Date: 01/23/2023 02:22 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
72 pinto
Date: 06/23/2016 12:40 pm
New cam
Date: 01/23/2017 05:11 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Date: 09/01/2017 07:52 am
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 07/04/2022 07:55 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
  • Online today: 1,972
  • Users: 1
  • Guests: 122
  • Total: 123
  • cbdpxp
8 Inch rear ends
Started by turbopinto72, July 14, 2004, 04:45:33 PM
tinkerman73
Alright. Thanks. Sound like a no go!
Jody Michielsen
tinkerman73, I believe 1979 was the first year of the FOX chassis Mustang.  If correct, it has a 4 link suspension with integral carrier rear.  It will take some cutting and welding to get it to fit into the Pinto.  It also is not the stronger 8.8" rear that came in the later FOX Mustangs (first in about 1986).
Not sure what transmission it came with but it is not the World Class version of the T-5 which came out in the mid 1980's.  The drive shaft may be useable but measurements would need to be take of your final combination to be sure
tinkerman73
Alright, as I read through here, I read that the mustang 2 rear ends are best to use. I see a difference from them to the 80's model. But I dont recall seeing anything about a 1979 Cobra mustang rear end. I see it has a 4 bolt pattern. Would they typically be a 8" and would they bolt up or need minor mods. If any one knows, let me know. I know someone that has a 79 cobra in bad shape. Once I start getting pay checks, I might be able to buy it cheaply. Also, what are the typical trannies in these and would the drive shaft be of any use? Thank you.
Jody Michielsen
I used an 8" from a '67-'68 mustang and traded a guy the 5 lug axle's for 4 lug from a 6 cyl Maverick.
Jippah
Quote from: Pintony on May 03, 2007, 08:58:32 AM
Hello jim,
I think it would be easyer to just get a 1971 Maverick rear.
that's the only option i have out here  :'(
check it out http://www.fordpinto.com/index.php/topic,17673.msg113519.html#msg113519
however, I'm the exact opposite of what most people here want... i want to keep my 4x4.25 pattern! its not fair that I'm stuck with what u guys want (72 Maverick 8") and you are all stuck with what i want (MustangII and V6 pinto 8")
sigh... such is life i spose lol
anyone want to ship a mustangII/V6 Pinto 8" to Oahu? surely it will be cheaper than the $300 the idiot at the junkyard here wants for the maverick 8"
*BANG*
"What was that!?"
'... Speed bump?'
1993 camaro (6cyl)
Bringing this back from the dead :-), going from the Pinto 6and3/4 to a Mustang II 8 inch rear. Are the U-joints the same?
Thanks,
wedge446
If the pinto 8" is 57" is the measurement from the pinion gear centerline 28.5" to both sides?
Is the drive shaft yoke centered on the axle or off set?
Quote from: apintonut on December 02, 2007, 10:56:44 PM
what about using a ranger / explorer / aerostar 8.8.   i have a locker for one and they are a dime a dozen. some are already posi.  any thoughts on this? has it been tried?
Maybe, but this thread is about 8" rears.
You CAN keep the 6.75" rear behind a 460 if you want, and if you go VERY easy on it you won't have any issues. That being said, the one in my wife's car was SHOT behind the stock 2.3 at 64K.
If you keep the engine stock and/or DON'T beat on it, it should last.
If the 6.75" does go, DON'T have it fixed ($300.+), just replace it ($50. or less), or get an 8" to put in it ($50.-$150. depending on the gears).
Quote from: srt on May 15, 2007, 02:54:55 AM
in my own personal opinion;  the OE rear end is fine for use with a 2.0 unless you are going to drag race the thing.  drawbacks?  you are limited to the gear ratios that are available and to tire/wheel size(s).
BUT, now that I've seen what Pintony has on his green '72 maybe the wheel /tire issue just went away !!  Looks nice P
osiyo59
Ok, So I have read this post through at least 5 times. What I would like to know is if there is any application where the stock 6 3/4 rear is good enough to run. In my squire I have a stock 2.0 but I am backing iit up with a t5 and I am trying to figure out whether I should moveup to the 8" or not. I have only been able to find one ocally and of course it is a 5lug and I was not planning on going that route with this one. Any thoughts...Bill...Tony...Brad?
Rob ???
Thank you to all the replies.  I appreciate the time involved. After reading all the posts and thinking about it, I believe I will go with the Moser package. :read:  Bob I will be e-mailing you for details.
I also remember reading that Ranger 5 lug 10" brake drums would fit the 5 lug. I will see if I can find it.  I don't know if I will go with drums or swap to disc brakes.   :lost:
Anyway the axles solve this issue so on with the next one.  BTW: my Pinto comes home at the end of the month.  I now own 1/2 of it but not sure which half.
Hairball
Around 15 years ago I built a V8 Pinto. I used an 5 lug 8 inch rear out of a Maverick. I threw away the steel an rubber spring perch and used a torch to widen the holes for a 3 inch u-bolt.
After blowing up the 8 inch (N.O.S., 302, 4 speed top loader), I used an 9 inch Lincoln Versailles rear. It fit perfectly and was bulletproof.
Fastforward to now.
