Date: 07/30/2018 04:32 pm
Date: 09/17/2024 12:35 pm
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Date: 10/14/2019 08:24 pm
Date: 10/11/2019 11:13 am
pinto wagon parts
Date: 12/19/2019 01:43 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Date: 01/23/2017 07:41 am
  • Online today: 1,972
  • Guests: 130
  • Total: 130
8 Inch rear ends
Started by turbopinto72, July 14, 2004, 04:45:33 PM
You can use the Rear disc brakes from an Explorer. They work great.
Handy
Thank you for the very thorough tech info.   Great stuff!
This is really relevant to me as I just picked up my second Pinto and the brakes are fused (rusted for years).  Rather than rebuild what I've got I was thinking of doing the big switch to larger 5-lug Granda rotos, etc.  The front end sound doable but I'm wondering how to manage 5-lug wheels and brakes for the rear?   If I can find an early model Mustang, 8" rear end, I'll do that but is there another option?  Has anyone just gotten custom axles from Moser for Pintos (drilled for 5-lug) and used the rear brakes from a Ranger or something?
1980 Bobcat
1976 Pinto
 This note is filed under the ( Oh by the way).
One of the Biggest differences of the two axle housings is the spring perch brackets. On the early housing its aprox 1/2 inch WIDER that the late modle, which is the same as the stock unit. In order to use the early axle housing you will need to modify the spring perch either by cutting them off and re welding OR modify the brackets. Its aprox 1/4 per side so its not much but just enough not to work with out some help.
straw boss
Good informatin!  Thanks for posting it.
Some other differences in the 8" between , say a '76 and '80:
The brake line going to the right wheel was relocated over the pumpkin, instead of behind it.  I believe this had something to do with the gas tank hitting the rear end in a collision.  The clips that hold the brake line are rather stout and could rip open the tank.
Also, the brake hose assembly (from the body to the rear axle) is different starting in 1977.  The '76 and older hoses had the same size fittings for the two lines going to the brake cylinders.  In '77, the fitting for the left wheel brake line is larger than before.  It still uses a 3/16" brake line, but the fitting is larger.  The right wheel brake line fitting is the same size as before.
I cannot for the life of me figure out what they were thinking when they made this change.
 This is what the Late model center sections all look like. Note that it has ribs , both verticaly and horizontally. The early center sections only have horizontal ribs.
 where the early 8 inch is 1/2 inch wider or 1/4 inch each side. Which would be nice with a wide wheel/tire combo.
( Please disreguard the dimention, it is typed in on the picture incorrectly)
 The overall lengths ar different too. The Late model is the exact same length as your stock 6 3/4 unit.
spline ends
4 lug retainor
5 lug retainor
Late model
 Then there are the axles. The Berring's are the same but the length, spline length, width at mid point, and retainor are all different.
 And here are the Late model.
 Here are the dimentions of the early housing.
 Next, we will look at the Axle housing ends. These are simular but not the same at all. As you will see in the next few photos the early and late model units are not interchangable as they pertain to the axles and backing plates.
 Here is the Late model.
 We can start at the rear of the housing. The early housing has a drain hole in it and the late model does not. You will fill the Diff up from the plug in the carrier unit.
 In the next session of pictures I will show you the main differences between the ( Early ) and ( Late) model 8 inch rear ends.
Here is a picture of the two side by side. As you can see, you realy cant tell much from looking at them here.
 There are a few folks on theis list doing an 8 inch swapp in their Pinto's. And, there are questions.
I hope to answer some of those questions and make the swapp as painless as can be.
The first question is " what car can I get an 8 inch from".  The answer(s) are. Mustangs, Cougars, Maverick's, Mustang II and Pintos are the most common.
Now, are they all the same  NO. Depending on the year and type of donor car the rear end will be slightly different. However, they are mainly different between the 1965-1967 group and the 1968 and up group. I will be showing you the difference between a 1966 mustang and a 1976 MustangII.
