Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 05/19/2018 04:56 pm
Date: 05/18/2020 10:22 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 01/04/2017 04:07 am
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
Date: 07/01/2019 12:23 pm
  • Online today: 531
  • Guests: 458
  • Total: 458
72 DutchWagon project phase 2
Started by 72DutchWagon, March 07, 2015, 01:44:49 PM
Hey glad the got the mount I sent, and do not worry about shipping or paying for the mount, just happy to help out a fellow pinto owner with a great project, as for the mount being at an angle is odd , it is supposed to be flat , did you bolt the bottom up first then the side pinch bolt, you have to make sure the bottem is seated before you tighten the side one, the rubber mount has an alignment pin on it so make sure it is fully in when you tighen the nut , the two studs on top is for a bracket that supports the exhaust pipe , you can use flat bar on it, I removed it to save weight and shipping cost, can take a photo for you so you can copy it , and post more photos as you go, later. Blaine
Nice radiator, height not going to be an issue??..
72DutchWagon
Thanks Blaine! Trans mount arrived yesterday, I'll have a good look at how to fit this piece, first thing I noticed is that it is slightly angled towards the drivers side of the car (not bend or anything it looks like), is this part of how the three mounts are supposed to work together? If bolted up it would try to tilt the trans somewhat to the left? Or is the type E bottom mount at an angle?
Regarding the radiator issue, certainIy after Blaine commented that it wasn't the original piece,  I decided to splash out on this one, I went to QSP products in Waalwijk (just an hour's drive from where I live) and bought me a new aluminum radiator that is made specifically for MK1 and MK2 Ford Escort RS 2000's (also Pinto engined). Trial fitting went smoothly, no cutting required to the sides of the radiator frame, just a little bit at the bottom. Will show more pic's later after the SPAL electric fan I ordered arrives from QSP. I first had to figure out if there was room for a suction or blowing fan, luckily the suction fan fits.
Quote from: pinto_one on June 05, 2015, 05:27:27 PM
Thanks for measureing that for me , saves me from crawling in the mud to look and see, the yard wants a hundred bucks for it , and the few reasons I want it is its cheep , it's a five speed, and it lines up with the shifter hole better than the T5 ,  this is not going to be put on a high powered engine anyway, planning on a diesel conversion, adapt it to the engine ,  on the trans mount you can easy make it work,  it only three inches back than stock,  plain "A" would be shorten the trans bracket a inch and a half , and move the slots in the cross member a inch and a half,  plan "B" would turn the trans cross member back wards and put a plate to pick up the studs in the mount and weld it on,  hope this helps , post photos when you get the stuff , like to see it , later Blaine
You're still doing the conversion? WOW. Can't wait to see. That EFI is too high BTW...
72DutchWagon
Blaine, my measurement on the T9 from face of trans to bottom mount bolt hole is 14,57 inch (37cm).
This explains the extra adaptation that will be needed to get the original style mount in the right place.
I don't know if the front shaft and clutch are going to give you problems though.
As for the T9 transmission, it had a lot of bad press; not being strong enough and all that. But it has the exact right dimensions for our early Pinto's, and it has a huge aftermarket availability of parts and upgrades. If money is no problem you can go all the way to a Quaife QBE60G-H1 6-speed in-line sequential gearbox that can handle up to 375bhp (about $ 9200.- excl. taxes...) and it is a direct replacement upgrade for the T9!
More realistically, you can choose all kinds of upgrades to suit your wallet from countless companies because the T9 has a huge market in rallying, racing and kit cars.
Easy cure for the radiator/fan to close syndrome,  one I see that that is the radiator is not what cam with the car , but it can be used by bringing it to a radiator shop and have the side brackets swapped left to right moving the radiator forward a inch or so , I have done this to some V8 pintos in the past and trim the top just a tad , simple fix,   Next I took a tape measure of the stock trans from the pinto , type "E"   It's 11 1/2 " inches from the face of the trans (where it bolts to the bell housing to the bottom mount bolt , what is the type " 9 " 5 speed trans measurement of yours , know where one is here and thinking of putting one in my other pinto,  cheaper than a T-5 , later Blaine ,
72DutchWagon
Small but tedious job at the front, removing the viscous fan.
Trial fitting the original radiator made clear that the fan is too close to the radiator. This is caused by the Scorpio Pinto 2.0 having double pulleys and a wider viscous fan. So I had to make up two improvised tools; grind up an old 27 mm wrench to a width of 32 mm, and take a 51 mm chunk of square metal out of piece of U-iron. The U-iron is wide enough to fit over the pulley, and the "fork" holds the four pulley bolts to keep it from turning, on the other side the U-iron rests on the driver side frame bar.
The 32 mm wrench goes on the fan nut, and lengthened with a piece of pipe you pull it to the driver side (a little WD40 on the fan nut a day before may help), because this is a left hand thread.
Think I already know where it's heading with the fan/radiator solution, more in next post.
