1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Date: 01/24/2017 12:36 pm
Date: 04/10/2017 07:30 pm
Date: 01/30/2017 01:48 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Date: 10/24/2019 01:43 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
  • Online today: 535
  • Guests: 438
  • Total: 438
Hello fellow keepers of the flame-A long one from the new guy-71HANTO
Started by 71HANTO, January 24, 2008, 01:33:26 AM
Wow, it took a little while to read this thread.  Your Pinto looks super! Keep up the good work.  The MkI Cortina is one of my dream cars, I didn't know there were any in the US, When I was growing up, the guy down the street from me had 2 mkII Cortinas, still neat cars, but a little tame compared to the earlier models.  I lived in Germany when I was a little kid (Army brat), so my taste in cars reflects the first cars I saw.  My very first car was a Renault 10 (engine in the back, water cooled). I bought it for $50 when I was 16 and it took all summer to get it running (it sat for 10 years). I drove it till I was 18, bought my first Pinto (a brown wagon) for $190, and passed the Renault down to my brother, he learned to drive on it, but it died and parts were near impossible to find for it.  I admire you guys that do that much work to your cars.  Mine's just a daily driver, and mostly stock, but I love it just the same.
Here is an old scan of the dyno test on the Lotus engine now sitting in the engine bay of the Pinto. It is a normally asparated 1600cc or 98 cubic inches bored out from the original 1558cc. It has about 3 1/2 road race hours on it since the dyno test. The chart is hard to read but it shows 181.36 HP @ 7500 RPM and 133 FT LBS @ 5500-6000 RPM
Quote from: dholvrsn on September 04, 2008, 06:05:50 PM
How do you hook up a linkage to all those carburetors?
The Weber Carbs have a single, adjustable, concentric, rail type linkage. It's hard to see on the Twin Cam Engine in an earlier post of this thread when it was still in the Cortina.  The carbs are on the wrong side for the pinto original throttle cable. I will use the LONG one I pulled from the crunched Lotus Cortina (same issue because it was an imported left hand drive car).
fastbak390
1971 Trunk 2.0 - (mostly) AK Miller Turbo Setup
lencost
Quote from: lencost on March 05, 2008, 10:49:33 PM
A twin cam Lotus in a green Pinto, sounds like a perfect match to me. How close is it to British racing green?
I would like to see some of the looks on peoples faces when you open the hood.
Leonard
1975 Wagon 8" C4 2.8 V6
Here are some Labor Day weekend work-in-progress pics of the Pinto/Lotus. I cleaned the engine with degreaser then sprayed the original color gray on the 1558cc L Block. I left the head bare aluminum because I like the looks. Once the engine was in the pinto, I repainted the valve cover the original color blue with an air brush.
I also put the new 8 inch rear on the reconfigured leaf springs with lowering blocks (no pics yet) but the lower U Bolt brackets need to be modified to take a longer rear Koni shock.  I'm now waiting on a Type 9, 5 speed transmission that I'm getting in a parts trade. I will be putting only 133 ft lbs of torque through it but LOTS of sustained RPM.
Here are some progress pictures on the rear end springs adding Poly bushings. I turned down 1965 Mustang 9/16 bolt full Poly bushings from Energy Suspension using a drill press with a wood rasp. It takes hours and patience to turn these down correctly with the proper pre-load size while making them all consistent. I used a micrometer and measured as I went. The reason I left the larger flange is to help counter deflection or twist in the rear during hard cornering. I put the springs together using a large secondary leaf from my 1969 Mustang donor. I'm waiting until I can load the car to gauge the proper ride height so I can add a 1977 Ranchero rear anti-sway bar. I'll have the brackets welded to the bottom of the car once I determine the correct pivot point locations for the end links. I'll have pictures of this sway bar set up when I'm futher along to clarify.
65 Mustang Poly bushing next to an original 71 Pinto rubber bushing.
Just starting to turn down the first set.
Down to the correct size allowing for pre-load of the bushings once they are pressed in.
The un-turned Mustang bushing, the original Pinto, and the turned-down replacement with the large flanges left on.
The restored springs ready for assembly.
Here are the Large Eye bushings pressed in.
These are the rear shackle bushings after assembly.
The completed springs ready to be bolted in.
With the leaf springs installed.
I machined the lowering blocks to fit the new stainless locating bolts, nuts, and washers.
Thanks..more pictures will be coming with more progress. I had Currie Enterprises build the rear, press on new axle bearings, and replace the original wheel studs with longer racing type. They're about 50 miles from me and easy to find using a web search. They do top of the line work.
