Date: 03/30/2021 12:29 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 10/27/2018 03:30 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 10/28/2018 08:45 am
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
  • Online today: 531
  • Guests: 245
  • Total: 245
72 DutchWagon project phase 2
Started by 72DutchWagon, March 07, 2015, 01:44:49 PM
72DutchWagon
Thanks for the info guys, help is always appreciated!
The ride height came out OK I think, may'be an inch below stock, as if knew what stock height is...
The car was standing much to high in front, and I haven't got a clue about what springs were used, so it was always going to be hit or miss. I had to use somebody's measurement!
The engine is in the bay but still a lot of work has to be done, T9, battery, radiator, drive shaft, and fuel tank have to be installed, all of these things will have an effect on the stance of the car.
I will post pictures of course when everthing is in there.
Very nice 2.0 upgrade and T-9 installation.  The front suspension spring free length measurements in that old link were from used springs I had.  Just concerned that your ride height came out okay.
The stock 2.0 rubber motor mounts allow a lot of engine rotation.  So if you do end up with only 1/4" hood clearance, a engine torque restraint may help.  Today I have seen nylon straps/ropes used.  Back in the early 70's, IECO & Spearco sold a "engine anti-shake bar" torque arm with an additional motor mount to reduce this rocking and it did not noticeably increase harshness (see item PA614 in the linked catalog below, page 22 of 28).  It was made of angle steel so it is heavy.  If interested in the IECO item, I can measure and sketch up its dimensions for replication.
http://www.fordpinto.com/index.php?page=18
Looking good, but I would put some modlers clay on top of the manifold when you first run though the gears to make sure you do not ding the hood from the inside from the toque of the engine , 1/4 inch is very close to the hood, if it's in the very front you may be able to angle mill it and blend in the inside to match the flow, it should have more low end toque with that long runner manifold, are you using the stock vam or going mass air computer, and also that have a new vintage turbo kit on e bay for the engine , has the exhaust manifold and turbo , and the photos I see you do not have air conditioning, so you could mount the turbo and pipe it into a inter cooler and cross over straight into the intake manifold, nice work , Blaine in Missisippi😺
72DutchWagon
Not to fast Pintocrazed, I might be reasonably good at mixing puzzles, but this thing ain't running yet!
Pintocrazed
72DutchWagon
Engine mount brackets were transferred to the 85 Euro Scorpio 2.0 block, just a bolt on, new engine mounts were used,  Anchor 2363, I got these from Rockauto.
Then I put the engine back in the bay, no real problems here. When it is angled right, after fitting the T9 and making up a transmission bracket, it might just be that the injection manifold clears the hood, by a quarter of an inch or so, and the fan, which sticks out a little further (double belt pulleys), might clear the radiator.  We'll see how that works out.
72DutchWagon
I pulled out the coil springs which were way to long, I'm feeling sorry for the person who put them there and didn't know what was going wrong, must have been a hell of a job and with risks!
On the first image you can see the problem, left is already fixed, the right one is bending outwards in a frightening way, even against the shock, you can't see it but the wheel isn't touching the ground, so there is no tension on the suspension at all.
Next image is original height 11 2/8 inches, cut to 9 3/8 inches, the figure Oldkayaker mentioned for 71-73 Pinto's.
To avoid confusion, measuring device is in cm's.
After that I started removing old gasket from 2.0 injection intake, have to wait with reinstall because the wrong gasket (for carburetor intake) was in my engine gasket kit, so I'll have to order a new one.
72DutchWagon
Another few jobs done;
new dipstick tube in correct position, welded a bracket to pipe (scavenged from Scorpio) to fix to fuel pump delete plate upper bolt, and worked up the bottom with Devcon A plastic metal putty (yes, looks rather sloppy).  I don't think it will come lose. Ever.
I ordered a DANA SPICER 2-3-8431X 25 spline transmission slip yoke from Denny's Driveshafts, is advertised for Ford C3, also fits T9.