Yes I got your pm, this setup takes the same rubber mount for both transmissions, just the bracket is different , this one is the newer style one, very early ones only had the one bolt at the bottom (which most of the time got lose over time) later ones had the extra tab with a cross bolt to pinch the tabs one each side tight , will pull it off tomorrow and ck on shipping , and send more photos, later Blaine
72DutchWagon
pinto_one, yes the missing link! Since my car had it's 4-speed replaced at some time by a C4, the bracket between the trans tail and rubber mount is gone. I've only seen a simple drawing of it in a parts catalog. I would like the original part, will send you a PM to talk shipping.
Your explanation of the working of the mounts makes sense, I haven't checked the angle of the original Scorpio engine mounts yet, if they are also at an angle I see no problem in using the Scorpio trans mount, if they are flat it's time to rethink.
But I'm not confident that it's a simple bolt on, I don't think the mount on the T9 tail is exactly in the same location as on the type E, think it's a tad further back and deeper, which would still mean some adaption like in image "trans mount idea 1"? Please correct me if I'm wrong.
hope you did not cut up your mount , you have to use the type of mount that came with the car or you are going to later have engine mount problems , the angle you have in the front makes the engine want to slide to the rear, the org transmission mount makes it move to the front , so every thing is centered , this set up is used to dampen engine vibrations at low and high speeds , same is used on some aircraft, you need a org pinto standard transmission mount , for a type "E"  , it will bolt to your type 9 ,  got a few extra if you want one, have to check on the shipping ,  this should make things much better in the long run, later Blaine in the deep south state of Mississippi ,
72DutchWagon
He, lost momentum there for a moment. Been busy with domestic chores, and had a good motorbike Pentecost weekend with one of my brothers and family in the Belgian Ardennes.
To answer pinto_one, yes, this is one rough little Pinto, I'd say it even deserves a subcategory, call it a Ford Donkey. And I love my old donkey.
It has little dings and dents all around, and patches have been repainted at different times with whatever was around and the biggest brush (broom? Great runs) available. Interior is mixed red and black. It doesn't bother me that much because I have no intention of bringing it back to showroom state.
Back to business, I first made a real simple mock up trans mount based on using the original Anchor rubber mount. The wood in the image would be replaced by U-iron. But the original style isn't  a masterpiece of rigid design to begin with.
Then I decided to hack up the Scorpio mount and weld 2 pieces of pipe on it to mount it just like the C4 mount, no changes to the body. My sincere apologies for the crap welding job, hope it stays together.
The Scorpio rubber mount has its own problems, because leaking oil can puddle on top of it and slowly eat it away. Luckily new ones are still available.
As I said before, I want the cheapest, fastest route to getting this car running again after an engine conversion. There are many options for up rating and renewing these parts, but they cost more money and time.
First a runner, then if satisfied uprates.
Glad you got it the right way , but your carpet does bring a tear to my eye , 😱
72DutchWagon
So here it is, correction of the confusion going south situation; pinto 2.0 motor mounts in stock position. The "L" on the left bracket is now facing the driver.
People with an eye for detail will notice that the wires through the insulators are absent.
Reason is that the holes in the engine brackets for them aren't in the right position, they should be closer to the bolt. So cut the wire (Brian at Anchor says it usually doesn't affect the function of the mount) , or drill extra hole in bracket. Next time around I might drill the extra hole.
Shifter location looks OK, but still a little to the passenger side. Looking at the offset on the stock tranny mount, I get the impression that it is meant to be like that.
In the next post I hope to make an impression (everybody rolling on the floor with laughter) with my home fabricated mock up tranny mount.
72DutchWagon
Thanks again for all the response, good comments and clear pictures, I'll see if I have time this weekend to turn it all around again!
The angles of the motor mount flats on both ends and both sides are clearly arguing with each other, the mount steel brackets are mixed up there. Not saying that swapped back they will be 100% right but should be better as far as those angles. Look at pics directly above and mentally remove the rubber, the two flats are parallel.
L on a part as with all others means the left side as driver is sitting in the car.
Motors sitting correctly in the cars generally have the motor slightly higher in the front and why there is a correction angle generally built into the intake manifold to make the carb bowl pretty much dead level. Injectors do not need that though. Looks there like may need a bit more room on the back of intake to hood for the higher part of plenum there so that works out there as well.
Pintocrazed
This is the best pics I could take
I know about doing thing a few times before you get it right, I have had a few 2.0 over the years and the last one I pulled the engine out of was almost ten years ago, sitting here thinking about it I do remember that the open part was to the back, since the after market mounts you have may not have the alignment pins the org rubber mount had, that way you could not rotate then when you bolted them to the engine mount, they also were angled back alittle , the trans mount also had a pad like rubber mount that was angled to the front , (pushing forward) and keeping everything centered , like a big "V"  the more I think about it the more I remember , (good for the mind😜) but you almost got it, soon you will have the smell of old oil burning from the exhaust manifold from a smooth running efi 2.0 😷
72DutchWagon
OK, makes sense, now the only other unknown to establish is in which direction the open sides of the isolator cups should point, because that also has an effect on the whereabouts of the tranny tail.