Where did that lite weight third member come from? I want one!!!! Thanks for some better posting in a long time.
More photos of progress. I removed the old 71 Pinto rear replacing it with this modified 76 Stallion Pinto 8 inch with the better, bigger, cooler vented brake drums for racing. The new rear with the aluminum center section with it's larger axles weighs in at 148lbs including fluid and the brakes. The original 71 6.75inch weighs 118lbs. A 30lb difference. The Aerostar aluminum drive shaft weight difference should make up for a 1/3 of the weight penalty back over the original drive shaft with the added benefit of less whip saw force to the diff. In other words, less static forces or deadweight to overcome as the rear moves up and down. The new rear has a service rating of 350 FT LBS with the Detroit Locker TruTrax geared Posi and 4.63 gears. The Lotus engine only puts out 133 so it's strength is RPM not grunt... it shines only in a lite car.
I spread out the original springs with 69 mustang donors to show my race tuning choices to mix and match whatever pound and softness ratio works best. Next will come the front suspension rebuild and bushing upgrade with the cut V8 Mustang II springs. I also included a picture of the relatively clean low mile california parts. The leaf springs were obviously originally natural color metal. A little spray lube on the bolts before un-loosening them made the rear removal MUCH easier than I anticipated.
By the way Pintony...You raised the bar on your restoration project so now everything I touch thats staying with the race car.....I have to REST-TEA-FY in my CLONE-IF-A-CATION :hypno:    It's all your fault!!!! ;D
Here are some recent pictures of how I adapted a large oval hole 8 inch rear end housing from a 76 Stallion Pinto to fit the small hole mount type springs in my 71 eliminating all the extra isolator junk (weight). I used 1/8 flat metal stock and hand fit the blanks with beveled edges for a stronger weld. A local muffler shop welded all of the bottom and about 60% on the top where they could reach under the axle tube. The shop also cut my Mustang II V8 springs at the same time with their industrial cutoff saw all for $45. Not bad for LA.
I still need to detail the 1976 big brake backing plates before putting in the aluminum pumpkin, seals, and axles.
When I cut down the lowering blocks, I left a fraction of extra metal on them to hand lap them to the curve of rear leaf springs with the added extra leaf I pulled from my 69 mustang.
By the way;  ALL OF YOU HERE ON THIS SITE:  I really admire your dedication the the SPORT of owning a Pinto.
Hey  guys.  In 1971 or 1972 I worked at Ak Millers as a mechanic.  Two of us were in charge of putting the turbos and koni shocks and sway bars on all the (pre-body work) Pangras that came out of Huntington Ford in Arcadia. We cut the front coils and added lowering blocks to a lot of them but not all of them.
All the ones that we modified were 2.0 motors.  A couple had automatic tranmissions.  At the 'garage, we did not put together any 2.3 cars although, there was a 'kit' that was offered by Ak Miller Enterprises, (same guy-right across the alley-mostly custom work & mail order)
At that time (over 35 years ago) none of them out of our shop had chrome valve covers.  Some of them had a boost restriction device that fit into the compressor tube across the top of the valve cover.  Almost all did not.  The ones that did not have this restrictor all had a water heated casting through which the compressor tube would pass. This was to warm the intake charge prior to entering the combustion chamber.  It was suppossed to be a driveability issue.
The batteries were all relocated to the drivers side of the engine compartment using a modified stock battery tray.  They did not have any non-factory gaauges installed at our shop.
We put together 2 a day and delivered them in the afternoon and picked up 2 more to work on the next morning.
We burnt down (the motors-not the cars!) on a couple of them on the freeway 'test run' on the way back up to Huntington Ford.  Shhhh...don't tell anybody ;D
The cars all had a 2 1/2" exhaust ( now that I think about it, it may have been 2 1/4") from the turbine outlet to the rear where we hung a Walker Turbo muffler (part # escapes me) We did the exhaust work in house.
Mine was a '71 2-door, dark green metallic, 4sp with goodyear ppolyglas tires and the 2.0 motor.  It was my 1st new car and I still think that it was one of the best cars I have ever owned.
I put a turbo on it at the shop one afternoon after work and went cruising (street racing) that night.  The motor had an 'o'-ringed head that had been shaved .060" a Spearco adjustable cam pulley, a stock distributer with the dual diaphragm vacuum canister that was rigged to retard timing under boost.  It also had a water injector that utilized the windshield washer reservoir and a stock nozzle that was fastened to the air cleaner(later into the air horn of the carb) and the koni shocks, dropped on the ground with some special leaf spring s at the rear that were a new single leaf set-up.  Shocks at the rear were set loose, no rear bar but the front bar was a good sized 1  1/8" Interpart bar that I had made for me. Front springs were cut down out of an early chevelle.  Damn thing rode like a rock but on a smooth road up a canyon it was pure heaven and extremely tossable.