Last pic is cleaning Oregon dirt from the gas tank with curious Pinto looking on with one eye.
72DutchWagon
Here's a comparison of the 85 scorpio rear bowl sump and the 72 Pinto front bowl sump.
To my knowledge all European Pinto OHC engines have a rear bowl sump. In the past a lot of conversions of Pinto engines in older European cars meant a good deal of sump cutting and rewelding, this link http://www.premiermotorsportdevelopments.co.uk/ford-pinto-front-bowl-sump-with-pick-up-pipe-907-p.asp  brings you to a firm that still does this work.
The American Pinto 2.0 sump pan remains to this day a seldom seen object of myth in Europe,
so here are some pictures.
After spending a day clearing out the garage (it became an unworkable little place, the old engine and C4 transmission and lots of other stuff that was in the way went to another lock up), I just had time for one little job this afternoon; threading the old dipstick tube hole for an M12 bolt, so that hole is securely closed off.
Some people will find this project not exciting and slow, but I'm trying to build a detailed record of what it takes to do a reasonably simple first engine swap. Newcomers to the hobby don't learn a lot from forum posts like "me and my mate dropped  a V12 in a Yugo before breakfast".
I also believe in "stages" in the project, first see if I can build up a functioning car with a modern version of the original engine, and then look at ways to improve on that.
Quote from: 72DutchWagon on March 18, 2015, 01:22:52 PM
first hurdle easy pass; the oil pump pickup tubes from rear sump 85 Euro Scorpio Pinto to front sump 72 Pinto Wagon are a bolt in swap, no mean feat considering there's 13 years and the atlantic ocean between these two blocks.
Next hurdle to tackle is relocating the dipstick, just saw that Dianne's project is facing the same job in a 2.3!
Wow, another dipstick location challenge! Let's call the UN and demand equal design for each one ::). Too bad it's not a Cossie your dropping in!
Watching with great interest...
72DutchWagon
72DutchWagon
Now it was time for the auto box to come out. The auto and the T9 next to each other made it possible to compare some measurements; the auto box seems to be 0.7 inch longer then the T9, shouldn't be to much of a problem in the swap I think?
Gear lever position seems to be allright.
The rear crossmember location is a little off, needs some fabricating.
The outgoing shaft on the auto box is beefier though, so that means looking for a different slip yoke (and new u-joint) for the T9 (25 spline, 1.38 inch outer diameter).
If any of you have been here before and know of (a) part number(s), please let me know.
72DutchWagon
Sticking to the 2.0 gives you a 121 lbs weight advantage over a 2.3, and I'm not a racer, but I think that extra weight is also in the wrong place for going around bends.
Pintocrazed
I thought bout that but fuel injected 2.0 be cooler cause everybody is doing the 2.3 or 2.3 turbo
dianne
Quote from: Pintocrazed on March 08, 2015, 11:33:50 AM
I'd love to put a fuel injected 2.0 from there in my 73
You can do a 2.3 from a Fox Body. Mine is delayed waiting on the machine shop to get the crank back :( It's still at the place for paint too. Can't complain too much honestly. But you can go to a 2.3 Mustang EFI engine.
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Pintocrazed
72DutchWagon
Today the engine came out, see pic's. Second pic shows old engine and the 85 Euro Scorpio 2.0 EFI that should replace it.
72DutchWagon
Finally I parked the Pinto in the garage and I'm starting to get the old engine out.
I added some pictures; note the somewhat sloppy auto box conversion, the trans cooler is dangling in front of the radiator attached by old pieces of wire.
On the other hand, the starter motor and alternator look brand new.
A question for all you early Pinto drivers, since I acquired this car I had the notion that the front is to high up. I measured 9,5 cm = 3,74 inch between the top of the tire (175/70 13) and the edge of the wheel well. If this is to high, could it be possible that someone put in later Pinto/MustangII springs without shortening them to the correct height for the earlier ones?
