  • Online today: 452
  • Users: 1
  • Guests: 405
  • Total: 406
  • Wittsend
Hello fellow keepers of the flame-A long one from the new guy-71HANTO
Started by 71HANTO, January 24, 2008, 01:33:26 AM
Here is a cheap, easy, repair and prevention of the easily broken early door pulls. They are weak and the collar that holds the mounting screw pulls through. I repaired 3 broken out collars and one cracked one that was still connected. I added a bunch of JB Weld  to the back of the mounting area to spread the forces of the pull to a larger surface area. The door pulls can stand up to much more force now ;D
It needs straightening a little but here is the finished product-no more worries ;D
 :welcome:  stevewl1164!
This site's not hard to navigate at all, once you get used to it.  I've never been on the Ford Festiva forum but I can tell you that, in my opinion, this is one of the best run sites anywhere - our administrators really care about what's happening and do whatever it takes to make it work.
Quote from: stevewl1164 on January 24, 2009, 10:22:11 PM
Hello, my first visit to the forum...do not know how it works! Fordfestiva forum is easier! Anyway, I had a 73 Pinto..in 1982 it was the frist car I bought. It was a medium blue runabout with the deluxe trim package in and out...window and drip moldings chrome, thin vinyl insert bodyside moldings, deluxe wheel covers, no rub strips on the bumpers though. Two tone blue interior...dark blue and light blue in the middle. Cargo carpet. It was a 2.0 automatic with no air. It did have disc brakes...not power though. I LOVED that car. It was a lot of fun to drive.
:welcome: A lot of great information on this site but you do have to dig a little if you find the Pinto bug bites you!!! ;D
stevewl1164
Here's a short cut to faster track times....losing weight :lol: The first picture shows an original Pinto sized battery next to the 12V motorcycle battery that I will be using. Most racers (those who use on-board batteries) go with the gel cell pictured but they're still heavy. :hangover: The motorcycle battery weighs 17LBS and the Pinto battery weighs in at a hefty 41LBS. :hangover: I save a net 24LBS ;D I will put it in the rear passanger side foot-well to counter some of my heft :amazed: and keep the center of gravity low and away from the fuel cell in the trunk :fastcar:
This side view shows what I'm using for exhaust instead of full tube headers ??? :lost:. This cast iron header is from a 1971 Lotus Twin Cam Elan ($25 E-bay six miles from my house ;D). I am planning on 7500 RPM MAX (limited with a 6AL chip). This engine pulls easily through 8500 RPM.... if I let it....after it passes 9000 RPM, it becomes a potential "Bouncing Betty" :hypno:
This cast iron header will be extrude-honed to flow as well as a tube header up to 7500 RPM. This exhaust tuning increases the useable torque throughout the low and mid RPM ranges by moving the peak torque level lower on the RPM curve. The higher end is completely sacrificed but is no longer needed because of the 5 speed. I get less under-hood heat and the cast iron header should weigh about the same as a nest full of tube headers once it's been extrude-honed and I smooth and remove some of the extra outside material also.
For the tight twisties torque rules. However,  I could have spun to 8500 RPM with a four speed to get the same race times with a shorter engine life. No thanks $$$ ;D The Type 9, 5 speed allows me to use the mechanical leverage advantage of semi-radical 4.62 rear gears that multiply my electronically limited RPM and turn it into usable torque on the track and the street. I get a top speed of 137 MPH with 22.8 inch tires. The 1974 Hanto Lotus/Pinto 5 speed  Prototype allows me to race with 5 gears against the others limited by the vintage racing rules to only 4  :2fast4u:  I could still race at the events with a renegade 5 speed without the borrowed Hanto pedigree but I would be limited to racing in the "exhibition class". This class is where all the cars that don't fit the vintage requirements get lumped together on one grid. The speed differential of the oddball cars racing together means I'm racing in my rearview mirror  watching for some nut case with a twin turbo'ed Viper working the course mixed in with 30, 40 year old cars :accident: Thanks Mr. Hansen, for helping me stay out of the junk yard wars wherever you are..... :drunk:
http://blog.themustangguys.com/Hantopinto.jpg
http://jimsgarage.wordpress.com/2006/09/17/the-hanto-pinto/
Thanks Eric, you asked for 'em....the first picture is of the Mitsubishi Alternator with a Cortina Generator front pulley installed to help hide the modernness but I decided not to leave it and have to butcher the original wiring harness just to make it work. The next picture the original Pinto Alternator that my car was born with waiting for a larger diameter drive belt. The third picture is an original 2 ton Lucas Generator that the Cortinas came with (6 Volt!) :o.
