Windshield
Date: 01/15/2022 09:31 pm
Date: 01/24/2017 12:36 pm
Date: 10/11/2019 11:13 am
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
Date: 03/27/2017 10:07 pm
Date: 02/18/2017 04:41 pm
Date: 12/04/2018 07:40 pm
Date: 01/28/2019 05:15 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
  • Online today: 445
  • Users: 1
  • Guests: 179
  • Total: 180
  • Wittsend
302 motor mounting
Started by WTR 70, September 12, 2011, 03:39:21 PM
WTR 70
is your intake an air gap or anything thats higher? would the factory cast one work to where you wouldnt have to cut the hood?
RSM
The 289 and 302 are both Windsor engines so physically they are the same. It will depend on carb, air cleaner and intake as to how much hood clearance you will have. I have an aluminum intake with a Holley 650 which will fit under the hood...barely, but no room for an air cleaner so I will wind up with a hole in the hood.
From what I hear...An MII oil pan will allow a 289 to fit snug under the hood, not sure about a 302 though. I'm sure a lower profile air cleaner would be necessary as well.
WTR 70
next question. hood clearence, does the 302 fit under the hood or what is required to make it fit under the hood?
WTR 70
i keep seeing different ways of using the engine plate, getting some ideas now
Quote from: 71pintoracer on September 19, 2011, 07:47:28 PM
[so has anybody used the front engine plate?
I made my own engine mounts that are similar to a plate and very easy to do. Much easier than regular mII mounts I think. I outlined the entire swap into a '71, you can prob still find it if you do a search on V8 swaps, mine is in the projects section titled "71 V8 Swap, Let The Fun Begin" Should answer some of your questions. Haven't been around much lately, lot of issues going on but some members may remember me!
http://www.fordpinto.com/your-project/71-v8-swap-let-the-fun-begin!!/msg58137/#msg58137
[/quote]
289pinto
1978 Pinto wagon, 289, 8" rear, 17" cobra R rims
289pinto
Here are a couple pics of my notched oil pan:
289pinto
Yes my car is a v8. actually a 302 now and yes it has the sway bar in it. thats why i had to notch the pan. I'll try to take a pic of it.
WTR 70
i see your text thing says 289, does your wagon have a v8? and do you have the sway bar in it still?
289pinto
I used a early mustang pan and just notched the front of of it, the piece I cut out I just flipped over and welded back in. I wouldn't want to drive around without a sway bar myself.
WTR 70
WTR 70
definitely interesting setup for headers right there
WTR 70
Quote from: WTR 70 on September 16, 2011, 07:50:00 PM
do they make a header that will fit inside without cutting anything?
"They" used to ! LOL !
Picture is from the early 70s & the first V8 swap I did.
It was a kit from Holman (Herbert ?) & Moody. Came with motor mounts, headers & I think a couple other things ?
The old Heddmann Tarantula hedders that come forward but they aren't cheap & I havn't seen a set for sale in a year.
WTR 70
79prostreet
79prostreet
WTR 70
79prostreet
79prostreet
WTR 70
79prostreet
I would, also have a new set of headman headers to sell. can e mail a pic if interested. Bud
79prostreet
WTR 70
79prostreet
I have a v8 motor out of a 79 mustang ll( minus heads and intake ) so I would have a pan & pickup. was going to use on my project but went dry sump instead. Bud
79prostreet
WTR 70
thats what i was kinda quessing but i dont want to guess wrong, seems a good way to get good at changing motors haha
Most windage trays only clear the rod bolts by 1/4" but you would probably want 1/2" clearance at least if you aren't running a windage tray so the crank doesn't pick up oil from the pan. The pickup clearance should be 1/8" to 1/4"
WTR 70
or how far the pickup has to be from the pan
WTR 70
do you know how close the pan can be to the crank?
Making a pan of your own that wont leak is the tricky part. I can fab a pan that fits myself but trying to make it leakproof would test my patience something fierce.
