Date: 01/04/2017 04:07 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
73 rear hatchback glass
Date: 07/06/2017 11:33 am
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
77-78 front grill
Date: 04/07/2017 12:35 am
  • Online today: 403
  • Guests: 252
  • Total: 252
302 motor mounting
Started by WTR 70, September 12, 2011, 03:39:21 PM
WTR 70
can you post pics of the manifolds or email them to me?
Quote from: WTR 70 on October 02, 2011, 11:49:31 PM
should the stock manifolds clear with room or should the battery still be moved
I cannot answer the battery question, but my 72 with the 302w in it has the manifolds on & they clear everything.
RSM
If your using a Pinto with the 2.3 you leave the passenger side frame mount where it is. The drivers side mount is moved back 1". The Mustang II engine mounts fit right on them. Using a Mustang II oil pan gives clearance for the manual rack and pinion steering. A modified oil pan can be used.
WTR 70
how do the mustang 2 motor mounts work? does it make it a bolt in or do you still have to move something?
WTR 70
71hotrodpinto
Quote from: 71pintoracer on September 29, 2011, 09:04:49 PM
I put mine inside the trunk and ran a small diamater rod from it out through the tail light lens with a small round knob on it and a label on the lens that says "push off" per rules. Just a small hole drilled in a spare lens and the original put away for safe keeping!
Exactly what im talking about. A little innovation and a bit of work. Get an optima battery and i dont think you'll need a battery box or a firewall. But i may be mistaken per NHRA rules. They are usually over the top on things like this anyways. As far as just a place to mount it that's something you'll have to come up with.
However , unless you wrap ALL the tubes ( which will overheat and degrade the headers over a very short time ) you'll bake that battery in a few hundred miles. I'm just speaking from experience.
Wish you luck no matter what!
Lets see some pics!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
WTR 70
I actually looked at a drag wagon a while ago, and he put his kill switch in his tail light lens, he said everyone told him it would crack, but it worked great
RSM
For right now I wont be drag racing the car. It's just got to run and be driveable enough to get it on and off of a trailer for car shows.  Per NHRA rules the master switch has to be accessible so thats not happening right now.
71hotrodpinto
About the battery in the front. Id reconsider. The stock location boils batterys with the 4cly as it is. Plus theres the weight transfer issue if your drag racing a front heavy car.
I didnt even consider keeping it up front when i did mine just for the reliability factor.
Maybe you could put a kill switch in the backup lens or some other conspicuous location that would keep you from drilling holes in the sheetmetal?
Just some thoughts!
Edelbrock Airgap
Mil
I used 71 pintoracers post and made his mounts, made my oil pan to get the motor low as possible and it closes under a stock hood, but its a little snug. Had to move the battery back cause of the headers.
RSM
I'm going to attempt to leave the battery in the original location on mine. If I can find a battery with the right dimensions and enough CCA's I'll try it. I think I might have to wrap 1 header tube to keep the heat down under the battery. The only reason why I want to try this is since moving the battery away from the stock location means you have to have a kill switch per NHRA rules for racing. I dont want to drill any holes in the car and I would be very limited on where I can put the battery with the roll cage I have in the car.
WTR 70
so whats better, mechanical or electric fuel pump? and does the battery have to be moved out of the engine compartment?
Quote from: WTR 70 on September 26, 2011, 08:52:53 PM
That is really suprising there is that much difference, i always kinda figured they were realtively the same chassis's
I always thought they shared more myself till I wanted to use repop MII floorpans on my Pinto & began to realize absolutely nothing interchanges.
Quote from: 79prostreet on September 26, 2011, 08:24:14 PMFrom what I deducted the motor frame mounts had the same location to rack/ crossmember so they allow it to work on the Pinto,just a little tight on the transmission side.
