Date: 09/10/2018 10:41 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 01/04/2017 04:07 am
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 12/31/2017 09:03 pm
Date: 03/27/2017 10:07 pm
  • Online today: 525
  • Guests: 187
  • Total: 187
302 motor mounting
Started by WTR 70, September 12, 2011, 03:39:21 PM
WTR 70
any issues with exhaust doing it that way?
The MII mounts are a simple bolt on. No major work needed.
WTR 70
which way is easier? the motor mounts or motor plate and figure out how to mount it through rubber mounts
pinto1955
I have the driver side MII motor mount for sale on ebay or I could end it now. It has been rebuilt with the polyurethane insulator so it will never have to be replaced. Don
1972 Ford Pinto SS/MC, HP 2.0, 4 speed, 9" full spool w/6:50 gears
If you plan to drive it more than 500 miles a year use all rubber or urethane mounts. Less than 500 & lots of dragstrip duty then go plates & solid mounts. On a trip over an hour the solid mounting will drive you insane. Same goes for solid suspension bushings & heim joints.
WTR 70
motor plate or motor mounts better idea? and solid or rubber mount on trans? im putting a 302 and toploader in my wagon. would an 8.8 rear work out of a ranger? its the right width, wondering about strength. also wondering what and where to get an oil pan
