Lower Alternator bracket
Date: 08/26/2017 05:11 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 03/06/2017 01:19 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 11/04/2018 02:34 am
Date: 03/21/2017 07:47 pm
Date: 09/10/2018 10:41 pm
Date: 10/26/2020 03:24 pm
Date: 02/28/2018 09:18 am
  • Online today: 2,622
  • Guests: 2533
  • Total: 2533
Taking the turbo plunge!
76hotrodpinto
Quote from: Wittsend on October 14, 2015, 03:32:45 PM
BTW, this thread is the only activity on the Turbo section since July 22, 2015.  That other post regarded the Ranger cam and then on July 21st, 65 Shelby Clone posted.  Where are the other Boost Spoolers???
I'm not surprised. I'm usually waayyy behind in everything. I probably missed this hey day by decades.
Good point on the temp sender. I wonder if I can just figure out the reading for a warm engine and mimic the signal?
Yea the TPS too low is odd given the 1.17 you found. Frankly I don't think it is too critical. I think it just needs to function in roughly the 1-5 volt range and the ECU learns to adjust.  Now, maybe it is comparing to another sensor and the TPS "seems" too low for the other readings?  I know some of those sensors look like they loop through each other (maybe they parallel???). I can see where the temp sensor will give a rich condition if the ECU thinks the coolant is cold.  I'd look at finding a way to tap in the factory sensor even if it is a Tee in a hose.
All this has got me to thinking that if one has a number of potentiometers inline with the various sensors that there is likely some ability to tune the engine. Like in show a cooler coolant than it is and the engine richens up a bit. The deluxe version can use vacuum switches to trigger this effect on/of dependent on throttle input.
76hotrodpinto
Tps tip.
The plug ends on mine were hard to get the micrometer probes to pig tail into. So I slipped the pin connectors out and attached 8" leads to the black and green pins, and put it back together, pulling the 8" leads thru the corresponding wire holes . I used a small gauge single wire, and crimped a butt connector on the other end of each. It allowed me set the probes in the open ends of the butt crimps, for easy tuning. Just tuck out of the way when not being used.
76hotrodpinto
I deleted the temp sender to put in a mechanical temp gauge.
I just went through the tps process again. I had it at .94 when I originally tuned it, but it was at 1.17 when I just checked it. Put it at .94 again. It's a little smoother, but the afm is still showing a rich condition through all rpms. It idles at a perfect 1000 rpm. Still throwing the code 63, but I don't know if it needs more run time to recognize the adjustment. Haven't investigated the code 72 yet, not sure what to test yet, but that may be causing the rich mix.
Still no luck on the koer yet either.
 Is there a reason for the coolant temp sender code. Is it not functioning, you deleted/replace it?  This is a LONG thread to go back through.
If I remember correctly to set the TPS you disconnect something (idle compensator???) and set the idle RPM on the throttle body. Then you adjust the TPS for one volt (as I recall 0.94 is recommended). I deleted the EGR and as best I recall the KOER test still initiated.
  I also found it interesting because it seemed to initiate a cylinder balance test, but then, as someone pointed out, two injectors fire at a time in this system and it can't give an accurate result.  All I can say is when I initiated the CB test the engine ran rough in a cycle that seemed to disable injectors firing - go figure.  I also have the Innova 3145.  I bought it after getting tired of counting light flashes (and confusing pauses) on the Equus 3143 and before that the CEL bulb. Not a task for those who have ADD.  I don't and it was still befuddling at times.
76hotrodpinto
Hmm. What changes?
Delete list:
egr solenoid
temp sender
12v fans
ac clutch relay
(might be more, need more coffee)
Hardwired the fuel switch in premium position.
The tps was suspect before testing, might need replacing. The code 72 will require more investigation.
Other codes that I attribute to system mods:
o-51
o-84
c-51
What changes did you make to the stock system?
63 Throttle Position Sensor (TPS) signal too low
72 (R) No MAP or MAF change in "goose" test - retest, check for frequency or voltage change
Sub Notation: (M) 2.3L T/C - PCM re-initialized. Possible electrical noise, case ground or intermittent VPWR problem
76hotrodpinto
So I finally got around to playing with the code reader. I got the innova 3145. I got some codes that I know are from egr and temp sender deletes, and some that I need to do some checking on (codes were 72 and 63). The timing check was fine. But I can't seem to get it to run a koer test, or maybe I just don't understand what's happening. It does engage the the throttle for second, but that's all, then about a minute later, the display goes blank, like it has turned itself off. I did read that I can't run the koer until after I get a code 11 on the koeo. But how is that even posible, given the swap mods? I'll be messing around with the other codes, that still have existing systems to mess with. I'm just a little befuzzled that I can't get the koer codes.
76hotrodpinto
Quote from: Wittsend on September 26, 2015, 06:55:40 PM
I think that's enough shiny's.
Don't worry. The rust color cam sprocket helps tone things down. LOL  Also, if you can dig up the factory clamps they are a muted black color. Glad to see the progress. You turbo guys seemed to have slowed down a bit.
