1971 Pinto
Date: 03/04/2017 11:28 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 12/10/2016 04:11 pm
Date: 02/18/2017 05:55 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Date: 05/18/2020 10:22 pm
Date: 02/21/2017 06:29 am
Date: 02/04/2018 08:26 am
  • Online today: 1,106
  • Guests: 1081
  • Total: 1081
LongTimeFordMan
My consideration is that my car is an unrestored Galpin  survivor numbers car and i dont want to modify or cut it up.. ive done some minor bolt on mods like pertronix and carburetors but nothing that cant be put back..
Im doing a rebuilt engine to 1971 compression specs to drive and keeping the factory engine for my grandkids if they want to put it back to completely stock..
I understand that there are stronger parts out there  but i just want to keep mine stock..
And I dont really beat on mine.. just want to find spares while they are still moderately available..
Theres a 72 wagon in the classifieds herethat is already converted with turbo coupe  engine, 5 speed and 8 inch already installed..
Hummm..., my 150K miles T-5 that came out of the Turbo Coupe still functions fine. And parts are available.  If you get the one with the bellcrank the Pinto clutch cable connects. A simple plate of steel with two holes gets it over the crossmember. The stock Auto rubber trans mount was a bolt on (assume the manual is too) and all the steel mount required was a bit of slotting. In my case I went from a C-4 Auto trans/6-3/4" rear to a T-5/8" rear and the driveshaft fit without alteration.
So, basically what I'm saying is why spend a lot of money rebuilding the lesser stock Pinto 4-speed with hard to find parts? While they aren't falling off trees the 2.3 version of the T-5 at a Pick Your Part 40% off sale is under $100 out the door. They are rated at 240 Ft. lb. and mine has held up to the 190 HP of my Turbo motor.  I can't account for every drive shaft fitment but with my C-4 to T-5 swap I could either spend $$$ to adapt the driveshaft to the length of the weak 6-3/4 rear, or spend roughly $75 (40% off price) for a much stronger 8" and use the unaltered driveshaft. It is a no brainer.
For those that say the 5th gear of a T-5 isn't practical for the 2.0 engine..., well, just don't use it. You are still getting a better (useful 4 gears) transmission that likely suffices without a rebuild. And if it does need one, the parts aren't hard to find.
QuoteThe racing transmissions sell for about $2000 for a basic unit up to about $6000 for a full on dog box which is supposed to be good for 300 hp.
https://lencoracing.com/ST1200-4-Speed
;D
LongTimeFordMan
I called Taylor Engineering here in dallas and they stock all the parts to rebuild a WoG 4 speed..
They specialize in racing gearboxes and have what they call a "Rocket" which is an upgraded 4 speed and a "Sierra" which is the mercur 5 speed..
They will rebuild a 4 speed for about $500 and sell misc parts as well..
A.set of needle bearings for the countershaft is $55.
sounds good but try to find out what is included in what the vendor calls a "small parts kit"
you should definitely replace all the needle bearings that the counter shaft rolls on & definitely get the kit that includes new brass synchro rings
Quote from: LongTimeFordMan on December 24, 2018, 02:28:39 PM
I found a rebuild kit for the FoG 4 speed here.. what do you think
http://www.drivetrain.com/parts_catalog/manual_transmission_overhaul_kits/ford_fog_rwd.html
LongTimeFordMan
Quote from: LongTimeFordMan on December 22, 2018, 10:07:39 PM
Since many of you all have con erted to 5 speed.. do any of you sti have a decent factory 4 speed you coulde part with..  my 4 speed is beginning to whine a bit in 1st and 2nd and since I an redoing the 2.0 engine, I was thinking of getting a spare trans that I could rebuild to keep on hand..
front input shaft bearing and the countershaft needle bearings.  good luck.  easy to do but I don't think the parts are going to be easy to find.  especially the needle bearings.
LongTimeFordMan
Quote from: Bret Culpepper on December 15, 2018, 02:05:53 AM
Thank'ee.
Everyone I know that has had one despises it, evidently due to known issues w/ it's design & powerband issues.
