Mirror
Date: 04/15/2020 01:42 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
72 Pinto parts
Date: 12/04/2018 09:56 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 05/13/2021 05:29 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
  • Online today: 481
  • Guests: 211
  • Total: 211
302 motor mounting
Started by WTR 70, September 12, 2011, 03:39:21 PM
Quote from: WTR 70 on September 10, 2012, 09:20:11 AM
how do i put pics up on here? the project is nearing completion :) just wanted to show everyone how i did it
Photo bucket
Up load the pics. When ready to post copy the bottom (img) of the 4 links it will show. Paste it in it's own line.
WTR 70
Uncoated/Raw Headers
  • SB-Ford 260-351W (All)
  • 1-5/8'' Tube Diameter
  • 2-1/2'' Collector
  • SAP Port Shape
    776-D601-R
  • [/l][/l]
[/list]
WTR 70
would a radiator 21-3/8" Wide and 19-3/4" Tall fit in between the rails? i cant measure my car right now, 200 miles away from it and just found an aluminum radiator for 200, can someone let me know if this would fit between, thanks guys
WTR 70
possibly found an easier way to do exhaust, basically tubular manifolds...have to see how it works
WTR 70
they look like they'd work i just cant see payin that much haha
beaner
i have the hooker headers on my 73 and they fit fine
brad :)
jim72
It's my understanding that '71-'73's have a narrower engine bay thus conversion parts for '74 and later are not compatable. I have an N.O.S. set of hooker headers for early chassis pintos that I bought back in 1983 . They have never been bolted up or fired through. They have no rust or dings in them AND THEY MIGHT BE FOR SALE depending on the power plant I will be putting in my latest project. If I have the engine bay thing wrong please correct me.
norcalfiddy
hello all! im picking up a 73 and i already have a complete 5.0 HO out of my wrecked 89 mustang, and my question is, will 74-79 v8 swap headers fit in a 73?? or would i have to make some?..
heres the headers i found: http://www.summitracing.com/parts/HOK-6161HKR/Application/?prefilter=0
v8junkie
That looks like an awesome tool for designing headers, thank you for sharing Late!
73 Pinto Wagon
64 Falcon Futura Convertible
lateniteauto
Ice Engine Works makes a kit to mock up headers.  http://www.icengineworks.com/icewmain.htm I am currently waiting for my header flanges to show up so I can start mock up.  I am impressed with how easy these things are to use.  One thing I don't like about them, if you want to make a full length header, as the primary pipes start getting long, these plastic pieces don't support their own weight very well.  IEW recommends using super glue... I have found a few pieces of electrical tape does the trick quite well and you can reuse them over and over.  Check it out.  I will post a pic of the 53 ford truck that we have started using them on.  AWESOME.  We purchased the cheaper starter kit, and found that it is only enough pieces to do one side at a time.  Just my two cents.
WTR 70
kinda thinking we are going to have to come out and curve up then go back, it is a bit tight if we go down out of the head haha, we will see!
Quote from: WTR 70 on January 22, 2012, 01:32:44 PM
anyone ever attempt to build headers for these? i found a set of manifolds but only have an 1/8 inch on either side. just ordered flanges and 90 degree mandrel bends to try to build a set. if anyone has, any input would be appreciated
speaking from experience (not building them for pintos specifically).
be VERY patient. plan it out. really THINK about how those pipes will be routed. think about access for performing regular maintenance. think about ease of installation & removal.
WTR 70
Simple.
Start a Photo Bucket account. Load pictures. When done, put your cusor over a picture. In the pop up box there will be 4 code line boxes. Click the bottom (img) box & it will auto copy.
Right click in your post where you want the picture & "paste".
Leave a line or two between each picture, or they may end up side by each & make your post too wide.
You may want to start a topic in Your Projects about your build.
Would like to see pictures !
WTR 70
i'd post a pic of the pan but idk how to add that
WTR 70
Quote from: Reeves1 on January 18, 2012, 05:18:11 PM
Before you sell it, try it & a stock pan. See which one gives you more clearance for the engine to be lower & farther back.
i modified my stock pan and the stock pickup tube, i set it back farther then either of them would without being modified, so i decided to cut the stock one up insted of cutting the mustang 2 one, so i could resell it
Quote from: WTR 70 on January 18, 2012, 04:18:26 PM
anyone looking for a mustang 2 pan and pickup tube? i have one i'd sell now
WTR 70
Back in the 70s when I built the 3 72s with a 302w I used the stock pan as well.
v8junkie
Quote from: WTR 70 on September 15, 2011, 06:44:33 PM
so where is the cheapest place to buy a mustang 2 oil pan
I did a v8 into a 74 wagon years ago, i have many pictures of this car i may post later. My point i want to make though is that i used a 66 mustang 289 and altered nothing from stock on the motor except the passenger exhaust manifold. I had to mill off the heat tube for the choke for added clearance. I did however move the passenger 2.3 mount forward vs. Moving the drivers side back. So there are options, each having positives and negatives. I hope this helps.
73 Pinto Wagon
WTR 70
any factory ones that will work?
Your original rad will not be enough for a V8.
If you have a rad shop near by, they should be able to make any rad size you want.
WTR 70
i have been using the factory one of the 4 banger to mock up, i might just use that fan and the original radiator, i just had it redone and not really wanting to buy an aluminum one, even though $130 isnt bad
Haven't found a fan yet to try.
Went to the local junk yard & they had not a one ! All electric. Nothing older than 10 years.
WTR 70
do you have clearence for a fan and the radiator on the inside of the core support?
Quote from: WTR 70 on January 13, 2012, 12:24:45 AM
is that damper required or do ya know? or should it work by changing pump and pulleys
Just change pump, pulleys and alt brackets. Depending on what timing cover you have, it may need changing as well.
I was told I would have to change mine so ordered it. Turns out I did not need it.
One parts guy also told me none of the parts would work on my BOSS 302 as it is a big block. I told him no , it is not a big block. Just sell me the parts ! LOL !
I did however, have to order the 351C alt brackets , due to the bolt pattern on the heads. They should be here this week.
Alt is just hanging there on one bolt. The new brackets will make it sit different & back farther.
I am interested in seeing how you got it all to fit and still have a sway bar. I hope to keep my sway bar on when I do the swap on my 78, if at all possible.
WTR 70
