Date: 01/21/2023 04:19 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 10/31/2018 12:00 pm
Date: 03/29/2019 07:20 am
Date: 04/07/2021 06:12 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 10/03/2018 10:46 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
  • Online today: 1,972
  • Guests: 125
  • Total: 125
8 Inch rear ends
Started by turbopinto72, July 14, 2004, 04:45:33 PM
Sorry but the axles dont swap...they have a odd tappered small bearring.
If I had a MustangII or Pinto 8 inch to spare I would swap you.
Frank
that maverikc rear end is the one I been looking for...offered on early 71-73 Mav's and Comets with a 200 and automatic. the 8 inch rear is a 4.5 x 4 lug like the Falcons,Mustangs and Comets of the 60's. the Mustang II/Pinto axles dont fit the rear ends at all.
Not many Mav's in Oklahoma salvage yards....
Frank
Well Doug...
I thought there was a part in this conversation that said that the mav rear was 4 on 4.5  but I could not find it.
The only rears that have the factory 4 on 4.25 bolt circle are the M2 and Pinto V6..
If you are really slick and steady handed AND you are using old school MAG wheels you could elongate the bolt holes on the wheels or try some different axel combos.
From pintony
I got my Maverick axle home and discovered that the bolt circle is about 1/4" bigger than my Pinto bolt circle. What's up with that? What now?
I guess that I have to resign myself to a bit of measuring and cutting when I get both axles dropped.
Vaguely annoyed that the wagon that I got is one of the rare ones without the 8" rear and had the wimpy 6.75" one instead.
Quote
What are the dimensions of the holes and how critical is the precision? Are they something that I can torch out or do I need to measure twice and then carefully drill and dremell?
It is critical that the holes are the correct size and location so that the rear is installed where it needs to be, otherwize the rear will be too far forward, to the rear, or sideways. Some aftermarket springs have the pin in the wrong location anyway, so you can use this as a way to re-center your axle.
Not something I would do with a torch.
As for the size, they are the same as what is on your Pinto axle. I don't remember the size drill I used.
I used a hole saw, drilled two holes with it and used a cut-off to join the two, and some work with a file....
You can just drill one small hole and use the Mav. shock plate if you wanted.
Here is what I did to make the Stang and Mav. rears fit.
Quote from: Pintony on May 19, 2006, 09:56:22 PM
NOTE!
Number 3 is in-correct.
The rubber perch is perfect for the early Pinto!!!! ;D
Tony: I was talking about the MAVERICK rear not being set up for the rubber block assy.
I added info to my last post.
Quote from: 77turbopinto on May 19, 2006, 10:22:51 AM
Maverick 8" rear axle info (later years at least):
1) They are 5 lug, 4.5".
2) They are about .5" narrower overall than the Pinto 8" rear (drum to drum).
3) The perches are not set-up to use the rubber/block assy.s.
4) Like the 67/68 Mustang ones, the perches are narrower and the outside edge of the them are about the same distance apart as the Pinto perches (45"), on-center they are different.
5) The bearing retainer plates on the Mav. are the same as the ones on the 67/68 Mustang. (My plan was to put the shafts in a Pinto rear, but I would have to pull the bearings off the shafts to switch the retainer plates, so I just re-worked the perches like I did on the 67/68 rear to install it. I also have a pair of .25 wheel spacers to put it at the stock pinto track width)
6) The tubes do not taper, they are 3". You will have to use the Mav. shock plates and bolts, or slot the holes in the Pinto blocks and plates (like I did).
7) They take  different axle seals.
8) Hope this helps.
NOTE!
Maverick 5 lug 8" rear axle info:
1) The 5 lug ones are 5 on 4.5" and were on ALL 1973 and later Mavericks. The earlier ones had a 4 lug as well, but it is not the same lug pattern as a Pinto (4 on 4.5").
2) They are about .5" narrower overall than the Pinto 8" rear (ABOUT 56.5" drum to drum). IF the shafts are installed in a Pinto housing, they will engage the splines .25" less for each side; This is something to think about BEFORE doing. I have a pair of .25 wheel spacers to put it at the stock pinto track width.
4) Like the 67/68 Mustang ones (and others), the perches are narrower, and have a different O/C measurement, but the outside edge of the them are about the same distance apart as the Pinto perches (about 45").
5) The bearing retainer plates on the Mav. are the same as the ones on the 67/68 Mustang, but NOT the same as the 8" Pinto ones. My plan was to put the shafts in a Pinto rear, but I would have to pull the bearings off the shafts to switch the retainer plates, and along with the spline isssue, I just re-worked the perches like I did on the 67/68 rear to install it.
6) The tubes do not taper, they are 2.75" to the brake plate. You will have to use the Mav. shock plates and bolts (if you do this I think it will make the install very easy, but you will lift the rear of the car), or slot the holes in the Pinto blocks and plates; I slotted mine to run the M-II rear sway bar mount shock plates.
7) They take the same axle seals (two parts places told me otherwise, but they were the same as the 68-73 Mustang and the Pinto 8" rears).