Well, not everyone.  I've had the 1.6L in a 1972, the 2.0L in another 1972, and two 1974's and a 1978 Mercury Zephyr all with the 2.3L and I prefer the 2.3L, hands down.  No contest so far as I'm concerned, but everyone is entitled to their opinion.
Ah, I see. The NA 2.3 was pretty wheezy and weighty, but never really had any major design flaws that I know of.  It was even used in industrial and marine applications, both of which will find a weak point if there is one to be found.
That said, the 2.0 EAO is easier to get NA power out of despite the bad intake ports and it's quite a bit lighter.
Bret Culpepper
Quote from: 65ShelbyClone on May 10, 2018, 09:00:30 PM
The obvious option for North America is a T9 five-speed as it is heavily based on the Pinto's four-speed.
More importantly, what do you mean "crappy" 2.3?
Thank'ee.
LongTimeFordMan
You might check out these guys.. they do a lot of gearboxes race cars including the 2.0 sohc pintos.. pricy.. but they might be able to provide some interchaninfo.
They are helpful.. i got a roll pin for my gearbox there
http://www.taylor-race.com
Quote from: Bret Culpepper on May 09, 2018, 08:01:15 AM
Salutations y'all;
What is the collective point of view on a 5 speed trans for a 72 122c.i. engine?
I'm seeing a lot about the crappy 2.3, but not a lot on the 122c.i. Trans transplant.
Thank'ee & cheers
robertwwithee
Salutations y'all;
Thank'ee & cheers
I like the 5 spd behind both of  my 2.0.  One has a T9 while other has T5.  Run factory 3.55 gears with 205 60 13 tire.  Fast and good gas mileage.  T5 shifts smoother
LongTimeFordMan
Not sure about 5 speed in 2.0 but I have a 4 speed in my car with 3.40rear end and 14" aftermarket rims and tires and it does everything i need it to.
It seems to have a wide ratio low gear so starts are good, 1st finishes at 25-30 mph, 2nd at 45-50.
When properly built or even stock the 122 has a long power curve so I like the rather long gears, i see a lot of newer cars wirh 6 speeds and they shift about 3-4 times before I am out of 2nd and each takes time and clutch wear.
Especially the new mustangs, they make a lot of noise and Sometimes they shift 1st to 2nd before they cross the intersection but i keep up with them in my lil 122.
I would spend the money beefing up your engine for more power and torque and save a lot of adapter headaches.
Maybe just invest in a better carburetor like the standard ford or motorcraft 2bbl instead of the webber and let 5he engine work for you.
Bret Culpepper
Salutations y'all;
Thank'ee & cheers
hotrodln
Quote from: Wittsend on October 15, 2017, 06:42:40 PM
Most of the GM Camaro T-5's came with the standard GM trans to bellhousing bolt pattern. There was a point (late 80's/early 90's???) where they went to the Ford bolt pattern (likely a Chevy Guy day of mourning) but again you are dealing with the the input shaft length being different in addition to the points you made.  Also a lot of those GM T-5's aren't rated for a lot of torque. They never used them behind a 350, only 305's. They used the T-56 for the 350. At least the one thing some of the Camaro's had going for them (in a V-8 application) was the 2.95 first gear.  But frankly it seems to be a lot of mix/match to get ratios, input shafts, shift lever locations that each application needs.
I did this swap over the last year. I used the front half of the ford spec T-5 and the back half of a GM spec T5. i did put the shifter in the right place, but the speedo gear now reads off the BOTTOM of the output shaft ( not the top like it did on the ford) so it would have spun the speedo cable backwards- which means your old pinto speedo isn't going to work anymore- so i installed a Vehicle speed sensor instead. I will end up just using an electric speedo when I'm done with my project.
The 1.6L engines worked much better in the English cars in the 60's and 70's due to less EPA bs I guess. Was used for a long time in the SCCA race cars. I had several friends who raced Pinto with a 1.6L due to the fact they fit in a lower class in road racing back then.
