WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 07/04/2017 03:26 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 08/13/2021 10:39 am
Date: 10/26/2020 03:24 pm
Date: 03/25/2019 09:02 pm
Date: 03/16/2017 10:00 pm
  • Online today: 116
  • Guests: 58
  • Total: 58
Taking the turbo plunge!
Started by 76hotrodpinto, January 27, 2015, 11:59:24 PM
Quote from: Wittsend on August 10, 2015, 11:50:18 AM
Where as my Turbo swap fired up on the first twist of the key..., it had a miss at idle and ran totally crappy at about the 2,500 RPM range. I literally swapped every component, VAM, TPS, O2 sensor, temp sensors, TFI, distributor, coil, fuel pump, cleaned injectors, various hoses etc. - even the ECU and nothing made a difference. Nearly two years later on a whim I ran 12V directly from the battery to the coil and the problem went away.  I still don't know the cause, but the cure was to install a key switched relay directly from the battery to the coil.
I think the TFI has dwell control built-in, so running coil power through a ballast resistor/resistor wire could cause that problem.
"Got 100 miles on it since the swap, no major issues at all. This makes me nervous..."
Be thankful for that.  Where as my Turbo swap fired up on the first twist of the key..., it had a miss at idle and ran totally crappy at about the 2,500 RPM range. I literally swapped every component, VAM, TPS, O2 sensor, temp sensors, TFI, distributor, coil, fuel pump, cleaned injectors, various hoses etc. - even the ECU and nothing made a difference. Nearly two years later on a whim I ran 12V directly from the battery to the coil and the problem went away.  I still don't know the cause, but the cure was to install a key switched relay directly from the battery to the coil.
So, be thankful and enjoy. :-)
76hotrodpinto
I'm not having any issues, that I'm aware of(still have yet to run a diagnostic though). Just thought I'd try to eliminate weak links. I'll just get a sticker instead. Got 100 miles on it since the swap, no major issues at all. This makes me nervous...
I have never heard that these ignition systems have any special needs myself. I think defective wires are probably a bigger concern than the name on them. Autolite 764 plugs are not the only ones that will work well in a 2.3T, but they are original equipment, cheap, and easy to find.
The quality of ignition components will become more important as power levels increase. Denser mixtures are harder to light off so the coil voltage rises higher before the plug fires which is more demanding of all the insulating parts.
76hotrodpinto
I keep reading about other builds and their motorcraft wires. I can't seem to find any. I have msd street fire wires now. Not much more quality than the cheapos. I find a lot of posts about how picky the ignition system can be with these, and they all recommend the motorcraft plugs and wires. Maybe half of a 5.0l set?
I don't know if Motorcraft still has them, but the most common brands you're likely to see in a chain store (at least here) are Borg Warner (BW Auto), Bosch, and the house brand. I find a lot of the sub-$30 sets have very soft boots and sometimes the terminal will pull out of it and take the core too.
Taylor-Vertex, MSD, and Accel probably have good race-grade wires, but I haven't tried them.
76hotrodpinto
Is motorcraft still making spark plug wires for these? Or what is the best after market wire?
That's what I have and 185/75-13 rubber is barely enough on dry pavement with a stock 2.3T.  8) On even damp pavement my Runabout will squirm through 4th gear.  :o A wagon might not, but I don't have one of those...
The 8" I found has typical 3.00 gears as well and transmission gear spacing is a concern that's been in the back of my mind for a long time. 3.00s will probably suffice for a while until I go with more gear, a T-Lok, and possibly taller/definitely wider tires.
Depending on the rear ratio and tire size of the donor, a gear ratio can be figured that will match the original car behavior-wise. I think the '87-88 5-speed 'Birds had 3.55s, so exactly matching the RPM at 60mph in 4th in a Pinto with our tire size would require a 3.19 rear ratio.
My older donor car had 3.45s and spun a little higher in 4th, so 3.22s would match the original characteristics. Since 3.25s are the closest available ratio, the choice is obvious.
76hotrodpinto
I just replaced the back tires, and I couldn't even find a 205-70-13, not without going for a coker or some other big$ tire. I ended up with 185-75-13 tires. They will do until my big wheel swap. The guys at the tire store didn't even believe I was running 205-70's, they hadn't seen any in decades.
"I find that the stock 3.55 rear end I'm using has a bit too much gear even with a T3 turbo. At this point I think 3.25s will be about right for my car, especially as power/torque increases."
I couldn't agree more. Granted that tire size is also a factor. Side rant - Why can't the industry come up with some other measurement that factors rear ratio AND tire size. Something on the order of driveshaft revolutions per 100 ft., or mile or whatever (end of rant)?  When I was looking for my 8" rear at Pick A Part I ran into the guy who who was snagging them all.  He told me except for some limited use, rare, car/year combination the 3.25 was hardly used by Ford. He said the likelihood of finding an 8" with that ratio was basically nil. So to get that ratio it likely won't happen with a junkyard center section swap. It requires purchase of new gears and the task or outside cost of installation.