8) They need drums and wheels with the BIG center hole. The drums from my 68 stang rear would not fit (good thing the Mav. ones were in good shape, as a matter of fact they had more meat on them). They need rims with the 2.75" center hole, the same size as what is needed to go on a Granada rotor.
9) I will post more if I find any more details.
10) Link to photo of what I did to modify the Maverick perches: http://www.fordpinto.com/smf/index.php/topic,953.msg31360.html#msg31360
11) Hope this helps.
PaulHolcomb
Quote from: turbopinto72 on October 14, 2004, 03:18:49 PM
You can use the Rear disc brakes from an Explorer. They work great.
Do you have any information on how much work is involved in doing this swap?  I could really use some fast info on this as this would help me in the next 2 weeks before racing season starts.  Please email me at HolcombRacing@yahoo.com .  ThANKS
Some more info for those looking for a 5 lug 8":
The 65/66 mustangs with a v8 had the 8" rear, but it is narrower from drum face to drum face than the later 67/68 stangs (two or three inches, I do not have the exact dimentions, but they are much closer to a pinto rear). The rear in my car is about 59". The 65/66 ones are easy to pick out of a crowd, as the housing tubes taper near the ends (like the 23 spline pinto 6.75", pre-79), but all of them 65-68 have the same perch widths and size.  The tubes on the 65/66 have the same diameter as the pinto ones. These are not a bolt-in for a pinto, but they are not too hard to install. I have one (full assy) from a 68 in my pinto. The outisde to outside edges of the perches are about the same as for the pinto. I slotted the perches (off-center to the perch itself) to match the perches (on center) for the pinto. I then welded a 4inch piece of .5 rod to both inside edges of the perches to give it more support. I also had to open the holes on the mount brackets and use the u-bolts (1" longer than stock, I got them from Mustangs Unlimited) from the 68. I have stock 14" x 6 ford steel wheels with a 4" backspacing on the rear now, and have no issues with rubbing. I will admit it looks strange from the rear, but the rear sway bar gets you attention off of it.
I want to get a pair of 14" x 7 (5.5" B/S. custom made) race rims that will help the "look". I then want to cut the bead area off of a set of stock 13 inchers, and weld the hoop to the 14 inch wheels. Then a set of stock hub-caps will pop right on for the sleeper look.
I will get some pics as soon as I can.
osiyo59
I'm picking up a 76 runabout in a couple days and have plans to do a late model turbo swap with a 5speed. I want to run the 8" and this was very good info. Thanks for sharing. I just hope the car already has the 8" in it!
yes, shiney=good   i got my forged H beam rods today, and they are shiney!
kris kincaid
Did a little search, and now I understand.  :D
ganar dinero a espuertas
Quote from: kris kincaid on November 23, 2004, 08:33:31 PM
Nothing shiny on my car Brad. ???
Hummm, you do know about ( shiny=good) ???;D Please refer to the countless posts on this topic. Its kind of a matra we like to say.
kris kincaid
Kris, I called my sources and they admitted to having to weld on the large, 9" axle flanges to do the explorer swap. Sory to all for any confusion, and thanks to Kris for bringing to our attention. Now, that being said, I want to know if Kris has anything " Shiney" on his car.................. ;D
kris kincaid
Brad,
According to the April '99 issue of Hot Rod in which Joe Morgans Pinto was featured;
"Disc brakes were scavenged from an '88 Turbo Coupe and bolted to the Pinto 8-inch axle. Currie Enterprises offers a bolt-on adapter that mates a T-bird caliper adapter to the axle end"
Is this no longer accurate? Has Joe changed his setup?
Here is the link for that article:
http://www.mustangandfords.com/howto/28733/
Edit: the forum software is screwing with the link, try mustangandfords.com/howto/28733/ , but add "www" to the beginning
Quote from: turbopinto72 on November 23, 2004, 10:51:45 AM
Thats a bad link. BTW there have been several people that have used exploror brakes on their 8" rearends that I know. One of them is Joe Morgan.
kris kincaid
I was discussing this issue with a Currie rep, and he says the Explorer brakes will not fit the 8". I found the following artical that explains:
"According to Currie, this kit will be a direct bolt-on to rearends from ’73â€"’79 big passenger cars and ’77â€"’86 pickup trucks. "
I think I am going to try and figure out how to use them on an 8". Probably figure out what ends to use and weld them on.  :-\
Thank you! Saves me lots of work. I knew the brake shoes were the same. Thanks again, Tricky Dick.
CHEAPRACER
Yup, I used all my stock brake parts when I swaped an 8 inch. in fact, I never disconnected my brakes from the car, just layed them aside.
Will the rear brakes from a 6 3/4" rear end fit a 8" mustang 2 rear end? They look the same. Drums look the same. My 8" brakes are junk, but the 6 3/4 look like new. Help me out.
kris kincaid
I thought the Exploder rear brakes would only fit on the "Torino/Galaxie" big bearing 9" rear ends?? I had planned on just welding on the big bearing ends, but if they fit on an 8" as is, thats great!
yes they will work with no problems.
hoots
I picked up a housing and axles from a 78 MII, (not a posi) and a limited slip posi third member from a different MII. Will the axles from the non-posi rearend work with the posi third member?