Quote from: dick1172762 on October 29, 2017, 12:11:43 PM
The 1.6L cars needed all the help they could get as they were VERY under powered. I drove one in the Dallas rush hour traffic on the LBJ free way one day and I though I'd die any minute. The traffic was going 70+ and the Pinto with the gas pedal on the floor would not go that fast. Got off as soon as I could. Not one of Fords good ideas.
The brown '72 sedan I owned from 2007 - 2013 had the 1.6L and it would cruise all day at 70 mph; it just took a while to reach that speed!  lol
Quote from: dick1172762 on October 18, 2017, 02:17:47 PM
   You would need a very strong 2.0 engine to pull overdrive with any rear end ratio ever put in a Pinto by the factory. 3:55 is the very lowest gear put into Pintos from the factory and was in station wagons. Most Pintos came with gears around 3:00 and an overdrive is the last thing you would be able to use. It would take about 175 hp to pull such a gear and we both know that hp with a 2.0 is ONLY in an all out race car. 140 hp with a 2.0 is reasonable but with a lot of work and $$$$.
3:55 was available as the standard rear ratio when I bought mine in 1971 with a 2.0
There was a 3:73 available but I believe it came only in the earlier cars with the 1.6
Thank you for the picture. It seems a hard decision to find an acceptable cut-off point with the many intersecting lines/curves etc.. Perhaps I'll reconsider doing it in factory white like the rest of the car. So. Cal. has been hot and windy and epoxy priming outdoors needs to wait for just the right day. But after 10 years of "I'll get to it next year" I just decided that it IS going to happen... soon.
Update:  I had my nephew add a bit of roof color to what I thought was the best tie-in line and then change it to a flattened black. So, I thought I'd post it here in case you might have similar considerations.
LongTimeFordMan
The roof paint is actually Rustoleum rattlecan "hammered silver".
When the previous owner found it the luggage rack had been removed and some of the mounting points were rusted and he couldnt match the paint so he two toned it.
Heres a pic of the rear section
LTFM don't want to derail the topic, but I'm curious about your wagon's roof color. I can't tell if it is primer, or silver.  Also, what was the cut off point at the rear?  I'm in the process of prepping my wagon to epoxy prime as it has significant surface rust.  I actually like the two color look and am contemplating doing mine in a different color. I've seen a number of "cut off at the rear" points in my mind but seeing one in real life would be interesting.
LongTimeFordMan
As for the 4 spd pinto trans..  I really like mine... with the stock engine it launches really well in 1st and if I shift out of 1st at about  4500 at about 25 mph  it drops into 2nd at about 2300 just at the bottom of the power curve with the cam advance.  2nd gear tops about 45 mph at 4000. 4th at 45 mph is about 1900.
so I usually just do 1st, 2nd, 4th around town and only use 3rd when i need power on the fwy or slow to 35.
Look at  http://www.hvidberg.com/capri.htm   and the capri club of Chicago and capri club of north America  On the capri club of Chicago look at the drive line tech tips for a how to do it on electronic ignition for a 2.0 and how to do a T5 swap on a 2.0.
robertwwithee
Quote from: LongTimeFordMan on October 18, 2017, 03:20:36 PM
Actually i discovered the difference when I built my capri in 1980.. the shifter was a real piece of work..
I had a feeling that the flywheel was different as well..
I have a capri block that I am rebuilding... I assume that the blocks are the same and have rhe same bellhousing mounting holes, etc.
Sorry, the capri does have side loader. I was wrong.  Capri oil pan, dipstick, balancer (small cast unit), and front crankshaft housing different as well.
Quote from: LongTimeFordMan on October 18, 2017, 03:01:45 PM
Pix of pinto rims
VERY NICE! I didn't mean that the wagons only came with a 3:55, just that was just an option and Ford did not make a lower gear. 4:11 and 4:30 gears were made by Zoom when the cars were new in the 70's. About every 5 years I'll see a set on e-bay for sale. Very rare parts. And yes the tranies are wide ratios with second gear having a different ratio in some of the tranies. Why? Who knows but they are much looked for by the dirt track people for mini stock. BTW the blocks are the same.
