Date: 08/26/2018 06:23 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 08/17/2022 06:27 pm
Date: 04/28/2018 04:12 pm
Date: 08/01/2018 01:27 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Racing seats
Date: 10/24/2019 09:41 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
  • Online today: 116
  • Guests: 125
  • Total: 125
Taking the turbo plunge!
Started by 76hotrodpinto, January 27, 2015, 11:59:24 PM
76hotrodpinto
I cleared out the bondo from the holes, and mounted a trunk badge. It's the only piece of trim on it, but it's all those chevy boys will need. They can know it was a Pinto that shattered that bow tie dream.
76hotrodpinto
Gathered up most of the parts for a front end rebuild w/big brakes and tubular a-arms etc.. And I finally found a reasonably priced 55" jag irs to cram in there too, after some restoration. Coming up with a sub frame plan for the irs, and some more reinforcements for the  frame tie ins. Now I'm just waiting for the clouds to part this spring.
72DutchWagon
Good to hear that!!! Keep up the good work!!!
76hotrodpinto
I'm not giving up just yet.
Had a little set back, but I'm not done.
Ouch!  So sorry to hear this!  Is there any chance of salvaging anything?
Dwayne :)
??? This isn't the way these stories are suppose to end.
76hotrodpinto
Well... I'm ashamed to say, I lost my cool and the pinto is destroyed. Not wrecked, just shot, beaten and burned to the ground. Not my proudest moment. So I'll just thank all of you again... and bow out. Thank you.
76hotrodpinto
Do any of you use an adjustable fpr? I'm looking at getting one, and a manual boost control. I'm getting a gillis for the boost control, but I'm looking for advice on the fpr. The prices are quite varied, and they don't seem to be too different. What are the proved performers? Or at least, which ones should be avoided? My fuel pump is an sp1154, it's a little more psi than the factory pump.
76hotrodpinto
If I'm understanding the code definitions correctly, I think the 25 means the test was performed and there were no knocks to be detected during the test. If I don't do the wot test when prompted to, I get another code that says I didn't perform it correctly. It feels really smooth, and the response is great. I think it's about ready to mess with.
I'm not sure what the thing is about the full throttle test and the knock sensor. I do know it is to check the sweep of the TPS. Does that induce knock???  As stated the supposed KOER test is to (at some undetermined point) hit the intake manifold with a hammer to induce a frequency the knock sensor sees as engine knock. As stated you can also use the use the timing light and hammer whack to see if it is functioning (regardless of the testing in KOER).
76hotrodpinto
Interesting. My book says 25 is "no knock detected during test".
25 Knock sensor not tested (ignore if not pinging) – KS
"Testing would involve simulating operating conditions by connecting a timing light, starting the engine and tapping the manifold next to the Knock Sensor with a hammer. You should observe the timing retard momentarily."  From my understanding timing is pulled if the sensor is not functioning. This was general Ford information. I'm not sure how it applies to the T/C engine with an LA-3.
74 Was brake depressed after engine ID was received ?  Brake On Off (BOO) signal open or short to ground – BOO
After a bit of searching it seems the primary purpose of the BOO is for an Automatic to release the converter lock-up. It may have other applications (cruise control release, testing brake bulbs, etc.)  These latter seem more speculation than having proof.
Being you are running a T-5 I'd think the 74 Boo code seems irrelevant.
76hotrodpinto
Before I replaced the ect, it was causing a few codes. But now I only get code 11(allegedly all good), and 25 (no knock detected during wot). I wanted to make the ecu as happy as possible... before causing other codes!
I'm, not exactly sure what the code 75 tests, but in the testing process you are suppose to tap the brake pedal.  I think there is also a steering test where you move the wheel???  I never heard anyone say it was an issue in a swap.  The code 34 EGR I'm guessing momentarily triggers the EGR to open and looks for the mixture ratio to change. I'd think it serves two purposes. One it let the ECU know the electric/vacuum circuit is working and two, it lets the tester know if the EGR might be clogged.  Again, I never heard of EGR (other than leaking) being a problem in these swaps. When I removed mine I saw no difference in function though the removal certainly made the looks under the hood improve.
I'd also assume you were not getting a code 11 without the system seeing the coolant temp when the ECU went through its internal check list.  My recollection from all my searches at NATO was that a miss (stumble) at idle seems to be very common and often not resolved.  Anyway, it is good to see you are moving in the right direction.
76hotrodpinto
Finally getting consistent code 11. It's running much smoother, and I'll bet it gets better mpg. Now I'm thinking about a manual boost control valve again.
76hotrodpinto
According to the codes given, and the corresponding code definitions, that's all there is. Unless the computer and/or reader, or the manual are incorrect.
The Whistler
I disagree. But if you say so!!!
Turbo is a way of life
76hotrodpinto
It's just an egr code and a code for the boo(brake system). There is no egr or fancy brake system.
The Whistler
Why have you not fixed 34 and 75 they are easy to fix? And now are the cause of most of your problems!!
76hotrodpinto
So I put the temp sender back in and ran all the tests again. She did much better! Still throwing the #84 in koeo, but that's it. It throws #25, #34, #75 in koer. So all is good in LA3land. Apparently the computer likes to know the engine temp as much as I do. Still running rich, by the afm readings. It does have a slight stumble, barely even noticeable, and the exhaust doesn't smell rich in the slightest. So I'm going to run it for while and keep an eye on things.
The Whistler
76hotrodpinto
Quote from: The Whistler on October 16, 2015, 06:55:58 AM
Where is your BAP sensor? Is it installed correctly? Post a pic of it as installed.
I didn't change anything in the bap circuit, but it's been relocated in the cab under the dash. It's mounted at the same angle it was under the hood. Not sure it mattered, just didn't want to make a new bracket, so I modded the one it had. I'm putting the temp sender back in today, and re-testing.
36 to 40 MPG! WOW! My Fish carb on my Pinto will not do that good. Close but still less MPG's.
The Whistler
76hotrodpinto
I'm not opposed to upgrading to the pimp or similar, but I'm not going for those kind of numbers. This is my daily driver. I didn't delete my circuit for the temp sender, just took out the factory sender and installed my mechanical gauge. I think I'll just have to reinstall the other one, and get a matching 12v temp gauge, instead of the mechanical.
The Whistler
Gas mileage on my Pinto is about 36mpg and about 40mpg on my friends Mustang both with 2.3t. Tps voltage should be .84 to .96 at idle! And install the coolant temp sensor you are asking for trouble by trying to delete it! Also we have long ago left the stock ECU behind. Our 2.3's put out around 400hp on the ground! Also if you have done the swap properly and no sensor malfunctions you will only have the code for the egr.
