Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 06/25/2021 12:59 am
Date: 10/27/2018 03:30 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Hatch needed
Date: 09/10/2017 09:16 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 03/06/2017 01:19 am
  • Online today: 529
  • Guests: 303
  • Total: 303
Twin turbo 383w build (two 1/4 mile videos added sept 15th 2010)
Started by 78pinto, September 24, 2006, 10:38:22 PM
your thinking of a blowoff valve....for bleeding down boost.  The wastegates control the amount of exhaust flowing into the turbine section of the turbo, if you only had one wastegate it would only limit boost output on one turbo, because they each feed off one bank of cylinders independant of eachother.  If i had 4 turbos i would need 4 wastegates (two exhaust pipes into each of the 4 turbos) Hope you understand.
78Pinto,
    Am I seeing duel wastegates?? Wouldn't one common wastegate to both turbos be a little bit more controllable and safer for the engine? Afterall the boost is going to one common place.
The firewall hole has been repaired, along with the small hole in the passenger side wheel well where the downpipe goes through.  I'll finish welding the patches in when i pull the mockup motor....gotta wait for the new up22 fiberglass hood to arrive to make sure everything (carb, bonnet, intercooler tube) fits underneath it before i rip it all out, better safe than sorry!  Dash was supposed to be here this weekend but my buddy got busy so it'll have to wait till this week sometime. Also bought a couple of 3" Magnaflow mufflers for it.  Should sound pretty good!
71hotrodpinto
Quote from: 78pinto on November 24, 2006, 11:28:04 PM
  My budget started at 12k i'll be hitting 17k+.......*
OUUCCHHH!!!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
trust me..i don't need any help on spending money! ;D  My budget started at 12k i'll be hitting 17k+.......like i said, my wife is great :-*
71hotrodpinto
MMMMMM Tasty!!!
Jet hot has a black coating i think. I know im trying to spend your money LOL!
Or at least use the VHT ceramic paint. Its $10 a can pluss your sposed to use a primer also but probably cheaper than coating the "side pipes"
Your probably getting tired of hearing all the praise that your doing on this "mad machine" but i cant help it  SWEEET!!!!
Edelbrock Airgap
Mil
I didn't take a picture from the side, but you can't see them. The exhaust will run outside the unibody structure underneath and will exit out the sides infront of the back wheels (like sidepipes) It will all be done in flat black with stainless exhaust tips poking out.
71hotrodpinto
Hey whats the down pipe look like from the side of the car??
Wow those are big tubes. Now i see why i didnt even try to do a 3 inch system on my car. LOL
Edelbrock Airgap
Mil
turbo placement
put together
downpipes
downpipes worked out, had to cut a small section from wheelwell to make it fit on passenger side.  Blowoff is installed now.
Zoomies it is!  I took a close look at the downpipe dilema today and i think i have the answer....and on the drivers side will be no cutting of the fender wells/firewall  and passenger side just a little bit.  My engine will be on Mustang II motormounts, plus it will be strapped down, with very little movement allowed.  The exhaust will be held up with one mount ( and a lose backup just incase) so it is free to move as nesasary.  I have ordered the 3" pipes with 65-70 degree bends (4 in total) and will post pictures if all works out as planned.
71hotrodpinto
AHHH hell Just run them through the firewall.  OR OR! Maybe straight up!!?? "A LA" Tractor Pull Style!!!
LOL
But really to have any kind of clearance sounds like you need to have the floorpan humped out at least 2"
Also im wondering about the vibration from the engine and the weight of the turbos on the headers. My buddy at work has a Turbo 2.3 SVO Mustang RACE/STREET and its blowing up headers left and right. Well come to find out he has no Flex Coupling on the down pipe to allow for engine movement. Well after 2 headers hes going to get a flex for the new header.
So to recap im thinking 2 3" flex couplers on the downpipe and a couple of tunnels for the exhaust.
Unless you want to just dump it out behind the front wheels??!!!
Anyways looking good and well engineered.
Cant wait for more progress.
Robert
Edelbrock Airgap
Mil
got the silicone coupler and the blowoff valve installed today, next is the exhaust pipes to go from the turbos, down through the wheel wells and under the car....wish me luck, 3" is going to be tight!!
and from above
few more with the wastegates and downpipes attached.
i have posted a question regarding picture attachments in the Admin section, I'll see if its ok with the "Grand Poh-Bah" to increase that number but there may well be a good reason for it that i'm not aware of.  Jeff
I'm going to get on that bandwagon 78Pinto........
   There is enough room for six pictures. And considering it only takes miniwheats anyway,and considering I have begun my interior BUILD. I agree.
P.S.     That Bling thing kills me....When my daughter is out of medical school I as well will be Blinging all ooovverrrr my engine compartment.
whos idea was it to allow only two pictures per post....
continued..
more pictures
thanks Tony.
My mandrel bends came in on Friday so i spent some time doing the coldside mockup. I need a couple more silicone couplers and need to fine a final resting place for the Tial 50mm blowoff valve and the mockup will be done.  Then i'll do the downpipes for the exhaust.
Hey 78Pinto,
I never post anything about your threads.
Mostly because I know very little about the V8 conversion.
I did want to pop-in here and say that I really like the work you do!!!
And to say that I enjoy your posts even though I have nothing to contribute.
NICE WORK!
Thanks for holding down the V8 fort.
71hotrodpinto
Nahhhh PHHHHHHFFFFF!!!!
i think that you should use the heads you have on there just as is and ill take those crappy new heads you have off your hands for $20us inc shipping.
Hell the turbos are just going to blow all the crap in them off anyways!! ROTFLOL!
:lol:
:hypno: you will video the dyno run , :hypno: you will video the dyno run  :hypno:,you will video the dyno run  :hypno:,you will video the dyno run ,you will video the dyno run  :hypno:
Edelbrock Airgap
Mil
My new RHS 215 heads arrived yesterday. They are very nice for how cheap they are.  I bought them bare and had Manley valves and comp springs installed, they are 64cc chambers and outflow Victor jr's right out of the box.  There is alot of casting flash in the runners and i'll hit them with the die grinder before they get bolted on.  With a little work these heads will flow large!
Here is the link to their website, RHS is owned by Comp Cams.
http://www.racingheadservice.com/Products/Heads/PA-SBF.asp
Yes they will be coated, i use a local place....the Jet-hot place here in Canada charges way way too much money for what your getting.  If i can get the tig working i'll use it but its been giving attitude lately so they might just get hit with the mig.
71hotrodpinto
 Nice shortning going on there. You going to Tig the rest of the header mod once you get it finalized?? And dont forget the JetHot 2000deg coating. Only 3 "colors" but might be a good idea to protect your investment.
http://www.jet-hot.com/Pages/coatings.html
Edelbrock Airgap
Mil
other side.  I'll still need to "clearance" the headlight buckets on the inside corners a bit along with the marker light cups....no big deal though.
some pictures of the header modification.....had to take out alot of the collector length....but i stepped up to 3 inch turbo pipes  (going from the collectors to the turbo flange) instead of the 2.5 inch that they came with.