Gotta have a little rust, it's all about balance! I don't think any of the clamps on the tbird were original, when I got it.
It does seem slow in this part of the forum these days. I'm in the process of gathering all the parts for the next round of swapping. 11" discs on all 4 corners, new coil springs and shocks, tubular a arms, lsd for the 8", monospring system, disc master cylinder, all new bushings everywhere, rack and pinion, and dropped 2". And of course some new wheels to clear the discs.
76hotrodpinto
I got the last piece of my cooling system in, the overflow tank. I think that's enough shiny's.
76hotrodpinto
Finished up a few small things.
Put a drain valve in the radiator.
And dug thru the radiator hoses at the parts store till I found the right chunks to make decent lines in and out. I hate temp tubes.
76hotrodpinto
How much of an affect, if any, does engine temp have on fuel mixture? I've been running rich, not so bad that I can smell it in the exhaust, but rich on the mix meter. I've been gradually upping the temp setting for my fan, and have noticed that my mix meter is showing incremental lowering of fuel in the mix(at operating temp). Is it coincidental? My imagination? Or am I correct, that engine temp is part of the computers equation for determining fuel mix?
76hotrodpinto
Mine seems more accurate than before. According to the speed signs that read your speed, it's dead on too.
I have the trust issues after major work too, but most of it comes from all the new wiring. Mechanicals can usually be fixed on the roadside with simple tools...electrical, not so much.
My speedometer is surprisingly accurate (according to GPS) to about 1mph with the '86 Bird trans gear and the Pinto driven gear with 3.55s and stock tire height.
76hotrodpinto
It is running rich, and I have those tiny wheels. I've been mostly just driving it and monitoring all the systems for issues. Other than needing some tuning, it's doing perfect. I always go thru trust issues when I do a drive train swap, but I feel pretty good about things so far.
I think the one time I checked it was doing about 24mpg with a bad tune and routes and driving that did not help economy. I expect to get 26-28 when it's finally sorted out. That's what 2.3Ts got in most of the original (larger and heavier) applications.
18-20 leaves a LOT of room for improvement.
76hotrodpinto
What kind of mph are you guys getting out of your turbo setups? I'm surprised to find I'm getting 18-20 mph, or so. That's about 50% better than the 11-1 comp. na motor, I was running before. I feel pretty good about that.
Cool, but be safe. There was a guy on here a while back that had a grandpa like Squire Wagon, cheezy plastic hub cap, a beer box hiding his rear mounted battery - and a turbo conversion. He seemed to bait the Ricers too. There was an actually a web site about his car. Not sure how to link to it now.  But, yea, go PINTO!
Update: Found it. Click on the "more" when you get to the pictures for continuing information. http://www.cardomain.com/ride/2167062/1980-ford-pinto/
76hotrodpinto
Quote from: 65ShelbyClone on August 31, 2015, 07:02:05 PM
I don't yet, but this might offer some ideas:
http://stinger-performance.proboards.com/thread/732/fix-pcv-system-engine-blow
Perfect! Great info, thank you.
I haven't quite got the clutch broke in yet, but I let myself be goaded in to an excessive acceleration type situation with a lowered acura sporting a coffee can... my first victim! And I still have yet to really lay in to the throttle. This has been one of the more gratifying projects I've ever done.
76hotrodpinto
(sound of crickets chirping)
Any of you guys running an oil catch system? I don't think I need it yet, but I hear they become necessary at higher boost levels, which is inevitable. If you do, what size can are you using? And what size toobs?
76hotrodpinto
I fingered out the video posting deal... I think. So here is a short one. I'll post one of a joy ride, when I get a brave camera man. My first video, so don't expect any kind of quality.
76hotrodpinto
Quote from: 72DutchWagon on August 15, 2015, 03:52:04 AM
On posting a video, the one on my project was the first time I did this; went to youtube, right top click upload, logged in with a gmail account, uploaded the video following the simple instructions, and copy pasted the youtube url of the vid in my Pinto post.
Hope this helps.
So I need to make a youtube account? Will photobucket work? I use that for pics.
72DutchWagon
Hope this helps.
76hotrodpinto
I got my boost gauge and afm gauge installed. I had to swap a few around to satisfy my ocd, but I'm happy with the lay out now.
And here's a pic of some clouds, for those that may not have seen any for while.
76hotrodpinto
I have a short video of it now. I just have to figure out how to post it. I've never posted one before.
76hotrodpinto
I used the factory coil power wire(tbird), aftermarket coil and a fancy racing toggle, no resistor. I ended up mounting the coil where the stereo would be. I'll be going mech-less when I do get around to the stereo.
Yes, and to avoid troubles like that I opted to used the stock, 88 harness from the donor car. But, apparently not. There is a resistor wire in the TC harness (column), but I swapped the column too. Now, I did have to cut it (there was no other way of getting it out), but I soldered it and never altered its length.  Just one more mystery (and curse) of running a factory 87-88 harness. 76 HRP, did you use the stock coil and if so was there any resistor used?