I had to adapt the Pinto Alternator to the Cortina generator bracket using a sleeve, enlarging holes, and repositioning the bracket with new mounting holes to get perfect alignment with the other pulleys. I used another extra part from my 69 Mustang. The upper bracket has a Ford C9 # stamped in it. I like the fact that the Pinto unit sits low but I weighed it and its exactly 2 LBS heavier than the Mitsubishi unit >:( Oh well, It means I have to get more aggressive somewhere else. :fastcar:
Mitsubishi Alternator with Cortina Generator Pulley:
Pinto Alternator with underdrive aluminum Pulley and a little shined up:
Cortina heavy weight Generator fit for a WWII tank:
Size Difference Pinto/Mitsubishi:
A better view showing adapted Cortina and Mustang brackets:
bbobcat75
it looks like its coming together nicely!!! keep up the great work charles!! and post some more pics!!!
eric
1975 mercury bobcat 2.8 auto
I also had a chance to clean up the 1971 vintage 240Z aluminum brake drums, hand chamfer the venting holes C H Topping drilled in them, and test fit the 1976 Pinto 8 inch rear spec brake pads. The width of the pad in the drum looks perfect ;D
I had a chance to clean up the original 24K mile 2.0L alternator and add an underdrive aluminum pulley to save it's life in SUSTAINED high RPM race conditions. The added benefit is less drag on the engine giving me a little more acceleration. The 71 pulley is in front for size comparison. The only downside is I probably won't be rolling with my 1000 watt stereo cranked while charging my cel phone during a race ::) I had a lite weight Mitsubishi alternator I used in the Lotus Cortina but to keep it I would need to do wiring mods to the untouched 71 Pinto wiring harness. By staying 71 Pinto, I'm taking maybe a pound and a half weight penalty for the compromise but it looks period correct unlike the mobern Mitsubishi unit anyway. What looks like rust in the back of the Pinto unit is actually factory paint  ;D
The numbers on the 1971 Pinto Autolite alternator are: 15V 42A D0AF 10300 G NEG :fastcar:
bbobcat75
charles the car is looking good, cant wait to see the spolier on the car now!!
eric
lencost
71HANTO thank you thank you thank you for posting your progress.
Leonard
1975 Wagon 8" C4 2.8 V6
I had my brakes drilled for racing today at C H Topping Brakes in Long Beach. Ca. They did them for $50 each and checked the used 240Z Aluminum drums for warpage (none). The 71 Pinto Discs have flash rust but they are near new. This trick makes these ALL SEASON for the street. They will brake better in wet or dry as the gases and water are re-routed. Cheap insurance at $50 each. IMHO
:accident:
It took me 5 tries to get the wrong throw out bearing so I gave in and had the yoke of the Type 9 bearing retainer turned down to the correct 2.0L/2.3L slip yoke size ($60). The problem is that there are two 2.3L sizes listed. The Type 9 matches the 2.3L and 3.8L, and 5.0L slip yoke size but it is no longer made for my Tilton 1 Disc race setup (too much torque for a one disc is my guess). The 2.0L/2.3L in the books is too small to fit on the Type 9 yoke. After turning down the yoke diameter to work with the smaller bearing diameter, I have an unlimited supply of bearings ;D
Tall race bearing next to a Stock 2.3L, 3.8L. 5.0L one.
Turned down slide yoke to fit the bearing.
Another view.
blink77
CHARLES
Just happy to see any of these parts get used. I know I
saved this stuff for a reason. Nice job on the tranny!!!!
BILL
Quote from: blink77 on November 24, 2008, 03:43:21 PM
CHARLES
Thanks for the ANDREW JACKSON.
BILL
Bill, thanks for taking the time to hunt it down, take pics, and send it on to me, it works perfectly and the height was just about where I would have cut mine anyway ;D. Another derelict part pressed into service.... :fastcar:
With the Capri Console I got on the previous junk yard trip with a nicer looking leatherette Shift Boot fresh from Pick Your Part $3
Before
After
blink77
I got some test fitting done on the Pinto with the 240Z Aluminum drums after the machinist did some touch-up fitting to seat them correctly on the axle flange. I may need to fab a 1/4 inch spacer behind the backing plate to dead center the shoes but may get away with not. You can see the small gap in the closeup picture. I also played with a 1 inch wheel spacer that I had and one of my race rims. I think I will need to go 1/2 to 3/4 inch instead of the 1 inch but I'll know better when I get tires. I planned for 205X50X15 @ 22.8 inches. :fastcar:
I was also able to re-thread (metric 10mmX1.5 Die-same as Pinto 4-speed) and mount a Lotus knob on the cut off Type 9 stick shift assembly Bill (Blink77) was kind enough to send to me after I nuked mine :hangover:.
With console and nicer Pick Your Part shift boot from a 5.0 Fox Mustang.
Well I got a little done on the Pinto with mixed results. I tried to straighten the very bent shifter shaft on the Type 9 (T-9)  but broke the little plastic retaining stubs. Now I need another one. I rationalized that it was too far gone anyway.....it was'nt... :lost:
The good news is that I went to Pick Your Part looking for a Type 9 Shifter (did not find it), I did found a nifty mini center console from a Capri II. I can fit two gauges where the clock delete plate is or maybe my shift light. This was the FIRST time I went to two junk yards in the same weekend and did'nt see one Pinto. I have be seeing at least ONE every time for the last 10 trips straight. Mustang II yes... Maverick yes... Merkur yes... but an auto trans...DANG!