I would really like to get this right the third time, although it's good exercise, no need for going to the gym!
Looked again at the photos and hate to say this but you got the engine brackets backwards also, the parts marked are L & R  the Left side goes on the left side , this is detrmined buy sitting in the divers seat looking forward , not standing in the front looking to the rear, it should fit well after,
72DutchWagon
Thanks guys for the quick response. Pinto_one, the oil deflecting function of the cup already came to mind (after installing them and looking at them the logic kicked in), glad to have an extra opinion on that. Pintocrazed, looking forward to some pictures, and as you said please post, to completent the picture library of this great site. There are tons of images of 71-73's converted to 74 up and more exotic mounts but no originals.
There ya go that was quick ,😀
Looking at the last photo I do believe you have the rubber mounts upside down , the cup goes to the top, this is from memory , with the cup on top it will deflect any oil that might drip on it if you have a leak , with the cup the way you have it , will hold oil or anything that my drip onto it , it will destroy the mount , the oil will turn the rubber to a black goo over time, a. Few will see this post and send you photos, later Blaine
Pintocrazed
DUTCH,
I HAVE A 73 RUNABOUT WITH THE 2.O THATS NEVER BEEN OUT.SHOT ME A EMAIL ADDRESS AND ILL TAKE SOME TONIGHT.ILL ALSO POST THEM ON HERE SO ANYBODY CAN SEE FOR FUTURE REFERENCES
72DutchWagon
After fitting the T9 box to the 2.0 Pinto a strange new problem arises; the shift stick is in perfect location length wise, so no transmission tunnel hacking, but it is out of the middle, to much to the passenger side. Forcing it to the middle means the engine isn't straight in the bay.
This can't be right. I checked the photo's made during dismantling, and yes, I put the engine bracket's on the 85 Scorpio lump the same way as they were on the engine that came out. However, that doesn't mean that somebody couldn't have made a mistake in the past.
I could only find one set of left and right pictures of engine brackets on a 2.0 Pinto on posts by "Orange Alpine" on turborangerforums.com. If his were positioned right, then mine were wrong.
So, lift the engine and tranny again a few inches, and switch the engine brackets.
Now I have the bracket with letter "L" facing me on the left when standing in front of the engine.
After bolting everything down again the shift stick is in the middle, but I must admit that I'm still not satisfied with what I'm looking at, there seems to be too much stress on the insulators, and the block is too close to the firewall for my peace of mind.
Page 16 of the Ford Pinto Tech Manual 71-72.pdf mentions a Support Bracket (D1FZ6028A D1FZ6029A), a Mounting Bracket (D1FZ6030A D1FZ6031A) and the Insulators (D1FZ6038A). The insulator part number does cross reference to Anchor 2363. What the other 2 should look like I don't know. The ones I've got could theoretically even be 74's?
I can't find any other info on the install of the engine brackets and the positioning of the insulator (is it upside down?), I need some help here.
Could someone with a 71-73 2.0 Pinto please post some pictures of the setup in their (hopefully) untouched car?
I can't start work on the transmission crossmember until I know that the engine is in the correct place.
Quote from: dick1172762 on May 02, 2015, 06:40:12 PM
While in college my only car was a 1950 Ford with an Olds V-8. Had to change the clutch without a jack or lift. I drove it onto the curb with two wheels in the street and two wheels on the curb. Worked ok removing the tranie but about the time I started to replace the tranie it started to rain cats and dogs. The water kept getting deeper and deeper but I had to finish the job or miss school. The water was running from front to rear of the car and I was under the car with  my feet toward the front of the car. The water started to flow up both pants legs and ended up coming out around my collar and onto my face. Look at the number 6 picture to see how it looked when I did the clutch. But I did finish the clutch job. Anything for school.
LOL  You painted quite the image there!  The things we do for our cars!!!
Your getting there, has anyone here done one under the car with a dirt floor raise your hands,  ✋,  with that T-9,s extra gear will help alot, I still remember my 71 when I shifted into forth it always felt like I could shift one more time,
72DutchWagon
Lost two days trying to fit the T9 gearbox with engine at maximum angle and lots of wobbly stacks of wood.  Stupid.
Did some reading; how about centering your clutch plate first, yes, and put the gearbox in gear, so you can line up the splines...
My clutch center tool was a 10mm socket that just happened to have the right outer dimensions, I put a round headed bolt through it (filed a little less wide then the socket), and  a piece of wire behind the nut, to be able to get the socket out again after tightening the pressure plate bolts.
Using a socket extension didn't work, the socket would stay in there.
Ordered a $ 60.00 motorcycle scissor lift, mounted that on a cart, put the gearbox on top, and tied it to the lift with wire (why aren't these boxes flat at the bottom?), to keep it from falling off.
Then I jacked the box up, and carted it more or less straight to the engine.
This time success, but still, this isn't easy when you want to work alone, and the car is jacked up
only 14 inches from the floor. Space and equipment have their limits.