Otherwise it is 3.00, 3.40 or 3.55.  3.00 was OK as the turbo had the torque to pull that, but as I often complain they were miserable for regular "street speeds." You just couldn't find the right gear/rpm. I have 3.40's now and find them acceptable. I'm running 175-70-13" tires on Ralleye wheels and 65 MPH is 2,600 RPM in 5th gear. But at some point I'm bumping up to 205-60-13".... or .... [195/205]-60-14" if I can find another pair of SSP look a like wheels. Then I think I'll be even happier with the taller tires.  So, if your doing this one on the cheap I'd say 3.40's and tires taller than the basic 175-70-13".
76hotrodpinto
I have an 8" rear end out of an m2. I don't know the gear ratio, but it was a perfect match for the 4sp., not so much the t5 and 13" wheels.
I have plenty of time to thoroughly study the ecu options, as I need to replace every bushing in the car, and spiff it up as I go thru it, before I play the horse power game.
The PiMP is a licensed MegaSquirt-based product. Stinger Performance produces it and the owner is on turboford.org frequently as am I. It was meant to be a plug 'n' play MegaSquirt-II conversion for '83-89 Ford 2.3T vehicles. Since yours is using a factory ECU, it should be plug 'n' play too.
IMO, the throttle response is far crisper and generally better with a speed-density system like the MegaSquirt/PiMP/etc.
76hotrodpinto
My only complaint is the short tires are putting me at boost ranges when I'm at 35-37mph in 3rd... cruising down the street speed. Or lug 4th out. I think the bigger wheels will solve that.
I haven't done a whole lot of studying on the mega squirt system, other that the pimp is basically a mega squirt(alledgedly same former software designer?), but tailored for the 2.3. I do look forward to getting that vam out of there!
I'm not unhappy with the boost at all. I'm having a blast! Just need longer legs... And a roll cage!
Quote from: 76hotrodpinto on August 06, 2015, 09:23:55 AM
Not trying to get more boost out of her, just a little more delay before it starts spooling. Seems to start spooling at around 2400. I'd like to have it start at about 2900-3000.
T3 upgrade time. That or leggier gears and more tire. I have to ask though, why have it spool later?
It isn't really going to be possible without going to a different turbo that has larger exhaust housings available. The other option is to find/adapt a wastegate actuator that opens lower than 10psi and modify the boost control bleeder orifice to make it peak at the same ~15-16psi. Retarding the cam will move the torque later in the revs a bit. The fastest and cheapest solution is to tighten the nut behind the wheel.  ;)
If you get a PiMP ECU, it can provide for boost based on RPM between the wastegate actuator's minimum setting and  however high it will hold without a boost signal. I have my MegaSquirt-II set to provide high boost (16psi) whenever.
Quote from: 76hotrodpinto on August 07, 2015, 10:11:29 AM
Still have the stock cam and lifters. I'm not certain yet, but I'm thinking ranger cam, t3-t4, and the PiMP ecu as my first round of upgrades to the motor. I'm going to hold off on the boost control valve till I get my bigger wheels on. It could be just right if the larger wheels gets me the ratio I want.
Getting a turbo you can grow into is tough to do. A Ranger cam is also not an upgrade unless all you want is roller followers. Lots of people get hung up on the different lobe shapes, but actual events at the valve are indistinguishable from a stock turbo slider. A good aftermarket cam will be big bucks these days, unfortunately. I can hardly believe how much the prices have gone up recently.
Also, avoid TO4B-based compressors if you get a hybrid. They are ancient profiles and none of them are well-suited to the boost and flow requirements of the average 2.3T. There are many ways to identify them, but the easiest is by eight main blades on the compressor wheel.
Well looks like your on you way to the easy stuff, unbolt and bolt up , at least you can drive the car and make the small mods along the way , looking good and keep us posted , later Blaine
76hotrodpinto
I'm going to start the suspension and brake rebuild next though. It's become very clear that all of my bushings are shot, and not up to par with the capabilities of the car now(or before). I'm ordering a tubular A-arm and big brake kit up front, 2" drop. All 5 lug, front and back, via shortened 8.8(with discs) out back. And get a disc brake master cylinder put in. Considering going 4-link on the axle, but not sure yet.
Not sure what cam you are running, but with the Ranger Roller I'm "squeezing that last few drops out of the sponge" between 4,500 and 5,000 RPM. For sure by 5,500 RPM the "sponge is dry."  At least in hard throttle applications I feel more like I'm driving an old diesel truck that idles at 600 RPM and shifts at 1,200 RPM. It just seems like lag, BOOST, Shift, lag BOOST Shift etc.. Part of it may be my car. I'm still choking on a 2-1/4" exhaust.
From my experience I'd think that delaying the boost onset would be not be advantageous. I prefer to gently "lay into the throttle" and extend the feeling of acceleration. To that end I never found the 3.00 gears to be a detriment for that expressed purpose. They extended the acceleration process. The change to 3.40's was prompted by the need to be in a better RPM range specific to normal street speed.  I'm not racing or anything, just going for that "E Ticket" ride experience. So, we may be looking at different purposed.
