Date: 03/27/2017 10:07 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 04/27/2018 10:28 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 09/02/2021 08:21 am
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 05/24/2020 08:19 am
Date: 01/10/2022 03:41 pm
  • Online today: 261
  • Guests: 223
  • Total: 223
Any 5-speed alternatives to the T-5 conversion?
Started by Henrius, October 05, 2017, 10:55:14 AM
Quote from: dick1172762 on October 11, 2017, 04:51:51 PM
An early Capri would be another good find. The Capri club of America is a fairly large club so the cars are still out there. The Mexico Escort would be in the top of my bucket list.
I'll take one of these please, next to my Pinto version
I have a penchant for somewhat quirky cars and I'd think the Merkur somewhat fits that.  If it wasn't for the Calif. smog laws I'd consider one for a daily driver. Here is an oddity..., for as few Merkur's as I've seen there was a time about 8 years ago I went to a self serve yard after the Knott's Car Show and there were I think six Merkur's all lined up together. Sadly they were pulling cars in that row and I had a very short time to consider anything.
I like you never see a Merkur any more, but the Merkur Club of America has 4769 members. I'm a member just to look for 2300 parts. Very good web site.
As I've stated before when I got my Pinto back in 2007 I'd find about five Turbo Coupes every month when I went to Pick Your Part 50% off sales. Then within six months it trickled down to about one per trip.  Since about 2012 I think I've seen maybe one Turbo Coupe per year - if that.  Initially with the Merkur I'd see maybe one or two per trip, then shortly thereafter sporadically one or two for a few years. I don't think I've seen even one in over 5+ years.
Many of the upgrade parts (T/C, Murkur etc.) that were prevalent 10 years ago are very, very hard to find now.  A while back I made a post to that effect and asked, 'What are the most likely modern powertrain transplants to consider' given the limited parts that were typically used?  Maybe it is time to revisit that idea.
And, yea, that reverse speed thing? The only thing I can think of is a very high cold idle with an auto trans... (no clutch to slip), but the tire size wouldn't make that much difference.
Quote from: Henrius on October 07, 2017, 09:12:35 PM
What Merkur website are you talking about, and where in the heck do you find a Merkur T-9? I don't even remember Merkur cars in the US!
MERKUR CLUB OF AMERICA
Henrius
Quote from: LongTimeFordMan on October 06, 2017, 04:06:13 AM
According to a transmission sbop here in Dallas that builds racing transmissions, the mercur 5 speed is just a pinto 4 speed with an added secti9n in the rear with an additional gear.
Something you might want to look at is just moving up to 14" wheels and tires.  My wagon has 14 " alloy rims and 14" tires and 3.40 rear gears.  The combo probably equals about 3.20 gears, the difference a 1.1:1 overdrive would produce  the stock 4 spd is a wide ratio so starting off the line is no problem and it cruises pretty well.  The revs at 40 mph in 4th gear are about 1900 and at
70 mph right at 3000
Thanks. I have considered 14" rims. Problem is I am trying to keep looks original and I could not use the original hubcaps.
Plus reverse speed is so fast as it is, and converting to larger tires would make it even faster.
1973 Pinto Runabout with upgraded 2.0 liter & 4 speed, and factory sunroof. My first car, now restored, and better than it was when it rolled off the assembly line!
Henrius
Quote from: Wittsend on October 05, 2017, 01:46:59 PM
Something I would do is ask around about the 5 speed and the 2.0. My recollection was that in previous questions it was discouraged. The reason being there was not enough torque in the engine at the highway RPM (reduced with the overdrive) to make it reasonable.  Where as you have increased HP in the 2.0 it is likely in a higher RPM than the cruising RPM range.  You owe it to yourself to at least prompt the question before investing the time and money.  Make sure you post your rear gear ratio and tire size in any question you may ask.
Thanks for the reply. In increased the compression ratio to 9.5:1, put in larger valves, headers, and increased cam lift and duration. The car feels like it has more torque at all RPMs, but I have not dyno-tested it.
Henrius
Quote from: dick1172762 on October 05, 2017, 11:43:17 AM
The Merkur tranie was a T9 and is more or less a Pinto tranie with overdrive added on. I see them all the time on the Merkur web sites. Not any stronger than a Pinto 4 speed but worked ok in the heavy and more powerful Merkur's so they SHOULD be ok in a Pinto.
robertwwithee
Quote from: 72DutchWagon on October 05, 2017, 02:37:44 PM
The T9 would in my opinion be the preferred tranny upgrade for a Pinto 2.0, and indeed here in Europe it is the most common transplant.
You can read about my conversion to a T9 in my project. No transmission tunnel issues and gear lever in the right place.
However, The T9's available in the States come from 2.3 Lima Merkur's. I don't know if the bellhousing and input shaft of these T9's will be directly compatible with the 2.0. If not, then those parts will most probably have to come from Europe.
The transmission mount will have to be adapted, and probably driveshaft shortened and yoke changed. If the Merkur's had an electronic speedo, the transmission will not have a mechanical speedo drive, also something to keep in mind.
I just picked a T9 from merkur.  Let u know how it goes next week.  I did the T5 already.  3.4 rear, 23imch tire, 70mph/3000rpms. Netted 32mpg
I think Pintony had a T9 in his wagon and he had the tech on here of how he did it. Should be in the search forum.
The 2.3 T-5 moves the shifter forward... but not that far. A console can easily hide the forward offset. The most popular being the Mustang II console.  Others have used the the Merkur console (I have) though it is a bit "plasticy" and the front of it ends abruptly.  I'm sure there are other consoles out there that would work. I have the VW Rabbit console in my Datsun 510 and it is somewhat similar to the Pinto (sort of) console. The point being with a bit of creativity you can have the 2.3 T-5 and gain the looks and advantages of a console.
I suppose it depends on the Ratios available in the T9. I shopped around for the Ford 4 speed that had the closer 1st to 2nd ratios  for AutoX, but later went to hillclimbing and would have needed a 5 speed or the Closer 2nd 3rd 4th ratio box. Of course, a Quaife Rocket box can solve anything if you have the $$$. I had to use 20inch diameter slicks to get my final drive (3:40) to even pull the longer straight sections , and that's with 170 hp @ 6500RPM . 4th was nearly unusable everywhere.
Pintosopher, Spinning the driveshaft, not Yarns :D
LongTimeFordMan
72DutchWagon
Quote from: Henrius on October 05, 2017, 10:55:14 AM
The posts on modifying for the T-5 transmission have been interesting, but the stickshift would be at a different position and necessitate a new carpet- again!
Henrius
I upped the horsepower quite a bit on my 1973 2.0 liter engine and would now like to slow the revs down in my Runabout.
Somewhere I heard that there was  Merkur 5-speed transmission that would bolt right up with no mods. It might have been a T-8. Is it indeed compatible? If so, where could I look for one of these rare transmissions?