I ran into quite a few fuel distribution problems so I put on a 2bbl carb out of Ford truck and a different intake manifold and solved that problem.  I also knocke d the flywheel right off the end of the crank twice but solved that by having the crank re-drilled for SAE threads in 1/2": size AND dowel pinned the thing.
With a 3:55 rear gear, tires in the size of 185/70-13 continental radials at 35 #'s the car did a quickest in the 1/4 at Irwindale Raceway (it's a brewery now) like a 1347 at 101 mph.  Through the traps in 3rd gear at about 6000.  No boost control.  and 24 mpg to boot!
I haven't owned one since i sold the shell (with a full frame and a 9") in 1975 or 1976.
I was setting it up to take a 460 but got married instead!
fastbak390
Quote from: srt on March 07, 2008, 03:28:15 AM
i'm stuck   in the past with a lot of this stuff guys.  i hope i didn't come across wrong
I honestly didn't get that impression from you.
I edited my signature for accuracy though.  ;)
Did all of the AK Miller turbo motors have chrome valve covers?
Hey SRT,
I'm not sure what you are running for a Pinto?
I am glad we have you around if we need to ask questions about the AK Miller Turbo items.
Here is a photo of an AK Miller 2.0 engine that I have.
I do not have the rail... YET!!! ;D
Here are some oldies of the 1980 I bought new. They were taken around 1981-2. This is the first time out towing the boat. I was dry toasting to the boat for good luck. That boat could keep up with ANY unblown jet boat in it's day.  It was also one of the most dangerous things I have ever owned. OK... let the leg and dorky fashion comments begin.... :drunk:
fastbak390
Quote from: srt on March 06, 2008, 01:10:46 PM
i am curious about some of the details on the engine of the yellow cars motor.  the cast iron elbow/downpipe at the turbine exhaust and the metal (aluminum) piece connected to the compressor outlet and terminating at the rubber bellows over the valve cover as well as the alternator being located on the drivers side. were these mods made by the original owner or you.  those don't appear to be ak miller pieces
As Pintony mentioned, its a water cooled T3 turbo, elbow/downpipe, and crossover from an EFI 2.3. When the original turbo grenaded, he made up an adapter plate for the AK Miller manifold and the T3. I'm making a conservative 5psi with it.
The alternator was relocated by the previous owner as well using Ford bits for an A/C Pinto.
The great thing about having the alternator relocated is that the wiring harness can be entirely on the drivers side of the car... away from the turbo heat. I can also just screw my wideband sensor into the factory O2 sensor provision in the downpipe.
I just hate the rubber elbow though. It blows up like a balloon under boost and is a leak waiting to happen. I need to fab some piping as soon as time and money allows.
skrach
Quote from: Pintony on March 05, 2008, 10:51:49 PM
WoW Hanto,
Your engine bay looks grerat!!!
I do have 1 sugestion.
Your engine mounts are upsidedown the shield part should be toward the engine. The way you have them provide zero protection from heat and any oil that may lleak from the engine.
You can thank the San Jose factory boys back in 1970 that put these in. They are the 24,500 mile originals. I will put the new ones in the other way instead of the Australian way! :lost:
Quote from: Pintony on March 05, 2008, 10:54:41 PM
WOW! Cool! you have added a photo of the engine.
I am some-what confused about the Lotus engine. It has 2 cams, but only 2 valves pr-cylinder???
No Mater... IT LOOKS COOL!!!!
GO FOR IT!!!!!!
Thanks...Yes..two valves per cylinder...But...IT"S A HEMI :hypno:...well 1/2 of one!! ;D
This "hemispherical combustion chamber" Cosworth designed head dates back to 1963 but if set up right, can still pull nearly 2HP per cubic inch with NO added huffers or puffers.
Almost dead on! Yellow Spitfire Race Stripe Anyone? Nahhhh......
GO FOR IT!!!!!!
WoW Hanto,
lencost
Quote from: fastbak390 on January 31, 2008, 03:31:23 PM
Here is a pic of the Lotus Twin Cam being transplanted into the green Pinto...
Thank you Fastbak390 for teaching a man to fish....I mean post pictures....Well here is a couple from recent progress pics up front. I need to repaint the Lotus block from Ford Blue to the original Ford of England Gray then in it goes!
The Ford English gray is halfway between their weather and their teeth!! ;D
