74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 01/30/2017 01:48 pm
Date: 09/15/2019 12:38 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 09/10/2018 10:41 pm
Date: 12/10/2017 01:14 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Date: 10/27/2018 03:30 pm
Date: 03/07/2017 07:03 pm
  • Online today: 535
  • Guests: 506
  • Total: 506
Twin turbo 383w build (two 1/4 mile videos added sept 15th 2010)
Started by 78pinto, September 24, 2006, 10:38:22 PM
The Pinto goes for body and paint tomorrow morning! Yeay!
78Pinto,
    You hit that right on the nail head. The bell housing catches that cross member. Also, getting that engine down far enough and back far enough were two points that I spent much time deliberating.
        R&D_Horse
Dave, yes i cut a ramp into the top rear of the crossmember to make engine removal and installation easier...the bellhousing always cought on it and it gave me grief.  With the ramp and higher trans tunnel opening it SHOULD be a piece of cake now.  Yes i relocated the rack, forward and down about an inch for pan clearance and to lower the engine......hopefully bumpsteer will be mininum, time will tell ;D
Original74
Jeff,
I saw back a few pics where you cut some from the top rear of your crossmember. It appears in these last pics that you fabricated a bracket of some sort and remounted the rack bolts from their original holes through the crossmember. Is what I am seeing true? I could be being tricked by all the SHINEY black, LOL.
I think I have shared this with you before....when this thing is sitting on the ground, the tie rods and lower a-frame MUST be on the same plane, identical angles compared with one another. I learned the hard way, let me tell 'ya! With the speed this thing is going to hit down the strip, you HAVE to have the best steering possible....can't have it walking all over the place on you.
I know you KNOW what you're doing, just having fun following your progress.
And yes, GO POR-15!
Dave
Dave Herbeck- Missing from us... He will always be with us
1974 Sedan, 'Geraldine', 45,000 miles, orange and white, show car.
1976 Runabout, project.
1979 Sedan, 'Jade', 429 miles, show car, really needs to be in a museum. I am building him one!
1979 Runabout, light blue, 39,000 miles, daily driver
more picts
some pictures, POR-15 and relocated steering rack. I'll have to make a new steering shaft as it now is too short and will require another universal to keep it away from the framerail...i'll be ditching the rag joint ;D
pintojoeII
DON'T GET IT ON U IT DON'T WASH OFF WANTS ITS DRY
http://www.por15.com/
its very strong...stones won't chip it off.
Where do you get that stuff?
Today i spent from 10:30am to 4:00pm and 7:00pm till 12:30am working on prep and application of POR-15 to the inside floor, inside of the fenders, fenderwells and varios other parts.....underside starts tomorrow.  The stuff is really great and would recomend it to anyone that wants to brighten up the underside/chassis and suspension on their car (also prevents rust).  I'll post some pictures when i'm done.
underside....not a good picture
hood (continued from last post)
more
Just finishing up all my metal work as it goes for paint in the next couple of weeks.  I made the trans tunnel opening larger...the firewall will be fiberglassed to make it nice and smooth.  I cut a 1 foot long piece out of the engine crossmember and welded a peice in ramped so the trans doesn't catch on the flat edge anymore  (pain in the butt pulling engine and tranny before as the trans tunnel opening wasn't high enough and the trans would catch on the lip of the crossmember) Floor is patched and will be getting POR 15 this week.  New 3.5 inch up22 fiberglass cowl hood arrived and will need lots of prep work. No pictures, but i also relocated my steering rack forward and down a bit so i can lower the engine....and i didn't want to cut my new Milodon oil pan.
got the hood today at 3:15!  It was well packaged.  My overall first opinion was it was very poorly done job..workable on the  the topside...but the underside is truelly NASTY!  It looks like total crap and will require alot of work to make it look nice.  I wish they did a gelcoat on it also.  I forgot my camera, so i'll have to take some pictures tomorrow or saturday. Scale of 1 to 10 i'd give it a 3 prep work will take awhile i'm sure.
UPS lost it!  Just found out today its in the warehouse....it was supposed to be delivered to me Tuesday, when i called they said it was delivered!  I said well it wasn't delivered to me!!!! should have it in my posesion by Friday.
pintojoeII
all you have to do is lift the lip of the windsheild gasket and reach a nut driver in and undo the six screws. You'll need someone to hold a flashlight for you so you can see under the windsheild gasket.  BE VERY CAREFULL....don't pry to hard on the gasket or you'll break the glass!!
71hotrodpinto
 Hey there 78, how did you get the dash out?? My 71 has the dash bolts coming from the windshield track area. After ripping out Everything from under the dash I had to cut off the screws flush ( that was A BIT*& ) and then just kind of work it loose. then i got some threaded clips ( i forget the tech name for them ) and then used 10-32s from underneath. to bolt it back into place.
Also high horse, you can get a dash "cap' and they look great compared to the cracked dash. Oh and for 60 or so its way better than waiting 6 years for that NOS dash pad to come up on ebay for $300.
http://cgi.ebay.com/ebaymotors/FORD-PINTO-71-72-73-74-75-76-77-80-NEW-MOLDED-DASH-CAP_W0QQitemZ160067829711QQihZ006QQcategoryZ40017QQrdZ1QQcmdZViewItem
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
#1.....The dash pad is the factory original
#2.....no you don't have to take the windsheild out to get the dash out.
#3.....Its a Sony am/fm CD player
#4..... THANKS!
#1....Where did you get the dash pad? Mine is all cracked.
#2....Did you have to take the windsheild out to repmove the dash?
#3....Is that a radio????
#4....Very nice!!!!!!!!!!!!
        Impressed _Horse
PonyBoy77
Quote from: 71hotrodpinto on September 25, 2006, 12:37:26 AM
HOLLLY shizod
That thing must at least make a hundred horse!!! LOL
Talk about a tight package!!
Makes me feel inadiquate. I thought I was being thumpy by forcefitting my 351 Cobra-Jet in my '74 wagon!!! Gotta love 'em!
couple more. Look close.....you'll notice that even sitting in my basement...its reving to 3700RPM! ;D ::)  This Pinto wants to go!!
Just got my dash back from paint.....its VERY VERY shiny! :police:   The angle on the new speedo didn't impress me so i'm going to redo it along with the fuel level gauge.  The dash was painted with base/clear.
Quote from: turbopinto72 on December 18, 2006, 11:34:46 PM
I've heard of acid dipping the car for light weight but now that Jeff is rust dipping I think all The racers will be doing it.   :-X :-X :police:
it's the cheap "canadian" way to achieve light weight bodies!
the floor is now patched, after the hood arrives i'll pull out the mockup engine and weld in my firewall and floor patches (just tacked in right now) and get the pig ready for body and paint.
yup....lightwieght factory racer! ;D
HOLY FLOORBOARD BATMAN!!!!!
Now we know why it is so FAST!!! ;D
Ran into a setback today, seems my rustfree Pinto....isn't rust free!  All of this occured from the inside out, likely because of the windsheild gasket.  When i put the new carpet in two years ago it was just starting to rust, i should have fixed it then but i didn't and it spread. The holes are mainly over the unibody frame so i couldn't see them, when i took the wire brush to the floor i could see tiny pinholes.....i made them bigger by poking at them to see how far the rot went.  This in only on the drivers side, the passenger side is fine.  I'm cutting out the rusty section and putting in new metal, then i'll use POR15 on the entire inside of the floor, the underside will be done later as well. I never would have noticed this from underneath the car....at least not till it rusted alot more, have an eye guys!