I also made a little Resto progress on my Pick Your Part 15X7 Wheels I got a couple of months back.
Fresh from the junk yard ...
Road rash removed and Centers restored... I still need to put in HOURS of polishing....
I weighed the aluminum 240Z drums and the 76 Pinto cast iron originals to get a real idea of the difference.....4 LBS lighter EACH Drum ;D  I talked with a racer buddy who is also an engineer. He is telling me that for each LB LESS of rotating weight (mass), I should realize 3 more FT LBS to the ground. If this is true, I get 24 (4lbs+4lbs=8X3=24ft lbs) more accelerating HP that would be wasted on the engine trying to over come the resistance of the heft :hypno: I have 133 ft lbs total to work with. If 24 of those are freed up, that's a PLUS 17%.  My little 1600 chainsaw motor on steriods needs every tiny edge I can find. :fastcar:
Quote from: srt on October 31, 2008, 03:45:59 AM
I gotta hand it to you.  You are one clever guy.
Thanks SRT, as you may guess, I'm more into the go than the show when it comes to building a race car (but I do like to show how I make it go ;D). It's the little things that add up to make the difference between a front runner and a back marker. This Pinto will hopefully represent a little different image at the local So. Cal. road courses. Once sorted, I will be racing in B Sedan against early 912/911s, Alfas, BMW 1600/2002s, 510s, Lotus Cortinas, and 3.8L Jags, etc. These guys take no prisoners. They're in for a rude one ;D
Here are some pictures of Datsun 240Z ALUMINUM rear brake drums I am adapting to the 71 for racing (actually the adapted 76, 8 inch rear). These save substantial weight over the original cast iron Pinto drums and put more power to the ground faster with less dead weight mass to overcome. Plus with less unsprung weight, the suspension can do it's job and react faster for better control. The holes in the Z drums were re-drilled and a collar was added to fill in the size difference. I still need to machine down the collar bevel a tiny amount to get the drum to seat properly. The Pinto drum can be taken out to 9.060 and the Z drums go to 9.055. For the later, larger 8 inch rear drum Pintos, it looks like a 1/4 inch spacer behind the backing plate may be nessesary to align/center the shoes correctly in the Z drum. The smaller 6.75 rear end drums look like the correct offset to start. Updates after I get the drums to seat and I can fully check the operation. the total cost so far: Pair 240Z drums-Pick Your Part $35, Profressional machining: $160, Cost of NEW 240Z drums-$270 pair. The fun of doing something a little different-PRICELESS ;D
Original 1976 Pinto Drum and Two 240Z Drums
Original Pinto Max. Size 9.060
Original 240Z Max. Size 9.055
Re-Drilled Holes to 4.25 Ford Pattern
Mounted But Not Fully Seated
Testing the Offset of the Z Drum and my 15X7 Inch Junk Yard Wheels
Inside Clearance of Wheel to Fenderwell without Spacers.
I was able to get the detailing done on the Type 9 yesterday while I'm waiting for the clutch disc and throw out bearing I ordered to get to me. You might ask why I would try to detail the underside to show quality if it is just going to be a a race car???  EASY...I have a history (very brief fortunately) of showing the underside of my race car at speed....it just has to look pretty just in case :hypno: :hypno: :hypno:
Quote from: bbobcat75 on October 21, 2008, 05:40:59 PM
hey charles i sent ya a messsge with the total and my shipping address just let me know if you got it thanks
eric
Thanks Eric, got it and will get a money order in the mail to you tomorrow (Weds)+PM sent, Charles
bbobcat75
eric
Thanks for all the great comments and stories. Now that I have the Type 9 transmission 2.3L(1987) to 2.0L Bell(1971) to 1.6L Engine(1966) adaption issues behind me, I theoretically could have the car running and on the road in about 4 hours of work. But then.... I REALLY wanted to BELIEVE Santa was able to get his rotund self AND my 10 speed down our chimney :hypno:
I still need to detail the trans. and get a 23 spline Tilton 7.25 clutch disc and the correct  2.3L Tapered Nose Throw-out Bearing to go with my existing Tilton setup.
bbobcat75
that is going to be one sweet pinto, cant wait to see that car complete!!
keep up the great work and show some more pics along the way!!
Scott Hamilton
 :surprised:
You have a Serious Engine.. My Word...
I am green!
I got lucky at Pick Your Part. Found some SUPER lite 15X7 4X4.25 Pinto Racing Wheels by Dyna Lite???. Anyone know the story on these? :hypno: I was able to test the offset on a 74 wagon that was at the yard also. Paid $94 for the set then paid Bolton's Wheel Repair another $20 a piece to have the road rash welded up and removed (Gardena, Ca.)and at the same time they checked them for trueness. The load capacity is 1580 lbs each ;D