As far as delaying boost I'd thing going away from the IHI turbo would help. As I understand it was selected to bring boost on earlier - though it wheezes out sooner.
76hotrodpinto
Quote from: pinto_one on August 06, 2015, 07:06:13 AM
It's still in control, it only delays the opening of the waste gate for higher boots ,  but don't get too greedy with it , 💥. Nice that you got it finished, and thanks for sharing your progress with us, it help others that are thinking of doing the same thing , now go and enjoy
76hotrodpinto
Anybody running, or have run a manual boost control valve? How do, did you like it? Is it consistent in it's control? Does it create other issues?
76hotrodpinto
I got my engine bay wires all wrapped and strapped.
And put in a boot to block that hot turbo wind!
It may have been testing the EGR valve or idle air controller.
The TFI commands a spark even if the computer signal is lost entirely. It functions as a fail-safe so the car won't stop running in the middle of a freeway lane or railroad tracks or some other dangerous place. Since the injectors are paired, the ECU can't drop a single cylinder by cutting fuel either.
OEMs also go to great lengths to avoid controlling the engine in any way with spark only because dumping fuel and air into the exhaust will nuke a catalytic converter.
Makes sense - sort of. I understand that the injectors fire two at a time. But I have put the test into motion and the car paraded through the rough running cycle. So, I thought it just killed the plug firing. Now I'm perplexed as to what was occurring because the engine went into a mode that replicated an alternating rough running procedure???
Quote from: Wittsend on August 04, 2015, 02:04:18 PMBTW, the ECU can do cylinder balance tests (shuts each cylinder off momentarily and measures RPM drop) amongst other mostly unknown things that can be tested. Don't be surprised that you get codes because the ECU tests A/C, power steering, EGR etc. So, in our Turbo Pinto application I'd assume a CEL would be on all the time for those.
Unfortunately the cylinder balance test only applies to engines that had sequential EFI of which the 2.3T wasn't one.
Here's how to do the test light code reading method:
www.troublecodes.net/ford/
76hotrodpinto
I was just checking that out. I think I'll order me one. I expect the first conversation between the ecu and I will go something like "KEEE-RIPES!! What the hell happened to me!!"
Your welcome.  I ran my test wires into the car - as opposed to the stock under the hood location. It makes it easier to to do the testing from the drivers seat. When done I coil the wires up into the glove box. After now having tried my Innova 3145 I'd highly recommend it over the cheaper 3143 or just using the CEL. Having a numerical readout is so nice and assures the code is correct.
76hotrodpinto
That's exactly what I needed to know. Thank you. I did retain the test plugs.
The simple method for reading codes can be frustrating. There are initial codes, then the test codes, then closing codes. And they all have to be counted visually with the check engine light or an analog volt meter by counting pulses and pauses. At various times you need to perform functions based on timed intervals (like pushing the accelerator to the floor).  It is a bit like trying to read Morse code but never having done it before.  Some tests are done with the "Key On-Engine Off" and others "Key On-Engine Running."
There are code "readers" but they are not like OBD II. The simplest plugs into the test port and basically flashes a light like the CEL on the dash does and a switch to trigger the test. They also have a buzzer if you are more audibly inclined. You still have to do the interrupting of the pulses and pauses so it is not much of a help. These are in the $10 range on Ebay.  http://www.summitracing.com/parts/equ-3143
  There is a somewhat more expensive type that as far as I can tell does the counting for you and displays a code number. I actually have one, but have never used it. These are in the $30 range.  UPDATE: I just tested mine. It sure takes the "Mystery" out of counting light flashes and pause counts. It does display an actual number! This comes with a book that delves into the deeper side of OBD I too.  http://www.summitracing.com/parts/ino-3145
Ford also had a dealer style Rotunda reader and I think it piggybacked on the ECU. These are not cheap and if I recall correctly when you find one (the right one) are easily in the $500+ range.
Lastly be very weary of any reader that "says" it is OBD I and has even a hint of being an OBD II reader.  From what I saw these would never work. Innova and Equus are the only two "real" OBD I (Ford) readers I am aware of.
You will have had to retain or reinstall the test port from the ECU. It is a somewhat triangular connector with a single wire connector associated with it.  There is all kinds of stuff on the internet about OBD I (Ford) but you might try The Ranger Station http://www.therangerstation.com/ or NATO http://www.turbotbird.com/ as they deal with swap issues. Be careful too because I have seen where not every OBD I (Ford) code number is the same for each engine. Be sure the codes are specific to your engine/year.
76hotrodpinto
Never mind on the faulty tps. I wasn't getting a good contact. Just shoved the pointed probes thru the insulator and all is good. Would still like a tutorial on the whole code reading deal.
76hotrodpinto
Is there a guide to running codes? A how to for first timers? I haven't found the code list anywhere either, even if I did know how to test it. I know how to hook up either an analog meter or light to the eec test plug, but then...?