I have an 1980 CW that has a V6 and is mint. I want to use 5 lug Torque Thrusts.
I got 5 lug rotors ($29.95 each) and 2 inch dropped spindles ($169.95) from Speedway Motors.
My friend gave me an 9 inch Versailles rear.After some thought of all the work to install plus the price of calipers and rotors, I reconsidered.
I thought about a Ranger rear. Then it dawned on me. I called Moser, and for $60.00 they will drill my axles to the 5 lug pattern.So as soon as I find some 8 inch pinto axles, I will send them to get drilled, then use a transfer punch to mark and drill the drums. I want to keep my stock 4 lug axles in case I ever want to switch back???
I will keep you informed on the outcome and will put up a pic.
Dave
Nice green 1977 cruising wagon wanted
bob55
Jim,
If you're going to aftermarket axles anyway, Moser has the complete package:  axles, bearings, retainer plates, studs, etc.  Just got mine, very, very pleased with what they sent!  If you want details please feel free to email me at bob_10@comcast.net.
In a quandry......
Quote from: turbowagonman on May 03, 2007, 06:05:58 PM
Can't you just use the Axels from the '71' and later Maverics? Or will they not fit?
turbowagonman
Please read my post dated Nov 8 of last year in this thread.
HFJ: I think the axles are beefy enough for 400HP+ Pinto. If anything, I think you would have gear issues first. (based on what others that I know using those rears)
turbowagonman
Quote from: 77turbopinto on May 03, 2007, 10:48:17 AM
I have to agree, all you need is a pair of .25" spacers and slight modification to the perches and you are done.
I think all 71 and later ones are the same.
turbowagonman
Hello jim,
Hello jim,
Quote from: HELLFIREJIM on May 03, 2007, 08:38:24 AM
I have a MII 8" 4 lug rear and want to go to 5 lug axles.  Since this will be a turbo 2300 I am planning to put in aftermarket axles.
Now the questions to make sure I understand correctly.
Do I need to change the bearing retainer plate?
What is the best brake drum to use?
The internal componets to the brakes are the same, yes?
Can I use the same backing plates.
Obviously this is not a high dollar car so i have to watch my pennies but I want to make sure the brakes are right and safe.
Thanks for any help for this newbie at this 8" rear stuff.
WagonNut
Hey turbopinto72,
Thanks for the great info on these axles. I like many others am looking to convert to a 5 lug rear. I want to retain my Pinto rear and chang out the axle shafts. I know how to do this with Granada axles as it has been well documented. I have given up searching for Granada axles and have found a set of 66 Mustang axles. I read your post about the differences in the Pinto axle shafts from the 66 Mustang.
The bearings are the same but the retainers are different. I should be able to correct this by pressing off the bearings and using the Pinto retainers on the 66 axles.
The axle length of the 66 is about 1/4 inch too long. I would like to cut the 1/4 inch or so off the ends of the 66 axles and re-chanfer them.
The 66 axles are thicker in the middle. Will this prevent me from swapping them?
I would use the stock backing plates and brakes, but would look for 9" 5-lug drums.  I have the axles coming and am willing to experiment to make this work. I know it would be easier just to re-drill the axle shafts and drums to 5 lug, but I'm not comfortable with doing that.
Any thoughts that you (or others) have on this would be appreciated.
Thanks in advance, Kevin.
bob55
Hi all, has anyone had success buying aftermarket 5 lug axles for the Pinto/MII 8"?  I called Currie, their rep said "No way their axles would work", even if I used the original (smaller) retaining plates.
Any ideas short of having the standard small bearing ends welded onto the housing?  Has anyone else run into this?
In a quandry......
I have the axles sitting on the springs and snugged down. Boy, it was a pain to get every thing back together and aligned! Now I'm ready to tighten it down and would love to know the torque specs for the U-bolts and the shackles, please! Thanks!
I got the new U-bolts. The axle swap will start on my next days off. Now many foot-pounds do I torque them down too?
Any good auto parts store or 4x4 shop should be able to get you u-bolts.  Just get the three dimensions you need:  length, diameter of the axle, and diameter of the bolt.
I got the studs redrilled for the smaller bolt circle now. I am waiting on the parts store to get the seals in. Now where is a good place to get new U-bolts to clamp the axle down?
BTW, IIRC, 6-3/4 backing plates don't fit on 8" axles do they? Although I may swap the finned drums across.
mini9r
What year of explorer?
Quote from: turbopinto72 on October 14, 2004, 03:18:49 PM
You can use the Rear disc brakes from an Explorer. They work great.
I was tempted to put the Maverick axles in the Pinto 8" housing (mine had the same bearings). It looks like it would "work", BUT, the axles are 1/4" shorter (each), so 20%-ish less contact in the splines. Also, the retainer plates would need to changed, so new bearings are in order for that. It was easy just to modify the perches and install spacers behind the wheels.
A machine shop might be able to drill those for you too, I just don't know how much room the flanges have for the new hole pattern.
Is there a Maverick group similar to this group where I can ask about an axle trade?
Am seriously toying with the idea of drilling a new bolt circle in the Maverick flanges.
Did redrill some Studebaker Hawk hubs to take '50s Cadillac sabre wheels and that was a true pain.
