the bezel about 1/2 inch on each side & fit the radio. I also installed the blade terminals that will plug in to the speaker connections in the car. I lucked out & found a pair of Ford radio knobs in the garage tht look better compared to the Kraco knobs.
I sure will Bill.
Thanks for ID'ing yourself on here so I knew who to thank properly lol.
I should be fine with the carb & actually have a couple plastic nuts. Managed to hang on to them from the 78 I used to have. The carb seems alright & I have a rebuild kit for it but will let you know for sure.
blink77
Matt
Let me know when you get the aircleaner and stuff.
If I'd have thought about it I could have sent you
the plastic wing nuts that hold it on. If you need a
carb I also have a good one off a 1980. If you need
anything else, let me know.
Haha... Not a bad idea... Only thing is I have family with the last name Murphy & they drive me nuts. That would be a reminder lol.
Now for the update on the car. It's been too hot to really do anything outside but the good thing is the wiring harness from Steve AKA Alpine615 has arrived. Thanks! Now I have started the painful process of fixing the fire damage. It's not an exact match in some sections so I'm having to mod it a little. It seems that there are some wires for extra parts that aren't on my car. No harm as the old wiring,although burnt to a crisp, is still able to be used as a template for anthing that needs to be switched. It's gonna be perfect once I get it all installed.! I also have an air cleaner assembly from someone in Michigan, who I don't know his username on here. Hopefully he can chime in on here & shed some light on the mystery lol. I'm also gonna be getting the radio ready to install in the car. Just gotta crimp some connectors & in it goes.
The radio is a kraco weather band radio an will work great until I part out the 77 & install the 8 track from her.
Future mods for this car include a/c, dual horns, and map light. Everything else is pretty much in the car! All I have to do is fix the rust outside & get her repainted. I'm leaning towards the robin egg blue since that was original but I'm not totally sure.
i believe id name the car Murphy,,,, you know,,, as in murphys law.....:D
Nope, no updates. The power is out at my house due to a series of heavy thunder storms so I haven't been able to touch the car recently. It's cool about the harness. Like I said I haven't been able to work on the car anyways.
Alpine615
Any updates??
Also, sorry I've been a complete jackass and not sent out the harness yet. Just too busy getting work done on the house so my parents can list it...and this past weekend was spent in Connecticut with the lady. I will tackle this tonight.
Hope all is well with you,
-Steve
1980 Runabout
Didn't do a damn thing to the car today. Just too hot out. When it hits 103 in Ohio there is a problem. I have a replacement radio I plan on installing in the car that is a little more period correct. I got it for free when I got the 8 track radio I won off ebay. It's not an 8 track but is a nice weather band radio. It will go in until I take the radio from Harold II & install it. The Sony digital radio that was in the car had sticky buttons & no working passenger speaker. I think it was a problem with the radio but will find out for sure after installing the replacement radio.
Oh, I will be there... The car will be there too. WOuldn't miss it for the world
