Date: 08/13/2018 02:46 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 12/20/2016 10:47 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Date: 04/30/2023 04:31 pm
  • Online today: 489
  • Guests: 201
  • Total: 201
302 motor mounting
Started by WTR 70, September 12, 2011, 03:39:21 PM
That pan wont fit. Not even close.
WTR 70
almost thinking getting a normal pan and modifying it to work would be easier
RSM
I do not believe that will work in a Pinto. It looks like a standard Ford oil pan.
WTR 70
i think i might have found an oil pan. the sales guy said it is for the mustang 2
http://www.drivewire.com/search/?Ntt=rpws9532&N=0&uts=true&t_event=true
All those look to be rear sump fox pans reeves and as far as i know no one makes a Mustang II pan unless you can special order it.
http://www.milodon.com/oil-pans/street-oil-pans-ford80.asp
One of them work for you ?
Mine is a one off special build just for this car. Note the notch so the engine sits as low as it can over the rack.
Cheapest...A junk yard. I can get one for $15.00....If I can nab it before someone else does. Almost had my chance a few months ago but someone beat me to it by a day! :'(
The most credible and available place to get it? MustangII.net, but good luck finding someone who will let go of it. Probably won't be very cheap either.
These Stang II pans are worth their weight in gold when it comes to hot rodding a Pinto or restoring a Mustang II, no joke about it.
Don't forget to get the oil pump pickup tube if/when you get the pan. I have heard they are a matched set (please correct me if I am wrong).
WTR 70
so where is the cheapest place to buy a mustang 2 oil pan
WTR 70
Quote from: Bigtimmay on September 14, 2011, 11:36:36 PM
Cal-tracs are easy to build. Heres a how too http://www.hotrodsandhemis.com/Traction.html to help yah build them. Ill prolly build my own too. Just i dont see me trying to build a split-mono leaf spring. lol
that is an awesome link!
Lo5ts of cars dont runs sway bars they just get more body roll then normal but if you dont drive crazy itll be fine.
As for a sway bar that will fit I dont think any will fit its pretty tight in a stock pinto with a 2.3 and the V8 pretty much takes up every inch of space there is.
I've been watching this thread since I have plans for a mild V8 in my 78 Sedan when I can find the Mustang II headers and oil pan + pickup.
With the sway bar removed, how bad is the steering? I have a sway bar on the car right now (15/16" from a station wagon), and it made a big difference when cornering compared to how it did without it.
Is there any other bar you can use with the V8 in the car?
Quote from: WTR 70 on September 14, 2011, 11:32:29 PM
i saw that caltrac kit. it looked pretty sweet to me, but my fab skills are better than my "filling someone elses pocket" skills. i wanna build something like that.
WTR 70
In a drag app you want the front to lift and the rear to hook is the best way to put it.Usually when the front lifts it forces the rear tires to plant themselves and grip the pavement.
A rear sway bar can be useful for drag racing along with some sort of traction device and good shocks.
I personally want to run split mono-leaf springs and Cal-Trac traction bars both of which are sold by Calvert Racing.
WTR 70
well dont think i will have that issue haha, but i didnt know that you didnt want one for the drag strip.
Nope you don't want to run a front sway bar on any car that will be at the strip unless its able to be disconnected. As for driving on the street it wont matter a whole lot unless your trying to keep up with a Porsche or sumthing in the corners anyhow.
RSM
Straight line racing doesn't need a sway bar. The main purpose a sway has is to control body roll when cornering.
WTR 70
so street and mild strip would not be an issue with out it then
Most people dont care about removing the sway bar to put a V8 in a pinto since all they are after is going fast in a straight line or looks.
A V8 road race pinto wouldnt be a very good idea and would prolly just end up handling like crap. Thats about the easiest way to put it. If yah wanna go fast its a perfect swap.
WTR 70
i even looked at a guys car and he never said anything about the sway bar.. that sucks. and are the arms just to help the torque of the motor?
Quote from: WTR 70 on September 13, 2011, 09:01:52 PM
never seen arms like that before... interesting.
http://www.cvfracing.com/adjusting-rods-s/125.htm
I have ordered a number of items from them & all worked out well. This included shipping to Canada.
RSM
Well maybe they don't have a clue at to what they are doing?......
WTR 70
wonder why that detail woukld have beewn left out from the people i talked to
WTR 70
never heard that before...crap
Mustang II front sump pans are totally different on how its shaped compared to any other front sump. http://www.geocities.ws/frdsford/sidebysidepans1.jpg one on the right is a MustangII pan. Plus the sway bar needs to be removed from a pinto to run the V8.
WTR 70
well if im not mistaken the mustang pan is also front sump, so what would the difference be?
gunna need a pan from a Mustang II
WTR 70
would the oil pan on the 73 mustang motor work?
WTR 70
i finally got my motor, 302 out of a 73 mustang, got my transmission, toploader 4 speed out of a 68 mustang, and my limited slip 8.8 out of a 88 ranger. think all i need is the oil pan and pickup, and motor mount style.
WTR 70
never seen arms like that before... interesting. does anyone have the hooker header or hedman header link to the kits that are supposed to be out there, i cant find them. and any info on oil pans would be awesome, trying to gather parts so i can do it over christmas break (damn college schedules)