If that was true the sway bar would fit. I've never measured but I "think" the engines all mount about 3/4" to 1 1/4" forward in an MII compared to a Pinto. MII & Pinto front framerails dont interchange & I'm betting if you measured engine mount bolt hole locations in both cars you would find the MII holes slightly farther forward from the crossmember. I would also bet the mounts are 3/8" to 5/8" higher on the frame rails as well. That tiny bit makes a HUGE difference in fit.
WTR 70
79prostreet
I pulled a tape measure on a Mustang ll and found it was 5'' longer from cowl to radiator support,the pc from bottom of steering shaft to rack looked about 3'' to 4'' longer. That's why a v8 fits so much better and would think a better weight transfer for racing. From what I deducted the motor frame mounts had the same location to rack/ crossmember so they allow it to work on the Pinto,just a little tight on the transmission side.
79prostreet
The thing is that the crossmember & suspension pieces are the same between both cars but the engine bays are completely different. Inner fenders, core support, firewall etc. do not interchange & frankly it's amazing that the MII oil pan is even close enough to allow the swap.
The framerails are the same width which is why the mounts will fit but the V8 sits a tad farther forward & slightly higher in the MII  but you can't do that in a Pinto so it's a tight fit.
WTR 70
so i looked at a 4 cylinder mustang 2 tipped on its side, junkyard, got a set of shock plates for the rear axle to start fabbing up the traction bar setup, anyway, the 4 cylinder looked like it had a lot of room around the cross member and sway bar. just wondering how much different the 302 mustang 2 oil pan is from that or how they are different. i know the 4 cyl to 302 is different, but was wondering if they sat lower or what in them
WTR 70
that seems like the way to go to me then, all the other plates require an electric fuel pump that i have seen
You mean as far as clearance? no, none at all, used a stock 302 fuel pump but I did relocate the fuel lines because on the '71-'73 body they run inside of the frame rail.
WTR 70
Quote from: 71pintoracer on September 22, 2011, 07:53:38 PM
Yes thats mine. Doing the mounts that way clears up a lot of room for the starter and the headers. As far as the hood, I think a few have tucked the engine under a stock hood with a low intake and low profile air cleaner just because they wanted it to look as stock as possible, but even a small hood scoop will help and unless you have some very quiet mufflers it's not going to be a secret very long. I can't seem to fool anyone.
Also did you have any issues with the fuel pump?
WTR 70
HAHAHA ya im just going for the fooling people while the car is off, after that nobody will be wondering  :)
Quote from: 71pintoracer on September 22, 2011, 06:49:50 PM
Pinto5.0, hard to tell w/o a mII pan to compare it to but the issue is where the pan angles down to the sump. The mII pan is flat not angled at all and kind of dished out right at the sump to give more clearance for the rack. I had to use one to make my headers fit right. I've seen those low profile pans on e-bay as well, sure would be nice to know if they would work because the mII pans are pretty rare although they do pop up from time to time.
Like I said I was gonna make my own frame mounts so that slight angle was no biggie. I was gonna position the engine to clear everything THEN make frame mounts to keep it there. I was also gonna use standard 302 rubber mounts since I have a new pair already. Now that I have the '73 all that out the window since I have to swap the crossmember.
WTR 70
no difference in height just the weight issue. It's a really tight fit to get it under the hood.
(Thanks for posting the link to my swap Reeves1! :) )
i believe your car is the one i saw with the seperated motor mounts that bolt to the heads wasnt it?
WTR 70
so i should just do an after market intake and cut the hood
Quote from: WTR 70 on September 22, 2011, 06:22:44 PM
is the height different from a 4bl to a 2bl stock cast intake?
WTR 70
RSM
The intake is called an Xelerator...not sure who made it. It's not an air gap but sits higher than a factory cast iron 4bbl intake manifold.
I finally snapped a few pics of the pan I got off Ebay a couple years ago. I haven't been able to compare it directly to the MII pan but it looks close. I was going to make my own frame mounts anyway & I had to cut the hood for the tunnel ram so if I had to raise the engine slightly to make it work it was no biggie. For $69 bucks with the pickup it was worth the shot.
